  1. Jun 9, 2023 at 9:41 AM
    tattooedsnake
    tattooedsnake Well-Known Member
    Erick
    Connecticut
    '10 TRD sport 4x4
    -Bilstein 6112 front shock. Leveling lift -Bilstein 5100 rear shock w/TSB leaf pack. -Cooper Rugged Trek 265/70/17 -EBC front ultimax rotors w/yellow pads -Stoptech sport rear drums -Steel braided brake lines -Wet Okele seat covers front/rear with heaters -Custom built exhaust with Black Widow venom 250 muffler -Afe Stage 2 Dry CAI -Diode dynamics SS3 fog lights yellow. -OPT7 Projector Headlight Assembly w/Black backing -Undercover Flex Tonneau cover -Weather Tech floormats front and back
    I like that they are different than what everyone else gets.
    I had Wildpeaks before these and Open country At2 before those. Least road noise of the 3 so far and they don't have the speed wobble at 65 like Wildpeaks do.
    TwinTaco31719[QUOTED] likes this.
  2. Jun 9, 2023 at 9:41 AM
    4WDTrout
    4WDTrout Perpetually dreaming of tall trees & rivers
    Theo
    08 4WD SR5 DCSB
    Total Tacoma nOOb.
    hxp05560 likes this.
  3. Jun 9, 2023 at 9:46 AM
    tattooedsnake
    Erick
    Connecticut
    '10 TRD sport 4x4
    I replaced the brake lines with Stainless steel ones while still on the OEM brakes it is was a definite change from spongy brakes.
    I did EBC rotors/pads and stop tech drums upgrade last year and it's a huge difference. Both make a difference, but installing performance brakes won't give you the max performance boost with stock rubber lines.
    BearB likes this.
  4. Jun 9, 2023 at 9:57 AM
    chiffonade
    chiffonade Well-Known Member
    i have the same kit + stainless lines and my brakes feel firmer and grab better but most importantly do not fade at highway speeds in hot weather. obviously you also need to do a very thorough brake fluid flush. i have a 2015 with e-booster.
    just upgrading the stock pads and rotors and lines will be a huge increase in 'feel'. the big brake kits have all that, and are thicker/larger for more endurance (more heat resistance). the actual scrub surface of the pads isn't much different... you can only fit so much brake under a 16 or 17" wheel.
  5. Jun 9, 2023 at 9:58 AM
    BearB
    BearB Active Member
    Bear
    2014 Tacoma TRD Off Road 4x4 Access Cab - 6-speed manual
    30'' Rigid Industries front light bar BFG KO2s 265/75/R16 BAMF rear diff skid plate BAMF rock sliders BAMF Trilogy Skidplates BAMF LCA Skids Bilstein 5100s (4) Icon Dynamics MULTI RATE RXT LEAF PACK W/ ADD IN LEAF RIGd Ultraswing OvrLnd Camper Done! (almost ;)
    @Saechao503 I don't notice any big difference from stock on the pedal but they're definitely not spongy! They were recommended by a reputable brake shop and they say they help with brake performance. I'm not racing around and slamming on the brakes so I don't have that performance data. (I got 120K miles on original pads)
    I have a 6speed manual and a V6 and use a trick. When slowing down I don't down-shift through all the gears. I leave it in the gear it's in except if it's in 6th, I'll downshift. I keep it in the same gear until right before stalling (I don't let it shutter or anything), then push the clutch in. I learned that from getting a Swedish drivers license (quite difficult to get). It's more effective than downshifting because there's constant motor back pressure on the driveline, better on the vehicle, and more environmentally friendly. Learn something new every day!
    Charlie Bravo likes this.
  6. Jun 9, 2023 at 10:02 AM
    shabbs
    shabbs Well-Known Member
    Mark
    Toronto, Canada
    2014 Tacoma 4x4 V6 DCLB TRD Sport
    Skid plate - added 2014/10/23, Bed extender - added 2014/10/25, Tonneau Cover - added 2014/10/31, OEM Bed Mat - added 2014/11/12, AM/FM/CB AntennaX - added 2014/11/16, Smittybilt 27046B Beaver Step for 2" Hitch - added 2015/01/22, Trimax SXT3 Premium 5/8" Key Receiver Lock - added 2015/01/22, 2 x Grip 30' x 4" Heavy Duty Tow Straps - added 2015/01/23
    That hammock off the back... brilliant.
    Maximumdarkside likes this.
  7. Jun 9, 2023 at 1:03 PM
    Tiedie
    Tiedie Well-Known Member
    David
    WFOY
    Katzkin, Dobinsons full suspension. Redlinegoods console cover and door panel arm rests, Double USB charger in dash installed, Ballistic Jesters 16x8. BlackVue DR 590 Dash Cam
    Took the 14 year old bug flector off. Looks like a new truck.
    Greyhome likes this.
  8. Jun 9, 2023 at 3:31 PM
    TwinTaco31719
    TwinTaco31719 Well-Known Member
    Eric
    Glenbrook, NV
    2023 Lunar Rock LB Sport
    Good information!
  9. Jun 9, 2023 at 3:53 PM
    4WDTrout
    Theo
    08 4WD SR5 DCSB
    Total Tacoma nOOb.
    Get some Cooper Discoverer AT3 XLT’s. That’s what I run and love ‘em!
  10. Jun 9, 2023 at 5:28 PM
    10thMTNgrunt
    10thMTNgrunt This is the way, step inside.
    2013 TRD Sport
    I’m not sure what the bonding process is, but this stuff really works! I blacked out my Coopers with Renew and Protect once a year Blak trim and tire sealant. This stuff is gold, I used it to bring back my faded, originally black but sun bleached grey fenders on my first gen, they stayed black until I sold it two years later. It stains, tape off anything you don't want touched by it, and I recommend watching a few YouTube videos on how to use it properly. It’s not shiny which I really like, just a deep rich black. They have gloss and satin overlay solutions to layer with (I’m good without, but that’s just me) and a dash protective treatment as well. Will not bond properly if there is a silicon based product already on the applicable surface, if so you will need to clean/scrub/remove first.
    0B981D03-F67F-424F-887F-7FBE1A0A0BD3.jpg 665CA7E1-EC7C-4DCE-8E1E-C8D6FF6B35A2.jpg D94E2638-00B4-4986-846A-8F182D95CCE4.jpg
  11. Jun 9, 2023 at 6:44 PM
    Rezkid
    Rezkid Not a Well Known Member
    TJ
    WTX
    '08 DCSB TRD RT
    Little bit of this and that
    Rolled over 149500mi, gave it a wash and 303'd the mirrors and fender flares. Not perfect but cleans up decent.
  12. Jun 9, 2023 at 7:21 PM
    tattooedsnake
    Erick
    Connecticut
    '10 TRD sport 4x4
    Why... I have a new set of Cooper Rugged Treks.
  13. Jun 9, 2023 at 8:38 PM
    20somethingwidataco
    20somethingwidataco Yes, my avatar is a real car.
    Will
    Washington State
    2008 AC TRD SPORT M/T
    ACLB 6 SPEED: Suspension: Bilstein 6112s (3rd perch) (F) Taco Lean Spacer Bilstein 5160s (R) TSB Leaf Pack Wheelers Offroad 3 leaf progressive AAL Wheelers Superbump Front Duro Bump U bolt flip kit Duro Bump progressive bump stop 3rd gen TRD offroad sway bar Wheels and Tires: Summit Racing Wheel Dakars (Polished Silver) 285/70r/17 Goodyear Wrangler Duratrax (Load D) "Performance": AFE CAI with custom powdercoated white filter cover MagnaFlow Performance Series Exhaust URD Cam gears XTP Intake Manifold Spacer OTT Torque Tune Brakes: Stoptech Slotted Rotors Stoptech Sport Ultra Composite Brake Pads Wheelers offroad SS brakelines (Front) Interior: Kenwood DD headunit Oem Subaru Kicker Tweeters Alpine 6x9 (Front) & 6.5 (rear) (With Taco tunes speaker mounts) Alpine 500 watt amp Sound Deadening (Doors, Rear "wall", Roof) ODI Rouge Shift Knob Weather Tech Mats Painted/wrapped trim pieces Console Safe Console Vault Gridx Organizer Ram Phone Mount Meso Customs dual color map lights Meso Customs dual color dome light Wet Okole seat covers (Black) Wet Okole center console cover (Black) 1" Seat Raisers (Driver & Passenger) AJT Designs climate control and 4x4 knobs Back Up Camera Lighting: Retrofits (Mini H1's, RGB Halos, 5500k Bulbs)(Lenses wrapped in self healing PPF) Diode Dynamics SS3 Max SAE (Yellow) Diode Dynamics SS5 Pro (Yellow) Driving lights (ditch lights) Anytime fog mod Rigid Industries E series 32" Combo bar (spot/flood) Diode Dynamics XPR Reverse Lights Diode Dynamics XP80 turn signals Diode Dynamics HP5 Third brake light LED brake, parking lights and license plate lights Armor: Apex All Pro sliders BPF steel skid plate Bigass Trailer Hitch Camping/Storage: Tonneau Cover (Truxedo Roll Up) KB voodoo bed bars Pelican Vault (for gear) LED interior lighting Extra D rings in bed (6 total) Custom Powder coated white snow shovel with custom bedrail mounts Amazon special Traction Boards Hi Lift 48" Jack Other: All pro Bed Stiffeners Relentless Fab tailgate panel TRD sport graphics (Turd Gen spec) Anti Sun glare hood scoop wrap (Satin Black) Custom FleeBay grille 4 Hella supertones ECGS needle bearing Many Patches BPF shackle mount (With smittybuilt shackle) Tinted windows (Front/Rear) (18%) Meso Customs gasshole AVS inchannel window visors Diff Breather Kit 2012-2015 Oem Turn signal/folding mirrors (w/ sequential signals) 2012-2015 Oem LED taillights Full Size (285/70r17) spare DIY Larger Engine Splash Guards DIY Vipercut TRD radiator cap AC drip line mod Anti Tweeker tailgate lock
    Finally fixed the clank in my front end.....
    Now all I hear is the transmission whine, and throw out bearing chirp
    Conclusion: somehow I was missing the pad springs/clips/whatever the hell from my front right driver's side. Doubled up on them and the clank went away.
  14. Jun 10, 2023 at 4:21 AM
    williams63
    williams63 Well-Known Member
    chili
    nh
    2011 dblcb
    boss-c/o, boss rear leafs
    I bet that’s where my front end clank is coming from. I’ll have to look into that. If the sun ever comes back out.
  15. Jun 10, 2023 at 5:08 AM
    jackn7
    jackn7 Old Man Tan Taco
    Art
    So Cal
    2008 DCLB 4x4
    Just some stuff...
    Speed wobble? What speed wobble? First time I’ve heard of this.
    mchabot1987 likes this.
  16. Jun 10, 2023 at 7:09 AM
    dborrer
    dborrer Well-Known Member
    Mr. Dan
    St. Augustine, FL
    2006 Tacoma TRD Sport 4x MT
    2018 new Frame (thank you Rust!), FJ T-case swap. SPC(LR) UCAs, Bilstein 5100s front - rear, OME 883 at 0, HeadStrongOffRoad 3 leaf progressive AAL, MESO custom 2nd gen (Red/White) LED dome & Ultimate Maps, Spyder Halo Projector w LEDs (which SUCK), Spyder LED tails
    I hear a not a clank, but a squeak almost every time I depress the break pedal... I can't figure out where it's coming from.
    And of course the chirp of my original TOB.... (259K miles)
  17. Jun 10, 2023 at 8:10 AM
    SRick
    SRick Well-Known Member
    Rick
    2017 White Tacoma SR Access Cab Utility 4x4, 4 Cyl/5 SpdMT
    - ECGS Front 4x4 Needle Bearing Replacement Bushing - RCI Tacoma Skid Plate - Cooper, Discoverer AT3 4S, 265 /75 R16 116T SL OWL - 16" Dark Anthracite Alloy Wheel, PT94635160 - A/C Condenser Hose reroute - OEM all weather mats / OEM door sill protectors (stock) - Installed Intermittent Windshield Wiper Switch Assembly - Installed Towing rear light kit-4 wire - Installed Draw-Tite Max-Frame Trailer Hitch Receiver - Custom Fit - Class III - Installed CLAZZIO Leather Seat Covers, Gray - RCI Tacoma Gas Tank Skid Plate (on order) - RCI Tacoma Rock Sliders Rock Sliders
    New Tires, Cooper Discover AT3 LT 265/75R16, C1 tires. Next is fenders and suspension.
    Bagman, BearB, loyaltothetaco and 7 others like this.
  18. Jun 10, 2023 at 9:58 AM
    Goosie0080
    Goosie0080 Well-Known Member
    North East
    07 Tacoma Access Cab 4x4 base
    Painting my new lower fender flare... why you ask? Cause I'm a moron and ripped it off with my toolbox drawer when I was backing out of my garage..
  19. Jun 10, 2023 at 10:28 AM
    Burritopa
    Burritopa Well-Known Member
    Sean
    NSB, FL
    '15 PreRunner 4 door 4 banger 5 bed
    Man that thing looks cherry. Makes me wana tackle my UV molested plastic
    Rezkid and 10thMTNgrunt[QUOTED] like this.
  20. Jun 10, 2023 at 10:37 AM
    10thMTNgrunt
    2013 TRD Sport
    Appreciate it! This stuff does wonders for faded plastic and rubber, will bring back to a new like appearance, just tape things off and be thorough when applying it. Here’s a great YouTube video on how to apply it properly.
    https://m.youtube.com/watch?v=rS1xhoTiyLY&pp=ygURcmVuZXcgYW5kIHByb3RlY3Q=
    Burritopa[QUOTED] likes this.
