  1. Sep 23, 2023 at 5:40 AM
    wannabemtnbiker
    wannabemtnbiker Well-Known Member
    Derrick
    Georgetown Tx
    2008 White Tacoma Prerunner
    Just took a guess and changed out the front drivers side bearing assembly.
    Been experiencing a constant humm while the truck was moving.
    It definitely was that hub going bad.
    Got the assembly at O'Reilly for $170 and watched the shortest and most detail how-to vid from "FixItPhillip"
    https://youtu.be/BCP3wxUs-Vs?si=wHmM0Spwjzv-pY0p
    Had it changed out in under 2 hours.
    Jack the front end up at the center rubber post, that I had read about on a thread here.
    lynyrd3, dpele, drewnali and 3 others like this.
  2. Sep 23, 2023 at 6:21 AM
    ridefreak
    ridefreak Well-Known Member
    NM
    2006 DCSB TRD
    minor tweaks
    Nice job! Were you able to feel any play in the bad bearing prior to swapping the bearing out?
  3. Sep 23, 2023 at 6:32 AM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    99TacoDriver[QUOTED] likes this.
  4. Sep 23, 2023 at 6:59 AM
    EMR
    EMR Well-Known Member
    So Cal.
    2012 Tx Pro
    otherphone[QUOTED] and jackn7 like this.
  5. Sep 23, 2023 at 7:12 AM
    wannabemtnbiker
    Derrick
    Georgetown Tx
    No play what so ever. Kinda the reason I wasn't sure if it was a bearing that was making the humming noise.
    Once I took the brake rotor off and could easily spin the bearing, I could hear the bearings.
  6. Sep 23, 2023 at 8:00 AM
    2013XSPX
    2013XSPX Well-Known Member
    GA/FL Border
    2013 XSP-X
    Pelfreybilt front/rear, RCI underneath, Morimoto Headlights, Prinsu racks, SCS Brushed Copper Ray 10's, EO Sliders, Baja Designs and Rigid lights, Inca 4x4 Camper
    Five star resort
  7. Sep 23, 2023 at 8:13 AM
    JAGCanada
    JAGCanada Well-Known Member
    Canada
    2010 TRD Sport V6 Auto Double Cab MGM
    Brute Force, but I modified the bumper to accept new lights. Bought it in 2012 I believe.
    jpereira2[QUOTED] likes this.
  8. Sep 23, 2023 at 8:14 AM
    jpereira2
    jpereira2 Well-Known Member
    Massachusetts
    2013 double cab trd off road
    Bilstein 6112 4th notch Bilstein 5160 rear Camburg ball joint UCAs Old man emu dakar leafs 265/75R16 Cooper ST Maxx Crux stereo a/v interface UltraGauge ARE fiberglass cap Wet okole seat covers Retro fit source Led fog lights Superbrightled pods in rear bumper Superbrightled light bar in grill Rock blokz mud flaps SOS Rock Sliders RCI Skid Plates (to be painted and mounted)
    Its a good looking bumper
  9. Sep 23, 2023 at 9:04 AM
    lynyrd3
    Bill
    East Central Upstate NY
    What is the actual part to search for on that site ?
  10. Sep 23, 2023 at 10:53 AM
    NateTacoma
    NateTacoma Well-Known Member
    Nate
    2013 Tacoma
    was just gonna ask about these, my stock ones are falling off and was looking for good aftermarket ones
  11. Sep 23, 2023 at 11:04 AM
    NateTacoma
    Nate
    2013 Tacoma
    hopefully getting some work done on truck today, does anyone know the sizes of bolts for the bedside support brackets, mine are currently ziptied as you can see
  12. Sep 23, 2023 at 12:19 PM
    1SHADEofGREY15
    1SHADEofGREY15 Well-Known Member
    MD
    2015 TACO TRD OR MGM
    Picked up some new to me side steps for dirt cheap off of FB. Also got rid of the chrome bumper kinda-color matched bumper shellz and installed Alpharex taillights.
    Bagman, Burritopa, 69 Jim and 12 others like this.
  13. Sep 23, 2023 at 12:33 PM
    99TacoDriver
    99TacoDriver Well-Known Member
    South Louisiana
    OME 885x/5100s/LR UCA/3 leaf AAL/275/70/17 Terra Trac X-Venture
  14. Sep 23, 2023 at 1:31 PM
    NateTacoma
    Nate
    2013 Tacoma
    thoughts on this before i put in any more (all stainless)
  15. Sep 23, 2023 at 2:38 PM
    20somethingwidataco
    20somethingwidataco Yes, my avatar is a real car.
    Will
    Washington State
    2008 AC TRD SPORT M/T
    ACLB 6 SPEED: Suspension: Bilstein 6112s (3rd perch) (F) Taco Lean Spacer Bilstein 5160s (R) TSB Leaf Pack Wheelers Offroad 3 leaf progressive AAL Wheelers Superbump Front Duro Bump U bolt flip kit Duro Bump progressive bump stop 3rd gen TRD offroad sway bar Wheels and Tires: Summit Racing Wheel Dakars (Polished Silver) 285/70r/17 Goodyear Wrangler Duratrax (Load D) "Performance": AFE CAI with custom powdercoated white filter cover MagnaFlow Performance Series Exhaust URD Cam gears XTP Intake Manifold Spacer OTT Torque Tune Brakes: Stoptech Slotted Rotors Stoptech Sport Ultra Composite Brake Pads Wheelers offroad SS brakelines (Front) Interior: Kenwood DD headunit Oem Subaru Kicker Tweeters Alpine 6x9 (Front) & 6.5 (rear) (With Taco tunes speaker mounts) Alpine 500 watt amp Sound Deadening (Doors, Rear "wall", Roof) ODI Rouge Shift Knob Weather Tech Mats Painted/wrapped trim pieces Console Safe Console Vault Gridx Organizer Ram Phone Mount Meso Customs dual color map lights Meso Customs dual color dome light Wet Okole seat covers (Black) Wet Okole center console cover (Black) 1" Seat Raisers (Driver & Passenger) AJT Designs climate control and 4x4 knobs Back Up Camera Lighting: Retrofits (Mini H1's, RGB Halos, 5500k Bulbs)(Lenses wrapped in self healing PPF) Diode Dynamics SS3 Max SAE (Yellow) Diode Dynamics SS5 Pro (Yellow) Driving lights (ditch lights) Anytime fog mod Rigid Industries E series 32" Combo bar (spot/flood) Diode Dynamics XPR Reverse Lights Diode Dynamics XP80 turn signals LED brake, parking lights and license plate lights Armor: Apex All Pro sliders BPF steel skid plate Bigass Trailer Hitch Camping/Storage: Leer canopy LED interior lighting Sleeping platform (Storage underneath) Removable snowboard Yakima mounts Extra D rings in bed (6 total) Custom Powder coated white snow shovel with custom bedrail mounts Amazon special Traction Boards Hi Lift 48" Jack with custom Rail mounts to accommodate my sleeper set up Other: All pro Bed Stiffeners Relentless Fab tailgate panel TRD sport graphics (Turd Gen spec) Anti Sun glare hood scoop wrap (Satin Black) Custom FleeBay grille 4 Hella supertones ECGS needle bearing Many Patches BPF shackle mount (With smittybuilt shackle) Tinted windows (Front/Rear + Full canopy)(18%) Meso Customs gasshole AVS inchannel window visors Diff Breather Kit 2012-2015 Oem Turn signal/folding mirrors (w/ sequential signals) 2012-2015 Oem LED taillights Full Size (285/70r17) spare DIY Larger Engine Splash Guards DIY Vipercut TRD radiator cap
    Tacky. Look into other options before you drill anymore holes in that rare paint.
  16. Sep 23, 2023 at 2:39 PM
    stbear
    stbear Well-Known Member
    SE PA
    2015 DCSB TRD Sport MGM
    Duct tape or zip ties, fixed is fixed.
  17. Sep 23, 2023 at 2:54 PM
    WiscoTaco4x4
    WiscoTaco4x4 Well-Known Member
    Brady
    2015 SR5 ACLB 4x4
    when I had this issue I just ordered replacements from toyota themselves. The whole thing and its good as new.
  18. Sep 23, 2023 at 4:06 PM
    reinnov8r
    reinnov8r Member
    Finally got around to installing a set of TRD wheels and 265/70/17 Falken Wildpeak tires. Also put in LED taillights. I need to find some time to put in the matching headlights and TRD PRO grille.
  19. Sep 23, 2023 at 4:11 PM
    TJRTACOMA
    TJRTACOMA Well-Known Member
    Tony
    Rialto, CA
    07 Speedway Blue Tacoma TRD Sport
    Billet Grille, Pop N Lock
  20. Sep 23, 2023 at 4:41 PM
    NateTacoma
    Nate
    2013 Tacoma
    that was the broken flare that i was using, it would be the bottom where you cant see it really, but not sure about other options, had zip tied well and still fell off when i go on highway
