  1. Jul 29, 2023 at 5:47 AM
    banditcamp
    banditcamp Well-Known Member
    daniel
    2015 Super White DCSB Off Road
    I don't think the 6 foot bed would have helped this from happening. A trailer hitch bed extender may have though.
  2. Jul 29, 2023 at 6:22 AM
    Dr3w
    Dr3w Well-Known Member
    Drew
    805
    2007 White DCSB Sport
    VLEDs LPX, really well built product https://www.vleds.com/lpx-13-red-white.html
    And for the shell, I used a paint scraper to carefully get between the old light and the mounting tape. Then used some goo gone to get rid of the residue and then polished and buffed the area
  3. Jul 29, 2023 at 6:46 AM
    mrproduxn
    mrproduxn Well-Known Member
    steve
    Retired DoD SE VA
    Tacomas 1987,2000,2008, 2016,2012,2008
    Retired/Hobbyist old as f***
    I carry 12' long metal bars, mostly 6061 aluminum, frequently in my long bed. This is why I always buy access cabs. I angle it as much as possible to minimize the overhang. I now put old rubber floor mats under the bed end and strap it down tight to the bed. I think this helps cushion the load. My path carries me over a bumpy road and a raised, fairly smooth, railroad crossing at 35-40 mph. Never caused any damage to my tailgate in 3 Tacos over 4.5 years. This does put nearly 7' of the load in my bed off the tailgate. Being metal is doesn't flex as much as lumber.20200120_122452.jpg
    dborrer[QUOTED] likes this.
  4. Jul 29, 2023 at 6:51 AM
    Tiedie
    Tiedie Well-Known Member
    David
    WFOY
    Katzkin, Dobinsons full suspension. Redlinegoods console cover and door panel arm rests, Double USB charger in dash installed, Ballistic Jesters 16x8. BlackVue DR 590 Dash Cam
    The only thing that might have helped not have this happen would have been to spread out over the width of tailgate. Don't beat yourself up too bad shit happens. If you want to replace I would look at just the metalshell thats whereit't bent. Here's that part # for around $400.00
    65701-04013
  5. Jul 29, 2023 at 7:00 AM
    Tiedie
    David
    WFOY
    Here ya go right around the corner from you.
    https://www.ebay.com/itm/234964965482?epid=672154564
  6. Jul 29, 2023 at 7:26 AM
    SomeGuy_GRM
    SomeGuy_GRM Well-Known Member
    2009 Tacoma SR5 TRD Off Road
    I think it was made by Raider, but there's no badging on it. Wedge design, it's not the canopy I would buy, but it came with the truck.
  7. Jul 29, 2023 at 7:56 AM
    elricfate
    elricfate Well-Known Member
    2009 Tacoma AC Silver Mica
    I mean, also tailgate reinforcement panel or tailgate reinforcement cap, or both. When I hauled 16 foot poly deck boards it was on a reinforced tailgate with a hitch bed extender, no issues.
    dborrer likes this.
  8. Jul 29, 2023 at 8:00 AM
    TacoTuesday1
    SD CA
    idk. My inner parts were bent underneath the plastic. They’re said to be weak. Outer skin dented. PDR shop fixed it for like $100. Installed a Relentless Fab tailgate reinforcement shortly after. Non ribbed, full wraparound, steel.
    dborrer and Tiedie[QUOTED] like this.
  9. Jul 29, 2023 at 11:36 AM
    ScrippsRanch67
    ScrippsRanch67 Well-Known Member
    Bob
    06 Tacoma Pre-Runner 2wd Quad Cab short bed
    Fiberglass shell
    Allied Gardens?
  10. Jul 29, 2023 at 1:52 PM
    bob1008
    bob1008 Active Member
    The woolwax™ Pro Gun normally operates at 70-90 psi. With the extension wands you may need to go to 110-120psi to push the coating thru that extra couple of feet. The gun is rated up to 175psi so it's never an issue.
    Generally speaking any compressor that's adequate for spray painting will work for undercoating. For instance, some of the really small compressors at Harbor Freight say right on the box "not adequate for spray painting".
    elricfate[QUOTED] and jpereira2 like this.
  11. Jul 29, 2023 at 1:57 PM
    jpereira2
    jpereira2 Well-Known Member
    Massachusetts
    2013 double cab trd off road
    Bilstein 6112 4th notch Bilstein 5160 rear Camburg ball joint UCAs Old man emu dakar leafs 265/75R16 Cooper ST Maxx Crux stereo a/v interface UltraGauge ARE fiberglass cap Wet okole seat covers Retro fit source Led fog lights Superbrightled pods in rear bumper Superbrightled light bar in grill Rock blokz mud flaps SOS Rock Sliders RCI Skid Plates (to be painted and mounted)
    Used the pro gun for a long time. Just picked up the supreme, can't wait to try it out.
    bob1008[QUOTED] likes this.
  12. Jul 29, 2023 at 2:02 PM
    bob1008
    You will really like it . It's an awesome gun. Especially when using it with the extension wands. The Pro Gun has been the standard of the industry for almost 20 years. And it works great. But because the canisters are plastic, we can't pressurize them. So you are relying only on the siphon tube. It does a great job, but can be challenging with the long extensions.
    The Supreme gun is a metal pressurized canister. It has a much greater velocity to push a coating thru the extensions. That gun come with a 36" 360degree wand. Plus other assorted extensions.
    jpereira2[QUOTED] likes this.
  13. Jul 29, 2023 at 2:17 PM
    TruKnight
    TruKnight Well-Known Member
    Tru
    Arkansas
    Autobot Mall Crawler
    read build thread
    wiretapped my turn signal mirrors directly into the daytime running lights
    works like you would expect. the orange tinge on the edge there is them working, its just washed out in the picture.
    I left a few paragraphs in my build thread on post #380 with my thoughts about wiring this mod if anyone finds this on a search later and needs help for a 2nd gen cause most of the threads I saw were for 3rd gens and/or not very helpful.
    BricktopNemesis and tacomakid96 like this.
  14. Jul 29, 2023 at 2:23 PM
    771Doug
    771Doug Well-Known Member
    Virginia Beach, VA
    '08 V6 Pre-Runner
    Ran some junk over to the landfill, today. Of course, I put a nice, deep 6" scratch in the tailgate trying to load a
    big charcoal grill by myself.
    Grrrrr.
    I see the future... me sweating my ass off rubbing out said scratch, tomorrow.
  15. Jul 29, 2023 at 3:03 PM
    Tacofuze!
    Tacofuze! Member
    Denver, CO
    2015 Tacoma Double Cab TRD OR 6 Speed MT
    Gave it a wash and wax - first time using Chemical Guys products. I like the results!
    Also replaced my headlights with some OEM TRD Pro headlights, installed Diode Dynamics fog lights, and swapped the grille.
    Waiting on clearcoat to arrive before paint matching the shroud, but I couldn't wait to see it with the new grille and I had it off anyway...
  16. Jul 29, 2023 at 4:09 PM
    elricfate
    I generally just crank the regulator to 85 psi and I've never had an issue with the wands being too hard to push. But it's good to know just how high I can get the pressure up to before it fails :D
  17. Jul 29, 2023 at 4:43 PM
    LtDan12a
    LtDan12a Well-Known Member
    Dan
    2015 DCSB
    a few things, and some vinyl....
    I scored a deal on some 17" Fifteen52's and tires. The color wasn't my first choice, but if I don't like it after a couple weeks, it's nothing a can of spray paint can't fix!
    srspicer, Taco401, powder1134 and 4 others like this.
  18. Jul 29, 2023 at 5:01 PM
    hotwheelsguy
    hotwheelsguy Member
    2013 5-Lug Tacoma Regular Cab MT.
    Replaced shift knob, had window tint applied, installed tonneau cover & installed a bed extender.
    Those wheels look awesome, too bad they don't make them in the 5-lugger pattern.
    LtDan12a[QUOTED] likes this.
  19. Jul 29, 2023 at 5:04 PM
    BricktopNemesis
    BricktopNemesis Member
    2013 Reg Cab 4x4 auto Tacoma
    Coming along nicely imo.
  20. Jul 29, 2023 at 5:12 PM
    LtDan12a
    Dan
    2015 DCSB
    Reminds me of a stomper from the 80's... I like it!
