  1. May 18, 2023 at 3:33 PM
    dborrer
    dborrer Well-Known Member
    Mr. Dan
    St. Augustine, FL
    2006 Tacoma TRD Sport 4x MT
    2018 new Frame (thank you Rust!), FJ T-case swap. SPC(LR) UCAs, Bilstein 5100s front - rear, OME 883 at 0, HeadStrongOffRoad 3 leaf progressive AAL, MESO custom 2nd gen (Red/White) LED dome & Ultimate Maps, Spyder Halo Projector w LEDs (which SUCK), Spyder LED tails
    The irony... Amazon delivered this to me this week. What's the difference? NB Laser vs 200 ??
    Having purchased aftermarket "Spyder" shit non, OEM housings and "projector" lenses in the past.... and having the housings yellow and haze mere months out of 12 mo warranty... (sand paint and fade again...) no way i'll pay for anything other than an OEM housings going forward.
    Personally I am not keen to bake and dis-assemble/reassemble myself just to do that (Ultimate type upgrade) mentioned by others. So i'm going to keep it relatively simple and:
    https://www.tacomaworld.com/threads/the-ultimate-headlight-upgrade-h4-not-led-or-hid.398066/
    SSX999[QUOTED] and Dekoy909 like this.
  2. May 18, 2023 at 4:09 PM
    Truckdogipa2
    Truckdogipa2 Well-Known Member
    Mark
    2011 Tacoma trd sport long bed
    New frame, Upper control arms, roof rack , method wheels fallen tires duel battery
    Did a few things
    1. Installed remanned denso alternator
    2.changed idler pullies
    3.Changed some rusted screws in engine bay
    4. Added 14 in portable tv that flips down from bed ceiling
    5. Made bracket for PlayStation
    6. This is a well-known fact that our Tacoma‘s can’t take the weight of two batteries. Therefore, I made a bracket that went straight down to the frame that I bolted in with 8 mm bolts and tapped in to frame. It is hard as hell right now.
    7. Changed serpentine belt
    8. Did the big 7 1/0 wire for jeep wires.com
    LeakyAC, srspicer, rob1208 and 9 others like this.
  3. May 18, 2023 at 5:41 PM
    trdspectacoma
    trdspectacoma Well-Known Member
    B.I Hawaii
    13 dCab preRunner
    you could DIY like the fortin kits they sell on ebay from lessco electronics couple of taps and a little programing and all done. it just matters if you have the " G Key"
  4. May 18, 2023 at 5:53 PM
    powder1134
    powder1134 Well-Known Member
    2014 Tacoma TRD Off Road
    Swapped my softopper for a hard cap. I was on the fence but I really like the look and the space this provides. Ordered Yakima roof tracks today and will start to work on a rack system for the cap.
  5. May 18, 2023 at 6:44 PM
    SSX999
    SSX999 Well-Known Member
    2015 Tacoma TRD Off Road 6MT
    You got the better bulb, that's the difference! :thumbsup:
    dborrer[QUOTED] likes this.
  6. May 18, 2023 at 7:27 PM
    Hotrodroxie
    Hotrodroxie Active Member
    NEO
    08 Tacoma dbl 4x4, poor girl stock
    Sorry, not on here often....
    The one I got is literally obsolete now- it’s over a decade old lol I have the box (for lifetime warranty via BEST BUY install) so I could lyk what it is, but there’s no point. I do recommend getting one from Best Buy- assuming they still offer lifetime (of the ownership/operation) warranty coverage on their installed equipment. I’ve have the entire unit replaced twice; once when the brain fried for an unknown reason- and if there are any other issues in the future, I will get upgrades to what’s available now (for free) since my original model is obsolete.
  7. May 18, 2023 at 8:19 PM
    AwArD
    AwArD Well-Known Member
    2012 Tacoma Trail Teams TRD sport Double Cab V6 4.0
    Icon Rxt rear leaf option 2 Elka 2.5 DC Reservoir Front/Rear with 600lbs/14inch coil JBA Offroad STD high caster UCA Whiteline LCA inner bushing Mevotech TTX LCA Ball joint Woodward U-Joints Intermidate steering shaft mod Uni filter mod TRD Cat-Back Exhaust Timbren Active Off-Road Bumpstops Front/Rear Overland Torque Tune (OTT) by Yotatune Amsoil signature engine/transmission Amsoil SEVERE GEAR 80W-90 Front/rear diff and T-case Tacoma bed mat Weathertech mat front and rear cabin Summer BFG Ko2 265/65r17 E rated / Fuel Rebel 6 Bronze wheels Winter Nokian Hakkapeliitta 10 studded, 265/65r17 / oem Toyota wheels
    I know it's a controversial topic but today i wanted to fuck around and find out.
    It's been a year since i put a new suspension on it. It improved the ride alot (the original suspension was pretty done at 135 000 miles), i tested so many setting on the damper control, tyre psi, coil spring rate and the truck alignment. I was close but never reached the "smooth" ride i was looking for.
    I watched a series of video from Overland Outfitters last week blind testing a couple of shock setup on a 3rd gen Tacoma. These test was not very scientific per say but these dude know their stuff and it raised some question in my mind when they talked about body roll and ride quality. The test was done on-road and off-road and they where glad to not have a sway bar on some combo because the ride was stiff.... This was a lightbulb moment for me so i needed to try for myself with my setup and i'm very surprised by the result i got this evening.
    Took a short drive on the highway and on a few bad dirt road i know and i can say that the ride improved alot. Took all the corner the same speed, tried to swerve left and right. The body roll is here now, it's minimal but the truck still very easy and predictable to drive. I will add some weight this weekend to re-test but i think i understand why people have removed this part and never put it back.
    I will need to do some safety test to push the VSC to see how this affect the traction control when reacting to a fast steering input, for now it seem to arm/kick like before so i will be good to push it and feel how the weight move when the system take control of the truck.
    banditcamp likes this.
  8. May 18, 2023 at 8:28 PM
    20somethingwidataco
    20somethingwidataco Yes, my avatar is a real car.
    Will
    Washington State
    2008 AC TRD SPORT M/T
    ACLB 6 SPEED: Suspension: Bilstein 6112s (3rd perch) (F) Taco Lean Spacer Bilstein 5160s (R) TSB Leaf Pack Wheelers Offroad 3 leaf progressive AAL Wheelers Superbump Front Duro Bump U bolt flip kit Duro Bump progressive bump stop 3rd gen TRD offroad sway bar Wheels and Tires: Summit Racing Wheel Dakars (Polished Silver) 285/70r/17 Goodyear Wrangler Duratrax (Load D) "Performance": AFE CAI with custom powdercoated white filter cover MagnaFlow Performance Series Exhaust URD Cam gears XTP Intake Manifold Spacer OTT Torque Tune Brakes: Stoptech Slotted Rotors Stoptech Sport Ultra Composite Brake Pads Wheelers offroad SS brakelines (Front) Interior: Kenwood DD headunit Oem Subaru Kicker Tweeters Alpine 6x9 (Front) & 6.5 (rear) (With Taco tunes speaker mounts) Alpine 500 watt amp Sound Deadening (Doors, Rear "wall", Roof) ODI Rouge Shift Knob Weather Tech Mats Painted/wrapped trim pieces Console Safe Console Vault Gridx Organizer Ram Phone Mount Meso Customs dual color map lights Meso Customs dual color dome light Wet Okole seat covers (Black) Wet Okole center console cover (Black) 1" Seat Raisers (Driver & Passenger) AJT Designs climate control and 4x4 knobs Back Up Camera Lighting: Retrofits (Mini H1's, RGB Halos, 5500k Bulbs)(Lenses wrapped in self healing PPF) Diode Dynamics SS3 Max SAE (Yellow) Diode Dynamics SS5 Pro (Yellow) Driving lights (ditch lights) Anytime fog mod Rigid Industries E series 32" Combo bar (spot/flood) Diode Dynamics XPR Reverse Lights Diode Dynamics XP80 turn signals LED brake, parking lights and license plate lights Armor: Apex All Pro sliders BPF steel skid plate Bigass Trailer Hitch Camping/Storage: Leer canopy LED interior lighting Sleeping platform (Storage underneath) Removable snowboard Yakima mounts Extra D rings in bed (6 total) Custom Powder coated white snow shovel with custom bedrail mounts Amazon special Traction Boards Hi Lift 48" Jack with custom Rail mounts to accommodate my sleeper set up Other: All pro Bed Stiffeners Relentless Fab tailgate panel TRD sport graphics (Turd Gen spec) Anti Sun glare hood scoop wrap (Satin Black) Custom FleeBay grille 4 Hella supertones ECGS needle bearing Many Patches BPF shackle mount (With smittybuilt shackle) Tinted windows (Front/Rear + Full canopy)(18%) Meso Customs gasshole AVS inchannel window visors Diff Breather Kit 2012-2015 Oem Turn signal/folding mirrors (w/ sequential signals) 2012-2015 Oem LED taillights Full Size (285/70r17) spare DIY Larger Engine Splash Guards DIY Vipercut TRD radiator cap AC drip line mod
    Mine was sketchy when I took it off for a short period. When I went to drift around on a (closed gravel road), my truck almost snap oversteered. It was sketchy af, and I didn't appreciate it so much. I came from the thicker TRD Sport sway bar, and moved to a thinner TRD offroad sway bar. I think it's a decent middle ground. Although, when I wasn't driving like a jackass offroad, it was worlds better. For free basically.
  9. May 19, 2023 at 12:27 AM
    MasonSTL
    MasonSTL Well-Known Member
    Green Bay, WI
    06 TRDOR AC MT
    I just put these in mine like a week or 2 ago. The instructions on their website are pretty good.
    Only pointer I would say is get the longest 17mm wrench you can find for the bolt that holds them in. That SOB takes some torque.
    Totally worth it though. Best way to get some extra oomph from the truck.
    tonytoco12[QUOTED] likes this.
  10. May 19, 2023 at 12:36 AM
    MasonSTL
    Green Bay, WI
    06 TRDOR AC MT
    Who needs new wheels when you got a case of rustolium :cool:
    Also made some mounts for my new bump stops. Some exhaust pipe, nut, bolt and spacer saved me $30 from buying fancy pants ones.
    dpele, tonytoco12, point45 and 3 others like this.
  11. May 19, 2023 at 4:18 AM
    AwArD
    It's that's what I apprehend, if this happen i still have my 700 coil in a box and i'm still on the very soft side of my shock damping control, i will probably try to dial that first to see before putting the Sway back. Glad to know there is alternative, didn't know there was a difference between the Sport and off road sway bar thanks !!
  12. May 19, 2023 at 4:51 AM
    banditcamp
    banditcamp Well-Known Member
    daniel
    2015 Super White DCSB Off Road
    I'm so happy with mine off. I have done emergency maneuvers on back roads trying to make it feel sketchy and sway so I'd know what to expect in a real situation and it doesn't sway. It feels and acts the way its suppose to. Smooth and predictable. I have 285 75 16, sliders, a low profile front bumper with a winch. My coils are 600 pound eibachs on their pro truck coilovers that were designed for a 3rd gen. (Third gens way a good bit more than our trucks) so I feel that may have a lot to do with how stable my truck feels without the bar. I don't see myself putting it back on ever.
  13. May 19, 2023 at 12:57 PM
    Ozzylara805
    Ozzylara805 Well-Known Member
    Oziel
    Grand Island Nebraska
    2012 trd off-road
    Tinted the front two doors to match the back doors on the Tacoma today!
    dpele, rob1208, Fluffymonkey and 20 others like this.
  14. May 19, 2023 at 2:29 PM
    FireZoneBlitz
    FireZoneBlitz Member
    2011 Tacoma TRD Sport
    Headlight haze was not repairable and I had melted DRL surrounds so I replaced the headlights and gave it a quick wash before attempting some paintless dent removal.
  15. May 19, 2023 at 2:35 PM
    Charlie Bravo
    Charlie Bravo Well-Known Member
    Charlie
    Coeur d'Alene, Idaho
    2009 Red Tacoma Access Cab 4wd 2.7MT
    RedLine Tuning hood QuickLIFT, Gen3 alloy 16x7J, All Pro Off-road bed stiffeners & IFS skid plate
    I have been a fan of Adam J. Turley's application of his mechanical engineering degree to products for the Toyota Tacoma and other makes and models since I brought the DLT (Dad's Last Truck) home to care for. First came the screwed together fob cases, then climate control knobs, and this week ordered the battery hold down and the v1 5MT shift knob with red anodized allen head screws plus a set of black oxide SS screws ($5, add a buck for the anodized set) so I saved a dollar!
    Today, the Taco was fueled up and given the free red wash at Hippo, courtesy of a recent service at Parker Toyota. Back in the garage, I'll start applying the emblem overlay decals from TVD to the sides and tailgate (color-matched, so it should give an understated chrome outline).
  16. May 19, 2023 at 4:27 PM
    taco-newb
    taco-newb Active Member
    Brigham City, UT
    2010 Grey Tacoma 4dr TRD Sport
    2" level in front
    Well, folks, I just so happen to have found a 12" sub that fits like it was made for the double cab Tacoma and will knock your head off!!! Probably should have done some video but you'll have to cut the brackets and strip that run along your back seat but once done, this thing fits behind the passenger rear like an absolute glove. Just tight enough you need to firm it into place but then there is absolutely no rattling, shaking or whatever and it sounds freaking off the charts!!! Cost is minimal compared to what you'd pay for a Taco specific sub.
    https://www.amazon.com/gp/product/B00TEQM1GW?ie=UTF8
    BraddahRO likes this.
  17. May 19, 2023 at 5:04 PM
    tonytoco12
    tonytoco12 Active Member
    Anthony
    2012 tacoma
    Bilstien Franken lift fox rear shocks trail gear front bumper body armor rear with swing out 35s sliders skids snorkel and other crap
    Working on getting urds exhaust cam gears in feels like I've been rotating the crank for ever trying to still get the timing marks together 16845410056357339365151288020255.jpg
    20somethingwidataco likes this.
  18. May 19, 2023 at 5:37 PM
    Tiedie
    Tiedie The Only Shantytown Resident.
    David
    WFOY
    Katzkin, Dobinsons full suspension. Redlinegoods console cover and door panel arm rests, Double USB charger in dash installed, Ballistic Jesters 16x8. BlackVue DR 590 Dash Cam
    Waited on FEDEX for the 5th straight day to make delivery of new suspension. Operational delay for 5 dayso_Oo_Oo_O. Totally unacceptable, ECGS guy reshipped on thursday and got it today via UPS.
    Company down road from me that makes custom foam products for things that fly, UPS Guy told me FEDEX hasn't picked up for 2 weeks:rolleyes::rolleyes:.
    Maybe tomarrow??????:angrygirl::angrygirl::angrygirl::angrygirl::angrygirl::angrygirl::angrygirl::angrygirl::angrygirl:
  19. May 19, 2023 at 8:11 PM
    20somethingwidataco
    Will
    Washington State
    Replaced my radiator support bushings hoping it would get rid of my never ending front end clank. Ya, it didn't..... I've read that perhaps the cam bolts holding in the lca need to be tight tight, so I'll try that tomorrow. Or Sunday.
    Ricardo13x likes this.
  20. May 19, 2023 at 8:26 PM
    20somethingwidataco
    Will
    Washington State
    2 of my lca bolts were pretty loose. Took two full (still hard to turn) turns to get to 130 ft lbs. So hopefully that does it. Done for the night
    srspicer, 4WDTrout and Ricardo13x like this.
