  1. Feb 28, 2025 at 1:34 PM
    flightmech08
    flightmech08 Well-Known Member
    Hillsburgh, ontario
    2007 trd double cab 4x4 6 speed
    old man emu lift kit with full dakkars. ARB front locker, rear dif vent mod 1.5" spacers
    I would check your fuel pump resistor as I just had this happen. It's between the battery and the headlight, disconnect plug and jumper the pins on the cannon plug to verify. if it runs then it's the resistor.
    Torspd, SSX999[QUOTED] and Pigpen like this.
  2. Feb 28, 2025 at 4:39 PM
    shoeshineninja
    shoeshineninja Active Member
    2018 Cement DCSB TRD Sport
    Whoops. My bad lol. Had 2 tabs up. I have love for and follow 2nd gens as well, and I obviously replied on the wrong one. Lol
  3. Feb 28, 2025 at 6:56 PM
    Pigpen
    Dan
    Northwest Montana
    Today was a rest day, but in the last week:
    "New" CVJ front axle (to match the other one)
    New front hub assembly
    New brake rotors and pads
    Flushed brakes
    Flushed clutch
    Flushed power steering
    Recently put in an alternator and had a new clutch installed too!
    lynyrd3, fasteddieyj and Tatts521 like this.
  4. Mar 1, 2025 at 4:40 AM
    NmapFE
    NmapFE Well-Known Member
    2014 DCLB 4x4 Limited. 6112’s/5125, KYB Top Hats, SPC UCA’s, Icon RXT leaf pack,
    I hope it goes well… thats “perdy”
    LG888 and TegoTaco[QUOTED] like this.
  5. Mar 1, 2025 at 5:59 AM
    lynyrd3
    Bill
    East Central Upstate NY
    Hit a deer about a month ago :mad:
  6. Mar 1, 2025 at 7:32 AM
    GorgeRunner
    GorgeRunner Out There
    2005 PreRunner
    If that's the extent of the damage, you got off pretty light. Or the deer are bigger and tougher out west.
  7. Mar 1, 2025 at 8:28 AM
    easleycrawler
    easleycrawler Well-Known Member
    Travis
    Easley, South Carolina
    2014 RC Taco 4wd
    Had the needle bearing delete and gear oil changed yesterday. Also had the drain and fill plugs swapped to the Lexus parts.
  8. Mar 1, 2025 at 8:51 AM
    Natalan4574
    Natalan4574 Member
    Nathan
    Tacoma Prerunner 2006 blanca
    Hi. I have a 2006 Tacoma and I was fed up with my digital clock being almost unreadable during the day so I ordered one from aliexpress for about $35. What I didn't expect was that the color would now be white but I'm still happy with it, it looks just like the 2012-2014 models. Now I'll have to change everything to white to match.
  9. Mar 1, 2025 at 9:34 AM
    tacokarl
    tacokarl Big Blue
    Karl
    Connecticut
    2008 Pre-Runner SR5 DCLB
    Can you provide the link? I'd like to take a look as I have the same issue during the day.
  10. Mar 1, 2025 at 9:45 AM
    Smills91
    Smills91 Well-Known Member
    Care to link the part that you ordered. I'd appreciate it. Please and thank you
  11. Mar 1, 2025 at 10:20 AM
    SSX999
    SSX999 Well-Known Member
    2015 Tacoma TRD Off Road 6MT
    Yes, that's what it was - mechanic called me at 5pm yesterday to let me know the part is "Toyota only" type of deal, and he won't receive one until Wednesday... smells like BS but whatever :annoyed:
    Edit: after reading a few threads on the subject here, going OEM is the way to go, so apologies to my mechanic for having doubts.
    Torspd likes this.
  12. Mar 1, 2025 at 10:57 AM
    lynyrd3
    Bill
    That’s it . Medium size doe . I slammed on the brakes and knocked the deer down and it got up and ran away . Hopefully when I get around to it I can heat that up and pop it out :notsure:
    ACEkraut and Tacos4ever15 like this.
  13. Mar 1, 2025 at 1:21 PM
    theolee
    theolee www.nickleecreations.com
    Theo
    SAN DIEGO
    Black 09 Tacoma SR5 Pre-Runner AC 4.0
    Anyone have a part number or a good seller they have used for the roof weather strips for an access cab? Much appreciated.
    fatfurious2 likes this.
  14. Mar 1, 2025 at 3:53 PM
    greywind0909
    greywind0909 Active Member
    2015 TRD OR Silver Sky Metallic
    NmapFE, moon22, DJ IslandBoy and 7 others like this.
  15. Mar 1, 2025 at 3:57 PM
    Citra
    Citra Well-Known Member
    Columbia River Gorge
    2014 TRD Sport
    Got a nice sunny weekend, so I finally got around to installing another ECGS bushing. The previous owner of the truck had stripped the drain plug out pretty badly so I had to weld a nut onto it so I could get it out and replace the horrible OEM drain plug. The fill plug came out fine, but I'm kind of wishing a had bought a replacement plug for that as well.
    Also, check out these spider nests on the lip of the front dif gasket. I can't imagine that's a great place to live.
    NmapFE, Hay Lobos and DesertRatliff like this.
  16. Mar 2, 2025 at 4:59 AM
    TacoD00d
    TacoD00d The Dude abides.
    NM
    '07 TRD Sport DCLB 4x4
    URD TCAI Hooke Road rear bumper Hooke Road front bumper
    Installed a new front bumper w/light bar, new headlights and a new grille. For the bumper, getting everything to line up once in place took some...I'll call it violent finesse. Also, the support at the top of the stock bumper had to come off as it interfered with fitment of the new one.
    I didn't think it was going to be a big deal until I was installing the headlights, and realized without that thin brace I had nowhere to screw that end of the light housing to. As it turns out, the way everything is set up front, the grille provides enough outward pressure to hold the headlights in place, along with the screws on top and the one outside. It survived a trip half way across town anyway...
    I'll have to wait to see if it'll all hold up on a real adventure. IMG_20250302_053908.jpg IMG_20250302_054113.jpg
  17. Mar 2, 2025 at 5:53 AM
    easleycrawler
    Travis
    2014 RC Taco 4wd
    After having the needle bearing delete done, had ecgs actually do it Friday. Now I've got a clunk in the left front while making right hand turns. Any idea what it could be?
  18. Mar 2, 2025 at 12:43 PM
    Tacos4ever15
    Tacos4ever15 Well-Known Member
    2015 Pyrite Mica Tacoma TRD Off-road 4x4
    Wheel bearing ?
  19. Mar 2, 2025 at 1:00 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Check the torque on the CV axle nut, it should be 173ft lbs. If they pulled the CV axle to install the needle bearing and it didn't get torqued back down properly, as mentioned above, the wheel bearing is likely the issue
    easleycrawler[QUOTED] likes this.
  20. Mar 2, 2025 at 1:16 PM
    easleycrawler
    Travis
    2014 RC Taco 4wd
    I've jacked the driver side up and did the normal check for a bad wheel bearing and everything seems nice and tight, no movement up and down or side to side. Guess I could pop the cap off and check the torque.
