  1. May 13, 2023 at 10:25 AM
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
    Let’s see if you guys can spot what I did today? lol!
  2. May 13, 2023 at 11:00 AM
    lynyrd3
    Bill
    East Central Upstate NY
    Half a spray can did both . My order of 6 cans of Krown came the other day . I hit them again .
  3. May 13, 2023 at 11:03 AM
    lynyrd3
    Bill
    Wash day is finally here ! Did the wife’s RAV4 as well .
  4. May 13, 2023 at 11:31 AM
    Burritopa
    Burritopa Well-Known Member
    Sean
    NSB, FL
    '15 PreRunner 4 door 4 banger 5 bed
    Yeah, just the 2 10mm bolts per side and pull the fender liner back. Took maybe 30 mins
    szidls[QUOTED] likes this.
  5. May 13, 2023 at 12:28 PM
    mrproduxn
    mrproduxn Well-Known Member
    steve
    Retired DoD SE VA
    Tacomas 1987,2000,2008, 2016,2012,2008
    Retired/Hobbyist old as f***
    Did my 3rd gen from the top without removing the grille. Is this an option for swapping fogs on 2nd gens.
  6. May 13, 2023 at 12:38 PM
    Burritopa
    Sean
    NSB, FL
    Not that I'm aware, just gotta bend back the fender liner and remove the 2 screws on each fog side.
    Turn your wheel to the outside of whatever side you're working on, plenty of space. Did it on my driveway no ramps etc.
    I was impressed w the DD ones bc they're literal plug & play.
    No wiring, no aiming. Im a lazy bastard, so they were right up my alley :taco:
    ace96 and Tacos4ever15 like this.
  7. May 13, 2023 at 12:41 PM
    Z7Xtreme
    Z7Xtreme Always Overestimated
    Chuck
    In a tree somewhere
    2015 trd Black Ops edition
    884's and 5100's with HS 1/4" taco lean spacer,1 inch toytec block and 5100's,SPC uca's,SCS Ray 10 wheels,265/75/16 Falken Wildpeak AT3,oem running boards,oem skid plate,WeatherTech floor liners,WeatherTech window deflectors,Access tonneau cover,WeatherTech stone and bug shield ,BPF tow hook,oem bed mat,pro grill,tacomabeast headlights,cali raised ditch brackets with Rigid lights,Rough country 30” lightbar on Rigid brackets RCI bedrack, KC rear lights,maxtrax,dual rotopax.
    Bedrack:cool:
    TegoTaco[QUOTED] likes this.
  8. May 13, 2023 at 12:42 PM
    mrproduxn
    steve
    Retired DoD SE VA
    I am content with the stock 2008 fogs however the lens have become very opaque. Had the BajaDesigns sport ambers in my 3rd gen and loved them. They were not DOT approved and would blind a blind man. Not planning to spend that $340 for my 2nd gen.
    pahaf and drewnali like this.
  9. May 13, 2023 at 1:34 PM
    MA_TACO
    MA_TACO Well-Known Member
    Wesley Chapel, FL
    Haven't had any issues with it and it's loaded with features. The kit for Tacos came with everything needed to install using factory wires(adapters etc.) and is plug n play. The steering wheel controls all work just fine. It's a floating screen design so the sides are covered by an accordion style rubber filler thingy so you can't see any wires. You can find it on Amazon https://www.amazon.com/Stinger-Replacement-2005-2011-Navigation-STH10TACOM/dp/B08NK8JNBR
    El Tano[QUOTED] likes this.
  10. May 13, 2023 at 1:37 PM
    TegoTaco
    Ontario, Canada
    Good eye!
    Z7Xtreme[QUOTED] likes this.
  11. May 13, 2023 at 2:46 PM
    SRick
    SRick Well-Known Member
    Rick
    2017 White Tacoma SR Access Cab Utility 4x4, 4 Cyl/5 SpdMT
    - ECGS Front 4x4 Needle Bearing Replacement Bushing - RCI Tacoma Skid Plate - Cooper, Discoverer AT3 4S, 265 /75 R16 116T SL OWL - 16" Dark Anthracite Alloy Wheel, PT94635160 - A/C Condenser Hose reroute - OEM all weather mats / OEM door sill protectors (stock) - Installed Intermittent Windshield Wiper Switch Assembly - Installed Towing rear light kit-4 wire - Installed Draw-Tite Max-Frame Trailer Hitch Receiver - Custom Fit - Class III - Installed CLAZZIO Leather Seat Covers, Gray - RCI Tacoma Gas Tank Skid Plate (on order) - RCI Tacoma Rock Sliders Rock Sliders
    Finished mounting and wiring my Flatbed project. Will weigh it in a week or two to see how much capacity I lost on the GVWR and load calculations from the weight of the new flatbed.
    E4x4, Bikinaz, Ricardo13x and 12 others like this.
  12. May 13, 2023 at 4:23 PM
    Seabass
    Seabass Give it to me. I'll break it for you
    Adam
    AZ
    '06 Sport 4x4
    Just a bunch of old crap
  13. May 13, 2023 at 4:39 PM
    powder1134
    powder1134 Well-Known Member
    2014 Tacoma TRD Off Road
    Don't you think a light bar on all the time may be a bad idea for oncoming traffic?
  14. May 13, 2023 at 5:04 PM
    TacoTuesday1
    SD CA
    like fogs on without fog or a flimsy bull bar held on with a couple bolts?
  15. May 13, 2023 at 5:11 PM
    babylon5
    babylon5 Well-Known Member
    David
    2015 Tacoma Double Cab TRD Sport
    Weatherstrip replacement
    I gather from the looks of it when the clips are removed the little tabs that hold it in are just bent down effectively breaking the clip?
    Seem like the only way to remove them which is just fine with me since you mention the new weatherstrip comes with new clips anyway. Just looks like they are designed as single use.
    I don't have a tool that exactly looks like that but a whole pile of similar tools I picked up to work on just about all retaining devices
    stbear likes this.
  16. May 13, 2023 at 5:47 PM
    jon_elc
    jon_elc Well-Known Member
    NorCal
    2011 SR5 4x4 Timberland Mica Snugtop Rebel
    245-70R-17 Revo3 Cut mudflaps 4.5" F / 1.5" R
    I changed my oil and filter today. 7 months and 7020 miles .... pretty much on schedule. i'm at 72k miles now.
    Corny Taco likes this.
  17. May 13, 2023 at 6:55 PM
    DaleRS
    DaleRS Well-Known Member
    Dale
    Cleveland, Ohio
    2015 Black DCSB SR5 w/ Snugtop
    Just installed some third gen Off-Road struts and rear shocks!
    Also picked up a set of third gen off-road rims that I'm going to hopefully get installed next week!
    jon_elc, mrproduxn and Z7Xtreme like this.
  18. May 13, 2023 at 7:07 PM
    NateTacoma
    NateTacoma Well-Known Member
    Nate
    2013 Tacoma
    full fender trim done!
  19. May 13, 2023 at 7:21 PM
    robm7
    robm7 Well-Known Member
    2012 TRD OR
    installed a new third brake light to my camper shell. the original lasted 10 years. it leaked and all but one bulb remained. easy install spent more time removing the old wires and cleaning the recessed area of 3M tape and dirt.
    jon_elc likes this.
  20. May 13, 2023 at 8:25 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Installed color matched grill, oem sport smoked headlights, installed rear bumper shellz and bed lined exhaust tip.
    kraftorama, dpele, Burritopa and 9 others like this.
