  1. Oct 14, 2022 at 10:41 AM
    MSgt O
    MSgt O Well-Known Member
    2013 Tacoma
    Put her to work again..Friend had some small sugar maple trees, went and dug them out and replanted them for over-wintering until transplanting next spring.
  2. Oct 14, 2022 at 10:56 AM
    AStinkyBumb
    AStinkyBumb Well-Known Member
    Indiana
    2013 DCLB SR5 4x4
    Are you lifted and did you measure drive shaft angles before and after the lift? If you didnt measure did you at least do a carrier bearing drop kit with any lift? vibes on takeoff are usually drive line angles being off which is a common outcome to lifts on these trucks and 2 piece drive shafts.
  3. Oct 14, 2022 at 11:00 AM
    Northbound_Taco
    Northbound_Taco Well-Known Member
    Nowhere Fast, Everywhere Eventually
    09 Off road build
    RCI skids/armor, SPC UCA, Fox 2.5 front 2.0 rear 16" TRD PRO rims/ 285/75/16, SS3 Pro fogs, Sherpa Roof Rack
    Yes been lifted for 3 years never had the issue before. Carrier barring is dropped and only thing I did recently is 33s but that doesn't change the driveshaft angle. I am guessing it was lack of grease. They each took about 4 pumps so there was probably a little slop in them.
  4. Oct 14, 2022 at 11:13 AM
    Its_Taconie
    Its_Taconie Well-Known Member
    Nelson
    North Hollywood
    2007 Tacoma DCLB PreRunner
    Fox Racing 2.5 (F); 2.0 (R), Archive Garage Leaf Springs, hanger/shackles, shock relocation, U-Bolt Flip Kit PLM P37 (TE37 Knockoffs) Bronze wheels, Nitto Ridgeline 35s, C4 Overland Bumper, Total Chaos Uppers, Outgear Solution HC Swingout, OTTune 4.88 Nitro Gears
    Looking forward to seeing the final product and curious to how you will secure them after the trimming.
    powder1134[QUOTED] likes this.
  5. Oct 14, 2022 at 11:23 AM
    Diabl0
    Diabl0 2005 TRD Off Road DC SR5
    Tim
    Massachusetts
    2005 TRD off Road DC SR5
    AUCar Android Stereo Bluetooth Katskin Leather Soft Bed Cover Dual kicker comp s10’s Bull bar Euro headlights Black grill Clutch bypass switch Alpine 6.5 and 6x9 speakers Kicker Subaru Tweeters Diamond floor mats Dick Cepek DC2 Wheels Toyo Open Country ATII Tires Black Aftermarket Grill Rhino lined Tube Side Steps Back up Camera
    Hauled home a new gaming chair for my office. Put it together in 5 min. Now where to take the old one? Humm
  6. Oct 14, 2022 at 12:54 PM
    Johnny DemonT
    Johnny DemonT Well-Known Member
    SW Burbs of Chicago
    15 Silver DCLB
    I did a little project that’s going to be controversial to some people but it came out awesome! I had retrofit source projectors retrofit it into stock housings for 85,000 miles then they started to become problematic… so I went back to original stock lights…. but I had this idea to retrofit in 7 inch jeep wrangler DOT approved LED assemblies! I’m hoping to dial in the output a little bit more tonight but last night they seem to be pretty good coming off of stock lights and retrofits!177EA616-5890-4366-96DD-E4EDF11ACBC3.jpg 5BA6879D-96E8-4748-B0B9-59465FD7427D.jpg06491527-D8FE-42C0-9CA1-D8BF385A8FE1.jpg B266AA9C-81D2-457E-AE03-18EF10C83ADC.jpgB4D076D7-4F0D-42BC-AC23-1C1C34638B54.jpg
  7. Oct 14, 2022 at 1:10 PM
    Yacob_D
    Yacob_D It's Fine, Leave It.
    Jacob
    The J
    08 Red, AC
    Couple nuts and bolts 4x converted
    @Johnny DemonT Did you attach the lights somehow to the stock adjustment points in the housing itself? Looks great!
    bootboiler and Johnny DemonT like this.
  8. Oct 14, 2022 at 1:16 PM
    TacoMatt
    TacoMatt Member
    So Cal
    2014 Tacoma Prerunner Access Cab TRD Sport
    Bilstein 5100’s with 2 1/2” lift in front and 1” in back. UnderCover Bed Cap. Train horn.
    I've ordered an amp for the front speakers and a couple of kits (install kits for the door speakers and wiring kits for the powered sub and amp). Figured I might as well amp the door speakers while I've got everything apart. I'll let you know once it's all installed.
    ***UPDATE***
    Finally got everything installed. The powered amp doesn’t really fit. I have it under the passenger seat and while it is under there, you can’t really adjust the seat forward or back. For me, for now, this isn’t actually an issue because 99.9% of the time I’m alone. But no, it’s not practical and I’m sure I’ll end up relocating it to behind the seat…which defeats the whole purpose, I didn’t want it exposed at all. Luckily it wasn’t too expensive (I paid $105 on Amazon).
    But it does what it’s supposed to do, there is now bass in my truck. I put in new door speakers and an amp for those as well so I’m still trying to get it all dialed in…not something I’m real good at so it may take awhile.
  9. Oct 14, 2022 at 1:21 PM
    elricfate
    elricfate Well-Known Member
    2009 Tacoma AC Silver Mica
    "controversial" - maybe - let's see your beam shots/cutoffs :)
  10. Oct 14, 2022 at 1:21 PM
    Johnny DemonT
    SW Burbs of Chicago
    15 Silver DCLB
    That is exactly what I did so I could use the bowl to center them. Now that said as you know there isn’t like a whole ton of adjustment there but I went off of how my projectors were mounted before. I had to really get creative with how to mount them basically using four small pieces of metal bracket it was a bit of a science experiment I had the micrometer out and everything:thumbsup:
  11. Oct 14, 2022 at 1:22 PM
    Johnny DemonT
    SW Burbs of Chicago
    15 Silver DCLB
    In due time my friend. It’s going to need some adjustment I work nights so I’m not sure if I’m gonna be able to get some photos tonight but I will have them for the people one of these days
    SpeedwayTaco160 and Yacob_D like this.
  12. Oct 14, 2022 at 1:24 PM
    Johnny DemonT
    SW Burbs of Chicago
    15 Silver DCLB
    On a general drive down the street the light output was adequate without being over the top even with my retrofits I always had everything aimed pretty far down for my cut off but I’m also lifted way up and my truck is already controversial enough. I actually think the stock bowls and bulbs unadjusted improperly were far more controversial when I was on 3” of lift and didn’t adjust them right away…..
  13. Oct 14, 2022 at 1:26 PM
    Gruber1922
    Gruber1922 Well-Known Member
    Tacoma, WA
    2015 Tacoma Sport
    This happened to me with my motorcycle. The gasket on my radiator cap wasn't sealing properly and I was losing coolant in my overfill area. Swapped out a new cap and it stopped.
    I also noticed the inside of my radiator was actually rusty. The lack of seal caused oxidation inside
    NavyDiver72 likes this.
  14. Oct 14, 2022 at 2:46 PM
    Diabl0
    Tim
    Massachusetts
    New rain guards. Came in today. In channel style. I’ve had bad luck with them on other cars where the window wouldn’t go up all the way. These fit nice. $40 on Amazon next day delivery. I’m happy with them. A9CD1A9A-99B5-4613-B186-3E80DC0DD136.jpg
  15. Oct 14, 2022 at 2:59 PM
    bootboiler
    bootboiler Well-Known Member
    Scott
    Santa Cruz
    Camberg UCA's, locking tailgate, hid driving lights, B 5100's, OME HD Leafs, bud built plates, Relentless rear bumper, sliders with kick, breathers on pumpkins, satochi grill, bed lights, JVC 730BT Head Unit, Finch Four Wheel Camper FWC, 1Up bike rack, 265/75 16 tires
    Got the passenger uca done. Do the driver tomorrow. One trick was to remove the grill to tap the bolt in. Another is a 22.5 socket for the lugs. Finished up the driver side, and all went well. Again, taking out the grill made is way easier to tap in the bolts
  16. Oct 14, 2022 at 3:20 PM
    powder1134
    powder1134 Well-Known Member
    2014 Tacoma TRD Off Road
    Me too. I'm thinking of using L brackets bolted to the inner fender? I have a box of the oem liner clips that I'll use on any existing holes in the wheel well, as well as a box of self tapping screws if push comes to shove.
  17. Oct 14, 2022 at 3:25 PM
    powder1134
    I recently upgraded all door speakers, head unit, and added a slim Rockville powered sub. I think for my needs it sounds great! I didn't want major bass like I did in the 90's. Just enough to supplement the door speakers. It pumps out way more than I had expected and i have had to dial it back some. Couldn't be happier with it.
  18. Oct 14, 2022 at 3:58 PM
    bootboiler
    Scott
    Santa Cruz
    I love me some big Bass! :) I love me some deep bass!
  19. Oct 14, 2022 at 4:06 PM
    RedWings89
    RedWings89 Well-Known Member
    Luke
    SE Virginia
    2014 SR5 DCLB
    Installed some new seat covers. Way easier with the seats removed.
  20. Oct 14, 2022 at 4:28 PM
    Alexely999
    Alexely999 Well-Known Member
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    Hauling and balling
