  1. Aug 28, 2022 at 9:34 AM
    Tactical_Panda
    Tactical_Panda Armchair Anarchist
    Tim
    Fredericksburg, VA
    2015 Tacoma Double Cab, Off-Road Edition
    AJT Designs Shifter AJT Designs Battery Hold-Down ARB Awning 2500x2500 ARB Twin Compressor w/ Slee Offroad Mounting Bracket Avid Brush Bar Avid Step Bars Black Rock Wheels Series 997 Type 8 Circuit Breaker/Relay Panel Custom TRD Decals Bulletproof Fabricating Raptor Grill Bulletproof Fabricating Cooling Panel Bulletproof Fabricating Tow Hook Duluth Trading Company Dog Hammock Exhaust Breather Mod eBay Special 3-Gallon Air Tank Expedition Essentials TPAM EZ Down tailgate damper Flagpole Mounts, Dual Foglight Mod Front Camera Rear Camera; full time available General Grabber tires Goat Armor Hella Supertone Horns Iggy Switch Panel Icon Dynamics Stage 3 Suspension Katskin Leather Interior KickAss camp shower LED Bed Lights LED Interior Lights Midland MXT275 GMRS Two-Way Radio OEM Audio Plus Reference 500 audio upgrade Plano Cases. 42" roof mounted, X2 Pop-N-Lock Tailgate Handle Prinsu Cab Rack Prinsu-like Shell Rack Redline Tuning Hood Struts Rigid Industries 40" Light Bar Rigid Industries Ditch Lights Rigid Industries Spotlights Toyota Bed Step UltraGauge EM Plus v1.4 Vixen Air Horns, Four-Trumpet Whole bunch of decals worth about 5HP each Yakima Road Shower, 10-gal
    Well I went and put in a new battery yesterday. While I was there the AutoZone guy hooked up a diagnosis box and it came back that my voltage regulator was tits up which means a whole new alternator.
    FML.
  2. Aug 28, 2022 at 9:41 AM
    IvanhoeTaco
    IvanhoeTaco Well-Known Member
    Eastern NC
    2005 Supercharged Converted Prerunner
    Total Chaos 3.5 LT, King Coilovers, 35x11.5r17 on Falcon T2, ADV 4 inch fiberglass, 4.88 gears, FJ cruiser transfer case, 4 runner front diff, Cab mount relocate, archive hangers, shackles, king 2.5x14 rear shocks, icon rxt leaf springs, king hydro bumps
    Run truck with all loads on, disconnect negative battery cable while the truck is running. If it dies, alt is bad. If it stays running normally, alt is fine.
    Dont run it more than 5 to 10 seconds disconnected. Easy way to check alt output.
  3. Aug 28, 2022 at 1:36 PM
    20somethingwidataco
    20somethingwidataco Yes, my avatar is a real car.
    Will
    Washington State
    2008 AC TRD SPORT M/T
    ACLB 6 SPEED: Suspension: Bilstein 6112s (3rd perch) (F) Taco Lean Spacer Bilstein 5160s (R) TSB Leaf Pack Wheelers Offroad 3 leaf progressive AAL Wheelers Superbump Front Duro Bump U bolt flip kit Duro Bump progressive bump stop 3rd gen TRD offroad sway bar Wheels and Tires: Summit Racing Wheel Dakars (Polished Silver) 285/70r/17 Goodyear Wrangler Duratrax (Load D) "Performance": AFE CAI with custom powdercoated white filter cover MagnaFlow Performance Series Exhaust URD Cam gears XTP Intake Manifold Spacer OTT Torque Tune Brakes: Stoptech Slotted Rotors Stoptech Sport Ultra Composite Brake Pads Wheelers offroad SS brakelines (Front) Interior: Kenwood DD headunit Oem Subaru Kicker Tweeters Alpine 6x9 (Front) & 6.5 (rear) (With Taco tunes speaker mounts) Alpine 500 watt amp Sound Deadening (Doors, Rear "wall", Roof) ODI Rouge Shift Knob Weather Tech Mats Painted/wrapped trim pieces Console Safe Console Vault Gridx Organizer Ram Phone Mount Meso Customs dual color map lights Meso Customs dual color dome light Wet Okole seat covers (Black) Wet Okole center console cover (Black) 1" Seat Raisers (Driver & Passenger) AJT Designs climate control and 4x4 knobs Back Up Camera Lighting: Retrofits (Mini H1's, RGB Halos, 5500k Bulbs)(Lenses wrapped in self healing PPF) Diode Dynamics SS3 Max SAE (Yellow) Diode Dynamics SS5 Pro (Yellow) Driving lights (ditch lights) Anytime fog mod Rigid Industries E series 32" Combo bar (spot/flood) Diode Dynamics XPR Reverse Lights Diode Dynamics XP80 turn signals LED brake, parking lights and license plate lights Armor: Apex All Pro sliders BPF steel skid plate Bigass Trailer Hitch Camping/Storage: Leer canopy LED interior lighting Sleeping platform (Storage underneath) Removable snowboard Yakima mounts Extra D rings in bed (6 total) Custom Powder coated white snow shovel with custom bedrail mounts Amazon special Traction Boards Hi Lift 48" Jack with custom Rail mounts to accommodate my sleeper set up Other: All pro Bed Stiffeners Relentless Fab tailgate panel TRD sport graphics (Turd Gen spec) Anti Sun glare hood scoop wrap (Satin Black) Custom FleeBay grille 4 Hella supertones ECGS needle bearing Many Patches BPF shackle mount (With smittybuilt shackle) Tinted windows (Front/Rear + Full canopy)(18%) Meso Customs gasshole AVS inchannel window visors Diff Breather Kit 2012-2015 Oem Turn signal/folding mirrors (w/ sequential signals) 2012-2015 Oem LED taillights Full Size (285/70r17) spare DIY Larger Engine Splash Guards DIY Vipercut TRD radiator cap AC drip line mod
    Replaced my UCAs.... still have a clank in the front end. I have new lcas, ucas, sway bar end links, tie rod ends, new sway bar, new coils, and still a clank. Any suggestions? Replacing the ucas made it way better but it's still noticeable....
    powder1134, Scrat and loyaltothetaco like this.
  4. Aug 28, 2022 at 1:50 PM
    Ezriderga
    Ezriderga Well-Known Member
    Georgia
    2008 Tacoma base truck
    My ‘08 Tacoma has been running a little rough lately, well it does have 419,000 miles on it, so I decided to change the PCV valve and see if that would help. I bought an OEM part and looked online to see how it’s done so I jumped in. I’m old (72) but I still like to do what I can. It was a little bit of a challenge however I got it done. WOW! was I amazed. My truck ran great, much better than it ever has.
    BTW, there is a threaded hole in the picture close to the PCV valve. Can someone tell me what is supposed to go there? TIA2C3AF014-E54F-4CCC-B881-D1342013507E.jpg
    D0m1n1ck, Bagman, powder1134 and 5 others like this.
  5. Aug 28, 2022 at 1:53 PM
    mrproduxn
    mrproduxn Well-Known Member
    steve
    Retired DoD SE VA
    Tacomas 1987,2000,2008, 2016,2012,2008
    Retired/Hobbyist old as f***
    As noted by others check lower control arm cam bolt torque with wheels on the ground. Check your steering wheel shaft/joint. Make sure the steering rack doesn't move at the mount bushings with wheels on ground and wiggling steering wheel with someone watching or having a hand on the rack. Another misleading traveling clunk sound can come from a cracked or broken rear leaf in the leaf pack.
  6. Aug 28, 2022 at 2:52 PM
    JAGCanada
    JAGCanada Well-Known Member
    Canada
    2010 TRD Sport V6 Auto Double Cab MGM
    Made a bracket out of flat bar to hold a fire extinguisher quick release (from Amazon)
  7. Aug 28, 2022 at 3:18 PM
    Scrat
    Scrat GRYLNG
    Jacob
    Woodland Park
    V6 SR5 '15
    ARE CX Topper, Yakima rails with various accessories, Bilstein 5100, Icon RXT, OME 886 coils, Firestone Ride-Rite, 265/75/16 KO2, Mobtown Offroad Rear Bumper., Diode Dynamic map and dome lights, headlight harness, Cali-raised bed stiffeners, Cali Raised accessory bed mount, Cobra 75wx st, Leixen VV898e, Safari Snorkel, SOS Sliders, CBI Full skids pack, and more coming!
    Make sure to blue locktite the sway bar link. I lost a nut and busted my boot.
  8. Aug 28, 2022 at 3:54 PM
    Dalegribble02
    Dalegribble02 Well-Known Member
    Savona British Columbia
    2014 SR5 4x4 meg grey sold
    Dobinson mrrs Deaver leafs archive garage hammer hangers.
    I helped pull down 2 big trees with my winch
    dpele, jackn7, fasteddieyj and 4 others like this.
  9. Aug 28, 2022 at 4:10 PM
    Dagralph
    Dagralph Well-Known Member
    2015 SW DCLB taco
    Big weekend for the ol girl:
    cowl induction snorkel on Friday. New bumps front and rear with a flippy kit, 6112, 5160, RXT, SPC UCAs on Saturday. Fluid film, wash, clay bar, polish and grapheme coat Sunday.
    hardest part was gettin the front oem bump stop out lol.
  10. Aug 28, 2022 at 5:51 PM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    First up, was repairing the roof rack lights. I bench tested them on Thursday and they worked so I knew it was the harness. I pulled the wiring down this morning first thing and as soon as I brought the harness down from in between the cab and the topper, the issue was found:
    Easy fix. Cleaned up the wiring a bit, too.
    When the RTT is mounted, the cover hangs off the driver's side so having the light on the rear rack was pointless. So I relocated them:
    Really happy with that.
    Next, I moved on to finally mounting the new rock lights. I've had these sitting around for 2 years. I used waterproof deutsh connectors for each light and each section of the harness. This means that if a light goes out, or a section of the harness goes out, only that light or section has to come out.
    I only have 6 lights; two of the old style lights and 4 of the newer style ones. It was still light outside so it wasn't totally dark:
    Not terrible.
    GARSHA91, theolee, jackn7 and 6 others like this.
  11. Aug 28, 2022 at 7:30 PM
    singletrack_ftw
    singletrack_ftw “I chopped the wrong leaf!”
    Tyler
    AZ
    ‘08 TRD OR 4wd
    https://www.tacomaworld.com/threads/singletrack’s-‘dad-shred-build-thread’-i’m-just-doing-it-for-the-kids.619250/ Sos offroad sliders (kickout + filler) Sos offroad full belly skids (steel) Sos offroad front recovery point Sos offroad concepts HC rear bumper with bedside kickout tubes Marlin Crawler LCA frame brace kit Trail Gear rear diff cover Bilstein 5100 + OME 885 Total Chaos UCA BILSTEIN b110 OME Dakar standard pack Wheelers Ubolt flip kit Wheelers Superbump f/r Wheelers SS extended brake lines FN five star 16x8 -25 Milestar Patagonia MT 315/75r16 Custom projector retrofit (acme super h1 + morimoto 4300k) Baja Designs S2 sport ditch pods on CBI ditch pod mounts Amazon AMAK rock lights CMC CB radio hardmount
    Trail 401 I think it’s called, 7hrs of 4low just lettin her eat. Took my 6 & 3 yo and it was a rough day in the HEAT, but they did great
    jafrisi, dpele, jackn7 and 24 others like this.
  12. Aug 28, 2022 at 8:29 PM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    What lights did you use? I have a bag of KCs I have been meaning to wire up as rock lights for 2 years. I like the idea for connectors good call.
  13. Aug 28, 2022 at 8:35 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Is the guy with the Tundra on here?
    I've seen some contractor snug tops for Tacoma like the one he has, the double doors and no tailgate, curious how he likes it?
  14. Aug 28, 2022 at 8:38 PM
    geekhouse23
    dwcfastrice likes this.
  15. Aug 28, 2022 at 10:46 PM
    TomTwo
    TomTwo I love God but I cuss a little
    Bill
    I-85 Southbound
    2013 TRD Double Cab Sport
    That’s great parenting!
    jackn7, Bagman and MSgt O like this.
  16. Aug 29, 2022 at 6:04 AM
    TomToy06
    TomToy06 Member
    Tom
    2006 Silver Tacoma TRD Off-Road DCSB
    Finally got around to replacing my body mount bushings. The drivers side rear one had been clunking for a few weeks. From the pic you can see why; it was totally rusted away from the bracket. Went with the Energy Suspension kit; still have to do the front radiator mounts. Got all new bolts too. Makes a huge difference. Was a real pain getting the rears out; the bolts were rusted in the sleeves. Ended up using an air hammer to get them loose. Good excuse to get new tools.:D Thanks to folks here who posted the instructions.
    burrito782, reallifedog and Scrat like this.
  17. Aug 29, 2022 at 6:09 AM
    99TacoDriver
    99TacoDriver Well-Known Member
    South Louisiana
    OME 885x/5100s/LR UCA/3 leaf AAL/275/70/17 Terra Trac X-Venture
    what rattle cans did you use?
  18. Aug 29, 2022 at 6:27 AM
    singletrack_ftw
    Tyler
    AZ
    ‘08 TRD OR 4wd
    Hahaha thanks! It was stressful tho
    Bagman and TomTwo[QUOTED] like this.
  19. Aug 29, 2022 at 6:59 AM
    TomTwo
    Bill
    I-85 Southbound
    Gotta give them stuff to remember, and they will remember stuff like that good on you.
    Bagman likes this.
  20. Aug 29, 2022 at 7:07 AM
    singletrack_ftw
    Tyler
    AZ
    ‘08 TRD OR 4wd
    It was an unforgettable day tbh. I was planning for 4 hours but it ended up being 8 hrs and a VERY remote trail. It was quite a trip to initiate them into wheeling. Prior to this, my oldest would throw up carsick even on curvy paved highway roads but I was careful with what he ate and let him distract himself with a tablet when needed. Either way it was an all day very very rough trail in the sun with no shade pretty much anywhere. They crushed it. I was low key miserable but they did great. So proud & there will be many many more trips to come.
