  1. Jun 24, 2023 at 4:18 PM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    Removed the bed mat and swept out the bed. Reinstalled the bed mat. :thumbsup:
    Tried a couple weeks ago and it started raining. :(
  2. Jun 24, 2023 at 4:57 PM
    NDTacoma
    NDTacoma Well-Known Member
    Anthony
    Minot, ND
    2015 Toyota Tacoma TRD Off Road Auto V6 Double Cab
    Washed and waxed her today
    drewnali, ryanh618, jackn7 and 13 others like this.
  3. Jun 24, 2023 at 5:26 PM
    2WD
    2WD Well-Known Member
    Pete
    2013 DCSB TRD Off-Road Pre-Runner Taco
    King 25001-119A, JBA HC and superbumps, EL095 leafs with longer overload leaf removed and 2 degree shim, Bilstein 5160 rears with fox roost shield on passenger side, King 2'' bump stops, B&M 70264 trans cooler, CSF FJ radiator, Leer Trilogy X2T bed cover, Scangauge, 34R AGM battery, weathertech floormats, Gold plug on the differential, fancy engine and diff oils, UNI air injection filter mod, Factory antenna chopped 4'', De-badged, Ram mount on A pillar, Cooper ST Maxx 265/75 R16.
    Too high, I'd shop around. More like 5-600 for ceramic.
    20somethingwidataco likes this.
  4. Jun 24, 2023 at 9:01 PM
    AZ_TACO
    AZ_TACO Well-Known Member
    2009 PreRunner TRD OR
    Toytec Boss 2.5” Front Toytec Boss 2” Rear SPC UCAs CMC Black Rhino Warlords BFG KO2s aFe Wet EA Filter Rigid D Series Pro
    1. Replace valve cover gaskets
    2. Replace plugs
    3. Replace various vacuum/coolant lines
    4. HPS upper/lower rad hoses
    5. New thermo
    6. Oil change
    7. Cleaning, cleaning, and more cleaning. MAF, throttle body, hood, various areas of the bay and the air box, upper intake and cover
    Technically I finished this all today, started Thursday night…
    drewnali, jackn7, POOLGUY and 2 others like this.
  5. Jun 24, 2023 at 11:03 PM
    blairrad
    blairrad Yoter
    Missouri
    Threw on some 255/80/17s! No lift (currently), and so far zero rubbing from street driving. Including steep up and down on driveway in forward and reverse, forward and reverse at full lock on level ground, and ruts/dives/slopes/bumps on the road. Haven’t been off-road yet.
    True 33” and no cutting or trimming! I do have the front mud flaps off, and the TRD Pro wheels have a +4mm offset which helps a lot.
    These are the new Falken RT (R/T01). They measure 33.3”, feel good on the road with little to no noise, look great, and were not bad price wise.
    Enjoy!
    sberkley92, JerzRob, drewnali and 7 others like this.
  6. Jun 25, 2023 at 6:10 AM
    sheld
    sheld Well-Known Member
    2012 Black TRD OR DCSB
    Raptor lined my silver truck cap
  7. Jun 25, 2023 at 10:03 AM
    jackn7
    jackn7 Old Man Tan Taco
    Art
    So Cal
    2008 DCLB 4x4
    Just some stuff...
    Wow, that came out really nice! It’s the details and the prep work. Looks great!
    sheld[QUOTED] and Canadian Caber like this.
  8. Jun 25, 2023 at 10:16 AM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Was this sprayed from a rattle can, rolled on, or applied with a paint gun? Turned out quite nice!
  9. Jun 25, 2023 at 10:46 AM
    mrproduxn
    mrproduxn Well-Known Member
    steve
    Retired DoD SE VA
    Tacomas 1987,2000,2008, 2016,2012,2008
    Retired/Hobbyist old as f***
  10. Jun 25, 2023 at 11:53 AM
    sheld
    Thanks! I think it can be applied all 3 ways. I took it as an excuse to buy a compressor and sprayed with a paint gun to get a finer texture.
    All in all it was probably as much as paying for line-X or Maaco but I still have half the paint for other projects
  11. Jun 25, 2023 at 3:15 PM
    HIghlande2
    HIghlande2 Well-Known Member
    Wilmington, NC
    15 DCSB Sport
    Little of this and a little of that
    Made it shiney again :rofl:
  12. Jun 25, 2023 at 5:48 PM
    WestCoastBestCoast
    WestCoastBestCoast Well-Known Member
    Wyn
    Portland, OR
    2005 SWB TRD 6MT 4x4
    Installed new 6x9 speakers in my front doors. Sound is already noticeably better than stock, and I’ll eventually do the rear doors.
    After install I noticed a 1/4” gap at the bottom of the door panel near the speaker? Anyone else have this? My assumption is the 6x9 I got is not the “exact size” as the stock ones. Might need to shave down the inside plastic that is contacting the outside edge of the speaker.
  13. Jun 25, 2023 at 7:47 PM
    tazgohome
    tazgohome Well-Known Member
    2009 Tacoma 4X4 SR5 V6 DCSB
    At 220K miles, conducted oil change on rear and front differential and transfer case. Went a bit longer than planned between changing. Make sure to check your part numbers for the plugs and washers for they have changed. Same part number for rear and transfer case drain and fill plugs now. Also upgraded to the Lexus 14mm hex bolt head drain and fill plugs for the front differential.
    jackn7, 4WDTrout and Canadian Caber like this.
  14. Jun 25, 2023 at 8:30 PM
    BluberryBCtaco
    BluberryBCtaco Making the magic happen
    BC Canada
    2007 Tacoma Sport DCLB
    3in lift, Tow package, Any time 400w inverter, in cab outlet, vinyl floor, roof rack
    Climbed a 45 degree rock that’s on an edge of a cliff.
    jackn7, TacoLolz, banditcamp and 6 others like this.
  15. Jun 25, 2023 at 10:55 PM
    Canadian Caber
    Canadian Caber R.I.P Layne Staley 67-2002
    Les
    B.C. Canada, eh
    2020 TRD Sport DCLB 4X4 Super White
    Sport wheels and your tire choice actually look pretty good on your truck. Don’t see that combo too often on pre 2020’s. And yes these trucks can be goats!
  16. Jun 26, 2023 at 6:59 AM
    gkomo
    gkomo Well-Known Member
    San Diego, CA
    2014 MGM AC SR5 4x4
    90k oil change.
    I think I went way too long on time duration (not mileage though) between the last change so bought a paint pen to write date and mileage on the filter this time.
  17. Jun 26, 2023 at 7:59 AM
    mrproduxn
    steve
    Retired DoD SE VA
    I don't really sweat the time on mine any more. I went 16 months on my final 3rd gen oil change but that was only 2300 miles. My current 2nd gen I change every 3000 miles but that is roughly 18 months. These semi or full synthetic oils are not hurt even at 5000 miles. At least not for my mostly mild driving habits. It will be another 12 to 14 months before I hit the next 3000 miles on mine. At my rate of driving my 2008 may hit the 100k mile mark around my 71st birthday in 2030. Can't see dumping clean oil with no miles on it. I considered doing a oil drain and fill every 6 months and a filter change once a year. I just can't justify the extra work. When I sold my 3rd gen in mid 2021, after 5.5 years, it only had 25k miles on it. I only averaged around 4000 miles a year on that one when I was still working. We usually fly for trips. I-95 from here to Florida and back is a nervy buzz kill. Even with the Charlotte or Atlanta layover we get there in 4 hours without needing I-95 induced xanax.
    gkomo[QUOTED] likes this.
  18. Jun 26, 2023 at 8:51 AM
    gkomo
    San Diego, CA
    2014 MGM AC SR5 4x4
    Ya I bought my parents 4runner which i now daily 95% of the time so mileage on the Tacoma has significantly decreased. Although, after this oil change the Tacoma does seem to run a bit smoother but could be just my mind. I'll probably just do year intervals if i don't reach the 5k mile mark in that timeframe.
    Maximumdarkside likes this.
  19. Jun 26, 2023 at 9:37 AM
    Its_Taconie
    Its_Taconie Well-Known Member
    Nelson
    North Hollywood
    2007 Tacoma DCLB PreRunner
    Fox Racing 2.5 (F); 2.0 (R), Archive Garage Leaf Springs, hanger/shackles, shock relocation, U-Bolt Flip Kit PLM P37 (TE37 Knockoffs) Bronze wheels, Nitto Ridgeline 35s, C4 Overland Bumper, Total Chaos Uppers, Outgear Solution HC Swingout, OTTune 4.88 Nitro Gears
    Now I have to go look at the bed of my truck cause of this. Crossing my fingers it isnt cracked. Going to purchase some bed stiffeners asap.
  20. Jun 26, 2023 at 10:33 AM
    Mods2Travel
    Mods2Travel Well-Known Member
    Daniel
    Fort Worth, TX
    2015 DCLB 4x4 SR5
    Level 8 MK6, 16x8, 6x5.5, +0 Offset Rims 285/75/16 (33") BFG KO2 tires 4.56 Gears from ECGS DIY bed/drawer slideout Bed Mounted Deep Cycle Battery/Fuse Box/Inverter/Isolator Yellow Wire Mod Rear Diff Breather Mod DIY Roof Rack Leer 180 Shell Bilstein 6112, Circlip #4 Bilstein B8 5160 Remote Reservoir Firestone Ride Rite 2407 Rear Suspension Airbags DayStar Cradles Camper Shell Radiator Fans for sleeping in warmer climates
    https://www.tacomaworld.com/threads/cowl-induction-snorkel.525314/
    Check out the first post on this thread for the cowl induction snorkel. Wire mesh on the sides of the cowl area and over the cabin air intake. They should have a hard time chewing through that metal.
