  1. Dec 14, 2024 at 3:23 PM
    1Shifter
    1Shifter Well-Known Member
    Jeff
    Outta the black and into the blue
    09 PreRunner
    Same as everybody else...
    Easy day, changed the oil and OEM filter. Also replaced wiper blades. Boring maintenance at 4k miles but the weather was decent so I took advantage of it. 20241208_125212.jpg
  2. Dec 14, 2024 at 5:55 PM
    Ginger-Vitis
    Ginger-Vitis Well-Known Member
    08 Tacoma 5spd
    Yes. I plan on rebuilding it again a bit lighter but still steel
  3. Dec 14, 2024 at 7:05 PM
    BadAndy10
    BadAndy10 Well-Known Member
    the 541
    '10 DC TRD OR
    Fox 2.5" extended travel coilovers, SPC UCA's, Wheeler's AAL & 5100's, Relentless front plate bumper, SCS F5's w/285's, Superbumps
    After 12 years of owning the truck, finally fixed one of the stupidest problems with the 2nd gen and relocated the trailer plug to the bumper. Destroyed the factory bracket and plug literally the first wknd in the woods hunting. Not my finest work but will be legal when towing the trailer come next camping season.
    sheld, reg188, rblalliance and 7 others like this.
  4. Dec 14, 2024 at 8:27 PM
    jakob8572
    jakob8572 Member
    Loudoun County, VA
    ‘05 Access Cab
    New Frame (not a mod but still worth mentioning), OME 3” Suspension Lift (Leveled), SCS Blaze 10 & Falken Wildpeak A/T4W (33’s), Revamped Exhaust System (Magnaflow Catalytic Converters & Flowmaster Flow FX CAT-BACK Exhaust), K&N High-Flow Cold Air Intake, CaliRaised Fog Lights & 32” Light Bar (Hidden), AlphaRex Headlights & Taillights, LED 3rd Brake Light, B&M Short Shifter, Body Armor 4x4 Rear Bumper w/ Rigid Flood Lights, Rigid Ditch Lights And more to come…
    Lifted & Leveled 3” (Old Man Emu)… Falken Wildpeak A/T4W - 285/70R-17 (33”)
    Flori-duh Taco, TomTwo and jackn7 like this.
  5. Dec 15, 2024 at 4:00 AM
    jackn7
    jackn7 Old Man Tan Taco
    Art
    So Cal
    2008 DCLB 4x4
    Just some stuff...
    I needed to see this! Every now and then I start looking at all these newer trucks with all their fancy doodads. I usually just buy something for mine and I’m fine. This helps. A lot! Thanks! She’s looking sweet!!
    DJ IslandBoy likes this.
  6. Dec 15, 2024 at 4:43 AM
    lynyrd3
    Bill
    East Central Upstate NY
    Monday is winter wheels swap day . And oil change .
    Cativelense likes this.
  7. Dec 15, 2024 at 5:01 AM
    CTSpruceMica
    CTSpruceMica My driving scares me too
    Dennis
    2014 Spruce Mica
    Same here Bill...though I'll let Town Fair Tire do it for free
  8. Dec 15, 2024 at 6:05 AM
    jakob8572
    jakob8572 Member
    Loudoun County, VA
    ‘05 Access Cab
    I have yet to find one of these new trucks that I like enough to justify replacing this one with (especially considering today’s prices). If I get my wish, this will be the last truck I’ll ever need to buy.
    This helps me when I think about anything outside of what I’ve got: https://youtu.be/yl06UTcOJ1I
  9. Dec 15, 2024 at 7:32 AM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Did you route the wiring through the shark fin? Nice and clean install
  10. Dec 15, 2024 at 7:43 AM
    Gruber1922
    Gruber1922 Well-Known Member
    Tacoma, WA
    2015 Tacoma Sport
  11. Dec 15, 2024 at 11:24 AM
    Lost Coast Adventure
    Lost Coast Adventure Active Member
    2014 Tacoma DCLB
    That would have been even better, but I don't have the shark fin on my 2nd gen. I routed the cable out to the roof rack and then down next to my rear window under and into the cab where I have the router in my back seat compartment.
  12. Dec 15, 2024 at 11:50 AM
    ProStar197
    ProStar197 Well-Known Member
    2013 TX Baja DCSB
    Damn that is a great improvement. Looks great!
    jakob8572[QUOTED] likes this.
  13. Dec 15, 2024 at 3:15 PM
    Positraction
    Positraction Member
    SoCal
    2005 TRD Off-Road PreRunner
    New 2020 tires and wheels
    Worked on my new-to-me Snugtop Rebel bed cap. Will order some new rear window struts and 3rd Brake Light replacement.
    Hay Lobos, Jmack69, LG888 and 10 others like this.
  14. Dec 15, 2024 at 5:14 PM
    RogerMexico
    RogerMexico Active Member
    2011 TURD SPURT
    Not so much what I did, but what I decided not to do.
    For the past couple of weeks I’ve been working on a rear seat delete project. I even started over once.
    The reason I wanted to do this is that a while ago I removed the stock subwoofer, and the empty holes for the mounting points, as well as the lack of a good option for mounting a replacement always bothered me.
    After I cut the pieces for the final assembly, I decided to apply bedliner like I had seen on some other projects here.
    I used Herculiner - what we had at the local hardware store. The stuff had a pretty bad smell and I got to thinking - even if I let all the gases evaporate, it will still likely give off some not so good chemicals if I put it in my cab over the long run.
    I decided to scrap the project and put back the original interior. I make some hasty cutting decisions in the past when I was first sound deadening in order to make mlv fit. I’ve had to use zip ties on some interior panel to make things work, but I got it back together pretty good this time.
    While I was at it, I also ran cable for an additional amp that I’ll add in the future.
    Hopefully, this will be the last time I take my truck apart for a really long time.
  15. Dec 15, 2024 at 8:25 PM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    Bring your truck out to this. I will be there too. Need to have more 2nd gens present :cool:
    LG888 and jakob8572[QUOTED] like this.
  16. Dec 15, 2024 at 8:32 PM
    jakob8572
    jakob8572 Member
    Loudoun County, VA
    ‘05 Access Cab
    I’m planning on it! Saw that note earlier today in the Northern Virginia Roll Call thread!
    fatfurious2[QUOTED] likes this.
  17. Dec 15, 2024 at 9:17 PM
    JDTRD01
    JDTRD01 Member
    Illinois
    2005 DCSB TRD offroad
    Installed a new Kenwood stereo
  18. Dec 16, 2024 at 3:15 AM
    Operator8
    Operator8 Well-Known Member
    Woodland Park, CO
    2005 White Tacoma TRD OR
    SAS INW
    What bulbs did you go with?
  19. Dec 16, 2024 at 7:50 AM
    BigCountry762x39
    BigCountry762x39 Well-Known Member
    TL
    PNW, Oregon!
    2009 Tacoma, with the cool white paint peel
    Arb Deluxe bull bar Front Bumper Ironman4x4 12k winch synth line AFE Intake OME 2.75in Dakar Leaf springs (R) Fox 2.0 bypass shocks (R) Bilstein 6112 (F) 33's on KMC wheels off road lighting comfort mods Redrock HD roof rack Retevis rt95 Radio Slotted Rotors and HD pads
    i really need to pull my kenwood again and move it back one more mounting hole so i can put the faceplate cover thing on! looks much better with it installed correctly!
    JDTRD01[QUOTED] likes this.
  20. Dec 16, 2024 at 10:33 AM
    Oreo Cat
    Oreo Cat Worst Member
    Coeur d’Alene, Idaho
    37s mounted and balanced
