  1. Dec 25, 2023 at 2:36 PM
    Sonofliberty92
    Sonofliberty92 T O Y O T A
    Mark
    Maryland 4 South
    2014 DCSB TRD OR, 2005 Tundra V8 4WD
    I had it on for about 4 months. First 2 weeks I loved the look of it. After that I had mad remorse.
    The fender was sourced from the same year and paint truck, $250 there from salvage yard. I had to swap my original fender flare to that because the one that came on the replacement was mangled from them uninstalling it. Then I had to buy an OEM air intake hose because that also has to be modified for the snorkel. Another $100. Then whatever the antenna is gonna set me back.:bananadead:
    The pin stripe and the plastic clips were a bother. Redid the striping 3 or 4 times. I broke about 8 of those plastic fasteners but thankfully I had those on hand. Took me probably 4-5 hours mainly because one of the snorkel bolts was in such a tight spot it took me an hour manipulating the wrench to get it loose. Between that and that dumb design of an antenna being seized. Should have been a 2 hour job.
    Unfortunately I gotta get that antenna and get that installed. I tried so hard to get it off but it just snapped the wiring. Was super pissed about it. Oh well.
    Tacoma13_NC likes this.
  2. Dec 25, 2023 at 2:38 PM
    TomTwo
    TomTwo I love God but I cuss a little
    Bill
    I-85 Southbound
    2013 TRD Double Cab Sport
    I did a metric ton of pin striping in the early 80’s I also hope I never see another roll of that stuff again :annoyed:
    Sonofliberty92 likes this.
  3. Dec 25, 2023 at 3:42 PM
    20somethingwidataco
    20somethingwidataco Yes, my avatar is a real car.
    Will
    Washington State
    2008 AC TRD SPORT M/T
    ACLB 6 SPEED: Suspension: Bilstein 6112s (3rd perch) (F) Taco Lean Spacer Bilstein 5160s (R) TSB Leaf Pack Wheelers Offroad 3 leaf progressive AAL Wheelers Superbump Front Duro Bump U bolt flip kit Duro Bump progressive bump stop 3rd gen TRD offroad sway bar Wheels and Tires: Summit Racing Wheel Dakars (Polished Silver) 285/70r/17 Goodyear Wrangler Duratrax (Load D) "Performance": AFE CAI with custom powdercoated white filter cover MagnaFlow Performance Series Exhaust URD Cam gears XTP Intake Manifold Spacer OTT Torque Tune Brakes: Stoptech Slotted Rotors Stoptech Sport Ultra Composite Brake Pads Wheelers offroad SS brakelines (Front) Interior: Kenwood DD headunit Oem Subaru Kicker Tweeters Alpine 6x9 (Front) & 6.5 (rear) (With Taco tunes speaker mounts) Alpine 500 watt amp Sound Deadening (Doors, Rear "wall", Roof) ODI Rouge Shift Knob Weather Tech Mats Painted/wrapped trim pieces Console Safe Console Vault Gridx Organizer Ram Phone Mount Meso Customs dual color map lights Meso Customs dual color dome light Wet Okole seat covers (Black) Wet Okole center console cover (Black) 1" Seat Raisers (Driver & Passenger) AJT Designs climate control and 4x4 knobs Back Up Camera Lighting: Retrofits (Mini H1's, RGB Halos, 5500k Bulbs)(Lenses wrapped in self healing PPF) Diode Dynamics SS3 Max SAE (Yellow) Diode Dynamics SS5 Pro (Yellow) Driving lights (ditch lights) Anytime fog mod Rigid Industries E series 32" Combo bar (spot/flood) Diode Dynamics XPR Reverse Lights Diode Dynamics XP80 turn signals Diode Dynamics HP5 Third brake light LED brake, parking lights and license plate lights Armor: Apex All Pro sliders BPF steel skid plate Bigass Trailer Hitch Camping/Storage: Tonneau Cover (Truxedo Roll Up) KB voodoo bed bars Pelican Vault (for gear) LED interior lighting Extra D rings in bed (6 total) Custom Powder coated white snow shovel with custom bedrail mounts Amazon special Traction Boards Hi Lift 48" Jack Other: All pro Bed Stiffeners Relentless Fab tailgate panel TRD sport graphics (Turd Gen spec) Anti Sun glare hood scoop wrap (Satin Black) Custom FleeBay grille 4 Hella supertones ECGS needle bearing Many Patches BPF shackle mount (With smittybuilt shackle) Tinted windows (Front/Rear) (18%) Meso Customs gasshole AVS inchannel window visors Diff Breather Kit 2012-2015 Oem Turn signal/folding mirrors (w/ sequential signals) 2012-2015 Oem LED taillights Full Size (285/70r17) spare DIY Larger Engine Splash Guards DIY Vipercut TRD radiator cap AC drip line mod Anti Tweeker tailgate lock
    Wet Okole Seat covers
    dpele, tacofish, BraddahRO and 11 others like this.
  4. Dec 25, 2023 at 6:55 PM
    Tacoma13_NC
    Tacoma13_NC Well-Known Member
    2013 SR5 4x4 DCSB 4.0L (Black) OTT
    Bilstein 6112/5160; JBA HD UCAs; 1.5" 3-Leaf AAL's w/ overload; OME CB drop; RCI aluminum skids w/ catalytic converter shields; Wheeler's U-Bolt flip kit with Superbumps; TRD Pro 4-Runner Wheels; Falken Wildpeak AT4W (265/70/17); Diode Dynamics SS3 Sport (Yellow) fogs; CaliRaised 32" hidden light bar; Morimoto XB LED headlights with upgraded HD harness; Unifilter mod; Rear-View mirror riser bracket; Truxedo Lo Pro tonneau cover; New OEM color-matched grille; Bumpershellz color-matched rear bumper cover; Ultra-Gauge MX 1.4 w/Spiker mount; Baja Designs S2 Sport Ditch Lights with SDHQ brackets; Fog Light Anytime Mod; Overland Tailor Tune (OTT); Yaesu FTM-150 GMRS/Ham radio; Viofo A229+ Dash Cam
    Well now you know and will never have to wonder. You did a great job at the repair!
  5. Dec 25, 2023 at 10:32 PM
    Tacoben
    Tacoben Benandblue
    Eigi
    Virginia Beach,VA
    2007 Toyota Tacoma V6 SR5 Prerunner 2WD
    My Build Page https://www.tacomaworld.com/threads/bantugin%E2%80%99s-taco-build.649938/
    Replaced Genuine 6pcs 90919-02248 UF495 Ignition Coils
    Replaced Upper Control Arm SPC Ball joint left and right then greased plus seafoam done before doing oil change.
    Firestone wheel alignment and Discount tire rotation done.
    Question:
    I have been using a Full Synthetic High Mileage Oil and change them less than 5k miles is that normal i havent even hit 5k miles yet and whats the max months should i change oil because i change oil since jan of this year lol im asking because im hearing people says you can go 10k miles without changing is that true guess if you drive a lot or i am good on what i have been doing or i can push it a little further i only use the truck to work which about 10miles one way and once in a blue moon of 3hr to 14hr travel.
    RickE24 likes this.
  6. Dec 26, 2023 at 5:55 AM
    Sutherbb36
    Sutherbb36 Active Member
    My2009taco, lo2hi, jackn7 and 7 others like this.
  7. Dec 26, 2023 at 12:38 PM
    1SHADEofGREY15
    1SHADEofGREY15 Well-Known Member
    MD
    2015 TACO TRD OR MGM
    Upgraded my window switches. Didn’t think I really needed it but I bought it anyway. Now I wish I had done it sooner.
  8. Dec 26, 2023 at 3:06 PM
    PirateMica
    PirateMica Well-Known Member
    2014 Pyrite Mica SR5
    Put new wheels (16x8, 0 offset) & tires on today. Maxed out at 265/75-16, because why not? Also did new pads and rotors, so my day was spent beating the sh*t out of the rusty retainer pins, and breaking the rotors free. They were all stubborn, but I finally won. Happy about the result, and ready for snow to hit tomorrow.
    henman911, Kolter45, dpele and 8 others like this.
  9. Dec 26, 2023 at 3:09 PM
    SandroCCM8
    SandroCCM8 New Member
    2012 White Tacoma TRD Sport DCSB
    Looks awesome! Where did you find the replacement?
    Kolter45 and don14002 like this.
  10. Dec 26, 2023 at 3:34 PM
    oldtoyman
    oldtoyman Small bore freak
    Kevin
    North of Seattle
    2019 Honda Monkey,2023 klx300 , 2013 prerunner TRD off-road
    I have the same wheels. Good look for a good price.
    PirateMica[QUOTED] likes this.
  11. Dec 26, 2023 at 3:50 PM
    SilTac10
    SilTac10 Active Member
    2010 TRD OR
    None
    Upgraded the headlights to some Alpha Owls. Pretty happy with them thus far other than a random wire that I need to rectify in the passenger side bulb. Also blacked out the badges and upgraded the air filter. Next up is Gen3 TRD wheels vs. the Baja wheel upgrade.
    RickE24, drewnali and SandroCCM8 like this.
  12. Dec 26, 2023 at 3:57 PM
    SilTac10
    2010 TRD OR
    None
  13. Dec 26, 2023 at 3:57 PM
    SilTac10
    2010 TRD OR
    None
    ^^^ If anyone has any experience on the best way to go about fixing this, ideas will be most appreciated.
  14. Dec 26, 2023 at 4:10 PM
    EMR
    EMR Well-Known Member
    So Cal.
    2012 Tx Pro
    If warranty exchange isn't an option, look up the BHLM mod. You'll probably have to throw it in an oven to loosen the glue to remove the front cover and reseal it.
    SilTac10[QUOTED] likes this.
  15. Dec 26, 2023 at 5:14 PM
    StayLion
    StayLion Member
    Nick
    2014 Tacoma TRD Sport Grey
    I walked out of my house and just admired it there. alone in the driveway.. then hopped into my company ford transit and drove away. Pondering future builds and versions of the truck that have yet to come to life.
    jackn7 likes this.
  16. Dec 26, 2023 at 5:41 PM
    Agoldxj
    Agoldxj Well-Known Member
    James
    Central Pa
    2009 SWB AC
    Yeah I’d make them send you a new one. For how much those things cost, that wire looks like hell.
  17. Dec 26, 2023 at 7:08 PM
    1SHADEofGREY15
    MD
    BraddahRO, tx novice and TomTwo like this.
  18. Dec 26, 2023 at 8:39 PM
    offroadtoyboy
    offroadtoyboy Well-Known Member
    Middle of nowhere Cali
    2006 Pre-Runner / converted to full manual 4WD / RC62 swap / Manual 4R trasfer case mod
    did you do anything particular to cause that?
  19. Dec 26, 2023 at 9:13 PM
    offroadtoyboy
    Back from powder coat.
    Crom, Kolter45, Corny Taco and 7 others like this.
  20. Dec 27, 2023 at 6:35 AM
    don14002
    don14002 Active Member
    I found mine on Amazon got a good deal over Black Friday. Probably the same that you get from Cartrimhome.
