  1. Jun 16, 2024 at 9:53 AM
    99TacoDriver
    99TacoDriver Well-Known Member
    South Louisiana
    OME 885x/5100s/LR UCA/3 leaf AAL/275/70/17 Terra Trac X-Venture
    The filter is hard to get off if you change it while engine is hot. At least in my experience it’s much easier to take off when the engine is cold.
    Fenwick1993[QUOTED], stbear and Mully like this.
  2. Jun 16, 2024 at 11:26 AM
    Tiedie
    Tiedie The Only Shantytown Resident.
    David
    WFOY
    Katzkin, Dobinsons full suspension. Redlinegoods console cover and door panel arm rests, Double USB charger in dash installed, Ballistic Jesters 16x8. BlackVue DR 590 Dash Cam
    Finished up this project today. Platform and locking storage compartments.IMG_20240616_135836113.jpg
  3. Jun 16, 2024 at 1:14 PM
    mrproduxn
    mrproduxn Well-Known Member
    steve
    Retired DoD SE VA
    Tacomas 1987,2000,2008, 2016,2012,2008
    Retired/Hobbyist old as f***
    This is why I love the old 2nd gen access cab fold flat rear seats. No need to build anything for the dog or packages. Just put a towel over it and good to go. Hated the new style in my 2012 and 2016 access cabs.20240616_160745.jpg
  4. Jun 16, 2024 at 1:18 PM
    Tiedie
    David
    WFOY
    I would have loved it too.
  5. Jun 16, 2024 at 1:29 PM
    TacoTuesday1
    SD CA
    determined that my 5th no spare TPMS simulator is leaking from the PCV cups seam
    Plan is try to abrade, clean, then smear RTV
    over pressure with bike tire pump
    Bring down to 29psi cold door spec
    re try getting rid of warning on dash
    I wonder the range of it. If it’s OK to store in roof cargo box or if that is too far away
  6. Jun 16, 2024 at 1:53 PM
    Dr3w
    Dr3w Well-Known Member
    Drew
    805
    2007 White DCSB Sport
    I did the same and store it in the storage box in the bed with no issues
  7. Jun 16, 2024 at 2:18 PM
    Citra
    Citra Well-Known Member
    Columbia River Gorge
    2014 TRD Sport
    Just recently picked up a 2014 TRD Sport and have been fixing it up here and there. Just finished replacing the OEM shocks with strut spacers that were already on the truck for Bilstein 5100's with some Dobinsons coils I found being sold locally. Went ahead and slapped on some JBA UCA's as well as new sway bar bushing and end links.
    Went to get an alignment afterwords only to be told it was impossible due to bent cam tabs so there's one more thing to try and fix up now (I guess it's time to learn how to weld?)
    sberkley92, lo2hi, drewnali and 9 others like this.
  8. Jun 16, 2024 at 2:38 PM
    700cinema
    700cinema Well-Known Member
    2014 Tacoma V6 4.0L 4x4 AC FLATBED UTE
    hangers and shackles install greatly improved travel and ride. May need to take a leaf or two out of my AP Expo springs…. Install was not as daunting when you gather up the right tools
  9. Jun 16, 2024 at 3:06 PM
    ucdbiendog
    ucdbiendog Well-Known Member
    Reno, NV
    2014 DCSB TRD OR
    Bilstein 6112 + 5160 + Dakar MD, Stubbs HD-SKO sliders, BAMF skids, BAMF front bumper, Relentless Rear
    welcome to TW! AKA the money pit. Nice lookin truck!
    Old Marine Cal and Citra[QUOTED] like this.
  10. Jun 16, 2024 at 3:39 PM
    Fenwick1993
    Fenwick1993 Hillbilly
    Not Fenwick
    Chesapeake, VA
    96 Tacoma 5Lug, 2015 PreRunner
    Stonewall is the fattest 5 lug slug ever
    Hadn't thought of that, but you're surely right. Heat expansion and all. I'm sure it didn't help my case lol. It'd been probably a good hour and a half, but there was still some heat left.
    lynyrd3 and 99TacoDriver[QUOTED] like this.
  11. Jun 16, 2024 at 6:06 PM
    dwcfastrice
    dwcfastrice Bacon makes everything better.
    David
    Southeast PA
    2007 Silver Mica DCSB
    So far: 2.5" Icon Lift, Steel Front bumper, steel rear bumper, Cali Raised Bed Stiffener, 12Volt.Solutions remote start, Stereo upgrade, A Pillar Ram Mounts, BAMF Behind the grill light mount with Sylania 20" bar; KB Voodoo Max 22" Rack, CVT Awning, Decked drawer system, pod lights
    Finally got the mushroom installed.
  12. Jun 17, 2024 at 5:13 AM
    ThePositiveWay
    ThePositiveWay Well-Known Member
    SE Tennessee
    06' DCLB TRD Sport Super White
    Sony XAV-9000ES Headunit, Steering Wheel Controls, Sony ES Series Door Speakers, Alpine PWE-S8 Sub
    At 202k, I did a pan drop service on my transmission. Cleaned the pan and magnets, replaced the strainer, and then did a full fluid exchange (used 14qts) by pulling the hose between the top of the auxiliary cooler and the bulkhead. Some 3/8 ID tubing and a garden sprayer made it easy to collect the fluid coming out of the cooler in a jug and pump new fluid back in through the bulkhead. Took me ~30 minutes for the fluids portion. Pulled out 13 qts, put in 14, had about 1/2 qt come out when I pulled the overflow plug after running the temp check.
  13. Jun 17, 2024 at 6:43 AM
    danteisme
    danteisme Well-Known Member
    South Western PA
    06 DCSB Sport, 96 Integra GSR
    Installed the redarc brake controller (still troubleshooting that) and installed rear timbrens to get ready for the camper's maiden voyage this weekend.
  14. Jun 17, 2024 at 12:12 PM
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
    What kit did you go with?
  15. Jun 17, 2024 at 4:26 PM
    308savage
    308savage Well-Known Member
    Adam
    East Tennessee
    2012 Tacoma TRD Sport DCSB
    Leveling kit, roll bar
    Pulled our 3,700 lb pop up this weekend for the first time with the brake controller hooked up. I’ve got the Tekonsha and had to set the boost all the way up to feel the camper brakes working.
    danteisme[QUOTED] likes this.
  16. Jun 17, 2024 at 4:35 PM
    Wildstang70
    Wildstang70 Active Member
    R-Squared
    Dallas, TX
    2015 Super White TRD OR (DCSB)
    Wheels & Tires: Stealth Custom Series 17x8.5 -10mm Ray10s in Brushed Copper w/BFG KO2 265/70/17 Front Suspension: Bilstein B8 6112 Front Coilover Kits Rear Suspension: Bilstein B8 5160 w/Remote Reservoir Shocks ATS Springs Heavy Duty Rear Leaf Packs Armor: Body Armor 4x4 Hiline Front Winch Bumper Toyota TRD PRO Front Skid Plate Recovery: Superwinch Talon 9.5sr Winch w/Synthetic Line Maxsa 20322 Metal Gripped Escaper Buddy Traction Boards Lighting: AlphaRex NOVA-Series LED Projector Headlights Black AlphaRex LUXX-Series LED Tail Lights Black-Red Extreme LED Sx6 Slim 38" Light Bar AngelMa 22'' Dual Color Amber/White LED Light Bar iJDMTOY Yellow Lens 24W High Power LED Wide Angle SAE Flood Beam Fog Light Kit Exterior: ARE CX Classic Truck Cap w/Fabric Liner UpTop Overland Alpha Double Cab Roof Rack UpTop Overland Alpha eX Tacoma Cap Rack Dirtcom Trail Swing w/Accessories Storage: Decked Drawer System Pelican V800 Vault Double Rifle Cases
    Welcome to Tacomaworld! You're going to have a blast setting up your rig.
    Citra[QUOTED] likes this.
  17. Jun 17, 2024 at 4:53 PM
    Williston
    Williston Well-Known Member
    New England
    2014 Tacoma 040 SR5 4x4 DC SB V6 AT5 Tow Pkg Entune+ Mostly stock with a few OEM mods.
    Stock (99.999%) OEM Bed Floor Mat, Front Bed Rail Cargo Net and hooks, Auto-Dim mirror w/Compass and outside Temperature display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. (winter) OEM All-Weather floor mats (summer).
    Are the switch backlights on this unit bright like the all the aftermarket ones I have seen, or are they more on-par with the OEM stock drivers switch backlighting on the Tacoma? It's the one thing that has kept me from doing this mod.
    Thanks in advance.
  18. Jun 17, 2024 at 4:55 PM
    apy_camper
    apy_camper APY CMPR
    Christian
    Fredericksburg, VA
    2015 MGM DCLB SR5
    SR5 package Tow package A.R.E. midrise camper shell with roof rack
    ...I'd rather not talk about it.
    lambit, ridefreak and PilotBoy352 like this.
  19. Jun 17, 2024 at 7:04 PM
    steveo27
    steveo27 Ask me about my weiner
    Pittsburgh
    '11 TRD Off Road & 1992 VW GLI
    The same shit everyone else has.
    Tiedie likes this.
  20. Jun 17, 2024 at 8:02 PM
    Tacoma13_NC
    Tacoma13_NC Well-Known Member
    2013 SR5 4x4 DCSB 4.0L (Black) OTT
    Bilstein 6112/5160; JBA HD UCAs; 1.5" 3-Leaf AAL's w/ overload; OME CB drop; RCI aluminum skids w/ catalytic converter shields; Wheeler's U-Bolt flip kit with Superbumps; TRD Pro 4-Runner Wheels; BFG KO2's (265/70/17); Diode Dynamics SS3 Sport (Yellow) fogs; CaliRaised 32" hidden light bar; Morimoto XB LED headlights with upgraded HD harness; Unifilter mod; Rear-View mirror riser bracket; Truxedo Lo Pro tonneau cover; New OEM color-matched grille; Bumpershellz color-matched rear bumper cover; Ultra-Gauge MX 1.4 w/Spiker mount; Baja Designs S2 Sport Ditch Lights with SDHQ brackets; Fog Light Anytime Mod; Overland Tailor Tune (OTT)
    I've never seen the aftermarket ones in person, but these are not terribly bright. I wouldn't say they are as subtle as the factory ones either, but very tolerable when driving at night. Mine are the blue ones but I wish I had the white. I use the auto switches almost every day.
