  1. Apr 9, 2023 at 7:27 AM
    Taco401
    Taco401 Member
    Luke
    2011 Sport MGM DCLB
    Weathertech Rain Guards
    Today I just drove it around to the various beach parking lots near the house.
    Over the course of the last week or so I also did a head-unit install and got my front plate mounted.
    For the head-unit I used a Pioneer AVH-2440NEX from my sister's 1995 Camry that just started knocking. I was able to use the same METRA 70-1761 from the Camry but I chopped up its previously ugly install and re-wired it all. Then I added a BATIGE Single Port USB 3.0 flush-mounted into the old cigarette lighter port for USB integration and opted to use a FingerLakes 2.5mm microphone mounted on the steering column rather than the old and tired Pioneer mic with a busted mounting platform. It's off-center which pisses me off but I installed it all in the dark after a pretty long day because I'm an idiot. Then it's all housed and held together by a METRA 99-2814G Dash Kit.
    Final Product:
    BATIGE USB:
    FingerLakes Mic:
    Re-Wired Harness:
    I was also able to get my front plated mounted with an @ACEkraut low profile LM-0511 mount. Great communication from him and super easy install. Just like my head-unit mic, it's a little crooked right now but that was operator error on my part and I will fix it someday... Probably. Also threw on WeatherTech Clear Covers on my plates in a color they call Beluga Gray.
    Front/Offset Look:
    Profile:
    Overhead:
  2. Apr 9, 2023 at 8:11 AM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Those plugs didn’t need changing. I would have put them back in after pulling the first one
  3. Apr 9, 2023 at 8:18 AM
    powder1134
    powder1134 Well-Known Member
    2014 Tacoma TRD Off Road
    Sorry......Skid.
    This is the RCI designated jack point, but as I said, I will also line up with the bolts since that attach to the front cross member.20230409_081400.jpg
  4. Apr 9, 2023 at 8:18 AM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    Drove to Harbor Freight yesterday to pick up some cheap tools to keep in the truck.
  5. Apr 9, 2023 at 8:19 AM
    Trouble_The_Tacoma
    Trouble_The_Tacoma Well-Known Member
    Conrad
    I Still need to do this mod.
  6. Apr 9, 2023 at 8:22 AM
    Trouble_The_Tacoma
    Conrad
    $17 Cerakote headlight restoration kit came in clutch!! Knocked 10 years off the truck in about an hour.
    I do recommend having an air compressor with air sprayer attachment, taking time with the sanding, or even going up to 3,000grit wet sanding, and finally only do one coat of the resin clear. If you wait too long between coats, it will get tacky and blurry or smear.
    Other than that, I’d happily have paid $50 for the results this kit provided. Still happy I got it for $17 though.
    asuchemist, Greyhome, GRNT4R and 16 others like this.
  7. Apr 9, 2023 at 8:38 AM
    Maximumdarkside
    Maximumdarkside Master of self destruction.
    J
    Sevierville, TN
    2014 4Runner Limited formerly 2015 Tacoma Prerunner and so many more!
    Mostly stock, just getting it to my liking, just happy to have had the taco and now my 4Runner.
    https://www.amazon.com/Throttle-Controller-Electronic-Accelerator-Compatible/dp/B0BC8GS8QT?crid=5NNKY3I3JHO4&keywords=tacoma+9drive&qid=1681054328&sprefix=tacoma+9drive%2Caps%2C114&sr=8-3&ufe=app_do%3Aamzn1.fos.006c50ae-5d4c-4777-9bc0-4513d670b6bc
    Decided to try this out, basically knockoff pedal commander. I know it doesn’t change anything tune wise and the same result can be achieved by pushing harder on the pedal, but I like to try little things like this and see how they stack against the real deal, having had the pedal commander before on another vehicle, and must say for $0 out of pocket (free gift card) it was worth the trial and did more to liven up my Tacoma's pedal more than the pedal commander ever seemed to do on the other ride, instantaneous response versus push harder if that makes sense.
  8. Apr 9, 2023 at 8:54 AM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    Pulled out the (purple) wires for the temp in the rear view mirror. Ran the antenna cable for my new GMRS radio. I’ll make another hole with a grommet for the other wires.
  9. Apr 9, 2023 at 10:52 AM
    ACEkraut
    ACEkraut Well-Known Member
    Aaron
    Durham, Maine
    2014 DCSB TRD Off Road
    Looks nice! Each bumper is slightly different so a little “adjustment” may be necessary. You should be able to manipulate the plate and straighten it out.
    Charlie Bravo likes this.
  10. Apr 9, 2023 at 11:48 AM
    Li0nel1234
    Li0nel1234 Well-Known Member
    Lionel
    Denver
    14 TRD OR DCSB SSM
    they were gapped at about .43-45 or so. Not great but not bad…
  11. Apr 9, 2023 at 12:05 PM
    Li0nel1234
    Lionel
    Denver
    14 TRD OR DCSB SSM
    is there a good how to on this? I need to do this to mine ASAP.
    amyracecar[QUOTED] likes this.
  12. Apr 9, 2023 at 12:41 PM
    srspicer
    srspicer Paint it black
    Lower Bucks PA.
    05' Black DBLC short bed
    Painting things black
    Need to pull back and take more pics. Looks like you will need to strip the entire panel. Looks like old body work on the second image. If you don’t sand down the paint and primer properly, you get ‘bull’s eyes’ under any new paint.take it to a good body shop, not MAACO, to get it refinished. My2c.
  13. Apr 9, 2023 at 1:05 PM
    MACKT28
    MACKT28 Well-Known Member
    2006DCLB
    Heretic Ditch lights Toyo Open Countrys AT2 HI VIS OVERLAND RTT
    I am in the same boat on the diff breather mod. I like the spot in the cubby you ran it to. Did you go straight up and run down the underside of the bed?
  14. Apr 9, 2023 at 1:36 PM
    NateTacoma
    NateTacoma Well-Known Member
    Nate
    2013 Tacoma
    will be good enough for now, will touch up later
  15. Apr 9, 2023 at 1:39 PM
    MACKT28
    2006DCLB
    I have to do that to mine as well. Looks exactly like yours did where did you come across the touch up paint from?
  16. Apr 9, 2023 at 2:10 PM
    NateTacoma
    Nate
    2013 Tacoma
    NAPA auto parts! called ahead and they mixed it up and was ready in a few hours, was about $40 cad
  17. Apr 9, 2023 at 2:13 PM
    MACKT28
    2006DCLB
    I'm gonna get with my napa store as well so assuming you gave them your paint code? And they had it mixed up for you?
  18. Apr 9, 2023 at 2:32 PM
    NateTacoma
    Nate
    2013 Tacoma
    yep i gave them my paint code, but they can figure it out for you if you give them your vin number
    jackn7 and MACKT28[QUOTED] like this.
  19. Apr 9, 2023 at 2:34 PM
    MACKT28
    2006DCLB
    I'll do that tomorrow so I can get my door sills cleaned up! Thank you for the help that helps out big time.
  20. Apr 9, 2023 at 2:36 PM
    NateTacoma
    Nate
    2013 Tacoma
    Anytime! this should help too! also i would spray with clear coat after, i have to do this still as well
    reallifedog and AR15xAR10 like this.
