  1. Oct 16, 2024 at 4:39 AM
    fasteddieyj
    fasteddieyj Well-Known Member
    Ed
    Hanover, PA
    2015 camping/mild wheeling rig. 2014 DD
    I really like it. I have had it on my other truck for several years now. Light output is pretty good and I also like that it at least seems a little whiter. I took some before and after pics, I'll have to look at them tonight and see how they turned out. Total cost was around $150 for the harness and the bulbs run $15-20 a piece depending on where you get them. Install takes an hour tops not including making the bracket for the relays.
    reallifedog likes this.
  2. Oct 16, 2024 at 8:10 AM
    PNW15
    PNW15 Well-Known Member
    2015 Tacoma DC LB SR5
    Which puddle lights did you use? Any resources you would recommend?
  3. Oct 16, 2024 at 8:22 AM
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, Kings, Locked, 295s and more.
    Retired now, so it doesn't get used very much.
    Took a load to the dump. Great truck, has never failed me.
    LG888, UMC, jackn7 and 14 others like this.
  4. Oct 16, 2024 at 12:41 PM
    Raceface35
    Raceface35 Well-Known Member
    Tim
    Murrieta, CA
    2011 Tacoma TRD OR
    King 2.5 Ext Travel Front & Rear, Icon Delta Joint UCA, OME Dakar "Heavy" Leaf Springs, 33x12.5R17 Ridge Grapplers, CaliRaised Sliders, RCI Bed Rack, Viair On-Board Air
    She’s alive! Canvas is up, now for the windows…
    UMC, Corny Taco, mark_tga and 11 others like this.
  5. Oct 16, 2024 at 6:59 PM
    blackgen2tacoma
    blackgen2tacoma Well-Known Member
    Andrew
    2013 black Tacoma limited
  6. Oct 16, 2024 at 10:39 PM
    Canadian Caber
    Canadian Caber R.I.P Layne Staley 67-2002
    Les
    B.C. Canada, eh
    2020 TRD Sport DCLB 4X4 Super White
    Thanks for the details. Most do Fluid Film here so I was interested in someone actually applying Cosmoline. Yeah, the price of the rp342 scared me away. At $20.00 per can of the CRC corrosion inhibitor was a better price point for a similar type product. I’ll be curious to see how it holds up to some heavy rain we recently received. Also expecting a Atmospheric River for 3 days coming up. I did use a little corrosion free too I got from Canadian Tire. Just on the spare tire mechanism and chain. I need to consider the inside of the front boxed area of the frame. Need to find a 360 straw spray adapter. Otherwise it was all the exposed areas of the C-channel frame with the CRC and anywhere else that was exposed. Not being in the rust belt, I’ll have to see how everything holds up when I inspect underneath next summer. I do regularly spray underneath at the pay and spray in the middle of winter if weather permits to keep the salt washed off as much as possible. Also, the 3rd gens have some sort of goop applied at the factory on all the frame lap joints. Hopefully that helps too. Really sucked crawling around on a tarp over a gravel driveway. Lift would have been awesome!
    Factory goop on lap joints.
  7. Oct 17, 2024 at 9:52 AM
    TacoTuesday1
    SD CA
    Tried to start it unsuccessfully twice before it ran the third time.
    wondering what it is now on top of the other 10-20 things it needs.
    maybe a starter. Creeping on 200k.
    Maybe the shitty stock fuel pump that should be replaced anyway. Guess I can start by throwing that at it see if it changes anything (the URD replaceable filter kit I would think)
    ACEkraut likes this.
  8. Oct 17, 2024 at 10:50 AM
    ACEkraut
    ACEkraut Well-Known Member
    Aaron
    Durham, Maine
    2014 DCSB TRD Off Road
    Was the battery disconnected for awhile?
  9. Oct 17, 2024 at 2:04 PM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    Got it today! Thanks again!
    canopycarl[QUOTED] likes this.
  10. Oct 17, 2024 at 4:09 PM
    joeyv141
    joeyv141 Well-Known Member
    Virginia
    08 DCLB 4x4 V6 TRD Sport
    On my previous 07 tacoma I had installed flush mount LED pods in the rear bumper. I put off adding rear lights on my current 08 tacoma till I just moved to a new house without good external lighting/street lights, so it can be annoying backing in when its dark. While I liked the flush mount pods I decided I didnt want to bother cutting the bumper this time. I previously moved the trailer plug to the side of the license plate, so I decided to use the threaded bolt holes to mount the light bar.
    Here is the light bar and switch I used, I would have rather all flood light but I liked the dimensions of this light bar.
    Over all I like how it came out, I did have to use flat stock to drop the mounting brackets down about 2 inches so the light would be flush with the bumper.
    20241017_170359.jpg 20241017_170404.jpg 20241017_170450.jpg 20241017_170529.jpg 20241017_184513.jpg
    HKG, LG888 and Bravisimo like this.
  11. Oct 17, 2024 at 4:39 PM
    Smills91
    Smills91 Well-Known Member
    Is there a simple plug n play harness to connect a back up lights like that into the taillights
  12. Oct 17, 2024 at 4:44 PM
    joeyv141
    Virginia
    Mine is not hooked up to the backup lights, I have a switch so I can use it anytime I want. I dont see why you couldnt tap into the backup light wiring for a relay signal so they do come on with the reverse lights.
  13. Oct 17, 2024 at 5:13 PM
    Corny Taco
    Corny Taco The Sauce
    Blake
    Columbus/Atlanta Georgia
    06 SR5 DCSB Prerunner
    -33 inch Nitto Ridge Grapplers -18 inch fuel kranks -Bilstein 5100s -OME normal duty dakars -Toytec/Eibach coils -Magnaflow off-road pro exhaust -Prinsu roof rack -nfab rock guards -EBay Faux Trd Pro Grille -Custom basshead audio build in progress
    Painted over the new frame ground location today.
    also found that the rear clunk I’ve been hearing for months is a blown shock. New set of 5100s going in.
  14. Oct 17, 2024 at 5:23 PM
    rblalliance
    rblalliance let the wookie win
    08 TRD OR DCSB 4X4
    Did you paint the fuel filler door or just left it black?
  15. Oct 17, 2024 at 5:32 PM
    Tacoma13_NC
    Tacoma13_NC Well-Known Member
    2013 SR5 4x4 DCSB 4.0L (Black) OTT
    Bilstein 6112/5160; JBA HD UCAs; 1.5" 3-Leaf AAL's w/ overload; OME CB drop; RCI aluminum skids w/ catalytic converter shields; Wheeler's U-Bolt flip kit with Superbumps; TRD Pro 4-Runner Wheels; Falken Wildpeak AT4W (265/70/17); Diode Dynamics SS3 Sport (Yellow) fogs; CaliRaised 32" hidden light bar; Morimoto XB LED headlights with upgraded HD harness; Unifilter mod; Rear-View mirror riser bracket; Truxedo Lo Pro tonneau cover; New OEM color-matched grille; Bumpershellz color-matched rear bumper cover; Ultra-Gauge MX 1.4 w/Spiker mount; Baja Designs S2 Sport Ditch Lights with SDHQ brackets; Fog Light Anytime Mod; Overland Tailor Tune (OTT); Yaesu FTM-150 GMRS/Ham radio; Viofo A229+ Dash Cam
    Replaced my battery yesterday with a DieHard Platinum AGM battery since I have quite a few extra electronics hooked up to it. I also wanted something a bit more "rugged" in terms of vibration and longevity and AGM seems to be the way to go. My question is do I need to have my OTT tune reflashed for this battery upgrade, or is it fine the way it is? My truck cranks up almost immediately now which is great.
  16. Oct 17, 2024 at 5:49 PM
    joeyv141
    Virginia
    Yes, to get the most out of yoir AMG battery you will need to up the desired charging voltage.
    Tacoma13_NC[QUOTED] likes this.
  17. Oct 17, 2024 at 6:01 PM
    Tacoma13_NC
    Any feedback on this or something similar with a fuse still in place?
    https://voltageboosterpro.com/product/spark/
  18. Oct 17, 2024 at 6:05 PM
    NoCoTacoMan
    NoCoTacoMan Well-Known Member
    Brian
    Northern Colorado
    2010 TRD Sport V6 4WD Ext Cab Long Bed
    Stockish
    I lubed my propeller shaft this afternoon. I'm getting a little vibration/shudder just on acceleration, no other time. I changed my u-joints last week (Spicer) a week ago because the old ones were a mess. I lubed the new ones before I reinstalled the propeller shaft but I guess it wasn't enough. Hmmm
  19. Oct 17, 2024 at 6:18 PM
    Canadian Caber
    Les
    B.C. Canada, eh
    Thanks for the details. Most do Fluid Film so I was interested in someone actually applying Cosmoline. Yeah, the price of the rp342 scared me away. At $20.00 per can of the CRC corrosion inhibitor was a better price point for a similar type product. I’ll be curious to see how it holds up to some heavy rain we recently received. Also expecting a Atmospheric River for 3 days coming up. I did use a little corrosion free too. Just on the spare tire mechanism and chain. I need to consider the inside of the front boxed area of the frame. Need to find a 360 spray adapter. Otherwise it was all the exposed areas of the C-channel frame with the CRC. Not being in the rust belt, I’ll have to see how everything holds up when I inspect underneath next summer. I do regularly spray underneath at the pay and spray in the middle of winter if weather permits. Also, the 3rd gens have some sort of goop applied at the factory on all the frame lap joints. Hopefully that helps too.
    Charlie Bravo likes this.
  20. Oct 17, 2024 at 6:19 PM
    joeyv141
    Virginia
    No experience with this product but the a quick glance at the website seems like it'll work fine, honestly if you've already got a tune it should be fairly easy for a tuner to just adjust this. Granted I have no idea the tuner would charge you.
