  1. Jan 13, 2023 at 4:42 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    LOL. Serious. They are very bright and impressive looking from the driver seat, but they are very bright in the wrong spot and not bright where they are supposed to be. Headlights should have the brightest part of their intensity right at the cut off as this is what projects distance. You also want to minimize foreground light as very bright light close to the vehicle isn't helpful, it is harmful. It reduces your night distance vision and draws your eyes down from the headlight horizon to where the headlights are focused. AlphaRex lights have the hot spot extremely low in the beam pattern, to the point it isn't even a legitimate headlight. The super low focal point causes very bright light immediately in front of the truck greatly increasing foreground light, which as I mentioned above is exactly what you don't want. However, from the driver seat this makes the headlights initially appear like a major upgrade, especially in areas of urban light, even though the opposite is true. And by dipping that hot spot so low in the beam, you've also lost your distance projection. So not only do your lights not project as far, your night vision is greatly reduced by the bad beam pattern making it so you can't see distance as well either, compounding the distance visibility problem. So you can now out drive your headlights, meaning that traveling at highway speeds, by the time an object is visibly illuminated by the headlights you will not have time to maneuver to prevent a collision. Because your night vision is reduced and your distance projection is reduced. A proper headlight design greatly increases the output intensity at the cut off without excessive foreground light, so you spot objects further away and maintain your night vision so that you have time to safely maneuver the vehicle to avoid a collision. There is a lot of science in headlight design, and AlphaRex doesn't use any of it.
    sberkley92, El Tano, dpele and 15 others like this.
  2. Jan 13, 2023 at 4:49 PM
    xguntherc
    xguntherc Taco Time
    Cory
    East Dallas
    11 TRD Off Road - Black
    Icon Stage 5, Nexen Roadian MTX, Fuel KB43 Block wheels, Baja Design XL 80s, Baja Squad Pro WC fogs, TacoVinyl grill, "dudebro" lights, Prinsu rack, trail rash pinstripes, BAMF hybrid bumper, sliders, and LCA skids, and a few other things I can't think of.
    Is that why I feel like I can't see shit at night since getting some 12-18 months ago? I just thought it was because I'm getting old.
  3. Jan 13, 2023 at 4:51 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Not because getting old (or at least not only), it is because you've replaced your actual headlights with short range floods pointed at the ground. If you want exceptional lighting on a 2nd Gen, this is the way:https://www.tacomaworld.com/threads/the-ultimate-headlight-upgrade-h4-not-led-or-hid.398066/
  4. Jan 13, 2023 at 4:53 PM
    the_black_tacoma
    the_black_tacoma Well-Known Member
    Griffin
    IN
    2008 Black Tacoma SR5 AC
    A couple
    Well….. while that’s obviously based off real knowledge of headlights and how they function, which I have very little of myself… I have to disagree. I drive highways and backroads at 1-2am as often as during the day, my windshield is blacked out with tint (35%) and I have 5% on all the other windows. I can see to drive with the drl’s alone at lower speeds, and I’ve never had the slightest problem seeing anything with them at any time other than heavy rain at night. They’re better than any other headlights in any car I’ve driven. Maybe I’m missing something but I took a video earlier today while adjusting them and they’re pretty bright at the cutoff. :confused:
  5. Jan 13, 2023 at 5:10 PM
    drewnali
    drewnali Well-Known Member
    Drew
    Dunnellon Florida
    2013 4X4 SSM TRD OR DCSB
    The bit of pipe with the 90 came from a LS1 intake kit. It’s 4” pipe, an 11” leg on that 90. The intake/scoop portion up front is Volant- which is 3.5” so I got a kit from AFE (part 59-80612) made for Chevy intake. Came with the 3.5x4 coupler, and the 4x4 coupler. Worked like a champ.
  6. Jan 13, 2023 at 5:11 PM
    reallifedog
    reallifedog wat.
    Jordan
    Denver
    08 Tacoma TRD OR
    Are those your low beams?? I could be wrong but they look like they're aimed a bit high.
  7. Jan 13, 2023 at 5:13 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    It is hard to tell with the high beams on, but those don't look like they have hot spots in the pattern.
    Check out 13:15-15:30, and it demonstrates what I am talking about.
    https://www.youtube.com/watch?v=kItoEHPgn98
    Also, your high beams are obviously misaligned. The headlight is not compliant if your high beam aiming is separate from your low beam. High beams are supposed to be fixed to the low beams and aimed by the low beam cut off.
  8. Jan 13, 2023 at 5:18 PM
    DetroitDarin
    DetroitDarin Specified
    York County PA
    Scratches and Whatnot
    PJohnson99, UMC, dpele and 5 others like this.
  9. Jan 13, 2023 at 5:21 PM
    the_black_tacoma
    Griffin
    IN
    A couple
    That’s low and high beams. And yes they may be, I adjusted them up today but might have overdone it. I’ll have to test and see
  10. Jan 13, 2023 at 5:26 PM
    the_black_tacoma
    Griffin
    IN
    A couple
    They are fixed to the low beams as far as adjustment goes. These headlights have always seemed slightly off with one cutoff being higher than the other but that’s my only gripe with them.
    As far as being compliant goes I’m not particularly worried about it. I run pods on my hood and toggle them like high beams, have wide ish wheels, rock lights and dark tint. In Indiana nobody seems to care honestly
  11. Jan 13, 2023 at 5:32 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    If the high beams are fixed to the lows (as they should be) the high beam aiming appears off from the manufacture. The right low beam looks higher, yet has a lower high beam. And the left beam which looks lower has a higher high beam.
  12. Jan 13, 2023 at 5:36 PM
    the_black_tacoma
    Griffin
    IN
    A couple
    They’ve been like that since I got them. An annoying defect but never bothered me enough to get them replaced or anything.
  13. Jan 13, 2023 at 7:15 PM
    Cleatus
    Cleatus Well-Known Member
    SoCal
    2015 DCSB OR 6spd
    2” or so lift
    Terrible pic, sitting at alignment shop, but I got 3 things done this week. 2 1/4” LT, 35’s
    and the last is the super white paint peel, rear drivers door. Still need to trim a bit more, no rubbing on the street. Cycled it yesterday with no coil on the shock and no bump stop, surprised to see it cleared everything with tire straight, with it turned cleared firewall, but hit front and rear portion of fender. Screwed up a limit strap installing it, new one should be here tomorrow, so a little trim, new strap, and then time to play!
    UMC, dpele, NmapFE and 7 others like this.
  14. Jan 13, 2023 at 9:51 PM
    baldridge
    baldridge War Eagle!!!!! KN4OYZ
    Bart
    Auburn, AL
    2015 MGM TRD Offroad and 2015 Black Prerunner SR5
    OME Lift with HD Dakar’s C4 Slim Line Bumper 4.88 ECGS Gears ARB Single Air Compressor ARB Rear Air Locker JBA UCA’s 285 BFG KO2’s Weather Tech Floor Mats Martin OffRoad Rack Console Vault KB Voodoo Cab Height Rack 23Zero RTT 23Zero Awning 23Zero Shower Tent Maxtrax Black MaxTrax amounting Pins Krazy Beaver Shovel Fiskers Axe Smittybilt ace and Shovel Mount Quickfists Rotopax 4 Gallon Rotopax Mounting Plate Rotopax Mounting Brackets Decked Storage System Alu Cab XL Tilt Fridge Slide ARB Elements Fridge OEM Skid Plate Local Sliders Uniden 510XL Cali Raised Tailgate Antenna Mount Fire Stick 3 foot Antenna PowerTray Fuse Panel Blue Seas Fuse Box Blue Seas Breaker Cali Raised Ditch Light Mounts Rigid Ditch Lights Alpha Rex Head Lights with LED bulbs Blue Ridge Overland Tacoma Attic Blue Ridge Overland Seat storage bags
    Well picked up another 15 with 45k miles about two weeks ago. Removed tool box, seat covers, home made bed mat, swapped out Huskey Floor liners with my Weather tech in Black truck, detailed inside and cleaned up out side. Got several things planned for the coming weeks.
    996DDB6A-ACD0-4D83-B587-89EA201E9D97.jpg C5445608-EC43-46F0-A6D2-D2DA5593256E.jpg FF1753C7-2F03-4768-8426-379A551C41B4.jpg
    El Tano, Flo_TRD07, TomTwo and 15 others like this.
  15. Jan 13, 2023 at 10:22 PM
    Canadian Caber
    Canadian Caber R.I.P Layne Staley 67-2002
    Les
    B.C. Canada, eh
    2020 TRD Sport DCLB 4X4 Super White
    Looks mint!
    Squirt and baldridge[QUOTED] like this.
  16. Jan 14, 2023 at 3:35 AM
    baldridge
    Bart
    Auburn, AL
    Yep! I got lucky. It was right down the road from me as well so didn’t have to travel to pick up. Drove a few 3rd gens but didn’t like them as well as 2nd gens. :thumbsup:
    jackn7 likes this.
  17. Jan 14, 2023 at 8:36 AM
    NmapFE
    NmapFE Well-Known Member
    2014 DCLB 4x4 Limited. 6112’s/5125, KYB Top Hats, SPC UCA’s, Icon RXT leaf pack,
    Epic! What caused you to need to do this and what equipment did you use to press them?
    Fixxxer[QUOTED] likes this.
  18. Jan 14, 2023 at 8:39 AM
    NmapFE
    So sorry man! This is exactly why I have my dash cam installed and keep mine in the garage when I’m not driving. People suck and most will take the easy way out.
    theolee[QUOTED] and stbear like this.
  19. Jan 14, 2023 at 10:04 AM
    Fixxxer
    Fixxxer Well-Known Member
    Port Angeles
    '13 TRD Sport DCLB Super White
    ARB Front/Rear Air Lockers, Nitro Gear 4:88's, Hutchinson Rock Monsters, SOS Concepts Front Aluminium Bumper, UpTop Overland Alpha XL Roof Rack, ARB Snorkel, AVS Rainguards, Redline Hood Struts, Weathertech Mats, Flyzeye led's, MESO Molle Rack, Meso LED Dome Light, K&N Air Filter, UNI Filter Mod, Bosch Wiper Blades, Snugtop Sportster Reinforced Canopy, Viper 2-Way Remote Start, ARB Twin Compressor,
    Last time I rotated my wheels and noticed the drivers side bearing felt a little rough and chose to ignore it for a little while longer even though I knew the bearing was going. That was 5000mi ago. Fast forward to 3 weeks ago I start getting obvious symptoms of a bad wheel bearing and got progressively worse. Road noise, feedback through floor area, and pulsation during braking.
    I don't care for aftermarket parts when it comes to engine and drivetrain components. OEM always fits and lasts longer.
    I used a 20 Ton H frame floor press to mate the hub and bearing. The process overall was easy. Lots of resources on here and some great videos on the Tube. Hardest part was seating the inner seal. Truck now feels so smooth!
    jackn7 and NmapFE[QUOTED] like this.
  20. Jan 14, 2023 at 11:00 AM
    szidls
    szidls Well-Known Member
    Scott
    Prescott Valley, AZ
    2014 MGM AC TRD OR
    Struts. Not sure what is wrong? Measured 3 times before drilling. Hood bracket 16 1/4” to hood mount. Fender mount 7 1/4” to fender bolt. Not sure if wrong pistons were shipped.
