  1. Apr 9, 2023 at 3:38 PM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    First hand wash of 2023. Water was still beading nicely since last wax in October.
    ryanh618, Fluffymonkey, Venom and 6 others like this.
  2. Apr 9, 2023 at 4:07 PM
    mchabot1987
    mchabot1987 Well-Known Member
    Elizabeth City, NC
    2017 Super White TRD Sport DCLB
    Yes
    Twinsies.
    Same color, wheels, and tires. Will be getting my wheels painted bronze though later this spring or early summer.
  3. Apr 9, 2023 at 4:23 PM
    huyner
    huyner CoCKaSiAn
    Huy
    Orlando
    2007 Tacoma TRD Prerunner Sport 4x4
    a lotta money spent, lotta scars made
    Finally installed my radiator and hoses from mishimoto Black Friday sale. Had a leak and hoping it’s from my front main seal, so changed that out. Also my water pump, thermostat, gates pulleys and belt. Guess I should check it more often. :annoyed:
    asuchemist, DaleRS, trvsl and 6 others like this.
  4. Apr 9, 2023 at 4:44 PM
    TacoTuesday1
    SD CA
    if you spend more look at Knipex. They have adjustable pliers so they can quickly slide to fit various sizes by pressing the button. Making them pretty universal and act like multiple tools in one.
    And their high leverage cutters are probably the best out there in terms of strength, sharpness, and high quality strong metal
  5. Apr 9, 2023 at 5:04 PM
    amyracecar
    amyracecar suck it up buttercup
    Virginia Applejack
    SouthEast USA
    2013 AC V6 MT OR Spruce/Mica
    I could not find a good how/to for this - - I should have taken more photos and at least tried, now I feel bad - thanks :)
    If you go up under the truck, on the drivers side of the transmission, near/on the slave cylinder - you will see a bleeder screw; looks like a nipple sort of. Mine did not have a cap on it but sometimes they have a black rubber cap on them.
    You need ~2ft of hose with 1/4in inside diameter, a bottle to collect the old fluid, new dot3 brake fluid [I got the bigger bottle to be safe] and a 10mm wrench to open/close the bleeder screw.
    1. Recruit a helper to push the pedal.
    2. Fill the reservoir to the brim with new brake fluid.
    3. Fill the old bottle with a few inches of brake fluid.
    4. Attach the hose to the bleeder valve and keep the other end SUBMERGED in the bottle/brake fluid - so you don't suck air back up into the system.
    5. Have helper depress and HOLD the clutch pedal down while you open the valve, let whatever come out.
    6. Close the valve.
    7. The helper will have to pull the clutch pedal back up.
    8. Repeat #5-7
    9. Check every 2x to make sure the reservoir stays full of fluid - so you don't get air into the system and have to start over.
    10. Do this until you get clean fluid coming out/you are satisfied it has been purged.
    11. Tighten the bleeder screw back down, wipe up ANY brake fluid you spilled; I used a rag with some degreaser on it - especially up near the reservoir b/c it will eat your paint and who knows what else.
    I also checked the bleeder screw a few times afterword just to make sure there were no leaks - it is a pressurized system, so leaks should be apparent but I am just paranoid like that.
    For me, it gurgled/made some noise the first few pumps, took maybe 4 pumps before the fluid moved smoothy thru the line - - and it seemed like there was some air in the system, so I just kept repeating until there was a clear stream and no air coming out of the hose..
    It is not like you can save brake fluid for later use anyways - -
    I was actually trying to delete the accumulator but I couldn't get the damn thing off b/c I couldn't get the top two bolts off of it due to not having the right tools for the crazy [lack of] clearance up there.
    Anyways - I apologized if this was a bit granular or long winded but I hope this helps.
    OZ TRD, PzTank and reallifedog like this.
  6. Apr 9, 2023 at 5:08 PM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    I have a couple pair of Knipex that I sue for other things.
  7. Apr 9, 2023 at 5:17 PM
    TacoTuesday1
    SD CA
    did part of this the other day; pulleys (belt already done)
    will probably go back in again later to do the WP
    pulleys were toast. WP pulley extremely slight sound while hand rotating, but didn't feel play in any direction (170k mi); maybe will do hoses
    put away the tensioner to do later
    I wonder if you replaced the serp belt tensioner;
    held it in my hand looking at where it goes, thing seemed like a PITA that'd add hours to the work
    mounting bracket on it turns sideways 90deg suggesting it has to sandwich to the engine between whatever bolts to it, likely A/C compressor or alternator (I forget which one it is)
    to take off belt, unbolt and swing out of the way, to gain access to the tensioner bracket
  8. Apr 9, 2023 at 7:38 PM
    Li0nel1234
    Li0nel1234 Well-Known Member
    Lionel
    Denver
    14 TRD OR DCSB SSM
    you’re a saint! Thanks!
    amyracecar[QUOTED] likes this.
  9. Apr 9, 2023 at 7:41 PM
    srspicer
    srspicer Paint it black
    Lower Bucks PA.
    05' Black DBLC short bed
    Painting things black
    You can take a look at page 6 of my ‘restoration’ thread. I went a little further on the repair and preventive maintenance for that same issue. Mine was worse.
    NateTacoma[QUOTED] likes this.
  10. Apr 9, 2023 at 8:10 PM
    huyner
    huyner CoCKaSiAn
    Huy
    Orlando
    My main concern was my main seal n decided to do everything while I had it apart…yeah, that tensioner, I just pulled the pulley off and used that…that tensioner can get done if I have to change out my alternator :anonymous:
  11. Apr 9, 2023 at 8:10 PM
    Corny Taco
    Corny Taco The Sauce
    Blake
    Columbus/Atlanta Georgia
    06 SR5 DCSB Prerunner
    -33 inch Nitto Ridge Grapplers -18 inch fuel kranks -Bilstein 5100s -OME normal duty dakars -Toytec/Eibach coils -Magnaflow off-road pro exhaust -Prinsu roof rack -nfab rock guards -EBay Faux Trd Pro Grille -Custom basshead audio build in progress
    So I ran the line up from the diff and zip tied it to the brake line mount. Above this mount there is a hole in the frame to run it through. Run it back a little bit in the frame and there is another hole near the bump stop strike plate thing. Then just run straight up to the cubby within the bedside.
    MACKT28[QUOTED] likes this.
  12. Apr 9, 2023 at 8:38 PM
    AdamM
    AdamM Semi-pro aardvark wrangler
    Adam
    Edmonton, AB
    14 DCSB base 6MT 4x4
    I installed some 1.25" spidertrax spacers today. I was changing out winters for summers, so tires are different, same tire size and identical stock wheels. Truck is getting old, trying to keep it interesting...20230409_213202.jpg 20230409_213010.jpg 20230409_202740.jpg 20230409_202702.jpg
  13. Apr 9, 2023 at 9:13 PM
    WestCoastBestCoast
    WestCoastBestCoast Well-Known Member
    Wyn
    Portland, OR
    2005 SWB TRD 6MT 4x4
    Wait, thats the jack point? I was going just behind the "window" since that is where the OEM jack point is. I thought that raised part of the Skids was for more space for the front differential?
  14. Apr 9, 2023 at 9:34 PM
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    SE Wisconsin
    2015 Toyota Sienna with rear locker
    It is NOT the jack point. It IS to give clearance for the front diff. I'll be happy to eat my words if someone links to the RCI instructions saying this is the jack point.
  15. Apr 9, 2023 at 10:39 PM
    MACKT28
    MACKT28 Well-Known Member
    2006DCLB
    Heretic Ditch lights Toyo Open Countrys AT2 HI VIS OVERLAND RTT
    Are those the total chaos tab gussets? I've gotta get mine done as well one of my tabs are bent luckily I have a buddy that has welded a few sets on. How is the alignment?
    geekhouse23[QUOTED] likes this.
  16. Apr 10, 2023 at 5:24 AM
    powder1134
    powder1134 Well-Known Member
    2014 Tacoma TRD Off Road
    I stand corrected.
    https://www.tacomaworld.com/threads/rci-front-skid-mod.654059/
  17. Apr 10, 2023 at 6:16 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    Total chaos cam tab gussets and Poly Performance taco tabs. Alignment is okay being done by a "master tech" at Firestone. I am looking into getting it really dialed in at a local shop that specializes in lifted trucks with aftermarket suspension components.
  18. Apr 10, 2023 at 7:24 AM
    LG888
    LG888 Well-Known Member
    MA
    2005 Tacoma Access Cab 2.7L M/T 4WD
    Keeping it running
    Yesterday I installed the Bird Dawg Industries mirror riser and the extreme tech deck. I am not that tall (5’8”) but this mirror riser has really increased visibility. Happy with this mod. Especially right as I prepare to do almost 800 miles (round trip) driving for work this week.
    Northbound_Taco likes this.
  19. Apr 10, 2023 at 8:05 AM
    Li0nel1234
    Lionel
    Denver
    14 TRD OR DCSB SSM
    Brother,
    I think you're missing a lug there?
    Raceface35[QUOTED] and 4WDTrout like this.
  20. Apr 10, 2023 at 8:08 AM
    Li0nel1234
    Lionel
    Denver
    14 TRD OR DCSB SSM
    Do infinity seats fit in the taco? Or did you custom order the seats with infinity logos? I'm so confused.
