  1. Jul 30, 2023 at 6:46 PM
    TacoTuesday1
    SD CA
    Saw this want to get extra valve covers to paint but nope too far in Lancaster CA, FB marketplace IMG_5625.jpg
  2. Jul 30, 2023 at 6:52 PM
    TacoTuesday1
    SD CA
    Pressure washed the engine bay and put this dressing
    It’s good but has a lot of fumes
    If there’s a better one lmk
    still need to wipe down with MF hopefully make it matte
    If not I’ll get more cans buddys want me to do theirsIMG_5626.jpgIMG_5599.jpg
  3. Jul 30, 2023 at 6:56 PM
    tacomakid96
    tacomakid96 Lions Not Sheep
    Phil
    Out n' about
    1996 Tacoma / 2000 4.7 Tundra TRD
    Jack up both your tires on the front and put something long like a jack handle or pry bar to pry under them. Press the tire up and see if you have movement/clicking from your ball joints as you move the tire up and down.
    Climberclimb likes this.
  4. Jul 30, 2023 at 7:07 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    I need to for sure, I tried just bouncing on the bumper but I didn't hear it.
    When 1st gens fail they fail, these don't haha
    tacomakid96[QUOTED] likes this.
  5. Jul 30, 2023 at 7:21 PM
    tacomakid96
    Phil
    Out n' about
    Yeah I never worried about the ball joints in my 05 but my 96 worry me all the time.
  6. Jul 30, 2023 at 7:31 PM
    JKO1998
    Utah
    I want to replace the bushings and balljoints on my 07 but I want a set of arms I can replace everything in and just swap.
    might do ball joints this week with our hunting season starting and then do everything right in the next couple of weeks.
  7. Jul 30, 2023 at 7:37 PM
    TacoTuesday1
    SD CA
    how do you like the Luno?
    I placed 4” foam diagonal and cut
    To fit me and gear in the spaces
    but it’s annoying that it doesn’t have a fabric cover
    this is what I ordered. I’d rather find all black and return though.
    If I face silver outside it’s obvious. Even with tint still visible.
    Silver facing inwards looks tacky
    don’t want to go through the hassle of putting fabric or paint and potential offgas sing of adhesive and paint
    So far I can’t find both sides black. I’m gonna look up what temp regular paint can handle and see if there’s anything flexible to crack less
    Like rubberized coating, plastidip, flex seal
    ideally in a can to roll or brush on. So I can put a thick coat or two carefully, hit the surface well, and not deal with overspray and fumes that happens with cans.
    Shaggs[QUOTED] likes this.
  8. Jul 30, 2023 at 8:05 PM
    BricktopNemesis
    BricktopNemesis Member
    2013 Reg Cab 4x4 auto Tacoma
    Night and day difference on overall ride quality?
  9. Jul 30, 2023 at 8:26 PM
    jasonl275
    jasonl275 Active Member
    '11 DCSB TRD OR 4X4 6MT
    Supercharger installed, but had to relocate the Controller Box to passenger side for ease of access to the Intercooler Reservoir
    LtDan12a, gkomo, drewnali and 6 others like this.
  10. Jul 30, 2023 at 8:57 PM
    TruKnight
    TruKnight Well-Known Member
    Tru
    Arkansas
    Autobot Mall Crawler
    read build thread
    2/10 difficulty
    its 2 screws and 4 push tab things to remove it from your truck, then on the back of the grill you have to remove it from the surround, its about a dozen screws and a dozen tabs to unhook, the best way to do the tabs is to have 2 pairs of needle pliers and pull both ends towards you and they will unsnap alot easier once the first one is done. you will also have to remove and transfer the rubber seal off your old grill, it comes off with another dozen plastic tabs, just squeeze the bottom with the pliers and pull up then press them into your new grill. same with the tabs, just press the new grill on and it all snaps in then replace the screws. it all went in very easy with no issues, but thats one reason I opted for the oem grill because I knew it would be hand in glove fitment, if you get the cheaper aftermarket it may not be exact in some spots, at least thats my usual experience with aftermarket body parts. hope that helps!
    Piperty[QUOTED] likes this.
  11. Jul 30, 2023 at 9:43 PM
    ScrippsRanch67
    ScrippsRanch67 Well-Known Member
    Bob
    06 Tacoma Pre-Runner 2wd Quad Cab short bed
    Fiberglass shell
    I fried my alternator by power washing and not protecting it or drying it out.
  12. Jul 30, 2023 at 11:06 PM
    blairrad
    blairrad Yoter
    Missouri
    I love them! No issues at all. Have done some light off-roading and still no rubbing. Time will still tell, but I’m happy.
  13. Jul 31, 2023 at 12:23 AM
    TacoTuesday1
    SD CA
    I hope not
    so far so good. Time will tell. Miles are high anyway.
    Pro shop policy is engines do get washed when needed, though avoiding direct spraying at alternator.
    Drying I think is either gonna be sitting parked to drip and evaporate
    or driving with engine heat to help
    Been over a day. Even without wash, alternator pulley probably wearing, brushes, etc.
  14. Jul 31, 2023 at 1:50 AM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
  15. Jul 31, 2023 at 2:57 AM
    TacoTuesday1
    SD CA
    I have basically the same setup.
    the warfab comes with 3rd gen tow plug holder so it required converting.
    that being said DD told me to get a different model C1. I think 4runner 5G.
    It plugged right in.
    DD tapped off right tail.
    Planning to tap left tail for shell.
    Manual toggle on switch doesn’t actually toggle them on so I need to figure that out. It only puts the tails in reverse themselves which aren’t bright.
    only things I would change:
    -if I add a swingout, it will block corner pocket(s) necessitating the need to switch to closer center mounted 2” like you have
    -my center is C1R strobe and brake which I like better and came out after. I’d rather have R/brake on the sides too but would require switching. Which if I go 2” later I don’t think they offer that in ‘R’ at least listed under Tacoma. Yet…
    TegoTaco[QUOTED] likes this.
  16. Jul 31, 2023 at 7:13 AM
    TacoTuesday1
    SD CA
  17. Jul 31, 2023 at 7:21 AM
    mistrchow
    mistrchow Well-Known Member
    Somewhere in Nature.
    11 SWB Taco TRD OR
    Little this, Little that.
    Caliraised molle
    Maximumdarkside and 4WDTrout like this.
  18. Jul 31, 2023 at 8:29 AM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    Looks REAL GOOD! We have made a few C1R pnp harnesses for the 2nd Gen Tacos, but it is always handy to be able to do it yourself!
  19. Jul 31, 2023 at 9:07 AM
    JdevTac
    JdevTac Well-Known Member
    Josh
    MD/GA
    2nd gen
    I got around to washing it. Lots of bugs from the recent long road trip.
    rtilton12, TomTwo, dpele and 11 others like this.
  20. Jul 31, 2023 at 11:20 AM
    RickE24
    RickE24 Well-Known Member
    OC/LA
    2006 Tacoma double cab TRD Sport, speedway blue
    I did an oil change, changed out front brake pads, washed and vacuumed my 2006
