  1. Sep 7, 2023 at 6:12 AM
    ridefreak
    ridefreak Well-Known Member
    NM
    2006 DCSB TRD
    minor tweaks
    Yes but it'll pass through a circuit breaker/cutoff switch located next to the battery like many of the others do.
  2. Sep 7, 2023 at 6:21 AM
    Truckdogipa2
    Truckdogipa2 Well-Known Member
    Mark
    2011 Tacoma trd sport long bed
    New frame, Upper control arms, roof rack , method wheels fallen tires duel battery
    Excuse me but I just farted . Just thought I should let you all know it was me
    LG888 likes this.
  3. Sep 7, 2023 at 8:05 AM
    Tiedie
    Tiedie Well-Known Member
    David
    WFOY
    Katzkin, Dobinsons full suspension. Redlinegoods console cover and door panel arm rests, Double USB charger in dash installed, Ballistic Jesters 16x8. BlackVue DR 590 Dash Cam
    Good thought it was the dog.
  4. Sep 7, 2023 at 9:31 AM
    srspicer
    srspicer Paint it black
    Lower Bucks PA.
    05' Black DBLC short bed
    Painting things black
    :thumbsup:Best mod I ever did to my ‘05 Prerunner. The second best was installing cruise control.
  5. Sep 7, 2023 at 10:40 AM
    Strictlytoyz
    Strictlytoyz Well-Known Member
    Charles
    HA\/\/AII
    07 Shitbox
    Decided to finally strap the front to prevent my upper uniball from being the limiting droop factor and to stop binding cv's. I do however need about a 2" shorter strap but an 11" was all I had and was able to use it to get the upper clevis mounted where I needed.
    Corny Taco, Tttacodan, dpele and 3 others like this.
  6. Sep 7, 2023 at 11:17 AM
    hellvetica
    hellvetica Member
    Los Angeles
    2020 TRD OR
    Oil change on my 08. First time using Royal Purple as well.
  7. Sep 7, 2023 at 11:32 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
  8. Sep 7, 2023 at 11:48 AM
    TacoTuesday1
    SD CA
  9. Sep 7, 2023 at 11:52 AM
    El Tano
    El Tano i am the one who knocks
    Pasadena. CA
    10 Tacoma TRD sport
    Corvette homelink FRONT: 5100 Blinstein set at 0 Procomp 3" leveling kit Allpro UCA’s. REAR: Icon Multi Rate RXT Leaf Pack 5100 Blinstein. 17x9 kMC wheels 0 BS 285/70 17 Wildpeak A/T4W C range Amp research steps. and a bunch of TSB's
    I'll tell you what no to do. Do NOT do it, lol...super tedious process, I tried again and failed again. I'm out.
  10. Sep 7, 2023 at 11:55 AM
    El Tano
    Pasadena. CA
    10 Tacoma TRD sport
    Second attempt at this.. Thread keeps twist every pass. Not sure what I'm doing wrong but it took me 1 hour to do 3 inches... Respect for those that did it..
    IMG_0517.jpg 71580452633__0F91539E-228C-4568-8DFE-4F3C64512D7B.jpg IMG_0519.jpg Second attempt at this.. Thread keeps twist every pass. Not sure what I'm doing wrong but it took me 1 hour to do 3 inches...
    East detailing steering wheel cover for sale :boink:.
    dborrer and Tiedie like this.
  11. Sep 7, 2023 at 11:58 AM
    EMR
    EMR Well-Known Member
    So Cal.
    2012 Tx Pro
    This awesome! Is there a 2nd Gen write up for this? I can only find 3rd Gen.
  12. Sep 7, 2023 at 12:11 PM
    JMcFly
    JMcFly Well-Known Member
    Central FL
    2012 Tacoma SR5 4x4
    what did you need the air compressor for?
  13. Sep 7, 2023 at 12:15 PM
    BigCountry762x39
    BigCountry762x39 Well-Known Member
    TL
    PNW, Oregon!
    2009 Tacoma, with the cool white paint peel
    Arb Deluxe bull bar Front Bumper Ironman4x4 12k winch synth line AFE Intake OME 2.75in Dakar Leaf springs (R) Fox 2.0 bypass shocks (R) Bilstein 6112 (F) 33's on KMC wheels off road lighting comfort mods Redrock HD roof rack Retevis rt95 Radio Slotted Rotors and HD pads
  14. Sep 7, 2023 at 1:52 PM
    WiscoTaco4x4
    WiscoTaco4x4 Well-Known Member
    Brady
    2015 SR5 ACLB 4x4
    srspicer likes this.
  15. Sep 7, 2023 at 1:57 PM
    Peeing on jeeps
    Peeing on jeeps That Yankee Rebel
    Dennis
    West of the Chippewa River
    Not your Mall Crawler
  16. Sep 7, 2023 at 2:18 PM
    tacokarl
    tacokarl Big Blue
    Karl
    Connecticut
    2008 Pre-Runner SR5 DCLB 1GR-FE
    Just did this 2 weeks ago. Best advice I can give you is don't use too much thread at once, I measured each section and then doubled that measurement for the amount of thread needed. Also I did not tie a knot in the thread at the needle, just passed the thread through the eye and left a tail of 3 or 4 inches. If it starts to get crazy on you and twist up you can pinch the thread tightly between two fingers and pull along the length of the thread, this will help get any twists out that have accumulated. Hope this helps man, It takes patience for sure. I had to walk away twice and take a break, but it's worth it if you see it through!
    dborrer, road2cycle, JKU3000 and 3 others like this.
  17. Sep 7, 2023 at 6:55 PM
    lesliechow91
    lesliechow91 Well-Known Member
    Noel
    Orange county
    2014 White DCSB TRD OR 4x4
    Bilstein 8112/8100, 295/75/16
    :rolleyes:Pulled the trigger on a few things:spending:
    -Solid motor mounts
    -XTP intake manifold spacer
    -URD cam gears
    -Archive shock relocation
    -12 inch bilstein 8100 bypasses
    - JD fab lower arm pivots
  18. Sep 7, 2023 at 7:07 PM
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    '15 DCSB TRD Sport 4wd super white (sold) '13 access cab SR5 4wd
    piddly stuff
    You’ll like the Archive relocation set. I’ve worked installing a couple they’re nice sets
    lesliechow91[QUOTED] likes this.
  19. Sep 8, 2023 at 6:45 AM
    ridefreak
    NM
    2006 DCSB TRD
    minor tweaks
    Someone stole mine in a parking lot, I didn't notice it right away not that it would have mattered. I replaced the mat and covered the bed with a tonneau cover.
    ACEkraut likes this.
  20. Sep 8, 2023 at 6:51 AM
    ACEkraut
    ACEkraut Well-Known Member
    Aaron
    Durham, Maine
    2014 DCSB TRD Off Road
    I drilled two holes in mine and took out the bed bolts and reinstalled them through the bed mat. No one will steal the bed mat without taking out the bolts or cutting the bed mat. Plus the added benefit is that the mat does not slide anywhere no matter what I push or pull on it.
