  1. Nov 22, 2022 at 4:17 AM
    T.Barn
    T.Barn Well-Known Member
    Todd
    Hampton Roads, Virginia
    2010 AC 4x4 6MT
    Before you make any decisions make sure to let the suspension settle. Took mine a few trips for it to settle down and it still does after many miles.
    Your fender cut looks similar to mine so I wouldn’t say you cut too much.
  2. Nov 22, 2022 at 4:18 AM
    Tactical_Panda
    Tactical_Panda Armchair Anarchist
    Tim
    Fredericksburg, VA
    2015 Tacoma Double Cab, Off-Road Edition
    AJT Designs Shifter AJT Designs Battery Hold-Down ARB Awning 2500x2500 ARB Twin Compressor w/ Slee Offroad Mounting Bracket Avid Brush Bar Avid Step Bars Black Rock Wheels Series 997 Type 8 Circuit Breaker/Relay Panel Custom TRD Decals Bulletproof Fabricating Raptor Grill Bulletproof Fabricating Cooling Panel Bulletproof Fabricating Tow Hook Duluth Trading Company Dog Hammock Exhaust Breather Mod eBay Special 3-Gallon Air Tank Expedition Essentials TPAM EZ Down tailgate damper Flagpole Mounts, Dual Foglight Mod Front Camera Rear Camera; full time available General Grabber tires Goat Armor Hella Supertone Horns Iggy Switch Panel Icon Dynamics Stage 3 Suspension Katskin Leather Interior KickAss camp shower LED Bed Lights LED Interior Lights Midland MXT275 GMRS Two-Way Radio OEM Audio Plus Reference 500 audio upgrade Plano Cases. 42" roof mounted, X2 Pop-N-Lock Tailgate Handle Prinsu Cab Rack Prinsu-like Shell Rack Redline Tuning Hood Struts Rigid Industries 40" Light Bar Rigid Industries Ditch Lights Rigid Industries Spotlights Toyota Bed Step UltraGauge EM Plus v1.4 Vixen Air Horns, Four-Trumpet Whole bunch of decals worth about 5HP each Yakima Road Shower, 10-gal
    The copper in the wire is what's corroding. If I snip to old connector of, sometimes the copper has corroded itself as much as two inches down in the insulation.
  3. Nov 22, 2022 at 4:24 AM
    elricfate
    elricfate Well-Known Member
    2009 Tacoma AC Silver Mica
    Is it possibly copper plated aluminum? Time to replace with some good quality solid copper standard or silicone wiring. BNTechGo makes some pretty solid stranded copper silicone wiring.
  4. Nov 22, 2022 at 4:24 AM
    jsucraig
    jsucraig Well-Known Member
    Craig
    Lynchburg, Virginia
    2013 Tacoma TRD Off-Road Double Cab
    Mudflaps removed, MESO LED Interior lights, 886 Fog Lamps for Reverse Halogens, Redline Tuning Hood Struts, Garmin Dashcam 20, 17X8 Chrome Helo HE791 MAXX Wheels, Cooper Discoverer AT3 265/70R17, JBL Speakers, JL Sub, and Alpine & Memphis Amps, mattgecko LED Bed Light & Under Hood Kit, Truxedo Low Pro QT Tonneau Cover, OEM Bed Mat
    Cut all of the corroded wire off, run new wire with new connectors, then use heat shrink to cover the connections. Problem solved.
  5. Nov 22, 2022 at 4:26 AM
    Tactical_Panda
    Tim
    Fredericksburg, VA
    It's probably that made in China shit.
  6. Nov 22, 2022 at 4:27 AM
    Tactical_Panda
    Tim
    Fredericksburg, VA
    Actually, I've tried that and the moisture still manages to seep in.
  7. Nov 22, 2022 at 6:10 AM
    Hayden334
    Hayden334 Well-Known Member
    Hayden
    Cullman, Alabama
    2010 Tacoma DCSB TRD OR
    2" spacer lift, 285/70 R17's and a Softopper.
    I have seen that, but I don't like the way it looks. Just seems unfinished or hacked. Plus I need a spot for my aux beam control panel as well.
  8. Nov 22, 2022 at 6:19 AM
    jproffer
    jproffer Well-Known Member
    Jim
    Perryville, MO
    '15 MGM Sport DCLB, V6
    That is my most hated job on the whole truck (so far lol)...
    If they'd close those clips in, it seems like it would be better....like on the hinge side. Make the "U" shaped slots, "O" shaped slots after the clips are in. If I could reach the things better without taking the whole headlight out, I'd try it and see if it worked. But, of course, if I could reach them better without taking the whole housing out.......we wouldn't be having this discussion :) .
    gugman likes this.
  9. Nov 22, 2022 at 6:57 AM
    Its_Taconie
    Its_Taconie Well-Known Member
    Nelson
    North Hollywood
    2007 Tacoma DCLB PreRunner
    Fox Racing 2.5 (F); 2.0 (R), Archive Garage Leaf Springs, hanger/shackles, shock relocation, U-Bolt Flip Kit PLM P37 (TE37 Knockoffs) Bronze wheels, Nitto Ridgeline 35s, C4 Overland Bumper, Total Chaos Uppers, Outgear Solution HC Swingout, OTTune 4.88 Nitro Gears
    Thanks for the advice. I guess I was imagining something completely different. Plus I am waiting on a front bumper so the weight of that would bring the chassis a little lower.
    T.Barn[QUOTED] likes this.
  10. Nov 22, 2022 at 9:06 AM
    Rezkid
    Rezkid Not a Well Known Member
    TJ
    WTX
    '08 DCSB TRD RT
    Little bit of this and that
    Trick I use for the passenger side is to remove the bolts holding the washer reservoir to the fender. You then can move it out of the way and have just enough room to make getting that bulb in/out doable.
    gugman and jproffer[QUOTED] like this.
  11. Nov 22, 2022 at 11:37 AM
    dpele
    dpele Pele Prints Vendor
    Dan
    Edmonton, Alberta
    2010 Tacoma DCSB
    Elka 2.0 w/ OME Dakars, 285/70/R17 Duratracs, & more!
    Talk about it... I think it's time for some new winter wheels! This was the second time they balanced the wheels.
    These are stock 16" TRD OR wheels
  12. Nov 22, 2022 at 11:58 AM
    4WDTrout
    4WDTrout Perpetually dreaming of tall trees & rivers
    Theo
    08 4WD SR5 DCSB
    Total Tacoma nOOb.
    Just get a Dynamic Balance instead of Static balance. Less issues with weights falling off etc
  13. Nov 22, 2022 at 3:18 PM
    dpele
    Dan
    Edmonton, Alberta
    2010 Tacoma DCSB
    That's a weird looking 2nd gen...
  14. Nov 22, 2022 at 3:41 PM
    mchabot1987
    mchabot1987 Well-Known Member
    Elizabeth City, NC
    2017 Super White TRD Sport DCLB
    Yes
    Damn lol. That's crazy.
    dpele[QUOTED] likes this.
  15. Nov 22, 2022 at 4:38 PM
    WiscoTaco4x4
    WiscoTaco4x4 Well-Known Member
    Brady
    2015 SR5 ACLB 4x4
    I got new wheels and tires put on my truck today. (Falcon Offroad T7's 17x9 -12 offset) Only slight rubbing on the mud flap on a full turn. Nothing some different mud flaps wont fix
  16. Nov 22, 2022 at 7:25 PM
    Wyckedan
    Wyckedan Well-Known Member
    Dan
    Woodinville WA
    2014 Stormtrooper AC 2009 Ducati Hypermotard 1100s.
    1 fully operational Death Star
    Get marine grade heat shrink. It has waterproof adhesive in it. If that fails then there is something else wrong
  17. Nov 22, 2022 at 10:31 PM
    DJSpeed
    DJSpeed Well-Known Member
    what air system you running
  18. Nov 22, 2022 at 10:51 PM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    Nothing. :(
    Once the cold weather set in I put a hold on mods. I do need to pick up some oil and do an oil change though.
    szidls and Cativelense like this.
  19. Nov 23, 2022 at 4:59 AM
    T.Barn
    Todd
    2010 AC 4x4 6MT
    I made a 4 way tire inflate system with parts from Amazon. It ended up being about $120 vs the inflated price of kits that are sold.
    That’s paired with an ARB compressor.
  20. Nov 23, 2022 at 9:05 AM
    Northbound_Taco
    Northbound_Taco Well-Known Member
    Nowhere Fast, Everywhere Eventually
    09 Off road build
    RCI skids/armor, SPC UCA, Fox 2.5 front 2.0 rear 16" TRD PRO rims/ 285/75/16, SS3 Pro fogs, Sherpa Roof Rack
    Took the tent off for the season. I always looks a little odd for the first couple days.
    jackn7 and fasteddieyj like this.
