  1. Feb 12, 2024 at 7:16 AM
    jtweezy
    jtweezy Well-Known Member
    Austin
    2014 4X4 DCSB OR V6
    Do you have a write-up on how you did it?
  2. Feb 12, 2024 at 7:44 AM
    El Tano
    El Tano i am the one who knocks
    Pasadena. CA
    10 Tacoma TRD sport
    Corvette homelink FRONT: 5100 Blinstein set at 0 Procomp 3" leveling kit Allpro UCA’s. REAR: Icon Multi Rate RXT Leaf Pack 5100 Blinstein. 17x9 kMC wheels 0 BS 285/70 17 Wildpeak A/T4W C range Amp research steps. and a bunch of TSB's
    After a full detailing day took her out to play in the snow ( not my choice :annoyed:)
  3. Feb 12, 2024 at 7:50 AM
    El Tano
    Pasadena. CA
    10 Tacoma TRD sport
    So your truck is one of those that identifies as a hybrid….
    jackn7 and 4WDTrout like this.
  4. Feb 12, 2024 at 8:37 AM
    Agoldxj
    Agoldxj Well-Known Member
    James
    Central Pa
    2009 SWB AC
    I don’t I just looked up some videos online. I did it from the bottom making everything way easier to access. I also didn’t change the whole tensioner assembly, just the pulley.
    I basically jacked it up to get it higher in the air, took the skid plate off. Then I took the tension off the belt and locked the tensioner with an Allen key, removed the belt, then swapped the pulleys out.
    The tensioner pulley is reverse thread 40 ft lbs
    Lower number 1 idler 40 ft lbs
    Upper 2 number 2 pulleys 29 ft lbs
    Skawdee likes this.
  5. Feb 12, 2024 at 12:24 PM
    Oregonhillbilly
    Oregonhillbilly Active Member
    Shawn
    Albany, OR
    2015 Bare-Bones SR5 DCSB
    Yep. I live in Oregon, where anyone can identify as anything.
    I did it for two reasons. 1. Some people will think it is really a hybrid. Which amuses me. 2. It’s a subtle troll of the dirt worshippers that know it isn’t a hybrid and will be annoyed when they see it.
  6. Feb 12, 2024 at 2:28 PM
    4WDTrout
    4WDTrout Perpetually dreaming of tall trees & rivers
    Theo
    08 4WD SR5 DCSB
    Total Tacoma nOOb.
    I thought that was mainly a Portland thing when it came to Oregon…
    When I’m up in Grants Pass I don’t see anything of that nature.
  7. Feb 12, 2024 at 3:46 PM
    TacoTuesday1
    SD CA
    even better for this than paint pens you have this
    Tamper marking compound or whatever
    Paint marker = draw on metal
    but this stuff drips on better
    jackn7 and AStinkyBumb[QUOTED] like this.
  8. Feb 12, 2024 at 5:30 PM
    igiles86
    igiles86 Active Member
    Ian
    South Eastern Pennsylvania
    2010 Access Cab, 4cyl, 5 speed, 4x4,
    Installed some Cali Raised molle console panels. Keeps everyday things within arms reach.
  9. Feb 12, 2024 at 7:24 PM
    20somethingwidataco
    20somethingwidataco Yes, my avatar is a real car.
    Will
    Washington State
    2008 AC TRD SPORT M/T
    ACLB 6 SPEED: Suspension: Bilstein 6112s (3rd perch) (F) Taco Lean Spacer Bilstein 5160s (R) TSB Leaf Pack Wheelers Offroad 3 leaf progressive AAL Wheelers Superbump Front Duro Bump U bolt flip kit Duro Bump progressive bump stop 3rd gen TRD offroad sway bar Wheels and Tires: Summit Racing Wheel Dakars (Polished Silver) 285/70r/17 Goodyear Wrangler Duratrax (Load D) "Performance": AFE CAI with custom powdercoated white filter cover MagnaFlow Performance Series Exhaust URD Cam gears XTP Intake Manifold Spacer OTT Torque Tune Brakes: Stoptech Slotted Rotors Stoptech Sport Ultra Composite Brake Pads Wheelers offroad SS brakelines (Front) Interior: Kenwood DD headunit Oem Subaru Kicker Tweeters Alpine 6x9 (Front) & 6.5 (rear) (With Taco tunes speaker mounts) Alpine 500 watt amp Sound Deadening (Doors, Rear "wall", Roof) ODI Rouge Shift Knob Weather Tech Mats Painted/wrapped trim pieces Console Safe Console Vault Gridx Organizer Ram Phone Mount Meso Customs dual color map lights Meso Customs dual color dome light Wet Okole seat covers (Black) Wet Okole center console cover (Black) 1" Seat Raisers (Driver & Passenger) AJT Designs climate control and 4x4 knobs Back Up Camera Lighting: Retrofits (Mini H1's, RGB Halos, 5500k Bulbs)(Lenses wrapped in self healing PPF) Diode Dynamics SS3 Max SAE (Yellow) Diode Dynamics SS5 Pro (Yellow) Driving lights (ditch lights) Anytime fog mod Rigid Industries E series 32" Combo bar (spot/flood) Diode Dynamics XPR Reverse Lights Diode Dynamics XP80 turn signals Diode Dynamics HP5 Third brake light LED brake, parking lights and license plate lights Armor: Apex All Pro sliders BPF steel skid plate Bigass Trailer Hitch Camping/Storage: Tonneau Cover (Truxedo Roll Up) KB voodoo bed bars Pelican Vault (for gear) LED interior lighting Extra D rings in bed (6 total) Custom Powder coated white snow shovel with custom bedrail mounts Amazon special Traction Boards Hi Lift 48" Jack Other: All pro Bed Stiffeners Relentless Fab tailgate panel TRD sport graphics (Turd Gen spec) Anti Sun glare hood scoop wrap (Satin Black) Custom FleeBay grille 4 Hella supertones ECGS needle bearing Many Patches BPF shackle mount (With smittybuilt shackle) Tinted windows (Front/Rear) (18%) Meso Customs gasshole AVS inchannel window visors Diff Breather Kit 2012-2015 Oem Turn signal/folding mirrors (w/ sequential signals) 2012-2015 Oem LED taillights Full Size (285/70r17) spare DIY Larger Engine Splash Guards DIY Vipercut TRD radiator cap AC drip line mod Anti Tweeker tailgate lock
    How do you like that EPS carry?
  10. Feb 12, 2024 at 7:43 PM
    Oregonhillbilly
    Shawn
    Albany, OR
    it mostly is, also Newport, Eugene and Salem.
    4WDTrout[QUOTED] likes this.
  11. Feb 12, 2024 at 9:53 PM
    Yammer
    Yammer Well-Known Member
    Will
    2005 TRD Pre Runner SR5 Access Cab
    Who makes the unit?
  12. Feb 12, 2024 at 10:37 PM
    igiles86
    Ian
    So far so good. Only have about 200 rounds through it. I like the compact size for a carry gun and the reticle is nice and bright. Can't say much for battery life yet. Time will tell.
  13. Feb 12, 2024 at 11:12 PM
    zerotimeouts
    zerotimeouts Well-Known Member
    Nor Cal
    2011 DCSB 4.0 S/C
    Sound deadening on the roof. Next need to build a box for the 8” sub behind seat and rearrange my amps.
    Tatts521, Corny Taco, GRNT4R and 9 others like this.
  14. Feb 13, 2024 at 4:29 AM
    AStinkyBumb
    AStinkyBumb Well-Known Member
    Indiana
    2013 DCLB SR5 4x4
    that was one of the first things I did, I also paint pen'd the bolts there too. I assumed the clack was so loud it had to be one of the arms but they checked out just fine. I drove it to work yesterday and there was no clack going into a parking garage like it normally does so I think I pinpointed the main issue. Gonna re torque everything else in a week or so just cause I was wrenching on things and don't want anything else to back out now
    I havent seen this before Im gonna go look at it now.
  15. Feb 13, 2024 at 9:11 AM
    20somethingwidataco
    Will
    Washington State
    Nice, I'm looking to upgrade from my 407k. Went shooting in the rain and it was awful. Honestly for living in the PNW, an enclosed reticle is a must I feel.
  16. Feb 13, 2024 at 10:29 AM
    4WDTrout
    Theo
    08 4WD SR5 DCSB
    Total Tacoma nOOb.
    :facepalm:
  17. Feb 13, 2024 at 11:09 AM
    Yammer
    Will
    Added Craigslist Smittybilt 3” running boards, $50! Replaced cracked, sunbaked tail lights with Amazonian el-cheapos. IMG_3490.jpg IMG_3491.jpg
    Wildstang70, dpele, pahaf and 2 others like this.
  18. Feb 13, 2024 at 11:59 AM
    mrproduxn
    mrproduxn Well-Known Member
    steve
    Retired DoD SE VA
    Tacomas 1987,2000,2008, 2016,2012,2008
    Retired/Hobbyist old as f***
    Good score on the running boards. I am handicapped and put them on every truck. Excellent door ding protectors.
    Yammer[QUOTED] likes this.
  19. Feb 13, 2024 at 4:06 PM
    sbMT
    sbMT Active Member
    Montana
    ‘09 Off-Road Access Cab
    I replaced my needle bearing with the ECGS bushing and replaced both wheel bearing-hub assemblies (purchased from 05Taco4x4's press service thread- highly recommend). Pretty sure these components were still original at 255k miles. Very grateful to live in a place that doesn't rust & destroy vehicles!
    4WDTrout, drewnali and mrproduxn like this.
  20. Feb 13, 2024 at 4:10 PM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    Mounted the ARB compressor under the hood. Now I need to wire it. I tossed the ARB harness and I'll make my own.
    SoCalSB, Burritopa and Cativelense like this.
