  1. Apr 23, 2024 at 9:25 AM
    TacoEspecial
    TacoEspecial SSSlow
    Mark
    Sacramento
    13 Sliver TRD AC
    BAMF RCLT Deaver Fox 2.5 StopTech Dana 60 37s 475:1
    Were you also using a front locker?
  2. Apr 23, 2024 at 10:40 AM
    Peter603Taco
    Peter603Taco Well-Known Member
    Peter
    New Hampshire
    2013 TRD Sport DCLB
    Finally put my tow package to good use the other day and picked up this rusted out NB2 VVT Miata parts car! Perfect donor drivetrain for my 1992 NA project that I'm building. Did a little over 100 miles towing round trip and still managed to get 15mpg in the taco so I'm happy with that.
    JAGCanada, GRNT4R, SigSense and 12 others like this.
  3. Apr 23, 2024 at 12:04 PM
    EveryDayIsTacoTues
    EveryDayIsTacoTues Well-Known Member
    2012 Pyrite Mica DCLB TRD Sport
    Got to take her on a 500'ish mile trip while hauling some material in the back. Also tested some mattress moving as well. I'll say this much, the Long Bed held a Queen and a Full at an angle easy-peasy using ratchet straps in an X configuration with the gate down. Also, for those that may need this ODDLY specific information, I was also able to transport a Queen Memory Foam mattress in the bed with the tailgate up and tonneau cover down fully enclosed. With the squish of the memory foam and the length wise compression of ratchets, all closed up nice. :rofl:
    Random "beauty shot" at a warehouse park after one leg of the journey.
  4. Apr 23, 2024 at 12:07 PM
    WillyTtaco
    WillyTtaco Well-Known Member
    Bill
    So Cal
    2014 DCSB TRD OFFROAD 4X4
    265/75/16 AT2 BILSTEIN,SNUGTOP MBRP,SPC UCA
    Got a shell! Only took a few years to find the right one at a good price. Love the look and security.
  5. Apr 23, 2024 at 12:12 PM
    xguntherc
    xguntherc Taco Time
    Cory
    East Dallas
    11 TRD Off Road - Black
    Icon Stage 5, Nexen Roadian MTX, Fuel KB43 Block wheels, Baja Design XL 80s, Baja Squad Pro WC fogs, TacoVinyl grill, "dudebro" lights, Prinsu rack, trail rash pinstripes, BAMF hybrid bumper, sliders, and LCA skids, and a few other things I can't think of.
    Watched her pass 150k miles. That's about it.
    jackn7, dpele and EveryDayIsTacoTues like this.
  6. Apr 23, 2024 at 12:41 PM
    TacoTuesday1
    SD CA
    opted to keep front open to avoid breaking things.
    Truck was climbing up hill where I assume most weight was rear.
    truetrac rear, 35@16psi
    I took a bad line. Lesson learned should’ve backed up, lined it up, and then sent it. To be off the clutch, rev, spin the tires, and have some momentum to safely bounce it up.
    It was tricky because back up is a cliff teetering on the edge loose ground.
    but that experience def showed me there may be a place for:
    -longer rear shocks for better contact
    -radio for spotter
    -crawlbox
    or more realistic
    -hand throttle
    and potentially bump start it. Heard about it. Don’t know if it’s only water.
    Might practice it first.
    Basically idea is this:
    -clutch start cancel
    -brake, 1st gear
    -turn the key so truck starts climbing without clutch
    -immediately get on the gas and spin tire
    -might avoid rollback
    -pray the stock starter is up to that
    I mean simple version
    Basically climbing up a wall the truck needed more momentum to bounce its way up
    maybe a front locker would’ve helped but too late. Theres folks who do without it.
    honestly if someone is at a shop and not trying to breathe that, water and drain bucket.
    Done that on calipers. Spray water, degreaser, brush it clean and then rinse it off. That cuts down on the dust. Water catches it rather than going airborne with compressed air that has warnings to not use around the brake system.
    even if over the years they switched to different materials in brake systems, it’s still not recommended to breathe.
    jackn7 likes this.
  7. Apr 23, 2024 at 2:18 PM
    mrproduxn
    mrproduxn Well-Known Member
    steve
    Retired DoD SE VA
    Tacomas 1987,2000,2008, 2016,2012,2008
    Retired/Hobbyist old as f***
    Better do a deep inspection on the bumper frame and supports. They are most likely toast.
    Thundertank[QUOTED] likes this.
  8. Apr 24, 2024 at 9:43 AM
    busychild
    busychild Well-Known Member
    Alberta, Canada
    14 DCSB TRD
    TRD Exhaust, TRD Sport Short Shifter, Skid Plate, K&N Intake, Bakflip G2 Cover, Husky Liners, Falken Wildpeak ATW3. Alpine ILX-259, JL Stealthbox w 10TW3, JL XD600, 2x JL 650-x (front and rear doors), Subaru Kicker Tweeters, Motegi Traillite 17x8.5, Westin Side Steps .
    Removed my crusty old N-Fab Nerf steps replaced with some Westin Outlaw Nerf steps. Think the plan was getting Prinsu rack and having a full step bar for easier access IMG_1975.jpg
  9. Apr 24, 2024 at 10:30 AM
    Makanahi
    Makanahi Member
    Mark
    07 tacoma prerunner 4.0 V6
    Stock
    Doing my 07 tacoma w/53,000mi., coolant flush & replacing spark plugs to denso iridium.
    478DblSport and point45 like this.
  10. Apr 24, 2024 at 12:04 PM
    Tacoma13_NC
    Tacoma13_NC Well-Known Member
    2013 SR5 4x4 DCSB 4.0L (Black) OTT
    Bilstein 6112/5160; JBA HD UCAs; 1.5" 3-Leaf AAL's w/ overload; OME CB drop; RCI aluminum skids w/ catalytic converter shields; Wheeler's U-Bolt flip kit with Superbumps; TRD Pro 4-Runner Wheels; Falken Wildpeak AT4W (265/70/17); Diode Dynamics SS3 Sport (Yellow) fogs; CaliRaised 32" hidden light bar; Morimoto XB LED headlights with upgraded HD harness; Unifilter mod; Rear-View mirror riser bracket; Truxedo Lo Pro tonneau cover; New OEM color-matched grille; Bumpershellz color-matched rear bumper cover; Ultra-Gauge MX 1.4 w/Spiker mount; Baja Designs S2 Sport Ditch Lights with SDHQ brackets; Fog Light Anytime Mod; Overland Tailor Tune (OTT); Yaesu FTM-150 GMRS/Ham radio; Viofo A229+ Dash Cam
    Greased my driveshaft and JBA UCAs today. I also lubricated the inner/outer tie rod ends and swaybar end links with white lithium grease injected into the boots with a syringe. I then cleaned them with some 303 protectant and sealed the puncture holes with RTV silicone.
    BraddahRO, GRNT4R, dpele and 7 others like this.
  11. Apr 24, 2024 at 12:15 PM
    4WDTrout
    4WDTrout Perpetually dreaming of tall trees & rivers
    Theo
    08 4WD SR5 DCSB
    Total Tacoma nOOb.
    Clean truck
    Tacoma13_NC[QUOTED] likes this.
  12. Apr 24, 2024 at 12:16 PM
    Tacoma13_NC
    Thanks!
    4WDTrout[QUOTED] likes this.
  13. Apr 24, 2024 at 12:33 PM
    E4x4
    E4x4 Active Member
    2015 TRDOR 6MT
    scleaf, dpele, TomTwo and 14 others like this.
  14. Apr 24, 2024 at 3:16 PM
    Raceface35
    Raceface35 Well-Known Member
    Tim
    Murrieta, CA
    2011 Tacoma TRD OR
    King 2.5 Ext Travel Front & Rear, Icon Delta Joint UCA, OME Dakar "Heavy" Leaf Springs, 33x12.5R17 Ridge Grapplers, CaliRaised Sliders, RCI Bed Rack, Viair On-Board Air
    Got the roof of the wedge on!
    scleaf, dpele, Hayden334 and 2 others like this.
  15. Apr 24, 2024 at 3:17 PM
    BigCountry762x39
    BigCountry762x39 Well-Known Member
    TL
    PNW, Oregon!
    2009 Tacoma, with the cool white paint peel
    Arb Deluxe bull bar Front Bumper Ironman4x4 12k winch synth line AFE Intake OME 2.75in Dakar Leaf springs (R) Fox 2.0 bypass shocks (R) Bilstein 6112 (F) 33's on KMC wheels off road lighting comfort mods Redrock HD roof rack Retevis rt95 Radio Slotted Rotors and HD pads
    how close to the door are you when you roll back out? looks super close to the door
  16. Apr 24, 2024 at 3:28 PM
    Raceface35
    Tim
    Murrieta, CA
    2011 Tacoma TRD OR
    I just measured lol. It’s 4” of clearance and I’ve got a 7’ garage. I’m on an OME heavy pack with the 2nd overload leaf removed in the rear and on 295/70r17’s
  17. Apr 24, 2024 at 7:32 PM
    Reapacheap
    Reapacheap Well-Known Member
    Kam
    Memphis/Bay Area
    2015 TRD sport double cab
    All-pro Fox 3" lift, FN wheels, 33" general M/Ts
    Do not fit
  18. Apr 24, 2024 at 7:46 PM
    TacoTuesday1
    SD CA
    Extra Hard Taco likes this.
  19. Apr 24, 2024 at 7:48 PM
    mlevimadden
    mlevimadden Well-Known Member
    Colorado
    13 DCSB TRD OR
    Greased driveshaft, changed oil, and rotated tires on my 2013 at 21k miles.
    jackn7 likes this.
  20. Apr 24, 2024 at 8:03 PM
    ProStar197
    ProStar197 Well-Known Member
    2013 TX Baja DCSB
    Washed it and installed the Morimoto third brake light. Received the cat shield so will install that this weekend.PXL_20240425_025552489.MP.jpg PXL_20240425_025540274.MP.jpg
    dpele, jackn7, Wildstang70 and 2 others like this.
