  1. Jan 17, 2024 at 1:58 AM
    Tatts521
    Tatts521 Well-Known Member
    New Jersey, Jersey Shore
    2012 tacoma-04cbr1000rr-22ktm890duke R-19 wr450f-98rm250
    These will be in on Friday.
    Unfortunately no garage so won't be installed till the spring.
  2. Jan 17, 2024 at 4:55 AM
    Greyhome
    Greyhome Well-Known Member
    Graham
    Richmond, VA
    2015 4Runner Trail
    I’ve always loved those wheels as well. Never seen them on a 2nd gen taco. They look nice!
    Bikinaz likes this.
  3. Jan 17, 2024 at 5:24 AM
    danteisme
    danteisme Well-Known Member
    South Western PA
    06 DCSB Sport, 96 Integra GSR
    I think chains would be better. If its ice, no amount of airing down will help. Also, I thought "pizza cutter" type of tire footprints were better in the snow? Or at least in deep snow. I could be wrong, but maybe air up?
  4. Jan 17, 2024 at 5:31 AM
    ZColorado
    ZColorado Well-Known Member
    Near Boulder Colorado
    13 DCSB OR 6MT
    35's,Kings, NWF, 488, Harrop, SPC, Archive, Method, RCI, C4
    Correct, narrow tires do better in snow. You want to reach the ground. Do not air down in snow or ice. You want high contact pressure.
    The single most important thing for ice and snow is tires. Snow tires are soft rubber that does not get hard when cold, allowing traction.
    Kolter45 and danteisme[QUOTED] like this.
  5. Jan 17, 2024 at 8:46 AM
    BigCountry762x39
    BigCountry762x39 Well-Known Member
    TL
    PNW, Oregon!
    2009 Tacoma, with the cool white paint peel
    Arb Deluxe bull bar Front Bumper Ironman4x4 12k winch synth line AFE Intake OME 2.75in Dakar Leaf springs (R) Fox 2.0 bypass shocks (R) Bilstein 6112 (F) 33's on KMC wheels off road lighting comfort mods Redrock HD roof rack Retevis rt95 Radio Slotted Rotors and HD pads
    when i use to hag out with lot of the land rover guys we use to all run skinny tires, and would purposefully try to spin tires to dig down for traction most often it worked!
  6. Jan 17, 2024 at 9:32 AM
    gpdx
    gpdx Well-Known Member
    Portland
    13 DCSB TRD Offroad
    5100/887, topper, rack, 265/75/16
    I agree that dedicated winter tires on that guy’s truck would be the best. Boise gets a fair amount of winter weather. But that’s also money that not everyone has.
    Chains aren’t that expensive and would’ve gotten him all over town.
    I know winter tires perform better at their highest psi. Airing down a/t tires in snow makes sense to me in the way I’ll air down for off road trails. Lower psi = larger contact patch = more traction. That likely won’t make a lick of difference on ice.
    Charlie Bravo likes this.
  7. Jan 17, 2024 at 2:37 PM
    TacoTuesday1
    SD CA
    I wonder if this is true. Narrow means stabbing into the ground with more weight on the patch.
    when I lived in CO the weather was temperamental so I didn’t air down. Because that would mean airing back up again every day. And less MPG.
    it’s never just snow and/or ice all the time there. It switches every day. Bunch of snow, then all sun coming out and warms up melting it all.
    Could be snow on the way to work in the morning and then gone by lunch. Not to mention if the plow trucks come out.
  8. Jan 17, 2024 at 5:03 PM
    OlAg
    OlAg New Member
    Lawrence
    Victoria Texas
    2008 Silver Tacoma TRD
    Today I got my Temp /Compass display to work on my 2008. (according to the Manual/quick ref guide it is a Toyota Accessory Meter). After watching a couple of Youtubes, I decided it was worth a shot. Had trouble finding anything on the forum ( still learning the best ways to search). But apparently there is a resistor that commonly has a bad connection.
    So I dropped the the assembly. One video pointed to one resistor and another pointed to the one next to it and opposite side. So I just resoldered all 4 connections. Went to put it back together. Good news, worked great. Bad news, couldn't find clips from the "posts". Tried without and it sagged.
    So after a little probing around with a magnetic tool , I found it (after seeing if I could purchase online). Only found one, but I believe that someone before had tried to fix this. 2 out of 4 plastic clips were broken and some wire splices were made next to the connectors which from all videos and photos, appears to be non-OEM.
    But it appears to hold well with the one metal clip and I found out it was 49 deg and heading West. :) Apparently , according to the videos, the dealers (stealers) wanted $900 to fix.
    I just purchased this truck about 2 months /2 thousand miles ago.
  9. Jan 17, 2024 at 5:09 PM
    mrproduxn
    mrproduxn Well-Known Member
    steve
    Retired DoD SE VA
    Tacomas 1987,2000,2008, 2016,2012,2008
    Retired/Hobbyist old as f***
    Fixed mine in my 2008 around 6 months ago. It reads however it is so dim I can barely see it in the daylight.
    OlAg likes this.
  10. Jan 17, 2024 at 5:30 PM
    point45
    point45 Well-Known Member
    SoCal, OC
    05 DCSB TRD offroad
    With snow the idea is that it cuts a rut in and helps track and most of the advantage is when stopping building up material infront of the tires.
    But if you can swing it dedicated snow tires are a step above, its not even funny how much better snow tires work. And if legal, studded tires...
  11. Jan 18, 2024 at 10:30 AM
    Tatts521
    Got a couple things in the mail today.
    RickE24, My2009taco, jackn7 and 11 others like this.
  12. Jan 18, 2024 at 11:40 AM
    SSMEDT
    SSMEDT Well-Known Member
    Georgia
    2010 DCSB PreRunner
    She’s getting old lol
    RickE24, herecomesace, gkomo and 17 others like this.
  13. Jan 18, 2024 at 1:34 PM
    Tacoma13_NC
    Tacoma13_NC Well-Known Member
    2013 SR5 4x4 DCSB 4.0L (Black) OTT
    Bilstein 6112/5160; JBA HD UCAs; 1.5" 3-Leaf AAL's w/ overload; OME CB drop; RCI aluminum skids w/ catalytic converter shields; Wheeler's U-Bolt flip kit with Superbumps; TRD Pro 4-Runner Wheels; Falken Wildpeak AT4W (265/70/17); Diode Dynamics SS3 Sport (Yellow) fogs; CaliRaised 32" hidden light bar; Morimoto XB LED headlights with upgraded HD harness; Unifilter mod; Rear-View mirror riser bracket; Truxedo Lo Pro tonneau cover; New OEM color-matched grille; Bumpershellz color-matched rear bumper cover; Ultra-Gauge MX 1.4 w/Spiker mount; Baja Designs S2 Sport Ditch Lights with SDHQ brackets; Fog Light Anytime Mod; Overland Tailor Tune (OTT); Yaesu FTM-150 GMRS/Ham radio; Viofo A229+ Dash Cam
    I removed the DD Elite Series fogs I bought a couple months ago and put my SS3 Sports back in. Although the light cutoff is very good on the Elites, I just couldn't warm up to the look of them on my truck. The SS3s look better in my opinion and do just as well in fog. I'll be selling my Elites as soon as I clean them and package them up.
    RickE24, BraddahRO, Kolter45 and 14 others like this.
  14. Jan 18, 2024 at 2:33 PM
    WiscoTaco4x4
    WiscoTaco4x4 Well-Known Member
    Brady
    2015 SR5 ACLB 4x4
    That intermittent wiper stalk makes a world of difference. You dont realize how nice it is until you dont have it, definitely a mod I wish I did sooner with my truck
    Tatts521[QUOTED] and 4WDTrout like this.
  15. Jan 18, 2024 at 3:47 PM
    Tatts521
    Not sure why it took me so long to order this. Just happened to be watching @boogie3478 video on it and ordered it the same day.
    WiscoTaco4x4[QUOTED] likes this.
  16. Jan 18, 2024 at 6:36 PM
    Reapacheap
    Reapacheap Well-Known Member
    Kam
    Memphis/Bay Area
    2015 TRD sport double cab
    All-pro Fox 3" lift, FN wheels, 33" general M/Ts
    Spent all damn day taking off my busted all pro ucas and fox 2.0 coil-overs off. I'm hurting but hoping it's worth it.
    Anyone run these performance elites have a setting for a daily driver they recommend.
    My2009taco, RickE24, Kolter45 and 8 others like this.
  17. Jan 19, 2024 at 2:51 AM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    Just ordered the exhaust for my truck. It should be here on Monday. Hopefully the shipping doesn't get messed up. I put my work address and it changed the "bill to" address.
    Not sure why but I have a confirmation so we'll wait and see.
    It's Walker from rockauto.com
  18. Jan 19, 2024 at 4:01 AM
    GearHead899
    GearHead899 Well-Known Member
    Justin
    Ocean View, NJ
    11' Black X-Runner, 06' RR X-Runner
    Last week I put my new URD spec-U headers on my 2011 and took my old Doug Thorley long tubes off. So I braved the cold yesterday and installed the doug thorleys on the 2006. I was careful but I have no idea how I got lucky enough that all the original manifold nuts actually came off with 241k miles lol. Now has Doug Thorley long tubes and y-pipe, and URD cat back
    https://youtu.be/C9uiRsmx-rw?si=V0MhFhshzYjq9eDp
    srspicer, jackn7, TRlPPlN and 2 others like this.
  19. Jan 19, 2024 at 4:37 AM
    TacoTuesday603
    TacoTuesday603 I welded it helded
    Jack
    New Hampshire
    2011 OR DCFB
    Fox and Locked suspension 63's Skinny 33's
  20. Jan 19, 2024 at 6:32 AM
    Its_Taconie
    Its_Taconie Well-Known Member
    Nelson
    North Hollywood
    2007 Tacoma DCLB PreRunner
    Fox Racing 2.5 (F); 2.0 (R), Archive Garage Leaf Springs, hanger/shackles, shock relocation, U-Bolt Flip Kit PLM P37 (TE37 Knockoffs) Bronze wheels, Nitto Ridgeline 35s, C4 Overland Bumper, Total Chaos Uppers, Outgear Solution HC Swingout, OTTune 4.88 Nitro Gears
