  1. Jan 19, 2024 at 7:30 AM
    Bikinaz
    Bikinaz It wasn't me!
    Hey You!
    Phoenix, AZ
    2014 Regular Cab 4x4 5MT
    Pelfreybuilt Skids. ModCo wheels. Sliders. Cruise Control. Intermittent Wipers. Fog Lights.
    I've been barless for almost 6 years now. I've had a couple white knuckle moments on the freeways around town, but never felt compelled to put it back on.
    Its_Taconie likes this.
  2. Jan 19, 2024 at 7:36 AM
    Its_Taconie
    Its_Taconie Well-Known Member
    Nelson
    North Hollywood
    2007 Tacoma DCLB PreRunner
    Fox Racing 2.5 (F); 2.0 (R), Archive Garage Leaf Springs, hanger/shackles, shock relocation, U-Bolt Flip Kit PLM P37 (TE37 Knockoffs) Bronze wheels, Nitto Ridgeline 35s, C4 Overland Bumper, Total Chaos Uppers, Outgear Solution HC Swingout, OTTune 4.88 Nitro Gears
    I've heard it isnt that noticeable, only on abrupt/quick turns. The shop where my truck is at the moment recommend to leave it on.
  3. Jan 19, 2024 at 7:39 AM
    TacoTuesday603
    TacoTuesday603 I welded it helded
    Jack
    New Hampshire
    2011 OR DCFB
    Fox and Locked suspension 63's Skinny 33's
    I dont have mine on with 6112's and I dont mind a bit. I have an 80 mile round trip commute every day.
    Its_Taconie[QUOTED] likes this.
  4. Jan 19, 2024 at 7:42 AM
    Bikinaz
    Hey You!
    Phoenix, AZ
    Yep, maybe I'm an expert driver and maneuvered Bessie past impending doom at 75, but I don't think Bessie would have performed any better with it on. :D
  5. Jan 19, 2024 at 7:56 AM
    Reapacheap
    Reapacheap Well-Known Member
    Kam
    Memphis/Bay Area
    2015 TRD sport double cab
    All-pro Fox 3" lift, FN wheels, 33" general M/Ts
    I'll take a look at those posts tonight. On my way to work I noticed trac off and engine check lights on. Could these be related? Never had these lights on my previous ~1" lift
  6. Jan 19, 2024 at 9:05 AM
    Yacob_D
    Yacob_D It's Fine, Leave It.
    Jacob
    The J
    08 Red, AC
    Couple nuts and bolts 4x converted
    Same - the commute, I did toss on some 700lbs coils. Little different valving on the 6112s compared to King, Fox, but No Sway Gang for the W!
  7. Jan 19, 2024 at 11:11 AM
    TacoTuesday1
    SD CA
    there’s nothing to hear. You take it off and feel the difference.
    if your suspension is not $100 it does a better job at working on its own, than a $100 suspension.
    Low flat cars with sway bars also have cheap basic untuned suspension with sway bars to bandaid poor design.
    See: Audi. Why do they put a front sway bar. Because the cars are nose heavy understeering pigs with the drivetrain a mile in front of the axle line instead of behind it. That on stock suspension don’t ride well.
    certain spindle gussets do not allow use of a sway bar. Made by shops that build trophy trucks who dont run sway bars on their vehicles or ones they work on.
    Its_Taconie[QUOTED] and Yacob_D like this.
  8. Jan 19, 2024 at 2:14 PM
    Dr3w
    Dr3w Well-Known Member
    Drew
    805
    2007 White DCSB Sport
    Wolfbox mirror dashcam, Joying head unit and YotaNation center console mount
  9. Jan 19, 2024 at 2:15 PM
    fasteddieyj
    fasteddieyj Well-Known Member
    Ed
    Hanover, PA
    2015 camping/mild wheeling rig. 2014 DD
    Drove it to work today since we were getting 4 or 5 inches of snow. The fact that I left early and took all backroads home was merely a coincidence. Unfortunately most of the roads were fairly clear, but I did find a few that hadn't been plowed.
    RickE24, BearB, jackn7 and 13 others like this.
  10. Jan 19, 2024 at 2:21 PM
    dpele
    dpele Pele Prints Vendor
    Dan
    Edmonton, Alberta
    2010 Tacoma DCSB
    Elka 2.0 w/ OME Dakars, 285/70/R17 Duratracs, & more!
    outdoorgb, Crom, BraddahRO and 12 others like this.
  11. Jan 19, 2024 at 2:29 PM
    Its_Taconie
    Nelson
    North Hollywood
    that looks awesome. Was the radio plug and play without splicing any wires? I had best buy remove a radio I purchased through a month ago cause it was acting up but they left the reverse, speed sensor and brake wires loose. I have no idea where they would be wired to on the new radio I plan on installing.
  12. Jan 19, 2024 at 2:52 PM
    Dr3w
    Drew
    805
    Yes, joying sends a harness specific to your truck. Everything is completely plug and play.
    Crom and Tatts521 like this.
  13. Jan 19, 2024 at 7:56 PM
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
    Info on mirror install?
  14. Jan 19, 2024 at 7:59 PM
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Fun was had entirely as an afterthought.
    fasteddieyj[QUOTED] likes this.
  15. Jan 19, 2024 at 8:00 PM
    Yacob_D
    Jacob
    The J
    08 Red, AC
    https://www.amazon.com/gp/product/B0895NMDKT?ie=UTF8
    I picked up one of these guys. Very similar and easy to install. Hard wired in to the truck with turn key on and off. Front and rear cams which can be switch or side by side. Just another option :thumbsup:
  16. Jan 19, 2024 at 8:38 PM
    Dr3w
    Drew
    805
    Yacob_D, oldtoyman and Wildstang70 like this.
  17. Jan 20, 2024 at 3:26 AM
    TegoTaco
    Ontario, Canada
  18. Jan 20, 2024 at 4:53 AM
    flatt-taco15
    flatt-taco15 Well-Known Member
    2015 DCSB TRDOR
    RCI full set steel skid plates 4x Innovations Sliders Rough Country 2" front spacer 1" rear steel block spacer Bird Dawg TechDeck
    That looks really good. Sorry if you have already divulged the Joying model but can you please post a link for it?
  19. Jan 20, 2024 at 5:23 AM
    dborrer
    dborrer Well-Known Member
    Mr. Dan
    St. Augustine, FL
    2006 Tacoma TRD Sport 4x MT
    2018 new Frame (thank you Rust!), FJ T-case swap. SPC(LR) UCAs, Bilstein 5100s front - rear, OME 883 at 0, HeadStrongOffRoad 3 leaf progressive AAL, MESO custom 2nd gen (Red/White) LED dome & Ultimate Maps, Spyder Halo Projector w LEDs (which SUCK), Spyder LED tails
    you used the wrong power resistor... ask me how i know... took me three tries to get the correct ones...
  20. Jan 20, 2024 at 6:06 AM
    Dr3w
    Drew
    805
    This one clips on top of the OEM mirror
