  1. Aug 2, 2023 at 3:29 PM
    ScrippsRanch67
    ScrippsRanch67 Well-Known Member
    Bob
    06 Tacoma Pre-Runner 2wd Quad Cab short bed
    Fiberglass shell
    Narcan?
  2. Aug 2, 2023 at 3:30 PM
    ScrippsRanch67
    Bob
    Fiberglass shell
    You can carry in your State? Loaded, unloaded?
    20somethingwidataco likes this.
  3. Aug 2, 2023 at 3:32 PM
    TacoTuesday1
    SD CA
    I mean if you have it it’s your call on what discretion you use if any
    Per ER’s, who have to use it
    They do, send people out the door, who then go repeat.
    most states can. LE can. Or you get a permit.
  4. Aug 2, 2023 at 3:32 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Never know when you're gonna find someone's ODing
  5. Aug 2, 2023 at 3:36 PM
    TacoTuesday1
    SD CA
    exactly.
    You could be at or walking by a party. House in the neighborhood. Place in the city. Some kid takes something laced unconscious.
    Maybe you know someone dealing with something like grief of a loss. Takes something they don’t know what’s in it to help fall asleep. Obviously not advisable but something that happens. An otherwise good person. Passes out.
    There you go. You have free shit in your truck that at least solves the problem for that period of time. It can be replaced for free.
    There’s many different scenarios.
  6. Aug 2, 2023 at 3:38 PM
    JKO1998
    Utah
    I wish they made some similar to stop a hangover
    dpele and Hayden334 like this.
  7. Aug 2, 2023 at 4:04 PM
    Trouble_The_Tacoma
    Trouble_The_Tacoma Well-Known Member
    Conrad
    Finally got around to lifting the truck. Before and after pictures attached.
    Ironman foam cell pros with powder coated springs. Couldn’t do the neon green. SPC UCAs
    2.75” front and about 3.5” rear
  8. Aug 2, 2023 at 4:18 PM
    TacoTuesday1
    SD CA
    why does the turd gen community praise it
  9. Aug 2, 2023 at 4:24 PM
    mrproduxn
    mrproduxn Well-Known Member
    steve
    Retired DoD SE VA
    Tacomas 1987,2000,2008, 2016,2012,2008
    Retired/Hobbyist old as f***
    I just happened to have a bad one. One of the first builds of the first year of a new gen. Thought everything was fixed after 6-8 months. Dumped some mod money in it. Paid it off in 27 months. Dumped more mod money in it. Then got transmission flashed again. Each month drove it less and less frequently. Then another recall. Then reading horror stories of timing chain cover leaks and an occasional rear main seal failure. Then another recall. Next thing is I hit 5 years and oh shit the warranty is gone. Then paranoid and the continuous thought of should I sell it or should I keep it or how far can I trust it. Then market values started climbing. Then SOLD. Then yet another recall letter. Went back to 2nd gens. No more paranoid thoughts. No more recall letters. Finally PEACE.
    Charlie Bravo likes this.
  10. Aug 2, 2023 at 4:27 PM
    Charlie Bravo
    Charlie Bravo Well-Known Member
    Charlie
    Coeur d'Alene, Idaho
    2009 Red Tacoma Access Cab 4wd 2.7MT
    RedLine Tuning hood QuickLIFT, Gen3 alloy 16x7J, All Pro Off-road bed stiffeners & IFS skid plate
    A fishery biologist I worked with had been a Navy plane captain, and he told us that a pilot had told his ground crew that breathing oxygen will cure a hangover.
    He also warned that it's not a long term solution; the hangover will return when that dosage fades...
    Tiedie likes this.
  11. Aug 2, 2023 at 4:29 PM
    JKO1998
    Utah
    Well I guess that's something
  12. Aug 2, 2023 at 4:37 PM
    mrproduxn
    steve
    Retired DoD SE VA
    I believe most bugs were worked out starting in late 2018. What they never fixed is the slug 3.5 and the wonky automatic damnsmission. Now everyone just throws tune money in them so they run almost as good as the 2nd gen 4.0. With all of the issues I had, with only 25k miles on it, I felt better just letting it go and going back to the reliable 4.0. I always said there is a good reason the 4runner still used the 4.0. It is a better engine. The 3.5 in other vehicles was not detuned like the 3rd gen Taco. That is plainly evident by the base hp of those other 3.5 models. It was awesome at saving gas but, as factory (de)tuned and engineered, in stock trim it could hardly get out of it's own way. I didn't spend good money on a new Tacoma that must need a tune for it to run normal. I blame myself, partially, for not being more aggressive in my initial test drive. Having owned other gen's before I just assumed the power would be there when I needed it. I think my pre-gen 1987 22R had more get up and go than the 3.5.
  13. Aug 2, 2023 at 5:51 PM
    ScrippsRanch67
    Bob
    Fiberglass shell
    No Country for Old Men
    Tiedie likes this.
  14. Aug 2, 2023 at 6:23 PM
    dborrer
    dborrer Well-Known Member
    Mr. Dan
    St. Augustine, FL
    2006 Tacoma TRD Sport 4x MT
    2018 new Frame (thank you Rust!), FJ T-case swap. SPC(LR) UCAs, Bilstein 5100s front - rear, OME 883 at 0, HeadStrongOffRoad 3 leaf progressive AAL, MESO custom 2nd gen (Red/White) LED dome & Ultimate Maps, Spyder Halo Projector w LEDs (which SUCK), Spyder LED tails
  15. Aug 2, 2023 at 6:29 PM
    Taco Wil
    Taco Wil Member
    2015 Prerunner SR5 Double cab 5ft bed
    I installed ironman 4x4 stage 2 lift tossed the old block lift. new roof racks coming soon:).
  16. Aug 2, 2023 at 6:39 PM
    Tiedie
    Tiedie The Only Shantytown Resident.
    David
    WFOY
    Katzkin, Dobinsons full suspension. Redlinegoods console cover and door panel arm rests, Double USB charger in dash installed, Ballistic Jesters 16x8. BlackVue DR 590 Dash Cam
    Me likey! Had my driver's side set at 2.75 and the passenger side set to 2.5 for the taco lean and got 3" in rear with Dobinsons suspension and SPC UCA.
  17. Aug 2, 2023 at 6:44 PM
    Tiedie
    David
    WFOY
    Nitrox is your friend. Divers trick helps to get those dives in the morning. Then back to driving again for the rest of the day.:thumbsup::D:yay:
  18. Aug 2, 2023 at 6:58 PM
    Flo_TRD07
    Flo_TRD07 Well-Known Member
    Ben
    2007 Tacoma TRD Sport Prerunner
    Truck things
    When I was Active Duty AF, I was a Flight Engineer on the C-5. I would occasionally re-run my oxygen mask pre-flight because I "messed it up" just to get another minute and a half or so of 100% oxygen when I had partied a little too hard the night prior.
    Charlie Bravo[QUOTED] likes this.
  19. Aug 2, 2023 at 7:24 PM
    Flo_TRD07
    Ben
    Truck things
    Starting last night and finishing up today, I installed a Flowmaster Super 40 and a "CAI" (we all know its just a short ram intake). I know I know, all of y'all are gonna blast me with "It's a v6 they don't sound good with any type of muffler and a ram intake robs power". Well... I did the research and watched countless videos to pick the muffler I did (my wife even likes it). And for the intake - it's a truck. It was never meant to be fast. I like the way it makes my truck sound WOT and it puts a little smile on my face. If I wanted fast I wouldnt have bought a truck in the first place. All in all for $300 bucks I'm quite happy with what I got out of it.
    I did notice one or two things. 1st being my trucks temp is running about 2-4 degrees warmer than usual. Albeit today was a warm day so I will have to see if it makes a difference on a cooler day, but I think my truck might be running a bit warmer due to not getting as cool of air from the stock intake. I can live with that. Number 2. I drove the route to where I work as a test of what mpg I get. Normally I get to work showing an Avg of about 13.5-13.7. Today after the mods, it was 17.1. That's with the truck warm on both occasions.
    The other benefit from installing these parts is that I got a new tool out of it! I was trying to use a hacksaw to cut the exhaust pipe. My wife ended up coming into the garage and told me she couldn't take the noise any-more and to go buy a sawzall. So I did:sawzall:
  20. Aug 2, 2023 at 7:26 PM
    jon_elc
    jon_elc Well-Known Member
    NorCal
    2011 SR5 4x4 Timberland Mica Snugtop Rebel
    245-70R-17 Revo3 Cut mudflaps 4.5" F / 1.5" R
    new shoes for the baby
    RickE24 and tinker_troy like this.
