  1. Jul 26, 2022 at 8:17 AM
    hxp05560
    hxp05560 Well-Known Member
    2009 TRD Off-Road
    TRD Pro Wheels - Duratracs Black Softopper
    Picked up a new to me bed mat.
    My knees already feel better.
  2. Jul 26, 2022 at 8:51 AM
    mrproduxn
    mrproduxn Well-Known Member
    steve
    Retired DoD SE VA
    Tacomas 1987,2000,2008, 2016,2012,2008
    Retired/Hobbyist old as f***
    That seems to be a very rare problem. If it was my truck I would pull and test that one control valve. If it is out of spec then would be worth replacing since it is already removed. Just my 2 cents.
  3. Jul 26, 2022 at 8:56 AM
    Northbound_Taco
    Northbound_Taco Well-Known Member
    Nowhere Fast, Everywhere Eventually
    09 Off road build
    RCI skids/armor, SPC UCA, Fox 2.5 front 2.0 rear 16" TRD PRO rims/ 285/75/16, SS3 Pro fogs, Sherpa Roof Rack
    That is what I am leaning towards. It hasn't thrown a light either just the "pending" code.
    Thats $250 I didn't want to spend on maintenance.
  4. Jul 26, 2022 at 9:16 AM
    mrproduxn
    steve
    Retired DoD SE VA
    VVT is a great thing for both performance and fuel management. It is however a system that can cause havoc especially when there is an oil deficiency. Look at how many Ford trucks, with 4.6 and 5.4 engines, have had major failures due to poor oil flow in the VVT system. Even my daughters low mileage Buick V6 has warnings concerning oil flow to that system requiring full synthetic oil changes between 3k and 3.5k miles. That one is due to pin sized oil ports feeding the valve timing system that gum up with thickening oil. I suspect, after reading the 5 pages in the TW thread "oil control valve location", that your problem is related to gumming of oil in that valve. You could probably buy some time by cleaning it with the right cleaner but I say replace it and forget about it. You would most likely never see that code again. Well not at least until the one on the other side pops a code P0012. I am in my 60's and started tearing into engines when I was 13-14 years old and I am constantly amazed at how much there is still to learn about cars and trucks. These forums, along with the relative youtube videos, are a constant never ending wealth of information and education.
    Doc Samson, jackn7, Philrab and 2 others like this.
  5. Jul 26, 2022 at 9:21 AM
    Northbound_Taco
    09 Off road build
    Yeah I read over that twice now and sounds like what is going on. If I'm going to take the intake off to check them they are going to get replaced. I'm almost at 180k so for piece of mind I think I will be changing them when I get time to. I'll try cleaning the filters first to see if they are dirty.
  6. Jul 26, 2022 at 10:52 AM
    cdex8357
    cdex8357 “Everybody gotta die sometime”
    “Dex”
    H-Town
    2013 Taco OR
    Mid travel FOX 2.5 Coilovers FOX 2.5 secondary bypass FOX 12” Triple Bypass
    Installed the McNeil +2 fenders up front. Took about 6 hours in this heat.
    Painted the inner fenders black.
    Finally done at 11 pm
  7. Jul 26, 2022 at 3:44 PM
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
    Removed TRD bedside decals.
    BA6DC34A-2745-4F61-994F-3278390EA350.jpg F827179B-894D-4121-8C59-B9B4D650B5D3.jpg
    05Taco4x4, drainsbe, theolee and 18 others like this.
  8. Jul 26, 2022 at 4:30 PM
    TomTwo
    TomTwo I love God but I cuss a little
    Bill
    I-85 Southbound
    2013 TRD Double Cab Sport
    NmapFE, theolee, Doc Samson and 6 others like this.
  9. Jul 26, 2022 at 5:09 PM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    Received my new inner tie rod and jam nut.
    I was able to replace the drivers lower control arm over the weekend and I checked on Monday to see if I can loosen the tie rods so I can align the thing. The passenger came loose but not the drivers side.
    Now to find time to replace the tie rod and do an alignment.
    jackn7 and Cativelense like this.
  10. Jul 27, 2022 at 12:52 PM
    themanbearpig012
    themanbearpig012 Well-Known Member
    Rudy
    Nipomo, Ca
    2015 DCSB TRD SPORT
    Fox 2.5 Factory Series Coil-Over Reservoir (Front) Fox 2.0 Performance Series IFP (Rear) Method "Mesh" 17x8.5|6x5.50|0/4.75" wheels
    Finally installed the @CaliRaisedLed push button for the ditch lights
    NmapFE, irayfz6, dpele and 2 others like this.
  11. Jul 27, 2022 at 5:21 PM
    WiscoTaco4x4
    WiscoTaco4x4 Well-Known Member
    Brady
    2015 SR5 ACLB 4x4
    I have done about 4k miles on my tacoma and so far so good!
    NmapFE, Z7Xtreme, jackn7 and 2 others like this.
  12. Jul 27, 2022 at 5:24 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Another 44,444 and she'll be broken in.
    I'm closer to 255555 miles.
    Actually... I'm over that...
    :bananadead:
  13. Jul 28, 2022 at 5:17 AM
    Doc Samson
    Doc Samson Well-Known Member
    Almost NoVA
    2009 Tacoma TRD Sport
    None... yet.
    I've done so much for the truck this summer and my last project was going to be taking care of the rear drums...
    Then, I found out why my exhaust sounds so "throaty"!
    Sigh...
  14. Jul 28, 2022 at 5:20 AM
    MSgt O
    MSgt O Well-Known Member
    2013 Tacoma
    BRRRRRPPPPPP....sounds like a Subaru! and I promise not to tell the wife you used one of the good towels...
    Doc Samson and jackn7 like this.
  15. Jul 28, 2022 at 6:38 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    I put some 4” auxbeam lights in the fog light spot, needa do the anytime fog mod.
    and now I needa find some new ditch lights, got brackets otw and a 8 button switch panel
    and get new head lights cause I don’t like these
    Tour991 and irayfz6 like this.
  16. Jul 28, 2022 at 7:20 AM
    Kombi
    Kombi Well-Known Member
    Zack
    08 Tacoma 97 Fjz80 01 Tundra
    Started my suspension and drivetrain upgrade
    Jd 2.25 LT with Fox RR coilovers
    Lc200 steering rack
    Rc Fab clevis and kel-tek made rod arms (dual shear at both ends)
    Front diff is getting 4.88s and Air locker
    Bigger brakes (gx470)
    Rear is going land cruiser 9.5 with 4.88 and Air locker..
    Currently have 37s on method beadlocks but debating 40s (I'll probably just run the 37s and decide later)
    Upgrading from single arb to a dual arb with a tank and hardlines/regulator ran.
    Cleaning up and painting a bunch of stuff, also looking for places to gusset and or strengthen as im going.
    Just wish the heat would calm down
    NmapFE, Tour991, Hayden334 and 14 others like this.
  17. Jul 28, 2022 at 8:05 AM
    Northbound_Taco
    09 Off road build
    My rear drums are on the short list. What brand did you go with?
    Rick_Taco likes this.
  18. Jul 28, 2022 at 8:35 AM
    AStinkyBumb
    AStinkyBumb Well-Known Member
    Indiana
    2013 DCLB SR5 4x4
    RIP oncoming drivers eyes
  19. Jul 28, 2022 at 8:36 AM
    JKO1998
    Utah
    Only use LEDs on empty roads?
    I know Indianas a bit behind in the common sense game but damn.
  20. Jul 28, 2022 at 8:38 AM
    elricfate
    elricfate Well-Known Member
    2009 Tacoma AC Silver Mica
    No but you're using floods as driving lights/fogs. There's no cutoff to discern, based on the blast of light in the picture. Who knows what it looks like up close, but fog lights shouldn't be above the level of the bottom of your headlights. They're only made to cover that space prior to your headlight's reach.
