  1. Jul 27, 2023 at 6:53 AM
    elricfate
    elricfate Well-Known Member
    2009 Tacoma AC Silver Mica
    As long as it can do 75ish PSI, you should be fine. It will just constantly be refilling.
    https://www.woolwaxusa.com/Woolwax®-Pro-Undercoating-Gun-_p_16.html
    I always recommend the pro gun because of the wands that are included, that 360* spray tip is absolutely fantastic for getting into our frames.
    I work with woolwax over fluid film, but this gun is specifically made for fluid film: https://www.amazon.com/Fluid-Film-FFSG-Spray-Applicator/dp/B07YF5BCDH
  2. Jul 27, 2023 at 12:05 PM
    ScrippsRanch67
    ScrippsRanch67 Well-Known Member
    Bob
    06 Tacoma Pre-Runner 2wd Quad Cab short bed
    Fiberglass shell
    You might want to see a Doctor about that urine sample.
    10thMTNgrunt[QUOTED] likes this.
  3. Jul 27, 2023 at 3:47 PM
    771Doug
    771Doug Well-Known Member
    Virginia Beach, VA
    '08 V6 Pre-Runner
    Swapped the tailgate panel with a Hooke Road. Pretty stout and the holes lined up okay. I did use the original screws since the washers they give you are a little too small.
    $125 OTD on ebay.
    I'm satisfied.
  4. Jul 27, 2023 at 4:15 PM
    reallifedog
    reallifedog wat.
    Jordan
    Denver
    08 Tacoma TRD OR
    Installed the RC Fab gussted spindles and new wheel bearings. Oh, and rotated the tires.
  5. Jul 27, 2023 at 5:53 PM
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
    Pretty sure it can go up to 125psi. Think I’ll be fine with mine, just might take longer correct?
  6. Jul 27, 2023 at 6:10 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Built a 15” extension harness for my speedometer gear so it would work with my crawl box and the longer AWD FJ case. Used some materials from an extra 1GR wire harness I have, so the wire gauge matches up and the colors are close. Still waiting on driveshafts but hopefully I’ll be driving this thing soon
    Ricardo13x, jackn7, DoulosXP and 7 others like this.
  7. Jul 27, 2023 at 9:57 PM
    ScrippsRanch67
    Bob
    Fiberglass shell
    Photos?
  8. Jul 28, 2023 at 3:18 AM
    elricfate
    Yep.
  9. Jul 28, 2023 at 9:23 AM
    gkomo
    gkomo Well-Known Member
    San Diego, CA
    2014 MGM AC SR5 4x4
    Gave her a wash this morning - she’s looking good:
    Unfortunately it’s finally happening, the roof clear coat is starting to go… the white spots in the top middle are new from the last wash I did not too long ago…
    Those other gray spots have been there for quite a while. Anything I can do to save it from getting worse? Have a professional detailer work with it? Its a bummer because i'm actually pretty good about washing/waxing/ceramic coating the entire truck. I guess the San Diego sun is too powerful - no option to park under cover/inside, however.
    wtp67, batacoma and DaleRS like this.
  10. Jul 28, 2023 at 9:28 AM
    99TacoDriver
    99TacoDriver Well-Known Member
    South Louisiana
    OME 885x/5100s/LR UCA/3 leaf AAL/275/70/17 Terra Trac X-Venture
    there may be a clear uv resistant vinyl that can protect it. mine looks like dog shit and im going to have to either repaint or just get a black vinyl to cover it. will most likely do the vinyl
    batacoma and gkomo[QUOTED] like this.
  11. Jul 28, 2023 at 11:33 AM
    TacoTuesday1
    SD CA
    I mean there’s always paint correction but that requires enough clear to work with. Or you can use cleaner wax, Iron-X, claybar, water spot remover, final non hard water rinse, etc where needed, then wax sealant and/or ceramic in whichever order
    if my truck looked that nice
    Before it gets worse
    I would wrap the roof in white vinyl. Then it’s already there if you end up putting a roof rack, and protecting one of the more vulnerable areas.
    gkomo[QUOTED] likes this.
  12. Jul 28, 2023 at 11:35 AM
    TegoTaco
    Ontario, Canada
    You can always wetsand it, use 2-3 cans of SPRAYMAX 2K clear, it might not come out perfect but you will hardly see it anyways.
  13. Jul 28, 2023 at 11:45 AM
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    Truck looks good. Is your truck an SR or SR5? I see it says SR5, and also has the SR pkg wheels and turn signal mirrors. Toyota could have added those exterior appointments to the SR5. Either way it's a nice looking truck.
  14. Jul 28, 2023 at 11:56 AM
    Tiedie
    Tiedie The Only Shantytown Resident.
    David
    WFOY
    Katzkin, Dobinsons full suspension. Redlinegoods console cover and door panel arm rests, Double USB charger in dash installed, Ballistic Jesters 16x8. BlackVue DR 590 Dash Cam
    Picked up from the frame repair shop before bad spots Stealership said twice nothing to worry about IMG_20230621_091644905~2.jpgIMG_20230621_092023312.jpg IMG_20230621_091820214.jpgthis is the passenger side where the A/C condenser drains onto the frame and travels back. Talked about many times on TW.
    What it looks like now after guy cleaned up all the questionable spots and applied woolwax IMG_20230728_114840468.jpg IMG_20230728_114740917.jpg IMG_20230728_114726808_HDR.jpg IMG_20230728_114704006_HDR.jpg IMG_20230728_114654189_HDR.jpg
    Maybe more pictures of the finish product to come. He told me to bring it back for touchups yearly but not necessary, that he does his every 3 years.
    Left the wife's Forester to get done today, pickup Tuesday.( Wife had knee replacement surgery this past Tuesday no rush).
    bob1008, jackn7 and fasteddieyj like this.
  15. Jul 28, 2023 at 11:56 AM
    Ginger-Vitis
    Ginger-Vitis Well-Known Member
    08 Tacoma 5spd
    I brought home an organ donor for my 2ed gen today. Couldn't find a 2kd so this will have to doPXL_20230728_012347586.jpg
  16. Jul 28, 2023 at 12:03 PM
    gkomo
    San Diego, CA
    2014 MGM AC SR5 4x4
    Good idea - would at least protect it from getting worse, but wouldn't cover up existing damage.
    As mentioned above, ya maybe a vinyl wrap would be the best bet to protect it from getting worse. I'm no paint expert so i don't know how much clear is left for someone to do a paint correction - still leaves the issue of it doing it again anyways. But thanks for the compliment!
    I definitely don't trust myself to do something like this, lol.
    Thank you - its actually just a 'SR'. To be honest, not sure why i put SR5 decals on the bedsides, maybe I didn't know at the time or bought some existing decals. Did it years ago and can't remember.
  17. Jul 28, 2023 at 12:26 PM
    robm7
    robm7 Well-Known Member
    2012 TRD OR
    71K trouble free miles.
    Washed and waxed the girl about three weeks ago. Today changed her oil and filter. Poured only 5 quarts of oil. Checked the level an hour later and she was good. What’s up with that?
  18. Jul 28, 2023 at 12:28 PM
    LongRedAndSpringy
    LongRedAndSpringy Active Member
    CA 805
    2006 Impulse Red Tacoma SR5 DCLB 4WD
    Icon Stage 1 Lift Kit 265/r70/17 KO2's 17"x9" -12/4.5" Method 312's
    Replaced spark plugs, ignition coils, gear oil, and coolant at 185k. Turns out the spark plugs were factory and in.. well, decent condition considering this was 17 years and that many miles. Replacement well overdue, and the truck runs a lot smoother now. At least I can be sure I'm running on all 6 cylinders now.
    jackn7 and robm7 like this.
  19. Jul 28, 2023 at 12:34 PM
    20somethingwidataco
    20somethingwidataco Yes, my avatar is a real car.
    Will
    Washington State
    2008 AC TRD SPORT M/T
    ACLB 6 SPEED: Suspension: Bilstein 6112s (3rd perch) (F) Taco Lean Spacer Bilstein 5160s (R) TSB Leaf Pack Wheelers Offroad 3 leaf progressive AAL Wheelers Superbump Front Duro Bump U bolt flip kit Duro Bump progressive bump stop 3rd gen TRD offroad sway bar Wheels and Tires: Summit Racing Wheel Dakars (Polished Silver) 285/70r/17 Goodyear Wrangler Duratrax (Load D) "Performance": AFE CAI with custom powdercoated white filter cover MagnaFlow Performance Series Exhaust URD Cam gears XTP Intake Manifold Spacer OTT Torque Tune Brakes: Stoptech Slotted Rotors Stoptech Sport Ultra Composite Brake Pads Wheelers offroad SS brakelines (Front) Interior: Kenwood DD headunit Oem Subaru Kicker Tweeters Alpine 6x9 (Front) & 6.5 (rear) (With Taco tunes speaker mounts) Alpine 500 watt amp Sound Deadening (Doors, Rear "wall", Roof) ODI Rouge Shift Knob Weather Tech Mats Painted/wrapped trim pieces Console Safe Console Vault Gridx Organizer Ram Phone Mount Meso Customs dual color map lights Meso Customs dual color dome light Wet Okole seat covers (Black) Wet Okole center console cover (Black) 1" Seat Raisers (Driver & Passenger) AJT Designs climate control and 4x4 knobs Back Up Camera Lighting: Retrofits (Mini H1's, RGB Halos, 5500k Bulbs)(Lenses wrapped in self healing PPF) Diode Dynamics SS3 Max SAE (Yellow) Diode Dynamics SS5 Pro (Yellow) Driving lights (ditch lights) Anytime fog mod Rigid Industries E series 32" Combo bar (spot/flood) Diode Dynamics XPR Reverse Lights Diode Dynamics XP80 turn signals LED brake, parking lights and license plate lights Armor: Apex All Pro sliders BPF steel skid plate Bigass Trailer Hitch Camping/Storage: Leer canopy LED interior lighting Sleeping platform (Storage underneath) Removable snowboard Yakima mounts Extra D rings in bed (6 total) Custom Powder coated white snow shovel with custom bedrail mounts Amazon special Traction Boards Hi Lift 48" Jack with custom Rail mounts to accommodate my sleeper set up Other: All pro Bed Stiffeners Relentless Fab tailgate panel TRD sport graphics (Turd Gen spec) Anti Sun glare hood scoop wrap (Satin Black) Custom FleeBay grille 4 Hella supertones ECGS needle bearing Many Patches BPF shackle mount (With smittybuilt shackle) Tinted windows (Front/Rear + Full canopy)(18%) Meso Customs gasshole AVS inchannel window visors Diff Breather Kit 2012-2015 Oem Turn signal/folding mirrors (w/ sequential signals) 2012-2015 Oem LED taillights Full Size (285/70r17) spare DIY Larger Engine Splash Guards DIY Vipercut TRD radiator cap
    You're tdi swapping the taco?
  20. Jul 28, 2023 at 2:20 PM
    Ginger-Vitis
    08 Tacoma 5spd
    Yes sir! My 2tr-fe is consuming tones of oil, I'm sure it's about due for a short block or some machine work. Decided to put that money into more torque instead.
    Ricardo13x, Hayden334, jackn7 and 2 others like this.
