  1. May 9, 2022 at 11:03 PM
    mphawk
    mphawk Member
    Bristow, VA
    2010 DC TRD OR
    OME 2885 front coil overs, Bilstein 5100 front, 5125 rear, ICON RXT pack (option 2), JBA UCA, Whiteline LCA Bushings (Best thing I've Done), ECGS front diff bushing, VLEDS Triton V6 headlight bulbs, VLEDS DRL, Power Stop front calipers, SOS rear bumper, RCI skid plate, Rough Country step bars, TRD gloss wheels, KO2 265 75. With the OME coil overs, ICON RXT option 2, I essentially achieved a 2 inch lift with no vibe issues, way less body roll than stock. With the Whiteline LCA bushings, my steering is hands off straight on the highway...night and day difference from OEM. Replaced upper and lower control arms, sway bar bushings, alignment cams and had some alignment cam stops welded on at 120K miles. Drives better now than when it was brand new.
    I was overdue for a headlight replacement...Installed VLEDs V6 Triton headlight bulbs, VLEDs DRL/ turn signal bulbs and VLEDs reverse lights. Pricey, but very happy with them so far. The headlights seem a bit brighter than the Sylvania Silverstar Ultras that I've replaced MANY times over the years. (Turned on the fogs on for light color comparison in the pic...I haven't swapped those over yet). I did not have to re-aim the headlights. (Made targets on the wall before the swap, and the VLED's bulbs were right on target in the OEM housings). I haven't had anyone flash beam me on 2 or 4 lane roads yet, and I do a lot of night driving. My original OEM DRL lenses melted with the 3157 bulbs, so hoping that doesn't happen again. The LED reverse lights are a huge improvement. Threw in some LED license plate lights as well when I did a bumper swap. DRL.jpg reverse lights.jpg
    Short story long, if you order new OEM headlights...make sure you are getting the improved housing with the glass DRL diffusers. I was a dumb ass...ordering OEM replacements, because I did not think there was any way they'd still have the melty DRL housings in the system anymore. I did not realize that I had said melty housings, till after I had installed the new headlights, which is a bit of a PITA with the bolt in the wheel well. Before I get flamed...yes I know that I could have ordered aftermarket projector headlights or whatever...for the money I spent on OEM housings and then stuffing them with VLEDs...
    PacTac, dpele, DG92071 and 1 other person like this.
  2. May 10, 2022 at 1:42 AM
    TomTwo
    TomTwo I love God but I cuss a little
    Bill
    I-85 Southbound
    2013 TRD Double Cab Sport
    I sorta like it :rofl:
    mphawk and TegoTaco[QUOTED] like this.
  3. May 10, 2022 at 2:49 AM
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
    :D
    TomTwo[QUOTED] likes this.
  4. May 10, 2022 at 6:02 AM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    ebay... $140
    mark_tga[QUOTED] likes this.
  5. May 10, 2022 at 7:11 AM
    pegleg6942
    pegleg6942 Well-Known Member
    Greg
    2015 Toyota Tacoma
    I bought an overlay for my front grille and it didn't fit, it was to small. I've looked at one for the steering wheel but noticed there's no room on the edges of the logo to the steering wheel for any overlay. It's supper close and tight so I don't think an overlay would work but thanks for the info.
  6. May 10, 2022 at 7:25 AM
    DG92071
    DG92071 Well-Known Member
    You went from the stock grey/silver to carbon fiber to black on your shifter bezel.
    I thought I was going crazy so I spent over a half hour to discover I am in fact crazy for spending over a half hour researching your interior color choices.
    Lmao!
    theolee likes this.
  7. May 10, 2022 at 7:25 AM
    DG92071
    When I put headlights in the oven to take them apart what temp should the oven be at? Thank you.
    Rezkid likes this.
  8. May 10, 2022 at 7:53 AM
    Rezkid
    Rezkid Not a Well Known Member
    TJ
    WTX
    '08 DCSB TRD RT
    Little bit of this and that
    Pretty low...like 250° or less.
    DG92071[QUOTED] likes this.
  9. May 10, 2022 at 7:57 AM
    Rezkid
    TJ
    WTX
    '08 DCSB TRD RT
    No mods today...but tomorrow the interior will be getting a slight refresh. New LED's to replace the several I have out, mostly in the switches to the left of the steeringwheel. Also have another set of Osram Nightbreaker Lasers as they're about the only bulbs I have found worth a damn for the Spyder/Tcmabeast headlights.
    pegleg6942 and JKU3000 like this.
  10. May 10, 2022 at 8:42 AM
    ty.s07
    ty.s07 Well-Known Member
    Alabama
    If memory serves, I preheated mine to around the 240* - 250* mark, once it reached temp I turned the oven off and put the lights in.
  11. May 10, 2022 at 8:52 AM
    scoomas
    scoomas Well-Known Member
    Scott
    2006 Silver Tacoma TRD/OR
    I think I put mine in the oven at 170* for 7ish minutes
    DG92071 likes this.
  12. May 10, 2022 at 9:04 AM
    Northbound_Taco
    Northbound_Taco Well-Known Member
    Nowhere Fast, Everywhere Eventually
    09 Off road build
    RCI skids/armor, SPC UCA, Fox 2.5 front 2.0 rear 16" TRD PRO rims/ 285/75/16, SS3 Pro fogs, Sherpa Roof Rack
    Added another patch.
  13. May 10, 2022 at 9:48 AM
    Dr3w
    Dr3w Well-Known Member
    Drew
    805
    2007 White DCSB Sport
    Looks clean! What size?
    3Riverz88 likes this.
  14. May 10, 2022 at 11:14 AM
    Millsy
    Millsy Sláinte
    Southern California
    Silver '13 DCSB 4x4
  15. May 10, 2022 at 12:05 PM
    10thMTNgrunt
    10thMTNgrunt This is the way, step inside.
    2013 TRD Sport
    Rotated my new Cooper at3 4s’ for their first 5000 mile rotation.
    While doing so, aired up the spare tire, for the FIRST time:eek:, it was at 10psi, possibly the first time it’s ever been aired up.
    Check your spares people:thumbsup:
  16. May 10, 2022 at 1:01 PM
    DG92071
    The other day I was on a circular style of a freeway onramp and I heard a loud pop sound. There weren't any cars anywhere in front of me. I just found out what that pop sound was, it was my windshield, and I'm fairly sure it was from a bb or pellet gun.
    Thank you for the replies on the oven temp!
    irayfz6 likes this.
  17. May 10, 2022 at 1:06 PM
    Northbound_Taco
    09 Off road build
    Hope it wasn't! You would be surprise at how far a tire can throw a rock. Think small pebble stuck in a tread rotating on a truck going 70 mph it can fly off well over twice that speed and significant distance.
  18. May 10, 2022 at 1:12 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Started building my down pipe last weekend. Still have a little ways to go, but got the pie cuts done so should be smooth sailing from here on. Up to this point it’s been about 8 hrs of fab/fitment for just the down pipe. It’s been a fun project though, quite a challenge for sure
  19. May 10, 2022 at 1:21 PM
    20somethingwidataco
    20somethingwidataco Yes, my avatar is a real car.
    Will
    Washington State
    2008 AC TRD SPORT M/T
    ACLB 6 SPEED: Suspension: Bilstein 6112s (3rd perch) (F) Taco Lean Spacer Bilstein 5160s (R) TSB Leaf Pack Wheelers Offroad 3 leaf progressive AAL Wheelers Superbump Front Duro Bump U bolt flip kit Duro Bump progressive bump stop 3rd gen TRD offroad sway bar Wheels and Tires: Summit Racing Wheel Dakars (Polished Silver) 285/70r/17 Goodyear Wrangler Duratrax (Load D) "Performance": AFE CAI with custom powdercoated white filter cover MagnaFlow Performance Series Exhaust URD Cam gears XTP Intake Manifold Spacer OTT Torque Tune Brakes: Stoptech Slotted Rotors Stoptech Sport Ultra Composite Brake Pads Wheelers offroad SS brakelines (Front) Interior: Kenwood DD headunit Oem Subaru Kicker Tweeters Alpine 6x9 (Front) & 6.5 (rear) (With Taco tunes speaker mounts) Alpine 500 watt amp Sound Deadening (Doors, Rear "wall", Roof) ODI Rouge Shift Knob Weather Tech Mats Painted/wrapped trim pieces Console Safe Console Vault Gridx Organizer Ram Phone Mount Meso Customs dual color map lights Meso Customs dual color dome light Wet Okole seat covers (Black) Wet Okole center console cover (Black) 1" Seat Raisers (Driver & Passenger) AJT Designs climate control and 4x4 knobs Back Up Camera Lighting: Retrofits (Mini H1's, RGB Halos, 5500k Bulbs)(Lenses wrapped in self healing PPF) Diode Dynamics SS3 Max SAE (Yellow) Diode Dynamics SS5 Pro (Yellow) Driving lights (ditch lights) Anytime fog mod Rigid Industries E series 32" Combo bar (spot/flood) Diode Dynamics XPR Reverse Lights Diode Dynamics XP80 turn signals LED brake, parking lights and license plate lights Armor: Apex All Pro sliders BPF steel skid plate Bigass Trailer Hitch Camping/Storage: Leer canopy LED interior lighting Sleeping platform (Storage underneath) Removable snowboard Yakima mounts Extra D rings in bed (6 total) Custom Powder coated white snow shovel with custom bedrail mounts Amazon special Traction Boards Hi Lift 48" Jack with custom Rail mounts to accommodate my sleeper set up Other: All pro Bed Stiffeners Relentless Fab tailgate panel TRD sport graphics (Turd Gen spec) Anti Sun glare hood scoop wrap (Satin Black) Custom FleeBay grille 4 Hella supertones ECGS needle bearing Many Patches BPF shackle mount (With smittybuilt shackle) Tinted windows (Front/Rear + Full canopy)(18%) Meso Customs gasshole AVS inchannel window visors Diff Breather Kit 2012-2015 Oem Turn signal/folding mirrors (w/ sequential signals) 2012-2015 Oem LED taillights Full Size (285/70r17) spare DIY Larger Engine Splash Guards DIY Vipercut TRD radiator cap
    I have a feeling that's why my TPMS light is always on.... replacing it with a full sized spare soon anyway
    10thMTNgrunt[QUOTED] likes this.
  20. May 10, 2022 at 1:39 PM
    10thMTNgrunt
    2013 TRD Sport
    For the record my TPMS light was not on and does work, at least as far as I know, last time it came on was over a year go, aired up tires (not spare) and light went off.
    That being said I do recall seeing a post or two about a low aired spare setting off the light. Maybe someone can chip in on this?
