  1. Nov 21, 2023 at 6:31 AM
    Sterling_vH111
    Sterling_vH111 Go do something real instead.
    Sterling
    socal
    2012 DCLB Prerunner V6
    Secretly Long Travel & Supercharged
    When I had 285’s the Peerless Auto-track chains were great. I believe they would fit your tire size. I forget the exact model
    I have, but their site filtered the variations for you.
    i need some chains for 35’s now !
  2. Nov 21, 2023 at 7:05 AM
    Its_Taconie
    Its_Taconie Well-Known Member
    Nelson
    North Hollywood
    2007 Tacoma DCLB PreRunner
    Fox Racing 2.5 (F); 2.0 (R), Archive Garage Leaf Springs, hanger/shackles, shock relocation, U-Bolt Flip Kit PLM P37 (TE37 Knockoffs) Bronze wheels, Nitto Ridgeline 35s, C4 Overland Bumper, Total Chaos Uppers, Outgear Solution HC Swingout, OTTune 4.88 Nitro Gears
    My next mode is swapping out my interior lights. I was going goo goo gaga for Meso products when I first got my Tacoma and every time I checked they were sold out. Must've been a sign cause they're overpriced and not the best.
    Im digging these RovrLab dome lights. Theyre working on a third brake light set up.
    https://rovrlab.com/products/rovr-dome-2nd-gen-tacoma-diode-dynamics-dome-light-conversion
    and have thought about adding footwell lights from VLeds. To give it that modern feel.
    https://www.tacomalifestyle.com/pro...iKDOO_Xq2j6XdLdCOxw1qt8v4r67NYIhoCuy8QAvD_BwE
    How does the video feed in the tailgate work? Do you have to put it in reverse or it just put out the video at all times?
    Tacoma13_NC[QUOTED] likes this.
  3. Nov 21, 2023 at 7:28 AM
    JdevTac
    JdevTac Well-Known Member
    Josh
    MD/GA
    2nd gen
    Tires are 37x12.5r17. The chains are DiamondBack LT, made by QualityChaincorp. I bought them off Harriscos (industrial supplier in Oregon).
    It was between these or some aggressive ladder style chains with cams. I decided on these for highway use and ease of install. And they were slightly cheaper. Some people seem to have a hard time getting diamond pattern chains tight. I bought some additional rubber tensioners to help with that.
    AStinkyBumb[QUOTED] likes this.
  4. Nov 21, 2023 at 7:38 AM
    steveo27
    steveo27 Ask me about my weiner
    Pittsburgh
    '11 TRD Off Road & 1992 VW GLI
    The same shit everyone else has.
    Powerstop Z36s.
    jackn7 likes this.
  5. Nov 21, 2023 at 8:04 AM
    JdevTac
    Josh
    MD/GA
    2nd gen
    I had some similar problems with the power up issue with an AUTOVOX T9 I bought. Sometimes it wouldn’t cut on and all I could fathom is it had something to do with extremes of temps so either it was too cold or too hot out. Then if I turned the vehicle off and back on it would power on. Either something in the software or an issue with a relay tripping in the unit, idk.
    What I did like about the T9 was that it didn’t have a front cam on it, and it mounted like the stock mirror so I was able to cover up the wiring under the OEM windshield wire cover.
    They definitely take some getting used to though and don’t compare to the OEM live video mirrors.
    Its_Taconie and EMR[QUOTED] like this.
  6. Nov 21, 2023 at 8:05 AM
    EMR
    EMR Well-Known Member
    So Cal.
    2012 Tx Pro
    When the vehicle is on, it has a standard rear view that is always on. When put in reverse (based on a signal from the reverse light), the view shifts to a lower and wider view with backup lines. Admittedly, I haven't hooked up the reverse yet because I ran out of time yesterday.
    Its_Taconie[QUOTED] likes this.
  7. Nov 21, 2023 at 8:10 AM
    EMR
    So Cal.
    2012 Tx Pro
    My neighbor has a fancy Cadillac Escalade with the OEM video mirror and that's what sold me on this. In practicality, it has a lot of short comings. I'll give it a few weeks to see if I get used to it and if the power issues gets resolved. So far really just underwhelmed.
  8. Nov 21, 2023 at 9:27 AM
    AStinkyBumb
    AStinkyBumb Well-Known Member
    Indiana
    2013 DCLB SR5 4x4
    Ill have to do some more searching to see if I can find something. Having a non standard tire size is biting me in this one area so far.
  9. Nov 21, 2023 at 10:10 AM
    Seabass
    Seabass Give it to me. I'll break it for you
    Adam
    AZ
    '06 Sport 4x4
    Just a bunch of old crap
    So technicallllllyyyy... there is spacing between my bumper lights and the radiator grill, and air flows around just fine and doesn't actually get obstructed. Not the same in something actually mounted on the grill that truly blocks airflow.
    Yacob_D likes this.
  10. Nov 21, 2023 at 10:26 AM
    TomTwo
    TomTwo I love God but I cuss a little
    Bill
    I-85 Southbound
    2013 TRD Double Cab Sport
    :facepalm:
    Seabass[QUOTED] likes this.
  11. Nov 21, 2023 at 11:18 AM
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    It may flow around those lights but probably at reduced air pressure against the radiator since some of the air mass will be deflected over the hood. You have a bow wave instead of an open grill. The thermostat could tell which is worse.
  12. Nov 21, 2023 at 11:19 AM
    MudFlap
    MudFlap Well-Known Member
    Tim
    Memphis (north mississippi)
    2012 TRD Off Road
    New wheels, tires, TPMS, and headlights! She's still looking good for a 12 year old truck. I would get in it and drive it anywhere.
  13. Nov 21, 2023 at 11:58 AM
    Williston
    Williston Well-Known Member
    New England
    2014 Tacoma 040 SR5 4x4 DC SB V6 AT5 Tow Pkg Entune+ Mostly stock with a few OEM mods.
    Stock (99.999%) OEM Bed Floor Mat, Front Bed Rail Cargo Net and hooks, Auto-Dim mirror w/Compass and outside Temperature display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. (winter) OEM All-Weather floor mats (summer).
    Changed the spark plugs. 129,800 on the truck. The only previous record for them was a change in 2015 @15,000 miles, so as far as I know, these have +/- 115,000 on them. They look like that might indeed be the case. (no NGK in the mix either) I'm always a little nervous when I remove plugs: never know what they might reveal. Appear well worn of course, but clean electrodes and the nice clean/shiny appearance above the gaskets. The idle is much better and seems like it starts better. I paid $6 each for them at the dealer. PCV and hose are next. I don't notice any difference on the power. I had some pinging under load when the hot weather was still here, so I'm hoping that will be gone now with the new plugs and the winter-blend gas.
    Anywho: Here's what spark plugs with 115,000 miles on them look like. :proposetoast:
  14. Nov 21, 2023 at 2:03 PM
    easleycrawler
    easleycrawler Well-Known Member
    Travis
    Easley, South Carolina
    2014 RC Taco 4wd
    Anyone know of any black Friday deals on bilstein 5100's? Or ARB front bumpers?
  15. Nov 21, 2023 at 2:32 PM
    JdevTac
    Josh
    MD/GA
    2nd gen
    Be a neat wind flow experiment, if someone hasn’t already done one.
    I think the Tacoma grill would be fine with lights in the grille if you cut out the center plastic section and used lights with comparable height. I think a 2011 Honeycomb grill would be perfect for it.
    20somethingwidataco likes this.
  16. Nov 21, 2023 at 2:57 PM
    LGE RAW
    LGE RAW Well-Known Member
    Rob
    Dothan
    2020 TRD Off Road DCSB 6AT Magnetic Gray Metallic
    New Mods in the works.
    I totalled it. Actually, I totalled it November 3rd. Hit a ~275lb hog after work just after dark. Dang thing looked like a bear coming out of the ditch. Luckily, I was only going about 35 to 40 mph and had a little time to break before plowing into it. Just got a replacement saturday. It's a 2020 TRD Off Road. I do hate a payment, but this 3rd gen is NICE!
    ridefreak, TacoLolz and TomTwo like this.
  17. Nov 21, 2023 at 3:11 PM
    TomTwo
    Bill
    I-85 Southbound
    Glad you lived through it, a hog that big can roll your vehicle. Oh and WAR EAGLE!!
  18. Nov 21, 2023 at 3:13 PM
    LGE RAW
    Rob
    Dothan
    War Eagle! Now I need to figure out how to update my profile and upload a few pics of Boarmagedden!
    jackn7 likes this.
  19. Nov 22, 2023 at 12:19 PM
    E4x4
    E4x4 Active Member
    2015 TRDOR 6MT
    Installed all auto window switches on my 2015. I don’t know why I waited so long to get them.
    GARSHA91, TacoLeeSD, Robb_R and 14 others like this.
  20. Nov 22, 2023 at 1:39 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Lights blocking wut?
    Seabass, SSX999, lo2hi and 4 others like this.
