  1. Apr 13, 2025 at 3:55 PM
    Tiedie
    Tiedie The Only Shantytown Resident.
    David
    WFOY
    Katzkin, Dobinsons full suspension. Redlinegoods console cover and door panel arm rests, Double USB charger in dash installed, Ballistic Jesters 16x8. BlackVue DR 590 Dash Cam
    I love Vieques :thumbsup:
  2. Apr 13, 2025 at 5:55 PM
    99TacoDriver
    99TacoDriver Well-Known Member
    South Louisiana
    OME 885x/5100s/LR UCA/3 leaf AAL/275/70/17 Terra Trac X-Venture
    Same with ours, dad dark red and mom normal golden. Mine has a white patch on the chest that was unique to only him in the litter.
  3. Apr 13, 2025 at 9:34 PM
    jawmes
    jawmes Well-Known Member
    James
    Kauai, Hawaii
    2007 Tacoma 4x4 PreRunner
    Torqued my new moog upper control arms nicely at ride height (I know… I know… I’m on a budget right now). Put the truck back down and gave it a shake test
    squeak… squeak.. squeak:frusty:
    LG888 likes this.
  4. Apr 13, 2025 at 10:45 PM
    TacoTuesday1
    SD CA
    evaluate it.
    -inner fender trim
    -outer fender trim
    -CMR
    -bump stop spacer
    -pinch weld hammer
    -mud flaps solution
    -offset choice
    -UCA’s
    -alignment
    hardest part with bigger tires is probably seeing if it needs JD Inner Fenders. Which probably comes with 35” and definitely 37”.
  5. Apr 14, 2025 at 6:05 AM
    LG888
    LG888 Well-Known Member
    MA
    2005 Tacoma Access Cab 2.7L M/T 4WD
    Keeping it running
    Took the tires off and now the truck waits for further inspection and more parts to be bought… what else do you see needing replacement/upgrade. I know the end links on both sides need it. I think I need to get new leaf springs and rear shock? Maybe just add-a-leaf and shocks?
  6. Apr 14, 2025 at 1:24 PM
    ProStar197
    ProStar197 Well-Known Member
    2013 TX Baja DCSB
    Thanks again. I ended up buying the same stuff except I went with the KS 270 tweeters.PXL_20250414_184239461.MP.jpg PXL_20250414_184224188.MP.jpg
  7. Apr 14, 2025 at 3:43 PM
    Micbt25
    Micbt25 Well-Known Member
    TM
    2015 MGM TRD Sport Access Cab 4X4 V6
    Installed 1320 Performance bed stiffeners and swapped out the taillights so the silver parts are instead black.IMG_0496.jpg IMG_0497.jpg
  8. Apr 14, 2025 at 4:03 PM
    MARSHBUSTER
    MARSHBUSTER Well-Known Member
    Jim
    Alamogordo NM
    2005 SR5 4X4 Tacoma TRD
    Grill Gaurd/ Winch Bumper, Mile Marker 9000 LBS Winch, Custom Head Ache Rack, Custom Rear Bumper, Marathon Camo Max 4 Seat Covers
    What Tail Light are those? They look A Lot better then the stock Tail Lights.
  9. Apr 14, 2025 at 4:29 PM
    Micbt25
    TM
  10. Apr 14, 2025 at 6:42 PM
    jon_elc
    jon_elc Well-Known Member
    NorCal
    2011 SR5 4x4 Timberland Mica Snugtop Rebel
    245-70R-17 Revo3 Cut mudflaps 4.5" F / 1.5" R
    i bought a slim fitting months ago, and lubed my front driveshaft today. 98k oh well, at least i finally did it.
    i stored my lube gun like this in case of leakage
    Kolter45, jackn7 and WyldeRayne06 like this.
  11. Apr 15, 2025 at 1:44 AM
    jpereira2
    jpereira2 Well-Known Member
    Massachusetts
    2013 double cab trd off road
    Bilstein 6112 4th notch Bilstein 5160 rear Camburg ball joint UCAs Old man emu dakar leafs 265/75R16 Cooper ST Maxx Crux stereo a/v interface UltraGauge ARE fiberglass cap Wet okole seat covers Retro fit source Led fog lights Superbrightled pods in rear bumper Superbrightled light bar in grill Rock blokz mud flaps SOS Rock Sliders RCI Skid Plates (to be painted and mounted)
    You need to be protecting that frame from rust. Hopefully it's not already too late
    Kolter45 and Charlie Bravo like this.
  12. Apr 15, 2025 at 2:47 AM
    herecomesace
    herecomesace Well-Known Member
    2013 Tacoma TRD Offroad Access Cab MGM Supercharged
    I have the OEM steering wheel from my 2013 just sitting on the shelf. I kept the audio controls though. Let me know if you’re interested.
    TaliTank13[QUOTED] likes this.
  13. Apr 15, 2025 at 8:36 AM
    BigCountry762x39
    BigCountry762x39 Well-Known Member
    TL
    PNW, Oregon!
    2009 Tacoma, with the cool white paint peel
    Arb Deluxe bull bar Front Bumper Ironman4x4 12k winch synth line AFE Intake OME 2.75in Dakar Leaf springs (R) Fox 2.0 bypass shocks (R) Bilstein 6112 (F) 33's on KMC wheels off road lighting comfort mods Redrock HD roof rack Retevis rt95 Radio Slotted Rotors and HD pads
    i keep mine hung over the trashcan in my shop it drips and makes the worst mess everywhere. but somehow my 50+ year old gun of my grandfathers only gets gummy on the tip side and will sweat a bit on the threaded ends
    NmapFE and jon_elc[QUOTED] like this.
  14. Apr 15, 2025 at 7:06 PM
    jawmes
    James
    Kauai, Hawaii
    On 885 coils with bilstein 5100 (2.25” lift). Also trying the moog control arms after having SPC.
    the ride is pretty good, feels a lot different than the SPCs though. Steering felt kinda heavier
    Kolter45 and lowmower like this.
  15. Apr 15, 2025 at 9:13 PM
    reallifedog
    reallifedog wat.
    Jordan
    Denver
    08 Tacoma TRD OR
    Made the last payment.
  16. Apr 15, 2025 at 9:22 PM
    All Visible Hues 14
    All Visible Hues 14 Well-Known Member
    Lynn
    East Tennessee
    2014 dcsb TRD off road
    Oil change 39 today. Knocked it out pretty fast. Even the zerks were lined up pointing straight down when I parked. Easy peasey.
  17. Apr 15, 2025 at 9:24 PM
    Smills91
    Smills91 Well-Known Member
  18. Apr 15, 2025 at 10:20 PM
    will.i.was
    will.i.was Well-Known Member
    Will
    Houston, Texas
    SC 2.5
    Fully welded in the rear and painted. Starting on front end shenanigans. All lines in engine bay are AN at this point. Prepping to cut the front cross member soon.
    HIghlande2, 69 Jim, hemitruk and 23 others like this.
  19. Apr 16, 2025 at 10:43 AM
    20somethingwidataco
    20somethingwidataco Yes, my avatar is a real car.
    Will
    Washington State
    2008 AC TRD SPORT M/T
    ACLB 6 SPEED: Suspension: Bilstein 6112s (3rd perch) (F) Taco Lean Spacer Bilstein 5160s (R) TSB Leaf Pack Wheelers Offroad 3 leaf progressive AAL Wheelers Superbump Front Duro Bump U bolt flip kit Duro Bump progressive bump stop 3rd gen TRD offroad sway bar Wheels and Tires: Summit Racing Wheel Dakars (Polished Silver) 285/70r/17 Goodyear Wrangler Duratrax (Load D) "Performance": AFE CAI with custom powdercoated white filter cover MagnaFlow Performance Series Exhaust URD Cam gears XTP Intake Manifold Spacer OTT Torque Tune Brakes: Stoptech Slotted Rotors Stoptech Sport Ultra Composite Brake Pads Wheelers offroad SS brakelines (Front) Interior: Kenwood DD headunit Oem Subaru Kicker Tweeters Alpine 6x9 (Front) & 6.5 (rear) (With Taco tunes speaker mounts) Alpine 500 watt amp Sound Deadening (Doors, Rear "wall", Roof) ODI Rouge Shift Knob Weather Tech Mats Painted/wrapped trim pieces Console Safe Console Vault Gridx Organizer Ram Phone Mount Meso Customs dual color map lights Meso Customs dual color dome light Wet Okole seat covers (Black) Wet Okole center console cover (Black) 1" Seat Raisers (Driver & Passenger) AJT Designs climate control and 4x4 knobs Back Up Camera Lighting: Retrofits (Mini H1's, RGB Halos, 5500k Bulbs)(Lenses wrapped in self healing PPF) Diode Dynamics SS3 Max SAE (Yellow) Diode Dynamics SS5 Pro (Yellow) Driving lights (ditch lights) Anytime fog mod Rigid Industries E series 32" Combo bar (spot/flood) Diode Dynamics XPR Reverse Lights Diode Dynamics XP80 turn signals LED brake, parking lights and license plate lights Armor: Apex All Pro sliders BPF steel skid plate Bigass Trailer Hitch Camping/Storage: Leer canopy LED interior lighting Sleeping platform (Storage underneath) Removable snowboard Yakima mounts Extra D rings in bed (6 total) Custom Powder coated white snow shovel with custom bedrail mounts Amazon special Traction Boards Hi Lift 48" Jack with custom Rail mounts to accommodate my sleeper set up Other: All pro Bed Stiffeners Relentless Fab tailgate panel TRD sport graphics (Turd Gen spec) Anti Sun glare hood scoop wrap (Satin Black) Custom FleeBay grille 4 Hella supertones ECGS needle bearing Many Patches BPF shackle mount (With smittybuilt shackle) Tinted windows (Front/Rear + Full canopy)(18%) Meso Customs gasshole AVS inchannel window visors Diff Breather Kit 2012-2015 Oem Turn signal/folding mirrors (w/ sequential signals) 2012-2015 Oem LED taillights Full Size (285/70r17) spare DIY Larger Engine Splash Guards DIY Vipercut TRD radiator cap
    Chasing down a weird overheating issue (it's happened twice after hard mountain pass driving). So far I've done a coolant flush, replaced the thermostat and radiator cap.
    Today I did the clutch fan.
    Also cleaned the fan blades, lots of dirt build up.
    We shall see how this helps, if not, next up is radiator, water pump and radiator hoses
  20. Apr 16, 2025 at 10:59 AM
    BigCountry762x39
    TL
    PNW, Oregon!
    get the rad loose I've helped friends chase overheating issues, and thrown parts like you have, only to remove the AC condenser from the mount, and found like a bunch of cotton wood fluf or other random stuff behind it pinned to the radiator causing a blockage. washed that all clear and back to normal. might be worth a look
