  1. Jun 19, 2022 at 12:18 PM
    12retire
    12retire •••••••••••••
    So Cal
    2014 TRD Off Road. Pyrite Mica
    My trac light went on after installing a locking gas cap. Put my oem back on and it went off.
    Dekoy909 likes this.
  2. Jun 19, 2022 at 12:18 PM
    DJSpeed
    DJSpeed Well-Known Member
    love the setup. where did you source all the parts?
  3. Jun 19, 2022 at 12:24 PM
    KILLINTIME
    KILLINTIME Like a Villain
    IvanhoeTaco likes this.
  4. Jun 19, 2022 at 12:47 PM
    99TacoDriver
    99TacoDriver Well-Known Member
    South Louisiana
    OME 885x/5100s/LR UCA/3 leaf AAL/275/70/17 Terra Trac X-Venture
    What are they? Look like summit
    IvanhoeTaco[QUOTED] likes this.
  5. Jun 19, 2022 at 12:55 PM
    IvanhoeTaco
    IvanhoeTaco Well-Known Member
    Eastern NC
    2005 Supercharged Converted Prerunner
    Total Chaos 3.5 LT, King Coilovers, 35x11.5r17 on Falcon T2, ADV 4 inch fiberglass, 4.88 gears, FJ cruiser transfer case, 4 runner front diff, Cab mount relocate, archive hangers, shackles, king 2.5x14 rear shocks, icon rxt leaf springs, king hydro bumps
    Cheap ebay wheels. Falcon t2. They are really light compared to the procomps I had.
  6. Jun 19, 2022 at 12:58 PM
    IvanhoeTaco
    Eastern NC
    Thanks dude. Im kinda regretting selling my light bar but im more conservative in my looks nowadays. 32 but I feel like an old man.
  7. Jun 19, 2022 at 1:04 PM
    KILLINTIME
    Yeah I’m 4 yrs older, I know what you mean haha.
    I like it better with out the light bar. I liked the light bar but the way it looks now is sick.
  8. Jun 19, 2022 at 1:15 PM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    Finished my harness and it's ready to be installed. I would've installed it today but my tools are at work.
    I did not bring my tools home because I didn't think I would finish it.
    Hope to have it installed next weekend.
  9. Jun 19, 2022 at 1:38 PM
    Mudman
    Mudman Well-Known Member
    Cerritos
    08 4X4 TRD Sport
    Replaced my clogged up washer nozzles. Tried everything I could to clean them out, but still wouldn't work right. Went with the Honda Odyssey ones that 1st gen folks have been using. BIG difference. Although much taller in profile.
    Canadian Caber likes this.
  10. Jun 19, 2022 at 1:50 PM
    IvanhoeTaco
    Eastern NC
    I felt like a goober with it on. Its like a big wing: on race cars they look cool and serve a purpose.
  11. Jun 19, 2022 at 5:10 PM
    EisenWill
    EisenWill Well-Known Member
    Will
    Shenandoah Valley
    2014 TRDOR DCSB
    RCI Aluminum Skids Alu-Cab Explorer Canopy
    On Friday I finally took my soft top off in preparation for the AluCab canopy install. Although I may just leave it off for a while. Kinda nice not having anything on the back for a change.
    fatfurious2 likes this.
  12. Jun 19, 2022 at 6:15 PM
    RocketTaco808
    RocketTaco808 Resident Telescope Expert
    Maui
    08 4wd URD MKIII.1 6-Speed
    Poly bushings all around, URD Headers, Composite Carbon Stage II clutch, TRD short throw, URD Spec U Exhaust, Tow package, Bunny Trails, Fairy Dust, Triple Dynamat Insulated, Blood, sweat, grit and some good old fashion elbow grease.
    Heh, discovered the underlying reason my 6 speed was having issues getting into gear.
    Hint, it wasn’t the master/slave cylinder I just replaced, or air in the lines..
    second hint, it was the pressure plate bolts coming partially loose making the pressure plate move away from the engine when clutch is pressed.
    Happy Sunday :)
    Northbound_Taco and DG92071 like this.
  13. Jun 19, 2022 at 6:54 PM
    Tour991
    Tour991 Supplier of used parts
    James
    South Reno/Tahoe
    97 2/4wd, 2014 DCLB 4x4, 99 T4R Limited (sold) 2024 4runner TRD Pro
    Looks like I'm going to need wheel spacers now. 285s rub on the uppers.
    Rick_Taco and fasteddieyj like this.
  14. Jun 19, 2022 at 6:57 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Yup.
    Already do a CMC?
  15. Jun 19, 2022 at 6:59 PM
    Tour991
    James
    South Reno/Tahoe
    Not yet. Didn't need it with the Bilsteins. Will probably do it soon with the Kings.
  16. Jun 19, 2022 at 7:52 PM
    99TacoDriver
    South Louisiana
    I’m looking for some lighter wheels as well. I have fuel hostages and if the spec sheet is right then they’re around 30lbs. I been looking at the summit raptors or FN Countersteer type x
    Did you notice a difference going to a light wheel?
    DG92071 likes this.
  17. Jun 19, 2022 at 8:26 PM
    20somethingwidataco
    20somethingwidataco Yes, my avatar is a real car.
    Will
    Washington State
    2008 AC TRD SPORT M/T
    ACLB 6 SPEED: Suspension: Bilstein 6112s (3rd perch) (F) Taco Lean Spacer Bilstein 5160s (R) TSB Leaf Pack Wheelers Offroad 3 leaf progressive AAL Wheelers Superbump Front Duro Bump U bolt flip kit Duro Bump progressive bump stop 3rd gen TRD offroad sway bar Wheels and Tires: Summit Racing Wheel Dakars (Polished Silver) 285/70r/17 Goodyear Wrangler Duratrax (Load D) "Performance": AFE CAI with custom powdercoated white filter cover MagnaFlow Performance Series Exhaust URD Cam gears XTP Intake Manifold Spacer OTT Torque Tune Brakes: Stoptech Slotted Rotors Stoptech Sport Ultra Composite Brake Pads Wheelers offroad SS brakelines (Front) Interior: Kenwood DD headunit Oem Subaru Kicker Tweeters Alpine 6x9 (Front) & 6.5 (rear) (With Taco tunes speaker mounts) Alpine 500 watt amp Sound Deadening (Doors, Rear "wall", Roof) ODI Rouge Shift Knob Weather Tech Mats Painted/wrapped trim pieces Console Safe Console Vault Gridx Organizer Ram Phone Mount Meso Customs dual color map lights Meso Customs dual color dome light Wet Okole seat covers (Black) Wet Okole center console cover (Black) 1" Seat Raisers (Driver & Passenger) AJT Designs climate control and 4x4 knobs Back Up Camera Lighting: Retrofits (Mini H1's, RGB Halos, 5500k Bulbs)(Lenses wrapped in self healing PPF) Diode Dynamics SS3 Max SAE (Yellow) Diode Dynamics SS5 Pro (Yellow) Driving lights (ditch lights) Anytime fog mod Rigid Industries E series 32" Combo bar (spot/flood) Diode Dynamics XPR Reverse Lights Diode Dynamics XP80 turn signals Diode Dynamics HP5 Third brake light LED brake, parking lights and license plate lights Armor: Apex All Pro sliders BPF steel skid plate Bigass Trailer Hitch Camping/Storage: Tonneau Cover (Truxedo Roll Up) KB voodoo bed bars Pelican Vault (for gear) LED interior lighting Extra D rings in bed (6 total) Custom Powder coated white snow shovel with custom bedrail mounts Amazon special Traction Boards Hi Lift 48" Jack Other: All pro Bed Stiffeners Relentless Fab tailgate panel TRD sport graphics (Turd Gen spec) Anti Sun glare hood scoop wrap (Satin Black) Custom FleeBay grille 4 Hella supertones ECGS needle bearing Many Patches BPF shackle mount (With smittybuilt shackle) Tinted windows (Front/Rear) (18%) Meso Customs gasshole AVS inchannel window visors Diff Breather Kit 2012-2015 Oem Turn signal/folding mirrors (w/ sequential signals) 2012-2015 Oem LED taillights Full Size (285/70r17) spare DIY Larger Engine Splash Guards DIY Vipercut TRD radiator cap AC drip line mod Anti Tweeker tailgate lock
    I'd really love to do something like this
    12taco12[QUOTED] likes this.
  18. Jun 19, 2022 at 8:29 PM
    20somethingwidataco
    Will
    Washington State
    Installed a taco lean spacer, and finally took my new 6112/5160 set up "offroad"
    Thanks for the hand again @crashnburn80
  19. Jun 19, 2022 at 8:42 PM
    Key-Rei
    Key
    Florida
    You'll definitely need it with 285's and spacers, and probably a pretty aggressive one.
    Tour991[QUOTED] likes this.
  20. Jun 19, 2022 at 8:43 PM
    Key-Rei
    Key
    Florida
    Dang; you got to hang out with Crash?
    :jellydance:
    crashnburn80 likes this.
