  1. Sep 22, 2023 at 8:16 AM
    Mods2Travel
    Mods2Travel Well-Known Member
    Daniel
    Fort Worth, TX
    2015 DCLB 4x4 SR5
    Level 8 MK6, 16x8, 6x5.5, +0 Offset Rims 285/75/16 (33") BFG KO2 tires 4.56 Gears from ECGS DIY bed/drawer slideout Bed Mounted Deep Cycle Battery/Fuse Box/Inverter/Isolator Yellow Wire Mod Rear Diff Breather Mod DIY Roof Rack Leer 180 Shell Bilstein 6112, Circlip #4 Bilstein B8 5160 Remote Reservoir Firestone Ride Rite 2407 Rear Suspension Airbags DayStar Cradles Camper Shell Radiator Fans for sleeping in warmer climates
    If you still can't get the smell out, look into an ozone machine. You can buy or rent them. I have a small one from Amazon that i've used in a few cars and rooms in houses that have smoke and pet smells and it works miracles. Just make sure to read the instructions. You just can't go into the area while it's running since it's not breathable, and then give it a couple hours to dissipate.
    jackn7 likes this.
  2. Sep 22, 2023 at 8:45 AM
    TimberTiger
    TimberTiger Get Western! ... ig @tcave87
    Tanner
    Arlington, Wa
    2014 DCSB Trd off road , 2002 Ext Cab Trd
    2014 DCSB: nitro 4.30 gears, Eaton/Harrop front locker, Bilstein 6112's w/ 650#, Camburg ball joint UCA's, Marlin cam tab gussets, Wheelers superbumps, Deaver U402 stage 2 leaves, bilstein b110's, u bolt flip, Archive hammer hangers, ADV weld co hybrid sliders, ADV weld co bed rack or Leer 180 w/ windoors, full RCI skids, SCS stealth 6, 35x10.5 kenda RT, ATH fab HC rear bumper, US offroad stealth front winch bumper, Smittybuilt x20 10k winch, ARB simpson III rtt, plenty of dents and scratches Now Sold 2002 TRD ext cab: 06 TRD Tundra coils, tundra 5100s, wheelers HD 3 leaf AAL, rear 5100s, ARB front bumper, SkidRow front skid, Leer commercial cap with windoors, 285/75r16 Kelly Safari TSR
    Do you have the part number for the lower seat fabric?
  3. Sep 22, 2023 at 10:50 AM
    99TacoDriver
    99TacoDriver Well-Known Member
    South Louisiana
    OME 885x/5100s/LR UCA/3 leaf AAL/275/70/17 Terra Trac X-Venture
    Anyone have luck removing the vinyl when it’s this bad? Method of removal?
  4. Sep 22, 2023 at 11:22 AM
    Gallowbraid
    Gallowbraid Known Problem
    Heat gun or hair dryer to loosen, peel it off and use one of these in a drill to get rid of the adhesive:
  5. Sep 22, 2023 at 11:34 AM
    20somethingwidataco
    20somethingwidataco Yes, my avatar is a real car.
    Will
    Washington State
    2008 AC TRD SPORT M/T
    ACLB 6 SPEED: Suspension: Bilstein 6112s (3rd perch) (F) Taco Lean Spacer Bilstein 5160s (R) TSB Leaf Pack Wheelers Offroad 3 leaf progressive AAL Wheelers Superbump Front Duro Bump U bolt flip kit Duro Bump progressive bump stop 3rd gen TRD offroad sway bar Wheels and Tires: Summit Racing Wheel Dakars (Polished Silver) 285/70r/17 Goodyear Wrangler Duratrax (Load D) "Performance": AFE CAI with custom powdercoated white filter cover MagnaFlow Performance Series Exhaust URD Cam gears XTP Intake Manifold Spacer OTT Torque Tune Brakes: Stoptech Slotted Rotors Stoptech Sport Ultra Composite Brake Pads Wheelers offroad SS brakelines (Front) Interior: Kenwood DD headunit Oem Subaru Kicker Tweeters Alpine 6x9 (Front) & 6.5 (rear) (With Taco tunes speaker mounts) Alpine 500 watt amp Sound Deadening (Doors, Rear "wall", Roof) ODI Rouge Shift Knob Weather Tech Mats Painted/wrapped trim pieces Console Safe Console Vault Gridx Organizer Ram Phone Mount Meso Customs dual color map lights Meso Customs dual color dome light Wet Okole seat covers (Black) Wet Okole center console cover (Black) 1" Seat Raisers (Driver & Passenger) AJT Designs climate control and 4x4 knobs Back Up Camera Lighting: Retrofits (Mini H1's, RGB Halos, 5500k Bulbs)(Lenses wrapped in self healing PPF) Diode Dynamics SS3 Max SAE (Yellow) Diode Dynamics SS5 Pro (Yellow) Driving lights (ditch lights) Anytime fog mod Rigid Industries E series 32" Combo bar (spot/flood) Diode Dynamics XPR Reverse Lights Diode Dynamics XP80 turn signals LED brake, parking lights and license plate lights Armor: Apex All Pro sliders BPF steel skid plate Bigass Trailer Hitch Camping/Storage: Leer canopy LED interior lighting Sleeping platform (Storage underneath) Removable snowboard Yakima mounts Extra D rings in bed (6 total) Custom Powder coated white snow shovel with custom bedrail mounts Amazon special Traction Boards Hi Lift 48" Jack with custom Rail mounts to accommodate my sleeper set up Other: All pro Bed Stiffeners Relentless Fab tailgate panel TRD sport graphics (Turd Gen spec) Anti Sun glare hood scoop wrap (Satin Black) Custom FleeBay grille 4 Hella supertones ECGS needle bearing Many Patches BPF shackle mount (With smittybuilt shackle) Tinted windows (Front/Rear + Full canopy)(18%) Meso Customs gasshole AVS inchannel window visors Diff Breather Kit 2012-2015 Oem Turn signal/folding mirrors (w/ sequential signals) 2012-2015 Oem LED taillights Full Size (285/70r17) spare DIY Larger Engine Splash Guards DIY Vipercut TRD radiator cap
    Took mine and had it redone professionally. A lot of people use steam to do it.
    99TacoDriver[QUOTED] likes this.
  6. Sep 22, 2023 at 11:54 AM
    99TacoDriver
    South Louisiana
    That won’t burn through the paint?
  7. Sep 22, 2023 at 12:06 PM
    99TacoDriver
    South Louisiana
    I saw a pretty genius trick for tint removal the other day that I’m wondering if it’ll work for this as well
    guy cut up a black trash bag and sprayed the tint he wanted to remove with water then placed the trash bag over the tint and parked it in the sun for a little while. Tint came off with all the adhesive with no problem.
  8. Sep 22, 2023 at 12:35 PM
    Gallowbraid
    It's a very soft rubber, so it shouldn't. Use the drill at a low speed with light pressure and it takes the adhesive off without doing any damage:
  9. Sep 22, 2023 at 1:53 PM
    jdg
    jdg Well-Known Member
    David
    Texas Panhandle
    2015 Tacoma SR5, V6, automatic, 4x4, extended cab
    All the time!!!
    Well I got my “Ark” fender well covers put on today, they are a lot thicker, and nicer than the OEM ones that’s for sure!IMG_3243.jpgIMG_3242.jpg
    RickE24, Dtoy, lynyrd3 and 8 others like this.
  10. Sep 22, 2023 at 2:41 PM
    JAGCanada
    JAGCanada Well-Known Member
    Canada
    2010 TRD Sport V6 Auto Double Cab MGM
    Finished restoration, including modification to allow installation of two Diode Dynamics SSC2. Went with a flat black wrinkle powder coat.
    RickE24, dpele, My2009taco and 6 others like this.
  11. Sep 22, 2023 at 2:59 PM
    PNW15
    PNW15 Well-Known Member
    2015 Tacoma DC LB SR5
    What are your favorite threads on this topic? I feel like I've seen too many!
  12. Sep 22, 2023 at 4:35 PM
    jpereira2
    jpereira2 Well-Known Member
    Massachusetts
    2013 double cab trd off road
    Bilstein 6112 4th notch Bilstein 5160 rear Camburg ball joint UCAs Old man emu dakar leafs 265/75R16 Cooper ST Maxx Crux stereo a/v interface UltraGauge ARE fiberglass cap Wet okole seat covers Retro fit source Led fog lights Superbrightled pods in rear bumper Superbrightled light bar in grill Rock blokz mud flaps SOS Rock Sliders RCI Skid Plates (to be painted and mounted)
    What bumper is that?
  13. Sep 22, 2023 at 6:07 PM
    EMR
    EMR Well-Known Member
    So Cal.
    2012 Tx Pro
    Not sure why I waited so long to buy this thing. 10 minute install too!
  14. Sep 22, 2023 at 7:40 PM
    TJRTACOMA
    TJRTACOMA Well-Known Member
    Tony
    Rialto, CA
    07 Speedway Blue Tacoma TRD Sport
    Billet Grille, Pop N Lock
    Probably the official 4runner side view mirror swap. But yes, theirs a lot of threads on this lol
    PNW15[QUOTED] likes this.
  15. Sep 23, 2023 at 3:48 AM
    Tiedie
    Tiedie The Only Shantytown Resident.
    David
    WFOY
    Katzkin, Dobinsons full suspension. Redlinegoods console cover and door panel arm rests, Double USB charger in dash installed, Ballistic Jesters 16x8. BlackVue DR 590 Dash Cam
    Morning everyone have a great and safe weekend.
  16. Sep 23, 2023 at 3:54 AM
    POOLGUY
    POOLGUY Well-Known Member
    JEFF
    ALABAMA
    2008 TRD Sport 6sp, 2015 TRD Offroad 6sp
    Dobinsons suspension
    :hattip:
  17. Sep 23, 2023 at 4:24 AM
    lynyrd3
    Bill
    East Central Upstate NY
    Deep cleaned the interior and did some rust proofing . Also lubed the uni-balls .
    dpele, lo2hi, 2WD and 4 others like this.
  18. Sep 23, 2023 at 4:24 AM
    otherphone
    otherphone Well-Known Member
    MA
    09 tacoma sport
    OME2.5lift w/medium leafs
    Where u get it? It bolts in? That's mint t
  19. Sep 23, 2023 at 4:27 AM
    lynyrd3
    Bill
    Oh I like that :thumbsup:
    TegoTaco[QUOTED] likes this.
  20. Sep 23, 2023 at 4:29 AM
    lynyrd3
    Bill
    Recent Battery clean up and repainted the bracket
