  1. Aug 14, 2022 at 8:03 PM
    AVGeek
    AVGeek Well-Known Member
    Boulder City NV
    2011 Barcelona Red Reg Cab 4WD
    I need to add sound damping material to my RC, how much should I be looking at buying to cover the rear wall?
  2. Aug 14, 2022 at 8:07 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Back walls should all be roughly the same, I think I used 1 box of Dynamat Extreme, did two layers and a roll of Dynapad.
    Helped tons but made me realize how loud the rest of the truck was so I did that too.
    1.5 rolls of Dyna Liner, Another roll of Dyna pad and 2.5 more boxes of Dynamat Extreme did the whole cab of my Access Cab, roughly 90% coverage and did inside the doors and on the door faces.
    So one bulk box of Dynamat Extreme should do you.
    T.Barn and AVGeek[QUOTED] like this.
  3. Aug 14, 2022 at 8:41 PM
    ZColorado
    ZColorado Well-Known Member
    Near Boulder Colorado
    13 DCSB OR 6MT
    35's,Kings, NWF, 488, Harrop, SPC, Archive, Method, RCI, C4
    VF1 from a 94 V6 pickup
    VF2 from a 4runner (I dont know the year)
    VF4 from a 2nd gen 6MT Tacoma (This is what I have in my truck)
    Key-Rei[QUOTED] likes this.
  4. Aug 14, 2022 at 8:42 PM
    Key-Rei
    Key
    Florida
    All the same size eh?
  5. Aug 14, 2022 at 8:50 PM
    ZColorado
    13 DCSB OR 6MT
    Surprisingly little has changed in the cases since the early 80s.
    The VF1 and VF2 just flipped from pass drop to drivers drop.
    The oil pump had to change a bit.
    The synchro for the high/low fork was not in my VF2 (it was clearly factory sealed, so it's not like it went missing)
    Front output is different length
    The input shaft oil seals is one of the subtle changes I noticed. otherwise it looks like a lot of the parts swap?
    I have not torn down the VF4 yet, It's the direct swap for my truck. MT input gear and everything. The shift motor is damaged though
    Ricardo13x and T.Barn like this.
  6. Aug 14, 2022 at 8:52 PM
    Key-Rei
    Key
    Florida
    What's an FJ (J shift) case considered?
  7. Aug 14, 2022 at 8:57 PM
    ZColorado
    13 DCSB OR 6MT
    VF4 I believe? It's more due to the transmission mounting pattern then anything... I think?
    NWF has a really cool table with all the various years their ecocrawler will fit and it calls them out.
    https://cdn.shopify.com/s/files/1/0509/2261/9043/files/EcoCrawler_Fitment_Guide_R00.pdf?v=1660254556
    Here is a blurry picture of the inside of the VF1 and VF2 cases. I did not check to see if it was blurry after I took it. oops.
  8. Aug 14, 2022 at 9:00 PM
    Key-Rei
    Key
    Florida
    That's pretty dope.
    I still need to split my FJ case and mod it for my twin sticks.
    Then actually freakin install the damn thing.
    Been holding my bench down for like 3 years.
  9. Aug 15, 2022 at 7:50 AM
    Philrab
    Philrab Curator of useless knowledge
    Phil
    New Orleans, Louisiana
    2015 Pyrite Mica Quad Cab Prerunner
    Bunch of Basic Taco mods.
    Did the DIY transmission flush and my sloped driveway didn’t do me any favors. Jacked the truck up to try to get it closer to level, ended up with fluid coming back out of the fill port when I’d tried to add that last quart, and just a drop or two came out when I heated up the trans to 115 degrees and pulled the overflow plug. I’m halfway between throwing a bubble level on the frame and trying again, but it’s gotta be pretty close.
    Also, 70,000 miles in Louisiana heat wasn’t kind to the fluid.
    dpele, Ricardo13x and Canadian Caber like this.
  10. Aug 15, 2022 at 7:58 AM
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
    Am I watching a scene of Narcos here? lol!
    srspicer, burrito782, Key-Rei and 2 others like this.
  11. Aug 15, 2022 at 8:30 AM
    henrilepuf
    henrilepuf Well-Known Member
    henri
    Northwestern Paraguay
    tacoma 2014 4x4 DCLB
    Yep, you're right !!! :)
    Moreover, it's a common practice overthere.
    But I'm not in that business LOL
  12. Aug 15, 2022 at 10:19 AM
    mrproduxn
    mrproduxn Well-Known Member
    steve
    Retired DoD SE VA
    Tacomas 1987,2000,2008, 2016,2012,2008
    Retired/Hobbyist old as f***
  13. Aug 15, 2022 at 1:46 PM
    Kombi
    Kombi Well-Known Member
    Zack
    08 Tacoma 97 Fjz80 01 Tundra
    Still working on the JD LT install
    37s spin free at full bump lock to lock
    40s rub just a little at full bump -not sure the wife will let me steal back her 40s that are for her 1st gen 4runner.. lol
    T.Barn, Karate1993, Hayden334 and 8 others like this.
  14. Aug 15, 2022 at 1:56 PM
    Ricardo13x
    Ricardo13x YT: @UrbanOpsOffRoad IG: @urban.ops.offroad
    Upland, CA.
    05 OR DCSB ProRunner(4x4 conv.), Chevy 63”s, NWF EcoCrawler, 35”s
    Random stuff. Oh! and converted to non ADD 4x4.
    savage!
  15. Aug 15, 2022 at 3:19 PM
    InfernoTRDPro
    InfernoTRDPro Well-Known Member
    Charlotte, NC
    2015 TRD Pro 4x4
    "OEM+"
    BigDawg Industries Mirror riser was a cheap and easy mod that makes life much better =)
  16. Aug 15, 2022 at 3:45 PM
    AStinkyBumb
    AStinkyBumb Well-Known Member
    Indiana
    2013 DCLB SR5 4x4
    So when I lifted my truck a year and a half ago I did things well and didn't stretch an abs sensor. I think however when I changed my hubs I stretched a wire. Changed them out months ago but just recently started getting abs and Trac lights on the dash. I hooked up my cheap obd reader to it and there aren't any codes so I don't suspect the wheel sensor is bad from the hub change. Will a bad wheel sensor always throw a code? If I don't get a code does that confirm the harness was stretched? Anyone have any input on how I tell if it's left or right harness?
  17. Aug 15, 2022 at 3:46 PM
    Dagralph
    Dagralph Well-Known Member
    2015 SW DCLB taco
    big dawg or bird dawg? Did you get one recently? I tried buying from their site but PayPal won’t let me put the order through.
  18. Aug 15, 2022 at 3:48 PM
    mrproduxn
    steve
    Retired DoD SE VA
    You need a scan tool that reads Toyota ABS codes. For my Ford I use forscan to read ABS codes. You probably need techstream software and a dongle for the obd2 port. I bought the forscan dongle and reader for $15 and I can read every code in my Ford. I also added navigation with the software. Just replaced an abs wheel sensor using it. I don't see anything anywhere that does this for Toyotas for under $60 and you still need to access the software to download.
  19. Aug 15, 2022 at 3:48 PM
    Dagralph
    2015 SW DCLB taco
    Should have, but didn’t, gotten before and after pictures. Went under the truck grinding and picking rust. Wiped it all down then hit it with rattle can rust reformer. It’s all ready for the 3 cans of FF I’ve got sitting in storage.
    also going in for a tune today.
    jackn7 and Big Foot like this.
  20. Aug 15, 2022 at 4:17 PM
    Big Foot
    Big Foot Well-Known Member
    Washington
    2014 DCLB
    jackn7 and loyaltothetaco like this.
