  1. Oct 24, 2022 at 6:16 AM
    vonellis
    vonellis Well-Known Member
    04 DLBC x4 S/C 97 2X 04 DBLC 4X S/C
    Some and some more
    Little bit of atf and trans filter action yesterday. 5ADB936A-1406-4A50-B28D-4DF070CD1CE8.jpg
  2. Oct 24, 2022 at 6:40 AM
    MSgt O
    MSgt O Well-Known Member
    2013 Tacoma
    @vonellis why you got so many tongue depressors?
  3. Oct 24, 2022 at 6:44 AM
    vonellis
    Some and some more
    About 10,000. There for work.
    MSgt O[QUOTED] likes this.
  4. Oct 24, 2022 at 8:06 AM
    orezona
    orezona title unspecified
    satan's skillet
    2006 TRD OR DCSB OMGWTFBBQ TL;DR
    WARRANTY VOIDED
    Ah, that's good to note.
    I'll probably start with the hose/clamp and then keep an eye on things. Thanks!
  5. Oct 24, 2022 at 8:14 AM
    Fixxxer
    Fixxxer Well-Known Member
    Port Angeles
    '13 TRD Sport DCLB Super White
    ARB Front/Rear Air Lockers, Nitro Gear 4:88's, Hutchinson Rock Monsters, SOS Concepts Front Aluminium Bumper, UpTop Overland Alpha XL Roof Rack, ARB Snorkel, AVS Rainguards, Redline Hood Struts, Weathertech Mats, Flyzeye led's, MESO Molle Rack, Meso LED Dome Light, K&N Air Filter, UNI Filter Mod, Bosch Wiper Blades, Snugtop Sportster Reinforced Canopy, Viper 2-Way Remote Start, ARB Twin Compressor,
    What is the advantage of the aftermarket coil packs?
  6. Oct 24, 2022 at 8:36 AM
    srspicer
    srspicer Paint it black
    Lower Bucks PA.
    05' Black DBLC short bed
    Painting things black
    I went with OEM for a new blower motor, resistor and pigtail. It was not that expensive and I have had 0 issues since.
    jackn7 likes this.
  7. Oct 24, 2022 at 9:23 AM
    Seth's Shadow
    Seth's Shadow Well-Known Member
    2014 Spruce TRD Offroad
    That's it
    Gallowbraid[QUOTED] likes this.
  8. Oct 24, 2022 at 10:04 AM
    Northbound_Taco
    Northbound_Taco Well-Known Member
    Nowhere Fast, Everywhere Eventually
    09 Off road build
    RCI skids/armor, SPC UCA, Fox 2.5 front 2.0 rear 16" TRD PRO rims/ 285/75/16, SS3 Pro fogs, Sherpa Roof Rack
    Thanks. I ended up pulling the lower dash out and using self tapping screws on the metal brace that helps hold up the steering column. I don't have any open switch blanks so I drilled into the dash also. Hard to see it in these pics but this spot is super solid.
    Does the light on yours stay on when you don't have a trailer hooked up?
    Hayden334 likes this.
  9. Oct 24, 2022 at 11:14 AM
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
  10. Oct 24, 2022 at 11:20 AM
    Fixxxer
    Port Angeles
    How long did you have the BP-51's on for?
  11. Oct 24, 2022 at 11:58 AM
    LongRedAndSpringy
    LongRedAndSpringy Active Member
    CA 805
    2006 Impulse Red Tacoma SR5 DCLB 4WD
    Icon Stage 1 Lift Kit 265/r70/17 KO2's 17"x9" -12/4.5" Method 312's
    Yesterday I prepped my truck for a road trip I'm planning next weekend with my folks. Oil/oil filter change, tire rotation, checked brake pads, other fluids.
    After all that was done I backed it onto the driveway to run a bit and get the new oil going. Then shut it off to recalibrate tire positions with my center console radio; it has a neat feature to give tire pressure/temp readouts in real time for each wheel but the positions need to be updated any time you rotate them. After a few minutes of doing that, I went to move her back into the garage. Keys in ignition, *click* ..... sheeeeeeit.
    After a few battery voltage tests and a few attempts of "contact impulse recalibration" of the starter motor using a metal rod, I noticed sparks off of one of the leads into the starter motor. Turns out one of the connectors was badly rusted and loose on the nut. Giving the nut an additional ugga dugga was enough to get the truck cranking again, but before the trip I'll need to clean it up and throw on some dielectric grease to keep it clean. Much better than springing for a new battery or starter motor at least.
  12. Oct 24, 2022 at 12:18 PM
    Northbound_Taco
    09 Off road build
    Luck you found the before your trip and it was an easy fix.
  13. Oct 24, 2022 at 12:18 PM
    NmapFE
    NmapFE Well-Known Member
    2014 DCLB 4x4 Limited. 6112’s/5125, KYB Top Hats, SPC UCA’s, Icon RXT leaf pack,
    Ripe for a good polish and the. Wax at that point…
    jrod2223[QUOTED] and cloudbnd like this.
  14. Oct 24, 2022 at 12:21 PM
    vonellis
    Some and some more
    As the world turns. Todays job s/c oil. My bay smells like rotten cheese now. 0B003FBE-53AB-4C3C-ACD2-0235AF1EF32E.jpg
    HappyGilmore likes this.
  15. Oct 24, 2022 at 1:50 PM
    TegoTaco
    Ontario, Canada
    61F78186-1588-4705-8531-F2C073A91413.jpg 1265AEFD-2BAF-4FD2-9F2B-0958CFB05AD4.jpg
  16. Oct 24, 2022 at 3:36 PM
    2013XSPX
    2013XSPX Well-Known Member
    GA/FL Border
    2013 XSP-X
    Pelfreybilt front/rear, RCI underneath, Morimoto Headlights, Prinsu racks, SCS Brushed Copper Ray 10's, EO Sliders, Baja Designs and Rigid lights, Inca 4x4 Camper
    Power Steering fluid exchange. Took 4 bottles to get clean looking fluid to reveal itself.
    jackn7 likes this.
  17. Oct 24, 2022 at 3:41 PM
    Sna
    Sna Well-Known Member
    Alberta
    ‘15 trd sport 6MT dcsb, mostly stock?
    Still waiting for a few parts but you get the idea. ETA- it's a portable diesel heater for those who are not familiar with these. Powered by an Ecoflow solar generator and mounted on a folding tire step to keep it off the ground and allow the exhaust to not be too close to the ground. The short pipe will be swapped for a longer one that will reach my tent.
    020CF367-2F54-474B-95C3-3D506D9EE8D7.jpg 27FB7BCD-1321-4BD2-99FF-F5B7674A6F26.jpg
  18. Oct 24, 2022 at 4:44 PM
    UnloadedRex
    UnloadedRex Tire and alignment guy
    Oscar
    Jacksonville, FL
    2007 DCSB Redneck Trophy Truck
    Bilsteins 5100, dobinsons coils, Apex Badlands winch, and lots of stickers
    Pretty sure you’re right there, my owners manual is long gone but my driveshaft has no fittings. Which is a shame cause I’ve already had one U-joint die on me.
    Buzzkill657 likes this.
  19. Oct 24, 2022 at 5:33 PM
    Buzzkill657
    Buzzkill657 Well-Known Member
    Jeff
    Im pretty sure im just gonna pull the driveshaft and take it to a driveline company and just have new carrier bearing and ujoints put in and shaft balanced. I dont think i need ujoints but might as well start with new ones just torn on weather i want to grease ujoints or be lazy and get sealed ones
    UnloadedRex[QUOTED] likes this.
  20. Oct 24, 2022 at 5:59 PM
    Its_Taconie
    Its_Taconie Well-Known Member
    Nelson
    North Hollywood
    2007 Tacoma DCLB PreRunner
    Fox Racing 2.5 (F); 2.0 (R), Archive Garage Leaf Springs, hanger/shackles, shock relocation, U-Bolt Flip Kit PLM P37 (TE37 Knockoffs) Bronze wheels, Nitto Ridgeline 35s, C4 Overland Bumper, Total Chaos Uppers, Outgear Solution HC Swingout, OTTune 4.88 Nitro Gears
    Got tires mounted on my newly powder coated FJ Cruiser wheels. Gotta say, I am excited on putting the lift on in a week or two.
    Had the center caps repaired and powder coated flat black.
