  1. May 12, 2022 at 9:05 AM
    20somethingwidataco
    20somethingwidataco Yes, my avatar is a real car.
    Will
    Washington State
    2008 AC TRD SPORT M/T
    ACLB 6 SPEED: Suspension: Bilstein 6112s (3rd perch) (F) Taco Lean Spacer Bilstein 5160s (R) TSB Leaf Pack Wheelers Offroad 3 leaf progressive AAL Wheelers Superbump Front Duro Bump U bolt flip kit Duro Bump progressive bump stop 3rd gen TRD offroad sway bar Wheels and Tires: Summit Racing Wheel Dakars (Polished Silver) 285/70r/17 Goodyear Wrangler Duratrax (Load D) "Performance": AFE CAI with custom powdercoated white filter cover MagnaFlow Performance Series Exhaust URD Cam gears XTP Intake Manifold Spacer OTT Torque Tune Brakes: Stoptech Slotted Rotors Stoptech Sport Ultra Composite Brake Pads Wheelers offroad SS brakelines (Front) Interior: Kenwood DD headunit Oem Subaru Kicker Tweeters Alpine 6x9 (Front) & 6.5 (rear) (With Taco tunes speaker mounts) Alpine 500 watt amp Sound Deadening (Doors, Rear "wall", Roof) ODI Rouge Shift Knob Weather Tech Mats Painted/wrapped trim pieces Console Safe Console Vault Gridx Organizer Ram Phone Mount Meso Customs dual color map lights Meso Customs dual color dome light Wet Okole seat covers (Black) Wet Okole center console cover (Black) 1" Seat Raisers (Driver & Passenger) AJT Designs climate control and 4x4 knobs Back Up Camera Lighting: Retrofits (Mini H1's, RGB Halos, 5500k Bulbs)(Lenses wrapped in self healing PPF) Diode Dynamics SS3 Max SAE (Yellow) Diode Dynamics SS5 Pro (Yellow) Driving lights (ditch lights) Anytime fog mod Rigid Industries E series 32" Combo bar (spot/flood) Diode Dynamics XPR Reverse Lights Diode Dynamics XP80 turn signals LED brake, parking lights and license plate lights Armor: Apex All Pro sliders BPF steel skid plate Bigass Trailer Hitch Camping/Storage: Leer canopy LED interior lighting Sleeping platform (Storage underneath) Removable snowboard Yakima mounts Extra D rings in bed (6 total) Custom Powder coated white snow shovel with custom bedrail mounts Amazon special Traction Boards Hi Lift 48" Jack with custom Rail mounts to accommodate my sleeper set up Other: All pro Bed Stiffeners Relentless Fab tailgate panel TRD sport graphics (Turd Gen spec) Anti Sun glare hood scoop wrap (Satin Black) Custom FleeBay grille 4 Hella supertones ECGS needle bearing Many Patches BPF shackle mount (With smittybuilt shackle) Tinted windows (Front/Rear + Full canopy)(18%) Meso Customs gasshole AVS inchannel window visors Diff Breather Kit 2012-2015 Oem Turn signal/folding mirrors (w/ sequential signals) 2012-2015 Oem LED taillights Full Size (285/70r17) spare DIY Larger Engine Splash Guards DIY Vipercut TRD radiator cap
    What products did you use for your truck? I'm rocking super white as well
  2. May 12, 2022 at 9:36 AM
    bebo_junker
    bebo_junker Well-Known Member
    Western Mass
    '05 X-Runner - '06 SR5 RC - '07 TRD Sport AC
    Black Ice Little Trees
  3. May 12, 2022 at 9:59 AM
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
  4. May 12, 2022 at 10:39 AM
    DG92071
    DG92071 Well-Known Member
    I Googled Mityvac and they make quite a few different things and I would like to know which product you were specifically referring to. Thanks.
  5. May 12, 2022 at 11:22 AM
    PzTank
    Above the Notches
    DG92071[QUOTED] likes this.
  6. May 12, 2022 at 11:39 AM
    Ralphtaco805
    Ralphtaco805 Well-Known Member
    15 Tacoma
    Bilsteins 5100 Hellwig Rear swaybar 17 trd sportswheels
    Can someone here take me to a forum or have any information about what’s the best tire size to with on 1.5 lift?
    I’m looking at height only
    For example 265/80r16,265/85r16 or 265/90r16 ?
  7. May 12, 2022 at 11:41 AM
    GlennHaggis
    GlennHaggis Doesn’t play well with others
    Glenn
    Ormond Beach, FL
    2013 Tacoma Double Cab
    A Bunch
    la0d0g, DG92071 and Rick_Taco like this.
  8. May 12, 2022 at 11:47 AM
    Ralphtaco805
    15 Tacoma
    Thanks but that’s a tire size calculator what I’m trying to find out is if I can install a taller tire on a 1.5 lift with out any rubbing or modifications no issues
  9. May 12, 2022 at 11:54 AM
    fourfourone
    fourfourone Well-Known Member
    2015 TRD sport(sold) 2023 Tacoma
    Theres like 10801831 threads about tire size and lifts.
    Wyckedan, williams63 and GlennHaggis like this.
  10. May 12, 2022 at 12:05 PM
    Northbound_Taco
    Northbound_Taco Well-Known Member
    Nowhere Fast, Everywhere Eventually
    09 Off road build
    RCI skids/armor, SPC UCA, Fox 2.5 front 2.0 rear 16" TRD PRO rims/ 285/75/16, SS3 Pro fogs, Sherpa Roof Rack
    I don't think anyone makes anything over 265/75. At least not that I have seen. If you have anything above a base with 5 lug (anything 6 lug) then you should be able to run a 265/75 with no issues any bigger probably wont fit without trimming or spacers. If you are looking for height and not width 255/85/16 is the way to go. 33s but skinny, should fit.
    DG92071 likes this.
  11. May 12, 2022 at 12:20 PM
    Ralphtaco805
    15 Tacoma
    Ok cool I’m go with 265/75r16 because I think it looks beefy currently have 265/65/17
  12. May 12, 2022 at 12:25 PM
    jproffer
    jproffer Well-Known Member
    Jim
    Perryville, MO
    '15 MGM Sport DCLB, V6
    That's what the calculator would have been for....
    Those 2 tires are 1/2" difference from center to OD (per side, of course). If you're running that close to rubbing now, you're running too close to rubbing :)
  13. May 12, 2022 at 12:38 PM
    Ralphtaco805
    15 Tacoma
    But won’t the 1.5 lift compensate for that 1/2 inch so I believe it won’t rub right ? I hope not so if anyone here has 1.5 lift with 265/75r16 tire with no issues please let me know
  14. May 12, 2022 at 1:27 PM
    Jimmy92870
    Jimmy92870 Well-Known Member
    Texas (DFW)
    07 DCSB PreRunner
    So the lift will clear at static ride height but anything bigger then stock will probably rub at full compression of the suspension. A lot of people mistake having a lift with clearance, but when the suspension is compressed fully there's no "lift" so you'll still rub unless you create clearance for the tire however a skinny tire or the biggest stock size you can fit will fit just fine.
    Ralphtaco805[QUOTED] likes this.
  15. May 12, 2022 at 1:49 PM
    2013XSPX
    2013XSPX Well-Known Member
    GA/FL Border
    2013 XSP-X
    Pelfreybilt front/rear, RCI underneath, Morimoto Headlights, Prinsu racks, SCS Brushed Copper Ray 10's, EO Sliders, Baja Designs and Rigid lights, Inca 4x4 Camper
    Fumoto valve fit perfectly under the RCI Skid.
  16. May 12, 2022 at 2:01 PM
    WillyTtaco
    WillyTtaco Well-Known Member
    Bill
    So Cal
    2014 DCSB TRD OFFROAD 4X4
    265/75/16 AT2 BILSTEIN,SNUGTOP MBRP,SPC UCA
    In the last month did a few upgrades. Really got after all the things I’ve been wanting to do for awhile !
    Bolt on MBRP cat back.
    Spectre cold air intake.
    $20 breather mod thing
    OEM skid plate
    TRD Pro grill insert.
    love them all! Didn’t break the bank and competed them all in my garage with limited install time.
  17. May 12, 2022 at 2:20 PM
    pahaf
    pahaf Well-Known Member
    paul
    NorCal
    2015 Tacoma TRD Off Road
    Bilstein 6112/5160 OME Meduim leaf pack JBA HD UCA 3* retard exhaust gear TRD Pro Sema rims 265/70R17 Falken Wildpeak AT3W
    Notice any power gains?
    DG92071 likes this.
  18. May 12, 2022 at 2:50 PM
    WillyTtaco
    Bill
    So Cal
    yeah! Not huge but for sure some added power. More happy with the sound of the truck now over anything
  19. May 12, 2022 at 2:55 PM
    point45
    point45 Well-Known Member
    SoCal, OC
    05 DCSB TRD offroad
    I have a different version that can be pumped or use a compressor but I will never change oil without it again on a passenger car.
    No removing 300 clips to get the under tray off or cleaning oil off after it splashes against a cross member. Even vacuum out the oil from the canister before removing the filter element so it doesnt drip everywhere.
    DG92071 and PzTank[QUOTED] like this.
  20. May 12, 2022 at 4:10 PM
    GlennHaggis
    Glenn
    Ormond Beach, FL
    A Bunch
    10801832
    markelhof, la0d0g and DG92071 like this.
