  1. Mar 20, 2023 at 4:08 PM
    Operator8
    Operator8 Well-Known Member
    Woodland Park, CO
    2005 White Tacoma TRD OR
    SAS INW
    Just put in an order for Alcan left springs, so I can ditch my block.
    Corny Taco likes this.
  2. Mar 20, 2023 at 4:09 PM
    rtilton12
    rtilton12 Get gas and GO!
    Robert
    Texas
    2012 Toyota Tacoma TRD Off Road 4x4
    Trail gear front and rear bumper, RTT, hitch grill, 12k lb winch, drilled and slotted front brakes
    awesome man! just little things here and there. keep going!!
  3. Mar 20, 2023 at 4:51 PM
    WiscoTaco4x4
    WiscoTaco4x4 Well-Known Member
    Brady
    2015 SR5 ACLB 4x4
    Happy spring everyone! Washed the truck today and hopefully its the last time I have to wash it in the garage.
    LeakyAC, trvsl, Z7Xtreme and 8 others like this.
  4. Mar 20, 2023 at 5:07 PM
    mchabot1987
    mchabot1987 Well-Known Member
    Elizabeth City, NC
    2017 Super White TRD Sport DCLB
    Yes
    Dude he lives right around the corner from me :rofl:
    I saw him drive by as I was leaving the neighborhood around 5pm today
  5. Mar 20, 2023 at 6:46 PM
    GARSHA91
    GARSHA91 YES, that is me on that Facebook group
    Chicago
    2015 TRD Off-Road DCSB
    Just a grocery getter
    Added 50HP
    trvsl, srspicer, gsxrdoug and 4 others like this.
  6. Mar 20, 2023 at 6:59 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Had to replace them on my 07... went with OEM outer tie rod links / Overland Custom Design sway bar links.
  7. Mar 20, 2023 at 7:50 PM
    All Visible Hues 14
    All Visible Hues 14 Well-Known Member
    Lynn
    East Tennessee
    2014 dcsb TRD off road
    So when are you gonna “come clean” and tell us what the secret ingredient is?
  8. Mar 20, 2023 at 8:26 PM
    hoffengineering
    hoffengineering Well-Known Member
    Taylor
    Orange County, California
    2015 DCLB 4X4
    Replaced torn CV boots with some tougher ones. Then tested them by getting the truck dirty (a little).
    trvsl, Rick_Taco, tacomataco2 and 7 others like this.
  9. Mar 20, 2023 at 8:36 PM
    Jimmy92870
    Jimmy92870 Well-Known Member
    Texas (DFW)
    07 DCSB PreRunner
    I need the 50 hp. Where can I find this?
  10. Mar 20, 2023 at 9:10 PM
    Ezriderga
    Ezriderga Well-Known Member
    Georgia
    2008 Tacoma base truck
    Detailed the exterior of my ‘08 Tacoma base truck which recently turned over 422,000 miles with original drivetrain. I clayed the paint and then added a coat of Collinite wax. Next project is to detail the interior.
    Smills91, trvsl, srspicer and 23 others like this.
  11. Mar 20, 2023 at 9:53 PM
    steveo27
    steveo27 Ask me about my weiner
    Pittsburgh
    '11 TRD Off Road & 1992 VW GLI
    The same shit everyone else has.
    Rebuilt the slave cylinder. It went out driving on Saturday. Luckily it happened close to home and I was able to limp it home.
    Another day, another oil change.
  12. Mar 21, 2023 at 4:01 AM
    Oregonism
    Oregonism Well-Known Member
    Vieques, PR
    2012 TRD Sport Prerunner
    Finally bit the bullet and tackled a project that I was dreading. Ironically, procrastinating made it so much worse. Rear bumper was rusting inside pretty badly. Sandy, muddy schmoo tends to build up with a nice mixture of salt and is basically a corrosion magnet. All the bolts holding the bumper together were nearly seized :annoyed:
    I spent several hours chipping, grinding and sanding as much rust as I could remove without a sand blaster. Then a heavy coat of rust converting primer, interior surfaces got a heavy coat of rubber undercoating, and the exterior a heavy layer of bed liner. Hoping the undercoat acts as a moisture barrier. Going to try and make a bi-yearly habit of pulling it, cleaning it out and checking the coating. Getting bumpers to PR is difficult and expensive, and I’d like to get another ten years out of this one. It’s still structurally fine, and it’s 95% cosmetically fine from the outside. Also, replaced all the hardware and sprayed the frame and surrounding parts with undercoat while the bumper was off. Luckily, the frame only has very slight cosmetic rust, if any.
    E433A935-7999-493E-92DB-DE05E1EB31D7.jpg 0F449714-9AB8-4507-9857-0CC50C817384.jpg B8605655-DCCA-4506-A8EA-BBA7E50844D3.jpg A9DD0BBA-0085-40AA-82F0-C83611BA1CD9.jpg 5E5874D5-F6E6-433D-B10A-4DA89702A177.jpg 3A1CE17A-7B5B-4A92-B2EA-CA90B634BBF2.jpg
    The joys of living in the Caribbean. Also, after doing my C4 fab front bumper, I feel like the design on my All-pro rear bumper is lacking in thought a bit. It’s a quality bumper, but some things just weren’t thought out.
  13. Mar 21, 2023 at 5:09 AM
    GARSHA91
    Chicago
    Link for the boots?
    stmpjmpr likes this.
  14. Mar 21, 2023 at 5:09 AM
    GARSHA91
    Chicago
    Jimmy92870[QUOTED] likes this.
  15. Mar 21, 2023 at 5:28 AM
    TreeFortRichard
    TreeFortRichard Barcelona Red is the best red...
    Brian
    42.3115167,-71.6638516
    '23 SR5 DCSB 4x4 Barcelona Red
    you no salt road baaahsatds!
    MSgt O and lambit like this.
  16. Mar 21, 2023 at 5:33 AM
    Venom
    Venom Well-Known Member
    Kevin
    Massachusetts
    It's in great shape for the mileage.
    It seems like you're a Meguiars fan, going by the bottles.
    Ezriderga[QUOTED] likes this.
  17. Mar 21, 2023 at 5:34 AM
    TreeFortRichard
    Brian
    Nice rebuild...I got mine replaced 50K ago when my fork snapped and throw out bearing seized.. $80 for the slave...there was no hope. This is what everything on my truck looks like at this point...
    And new!
    dpele likes this.
  18. Mar 21, 2023 at 5:37 AM
    Foghorn
    Foghorn Senior rooster, instructing in the art of roostery
    North Cackalacky
    2014 DCSB Off Road
    Wow! Clean, especially for an ‘07.
  19. Mar 21, 2023 at 6:20 AM
    Hayden334
    Hayden334 Well-Known Member
    Hayden
    Cullman, Alabama
    2010 Tacoma DCSB TRD OR
    2" spacer lift, 285/70 R17's and a Softopper.
    Well I decided to try my hand at wrapping the silver parts of my dash last night. All in all it came out pretty nice but man is it a pain to get the material in those curves. next up is the silver rings around the gauges.
  20. Mar 21, 2023 at 6:47 AM
    20somethingwidataco
    20somethingwidataco Yes, my avatar is a real car.
    Will
    Washington State
    2008 AC TRD SPORT M/T
    ACLB 6 SPEED: Suspension: Bilstein 6112s (3rd perch) (F) Taco Lean Spacer Bilstein 5160s (R) TSB Leaf Pack Wheelers Offroad 3 leaf progressive AAL Wheelers Superbump Front Duro Bump U bolt flip kit Duro Bump progressive bump stop 3rd gen TRD offroad sway bar Wheels and Tires: Summit Racing Wheel Dakars (Polished Silver) 285/70r/17 Goodyear Wrangler Duratrax (Load D) "Performance": AFE CAI with custom powdercoated white filter cover MagnaFlow Performance Series Exhaust URD Cam gears XTP Intake Manifold Spacer OTT Torque Tune Brakes: Stoptech Slotted Rotors Stoptech Sport Ultra Composite Brake Pads Wheelers offroad SS brakelines (Front) Interior: Kenwood DD headunit Oem Subaru Kicker Tweeters Alpine 6x9 (Front) & 6.5 (rear) (With Taco tunes speaker mounts) Alpine 500 watt amp Sound Deadening (Doors, Rear "wall", Roof) ODI Rouge Shift Knob Weather Tech Mats Painted/wrapped trim pieces Console Safe Console Vault Gridx Organizer Ram Phone Mount Meso Customs dual color map lights Meso Customs dual color dome light Wet Okole seat covers (Black) Wet Okole center console cover (Black) 1" Seat Raisers (Driver & Passenger) AJT Designs climate control and 4x4 knobs Back Up Camera Lighting: Retrofits (Mini H1's, RGB Halos, 5500k Bulbs)(Lenses wrapped in self healing PPF) Diode Dynamics SS3 Max SAE (Yellow) Diode Dynamics SS5 Pro (Yellow) Driving lights (ditch lights) Anytime fog mod Rigid Industries E series 32" Combo bar (spot/flood) Diode Dynamics XPR Reverse Lights Diode Dynamics XP80 turn signals LED brake, parking lights and license plate lights Armor: Apex All Pro sliders BPF steel skid plate Bigass Trailer Hitch Camping/Storage: Leer canopy LED interior lighting Sleeping platform (Storage underneath) Removable snowboard Yakima mounts Extra D rings in bed (6 total) Custom Powder coated white snow shovel with custom bedrail mounts Amazon special Traction Boards Hi Lift 48" Jack with custom Rail mounts to accommodate my sleeper set up Other: All pro Bed Stiffeners Relentless Fab tailgate panel TRD sport graphics (Turd Gen spec) Anti Sun glare hood scoop wrap (Satin Black) Custom FleeBay grille 4 Hella supertones ECGS needle bearing Many Patches BPF shackle mount (With smittybuilt shackle) Tinted windows (Front/Rear + Full canopy)(18%) Meso Customs gasshole AVS inchannel window visors Diff Breather Kit 2012-2015 Oem Turn signal/folding mirrors (w/ sequential signals) 2012-2015 Oem LED taillights Full Size (285/70r17) spare DIY Larger Engine Splash Guards DIY Vipercut TRD radiator cap
    What are the symptoms of that? Also, how many miles on it when it went out?
