  1. Jan 29, 2024 at 8:10 PM
    Mauinokapoi
    Mauinokapoi Member
    Kris
    Work in progress
    DAACCDCE-1D40-4EA1-915A-6F492864AC5F.png Also this hahaha . Theft preventative measures
    Ricardo13x, Yammer and RickE24 like this.
  2. Jan 29, 2024 at 8:34 PM
    pahaf
    pahaf Well-Known Member
    paul
    NorCal
    2015 Tacoma TRD Off Road
    Bilstein 6112/5160 OME Meduim leaf pack JBA HD UCA 3* retard exhaust gear TRD Pro Sema rims 265/70R17 Falken Wildpeak AT3W
    Hey….that’s my thing lol
  3. Jan 29, 2024 at 8:35 PM
    DJ IslandBoy
    DJ IslandBoy Well-Known Member
    Dave
    North Central WA
    2008 4x4 Tacoma Access cab
    how do you get power from the mirror? Is there a thread on this or a video somewhere?
    Interested for a dash cam. And there’s plenty of power for a cam that won’t blow a fuse or something?
  4. Jan 29, 2024 at 9:05 PM
    DJ IslandBoy
    Dave
    North Central WA
    hopefully the greasy dirt that was all over my latex glove from fiddling around squeezing my hand and bulb in there doesn’t burn mine out. Just replaced both this weekend.
  5. Jan 30, 2024 at 5:00 AM
    AStinkyBumb
    AStinkyBumb Well-Known Member
    Indiana
    2013 DCLB SR5 4x4
    When I did my lift I found it easiest to do front all at once and rear all at once that way if something goes bad you can still limp around looking goofy with one end in the air.
    For rear springs I lifted the rear end just enough so the axle and rear springs could flex to full stretch without hitting the ground then I put a jack under the pumpkin lifted a bit and undid all the connections. make sure you undo the brake line bolt so you don't overstretch the soft lines. then once everything is disconnected from the springs drop the axle a little and then you can undo the springs from the truck. this also allows for a taller spring to be reinstalled with the axle lower. Then you want to just snug everything up and put the truck back on its tires THEN torque everything. Otherwise you get binding issues if you don't torque at full weight.
    I am not familiar with Atlas springs but are they 4" of lift? If so how far do they droop and how far do they squish when flexed? If they droop a bunch your shocks and brake lines will be act as a limit strap if you aren't replacing them from stock which is not good at all. I would highly suggest getting longer soft lines as well as longer shocks. If they lift 4" and flex further than that you could get away with B110 shocks which are made for 3-4" lifts or at the very least 5125s which are made for 2-3.5" lifts. soft brake lines are made by a bunch of different companies just get braided to add some strength to them. I went with Wheelers 4" extended lines they went on great, getting the stock ones off was the biggest issue I had of my entire rear end. Also are you planning a carrier bearing drop bracket? lots of guys have vibration issues on take off after lift because drive lines are no longer aligned.
    For the fronts the UCAs will give you a fit when you try to pull the long bolt out because the bolt contacts the inner fender before being completely removed. There are two common ways of getting past this. 1) buy spare bolts, cut the stock ones and replace the bolts in the opposite orientation or 2) grab some vice grips and bend the fender enough to get the bolts out then back in. I bent the fender cause it was pretty easy to do and I didn't have to replace the bolts. Other than that UCAs are pretty easy just get everything looking close so you can drive it to the alignment shop and be sure to give the alignment shop the user manual from SPC if it has alignment specs included. My JBAs had a couple pages on caster, camber, and toe specific from JBA. Otherwise most alignment shops align to stock spec which wont work with a lift. I have heard SPCs have much more adjustment options and some times throw off new alignment techs (and some skilled if they have never seen SPCs)
    Carrier bearing drop kit: https://www.headstrongoffroad.com/store/p126/Old_Man_Emu_Carrier_Bearing_Drop_Kit_-_FK29.html
    Wheeler's extended rear brake lines:
    Bikinaz likes this.
  6. Jan 30, 2024 at 5:46 AM
    mrproduxn
    mrproduxn Well-Known Member
    steve
    Retired DoD SE VA
    Tacomas 1987,2000,2008, 2016,2012,2008
    Retired/Hobbyist old as f***
    Having just replaced 2nd gen old stock for new 3rd gen stock leaf springs last weekend I can tell you that, simply swapping stock 3 leaf for stock 4 leaf, working in the driveway, we came very close to stretching brake hoses beyond the limit. Not a bad job, especially with a 2nd set of hands, to slide out the old and slide in the new springs. I would not install any lifting springs without extended brake lines. Also, as stated in the previous post, stock shocks would be no good with any lift.
  7. Jan 30, 2024 at 8:19 AM
    IntellaSync
    IntellaSync Member
    Steven
    2013 Black Tacoma SR5 Access Cab PreRunner
    TRD Wheel/Tire Pkg, TRD Antenna, TRD Air Valve Cover, TRD Bed Mat, K&N Engine Air Filter, Bosh HEPA Cabin Air Filter, JCV KW-M730BT Apple Car Play, Interior LED lights, blackout 3rd brake, Window Tint, Hood and Window Air Deflectors, TRD Chrome Exhaust Tip, UWS Low Profile Tool Box, Toyota Trailer Receiver Cover.
    2013 PreRunner 2016 Sport Wheels, 2024 TRD Pro center cap, Heritage Grill, UWS low profile toolbox, Running Boards, all lighting replaced with LED inside and out. Rancho Shocks and Struts. Infinity tweeters and mid range Speakers, Alpine under seat sub and amp. TRD shift knob and JVC media player. Replaced both inside door handles with chrome from Scion. Painted calipers. Bridgestone A/T Revo 3’s.
  8. Jan 30, 2024 at 8:42 AM
    powder1134
    powder1134 Well-Known Member
    2014 Tacoma TRD Off Road
    Good idea to use 2 ratchet straps. I wrap them around the rear axle, one anchored towards the front of the truck, and one towards the rear. This way, you can use the ratchet to pull the axle forward or back to get it to seat.
  9. Jan 30, 2024 at 9:07 AM
    mrproduxn
    steve
    Retired DoD SE VA
    +1 for access cabs 2016 on 5100s vs 2012 stock vs 2008 on 2022 OR struts a.jpg
  10. Jan 30, 2024 at 9:51 AM
    banditcamp
    banditcamp Well-Known Member
    daniel
    2015 Super White DCSB Off Road
    That wheel and tire combination on the top blue truck looks so good. I like white letters and machined aluminum in my opinion is the best choice for blue or red vehicles.
  11. Jan 30, 2024 at 10:12 AM
    JRVfromDVT
    JRVfromDVT Well-Known Member
    Southern Vermont
    2006 Tacoma Access Cab
    Got it back from the shop late last night. Turned out just the hard line running to the clutch slave had rusted through. Master cylinder and clutch slave were both fine. $180 later she’s back on the road!
    Nateurboy and jackn7 like this.
  12. Jan 30, 2024 at 10:21 AM
    easleycrawler
    easleycrawler Well-Known Member
    Travis
    Easley, South Carolina
    2014 RC Taco 4wd
    GRNT4R, scrubdug, socartommy and 8 others like this.
  13. Jan 30, 2024 at 10:26 AM
    banditcamp
    daniel
    Nice. I have a white truck too. When I ordered my FN 5 star wheels I was going to get gun metal grey but they were on backorder so I ended up with black. I have thought about machining them down to the raw aluminum but I'm a bit worried I'd screw it up.
    easleycrawler[QUOTED] likes this.
  14. Jan 30, 2024 at 10:52 AM
    Tatts521
    Tatts521 Well-Known Member
    New Jersey, Jersey Shore
    2012 tacoma-04cbr1000rr-22ktm890duke R-19 wr450f-98rm250
    Love the 4runner wheels.
  15. Jan 30, 2024 at 11:24 AM
    Bikinaz
    Bikinaz It wasn't me!
    Hey You!
    Phoenix, AZ
    2014 Regular Cab 4x4 5MT
    Pelfreybuilt Skids. ModCo wheels. Sliders. Cruise Control. Intermittent Wipers. Fog Lights.
    You could buy mine in the tires for sale section. :D
    banditcamp[QUOTED] likes this.
  16. Jan 30, 2024 at 11:28 AM
    banditcamp
    daniel
    Haha. I commented on yours for sale. I'm on the opposite side of the country.
    Bikinaz[QUOTED] likes this.
  17. Jan 30, 2024 at 5:01 PM
    Oregonhillbilly
    Oregonhillbilly Active Member
    Shawn
    Albany, OR
    2015 Bare-Bones SR5 DCSB
    I figure I gained 20 mpg hwy and lowered my carbon footprint around 97%.
    I try to do my part.
    pahaf[QUOTED] likes this.
  18. Jan 30, 2024 at 5:05 PM
    Oregonhillbilly
    Shawn
    Albany, OR
    Don’t have the cash for all the lift parts, so I’m doing a lot of small things and DIY stuff.
    don’t mind the old mudflaps. I’m going to remove them and cut some length off and put them back on. I actually drug a front mud flap going over a speed bump the other day…
  19. Jan 30, 2024 at 5:25 PM
    Brenn1017
    Brenn1017 Well-Known Member
    2nd gen access cab
  20. Jan 30, 2024 at 5:45 PM
    Oregonhillbilly
    Shawn
    Albany, OR
