  1. Jan 4, 2024 at 11:09 AM
    Nateurboy
    Nateurboy Well-Known Member
    Nathan
    Colorado front range
    2008 DCSB 6 spd
    powerbrake d-line. Took advantage of Black Friday deals. I’ve only driven 30 miles or so but the difference over stock is impressive.
  2. Jan 4, 2024 at 11:10 AM
    545
    545 Well-Known Member
    2015 Access Cab
    sounds like the slip joint binding in his case
    4 runners have a two piece driveshaft?
  3. Jan 4, 2024 at 11:52 AM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Still would have a slip yoke, either on the shaft or the trans if 2WD
  4. Jan 4, 2024 at 1:45 PM
    bulldog
    bulldog Well-Known Member
    SW MO
    2023 Pro
    Umm…it’s a Pro Retired 4/29/2023 Dobinsons MRR Dobinsons UCA Dobinsons C59-314 Front Springs Dobinsons I59-110 Rear Springs 4.88 Yukon Gears CMC MobTown Sliders Line-Xed RCI Aluminum Skid BAMF Recessed Grille WARFAB Rear tube bumper SSO Full Plate Hybrid (sitting in the garage still) TTD Carbon Fiber Steering Wheel Clazzio Dark Gray Seat Covers 35% Tint Vinyl Tailgate Letters Undercover Elite Tonneau Apex Stealth Cali LED 31.5" w/upgrade OPT 7 harness and MicTuning Switch V5 Gemtech Homelink 265/75 16 Mickey Thompson Baja Boss A/T Volk Gloss Black 16” 17' Pro Rigid Fog Lights 17' Pro Tail Lights Complete sound proofing
    Liking these?
  5. Jan 4, 2024 at 2:13 PM
    gkomo
    gkomo Well-Known Member
    San Diego, CA
    2014 MGM AC SR5 4x4
    I believe it is NOT a 2 piece driveshaft (but not 100% sure - don't recall seeing a carrier bearing) and it is 4wd.
    When i grease the zerks on the driveshaft i can add a ton of grease to the slip yoke - if its binding is it already too late or just grease more?
  6. Jan 4, 2024 at 2:23 PM
    dpele
    dpele Pele Prints Vendor
    Dan
    Edmonton, Alberta
    2010 Tacoma DCSB
    Elka 2.0 w/ OME Dakars, 285/70/R17 Duratracs, & more!
    How is the radio reception?
    I hear these aftermarket units have poor FM reception. I listen to my phone a lot but I still like my FM radio in the morning... lol
    GRNT4R likes this.
  7. Jan 4, 2024 at 2:42 PM
    TireFire
    Olympic Peninsula
    The slip yokes can’t be greased through a zerk because there isn’t one, and adding one - for that matter - is a poor idea. Drive shaft has to be disassembled (make sure to mark both ends first) to grease the slip yoke. The blue stuff from Ford is best.
    If it actually is the slip yoke that’s binding, and not axle wrap or something else, then that’s probably because the old grease has dried out or washed out due to a torn boot. Unless the splines got damaged (unlikely) a clean and fresh grease should be the ticket.
    mchabot1987 likes this.
  8. Jan 4, 2024 at 2:55 PM
    EveryDayIsTacoTues
    EveryDayIsTacoTues Well-Known Member
    2012 Pyrite Mica DCLB TRD Sport
    The Rubritreks? Liking them so far. As expected they're not Highway Terrain quiet, but for an AT they're pretty darn quiet and comfortable on the road. They've handled some rain well and no vibes at 55mph. I'll try em in snow and above 65 mph soon.
    My2009taco likes this.
  9. Jan 4, 2024 at 7:05 PM
    P4x4
    P4x4 Well-Known Member
    Pascal
    2015 Dark Gray Tacoma 4x4
    I wanted to delete the grill chrome so I tried vinyl coverage. Not that complicated and nice outcome.
    I also took the time to install my new headlights.
    Before
    1-D6-A340-F-D6-AC-450-C-AEF8-2-F0-D0-F17_ca61be3093e7cb91ee94e173919a59232d8c0ba0.jpg
    After
    IMG-7121_d371ee551d5d16ab4c82e28bf1a30cc521cb7505.jpg IMG-7136_5ff1ce44ae0763386b59ed7c8e067a682fc607d7.jpg
  10. Jan 4, 2024 at 8:52 PM
    Tacoben
    Tacoben Benandblue
    Eigi
    Virginia Beach,VA
    2007 Toyota Tacoma V6 SR5 Prerunner 2WD
    My Build Page https://www.tacomaworld.com/threads/bantugin%E2%80%99s-taco-build.649938/
    installed under the hood New Arb 1gal air compressor tank attached solenoid for rear locker, 150psi moisture filter and Powertank pressure release valve still waiting for some attachment to install a pressure gauge and installed arb braided 1M line routed it and made the access hole in the lower passenger corner of the grill spray painted Slee under the hood Passenger side mount for arb twin compressor just waiting for the compressor to arrive removed washer fluid bottle to clean and will be installed after air compressor is installed.
  11. Jan 5, 2024 at 12:54 AM
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Put 60 psi in my air bags and carried a bunch of fresh cut green oak sections. No squat or bottom but had to remember to ride the parking brake backing down GF’s steep, slanted, wet driveway to keep the front wheels from locking up and sending me sideways into the creek. More yesterday, more tomorrow, and lots of splitting in my horoscope.
    jackn7, BigCountry762x39 and TomTwo like this.
  12. Jan 5, 2024 at 4:05 AM
    00Yota4r
    00Yota4r Member
    Pennsylvania
    15 DCLB Sport
    Bilstein 5100/OME 884 Bilstein 5100/Deaver AAL 275/70r17 Cooper ST Maxx Level 8 MK6 17x8 wheels Pro 2.0 Grille
    Replaced my nitto ridge grapplers with mickey thompson baja boss AT (265/70r17). They are amazing.
  13. Jan 5, 2024 at 8:17 AM
    HoulaHauler
    HoulaHauler Well-Known Member
    Andy
    Gwinnett Co., Georgia
    2013 1G3 DCSB
    I'm in metro Atlanta with rather strong towers but I rarely use the radio. I've had a stubby antenna for years w/ no problem and haven't seen any change since I moved to the android unit.
    jackn7 and dpele[QUOTED] like this.
  14. Jan 5, 2024 at 9:21 AM
    Tiedie
    Tiedie Well-Known Member
    David
    WFOY
    Katzkin, Dobinsons full suspension. Redlinegoods console cover and door panel arm rests, Double USB charger in dash installed, Ballistic Jesters 16x8. BlackVue DR 590 Dash Cam
    Went to the Dealership this morning for a oil/filter change and lube drive shaft, leaf pack bolts, SPC UCA's and alignment, tire rotation. So when did it get soo expensive? Last time I took it in it was like $50.00 it was $84.00. It was $39.00 for oil:eek: holy cow.
    Alignment was free bought a package, rotation free bought tires there.
    Only thing I was charged for was oil, filter, gasket and labor.
    Now for the good news here's the alignment numbers.
    Its_Taconie likes this.
  15. Jan 5, 2024 at 11:50 AM
    bagleboy
    Scott
    Norcal, Santa Rosa
    Just bought a 5 qtl 0-20 for $26 on sale at Tractor supply so $39 doesn’t sound too far off for a shop charge for 6. It’s not really the minimal savings but the opportunity to keep an eye on things from the bottom up. 7 years no rust.
    Micbt25 likes this.
  16. Jan 5, 2024 at 12:08 PM
    Tiedie
    David
    WFOY
    Ok I stand corrected about the price. Man I have thought about doing it myself but got lazy in my old age :rofl:. Yes I get keeping an eye on things,got home and greased my leaf bolts and that tiny no see em grease zerk on the drive shaft they skipped.:censored:
  17. Jan 5, 2024 at 12:29 PM
    Micbt25
    Micbt25 Well-Known Member
    TM
    2015 MGM TRD Sport Access Cab 4X4 V6
    I changed my oil today, Toyota filter with Kirkland synthetic. I was going to grease the drive shaft as I normally do, but it was too damn cold. I can’t wait to retire, move south where it’s warmer, the state believes in freedom, the roads aren’t salted like a pretzel and my governor doesn’t have teeth like Mr. Ed…and hopefully less bro-lean.
  18. Jan 5, 2024 at 1:11 PM
    EMR
    EMR Well-Known Member
    So Cal.
    2012 Tx Pro
    Camping with mostly RV’s but oh well. I’m out of the house!
    GARSHA91, Crom, Kolter45 and 18 others like this.
  19. Jan 5, 2024 at 2:25 PM
    pahaf
    pahaf Well-Known Member
    paul
    NorCal
    2015 Tacoma TRD Off Road
    Bilstein 6112/5160 OME Meduim leaf pack JBA HD UCA 3* retard exhaust gear TRD Pro Sema rims 265/70R17 Falken Wildpeak AT3W
    Where did you get the lower shock bushing? Looks like 6112?
  20. Jan 5, 2024 at 2:38 PM
    TacoTuesday1
    SD CA
    6112 is thick. That is thin. It's a 5100.
    Yacob_D and Nateurboy like this.
