  1. Jun 23, 2022 at 3:30 PM
    mrproduxn
    mrproduxn Well-Known Member
    steve
    Retired DoD SE VA
    Tacomas 1987,2000,2008, 2016,2012,2008
    Retired/Hobbyist old as f***
    I assume you used 3rd gen struts and springs and added a 1/2" top spacer. Did you do a lean offset or same spacer on both sides. What do you have in the rear. Sport or Off Road struts/springs. Mine has the 1/2" lean so figure I need a 1/4" driver spacer whenever I do 3rd gen Off Road struts and springs.
    SSX999[QUOTED] likes this.
  2. Jun 23, 2022 at 3:31 PM
    SSX999
    SSX999 Well-Known Member
    2015 Tacoma TRD Off Road 6MT
    Yes, they are takeoffs from a 3rd gen (2020) Off-Road, front and back, and the spacers in front are 1" on each side... there's a lean but at this point I don't care
    jackn7 and mrproduxn[QUOTED] like this.
  3. Jun 23, 2022 at 3:55 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Capped off the hole on top of Timbren's with a 1 3/8" rubber plug to help keep water/mud out... snug fit (no glue or sealant used). Not sure how it's gonna hold up... figured for $10 what the hell.
  4. Jun 23, 2022 at 6:07 PM
    singletrack_ftw
    singletrack_ftw “I chopped the wrong leaf!”
    Tyler
    AZ
    ‘08 TRD OR 4wd
    https://www.tacomaworld.com/threads/singletrack’s-‘dad-shred-build-thread’-i’m-just-doing-it-for-the-kids.619250/ Sos offroad sliders (kickout + filler) Sos offroad full belly skids (steel) Sos offroad front recovery point Sos offroad concepts HC rear bumper with bedside kickout tubes Marlin Crawler LCA frame brace kit Trail Gear rear diff cover Bilstein 5100 + OME 885 Total Chaos UCA BILSTEIN b110 OME Dakar standard pack Wheelers Ubolt flip kit Wheelers Superbump f/r Wheelers SS extended brake lines FN five star 16x8 -25 Milestar Patagonia MT 315/75r16 Custom projector retrofit (acme super h1 + morimoto 4300k) Baja Designs S2 sport ditch pods on CBI ditch pod mounts Amazon AMAK rock lights CMC CB radio hardmount
    Did a very thorough detail on my good friends MINTY CLEAN 2003 2wd v6 with 206k on it FOR SALE SLIDE IN MY DM’s if interested. Mechanically and aesthetically tip top.
    Alexely999, lococacho, dpele and 16 others like this.
  5. Jun 23, 2022 at 6:11 PM
    lynyrd3
    Bill
    East Central Upstate NY
    Good idea . Where did you find the plug ?
    OffroadToy[QUOTED] likes this.
  6. Jun 23, 2022 at 6:12 PM
    OrionZodiac
    OrionZodiac Member
    That is a fresh truck! Love it
  7. Jun 23, 2022 at 6:41 PM
    mrproduxn
    steve
    Retired DoD SE VA
    I had a white 2000 PreRunner and it was probably the best, most reliable vehicle I have owned in nearly 50 years of driving.
  8. Jun 23, 2022 at 7:57 PM
    loyaltothetaco
    loyaltothetaco It's part ATV, part SUV, and certified by the DMV
    Adam
    Bay Area
    Radiant Red 2006 DCSB SR5
    2.5" OME lift, Fox 2.5 coil overs, all pro expo leafs, ubolt flip kit w/ upgraded bump stops, 1.25" wheel spacers, 16" Bronze KMC Impact OL wheels, 295/75/r16 Nitto grapplers, beige Softopper, Brute force front bumper w/smittybilt winch, RCI rear bumper, caliraised rock sliders, TRD IFS skid plate custom swingout tailgate w/spare tire mount, TC bed stiffeners, Magnum force CAI, KC spotlights, tacomabeast headlights, rear seat molle panel odds and ends, hi lift, MESO interior lights, and a fuck load of patches… more planned for later.
    One of my favorite mods right there :thumbsup:
    Rick_Taco and Dekoy909 like this.
  9. Jun 23, 2022 at 9:42 PM
    Scorchedtaco
    Scorchedtaco Well-Known Member
    AZ
    2012 ac trd 4x4 sc , 2012 sequoia 4x4
    Does your truck have an airbag in that A-pillar?
  10. Jun 23, 2022 at 9:46 PM
    la0d0g
    running for the hills
    For crawling not hauling
    If so... YOU'RE GOING TO DIE!!!
    Raincity, Rick_Taco and Taco-Obsessed like this.
  11. Jun 23, 2022 at 9:48 PM
    TacoTuesday1
    SD CA
    No idea but it’s a common mod and given how cheap and feature lacking Toyota is it probably doesn’t
  12. Jun 24, 2022 at 2:12 AM
    GlennHaggis
    GlennHaggis Doesn’t play well with others
    Glenn
    Ormond Beach, FL
    2013 Tacoma Double Cab
    A Bunch
    Why am I hearing, “YOU’LL POKE YOUR EYE OUT, KID!!!”
  13. Jun 24, 2022 at 6:31 AM
    OffroadToy
  14. Jun 24, 2022 at 6:47 AM
    Northbound_Taco
    Northbound_Taco Well-Known Member
    Nowhere Fast, Everywhere Eventually
    09 Off road build
    RCI skids/armor, SPC UCA, Fox 2.5 front 2.0 rear 16" TRD PRO rims/ 285/75/16, SS3 Pro fogs, Sherpa Roof Rack
    There is no airbag behind the A or C pillars. They are in the headliner and side of the seats. If there was one there the handle would do just as much damage.
    ImMrCrash likes this.
  15. Jun 24, 2022 at 6:59 AM
    JdevTac
    JdevTac Well-Known Member
    Josh
    MD/GA
    2nd gen
    It partially deploys out behind the A pillar and deflect the plastic but just as you said the handle isn’t going anywhere. More likely to get a broken left hand hitting the mount than anything else.
  16. Jun 24, 2022 at 7:11 AM
    outdoorgb
    outdoorgb (.)(.)
    Burbs of Oregon
    2014 DCSB TRD Sport Silver Sky...
    A week or so back I installed a Kenwood DMX DD head unit. Then. yesterday I swapped the front 6x9's (disconnected tweeter) with a set of Alpine S-S65 components: 6.5" driver and silk tweeter. Brought back that spatial sound.
    jackn7 likes this.
  17. Jun 24, 2022 at 7:18 AM
    lynyrd3
    Bill
  18. Jun 24, 2022 at 8:59 AM
    Charlie Bravo
    Charlie Bravo Well-Known Member
    Charlie
    Coeur d'Alene, Idaho
    2009 Red Tacoma Access Cab 4wd 2.7MT
    RedLine Tuning hood QuickLIFT, Gen3 alloy 16x7J, All Pro Off-road bed stiffeners & IFS skid plate
    You should also bring the (good) beer, it's what good neighbors do. (We liked the Pearl Brewing product from Texas, even though it didn't look like much in the generic cans from the IGA in central Idaho.)
    crashnburn80[QUOTED] likes this.
  19. Jun 24, 2022 at 9:54 AM
    TRnCO
    TRnCO Well-Known Member
    Tim
    Elizabeth, CO
    07 and 14 DCSB 4x4 Tacoma
    lo2hi, Gr8rSherman8r, irayfz6 and 4 others like this.
  20. Jun 24, 2022 at 4:38 PM
    Minny Taco
    Minny Taco For the Horde!
    Minnesota
    2015 TRD Off Road DCSB
    - Dobinsons shocks and leaf pack - Level 8 MK6 wheels - 265/70/17 Goodyear Wrangler Duratracs load C - SPC UCA - Moog LCA - TRD Pro headlights - Bullet Proof Fab skid plate w/ Line-X - 3M Matte Black roof vinyl - Astrostart remote - Debadged - Black shifter bezel - Front window tint 50% - Color matched grill surround - MESO LED red/white map lights - Osram Super Bright H4 bulbs - Headlight Services upgraded wiring harness - Auxito LED reverse lights - Zulu Nylon Gear MOLLE visor cover - Truxedo Lo Pro QT tonneau - Weathertech floor mats - Weathertech vent visors - Redline Tuning Elite hood struts - OEM bed mat - AJT Design custom shift knob - AJT Design custom climate knobs - Center console organizer - Salex glove box organizer - 1" driver seat spacers - AntennaX 14" antenna - AVS door sill protectors - Trimmed OEM mud flaps - Candyapple red tow hook - Painted pinch weld and radiator frame - Custom radio knobs from Hondo Garage - Xtunes black tail lights - Black LED third brake light - Ruff Tuff Kryptek Typhon seat covers - ACEkraut license plate relocation bracket - Cali Raised Side Shooter ditch lights w/ lo-pro mounts - Subaru tweeters + Rockford Fosgate speakers - Thinkware F800 Pro dash cam - Stickers n shit
    Going to try HyperDip on my aluminum skid. It's held up pretty well on my back bumper so far. I spray a scratch protectant on it every wash which I think helps. Just didn't jive with the factory skid color.
    Pardon the dumpy garage. You folks with nice garages are fortunate!
    It's a 2 beer job so far but there are several coats to go yet. It's Friday!!
