  1. Jun 13, 2025 at 10:05 PM
    jon_elc
    jon_elc Well-Known Member
    NorCal
    2011 SR5 4x4 Timberland Mica Snugtop Rebel
    245-70R-17 Revo3 Cut mudflaps 4.5" F / 1.5" R
    i flipped 100k today but i forgot to stop an take an odometer pic
    drewnali, NmapFE and stbear like this.
  2. Jun 14, 2025 at 12:02 AM
    jarebear74
    jarebear74 Bar down or it doesn’t count
    Colorado Springs, CO
    2010 OR DCSB
    Got into a wrestling match with some extended ss brake lines. 2 flares stripped making it quite the match. Cut em out, reflared. Flushed the system with new paint stripper. Good to go!IMG_5423.jpg IMG_5425.jpg
    Absolutely. If you haven’t pulled the trigger already. They’re awesome and the owner is great. First few rounds, he texts you just to remind you to grease them up. No complaints! For sure get the recommended grease.
  3. Jun 14, 2025 at 5:42 AM
    JAGCanada
    JAGCanada Well-Known Member
    Canada
    2010 TRD Sport V6 Auto Double Cab MGM
    Wow... that's only 2k miles per year.... might be the lowest miles /year truck I've seen on here...
  4. Jun 14, 2025 at 7:56 AM
    loyaltothetaco
    loyaltothetaco It's part ATV, part SUV, and certified by the DMV
    Adam
    Bay Area
    Radiant Red 2006 DCSB SR5
    2.5" OME lift, Fox 2.5 coil overs, all pro expo leafs, ubolt flip kit w/ upgraded bump stops, 1.25" wheel spacers, 16" Bronze KMC Impact OL wheels, 295/75/r16 Nitto grapplers, beige Softopper, Brute force front bumper w/smittybilt winch, RCI rear bumper, caliraised rock sliders, TRD IFS skid plate custom swingout tailgate w/spare tire mount, TC bed stiffeners, Magnum force CAI, KC spotlights, tacomabeast headlights, rear seat molle panel odds and ends, hi lift, MESO interior lights, and a fuck load of patches… more planned for later.
    Funny you mention it I just bought some. Looking forward to getting em on.
  5. Jun 14, 2025 at 8:34 AM
    Mikes.Mischief
    Mikes.Mischief Well-Known Member
    2013 Toyota Tacoma Double Cab Texas Edition
    Some Interior, Some Exterior
    I had to cut some of the baffle material on the bottom side to make the front door panels fit. I had no issues with the rear speaker baffles.
  6. Jun 14, 2025 at 8:54 AM
    Mikes.Mischief
    Started off with some routine maintenance with an oil and filter change. Then I installed an expandable cup hold to make that circle in the shift bezel useful.
    https://www.amazon.com/dp/B0752DZ1SB
    I had some extra sound deadening material and figured since I'm changing the oil, why not apply some to the underside of the hood. I don't know if it will make a difference but this was more to use up the extra material I purchased.
    Awhile back I noticed the Nilight tow shackles were working themselves loose. I changed them out with a set of split shackles.
    https://www.amazon.com/dp/B0DMVQDKYD
    lowmower, drewnali, Hay Lobos and 4 others like this.
  7. Jun 14, 2025 at 12:02 PM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    Oil change, rotate and balance, new brake shoes, hardware and drums (finally), lubed upper control arms, straightened rear bumper bracket, checked lights and fluids.
  8. Jun 14, 2025 at 5:30 PM
    Notoneiota
    Notoneiota Well-Known Member
    Oakdale, MN
    14 Tacoma DCLB TRD Sport
    Mostly stock with a few minor mods.
    Knocked the u-joints and carrier bearing off the list. 266k miles. Figured it was about time.20250614_104639.jpg 20250614_160744.jpg 20250614_145353.jpg
  9. Jun 14, 2025 at 5:38 PM
    Taco Chum
    Taco Chum Member
    2015 TRD Pro Inferno
    Some
    Replaced antenna
    Kolter45, ProStar197, NmapFE and 2 others like this.
  10. Jun 14, 2025 at 6:27 PM
    steveo27
    steveo27 Ask me about my weiner
    Pittsburgh
    '11 TRD Off Road & 1992 VW GLI
    The same shit everyone else has.
    Reassembled, color sanded, and hand polished.
    Not 100% perfect, but I’m happy
    I think I’m going to paint the emblem black
  11. Jun 14, 2025 at 7:00 PM
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, Kings, Locked, 295s and more.
    Used it to haul the Banshee to the dunes today.
    Banshee is a twin cylinder, 2 stroke, 10K RPM Dune Killer.
    Both are just toys.
    jackn7, lowmower, dborrer and 16 others like this.
  12. Jun 14, 2025 at 7:59 PM
    RockinU
    RockinU Well-Known Member
    Texas
    Nothing… but I did replace the line pressure solenoid in the transmission of my daughter’s 07 Fj, then changed transmission fluid…and it’s the same transmission as both our Tacomas, so it kinda counts.
    jackn7 likes this.
  13. Jun 14, 2025 at 8:39 PM
    loyaltothetaco
    Adam
    Bay Area
    Need AT LEAST a few hours for that install :welder:
    Taco Chum[QUOTED] likes this.
  14. Jun 15, 2025 at 7:05 AM
    Williston
    Williston Well-Known Member
    2014 Tacoma DC SB 4x4 V6 040 [SL] SR5 Trim [ED] Entune Audio+ [TO] V6 Tow Package
    Stock (99.999%) OEM Bed Floor Mat, OEM Front Bed Rail Cargo Net and hooks, OEM Gentex Auto-Dim mirror w/Compass and Outside Temperature Display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. (winter), OEM All Weather Floomats (summer).
    Applied Nu-Finish to the roof and hood. It does a beautiful job removing all of the dark spots on/in the white paint.
    I like it because you can use it in the direct sun when it's hot out, don't have to wash the truck before you apply it, and you can put it on the whole truck first and then wipe it off with old towels: because the haze doesn't dry like Army military epoxy so you can't get it off. :thumbsup: And It beads up in the rain for months after you apply it:
    "The Once A Year Car Polish" :proposetoast:
    jackn7 and Charlie Bravo like this.
  15. Jun 15, 2025 at 8:40 AM
    Taco Chum
    Taco Chum Member
    Some
    Also, installed a Garmin X110 Dash Cam. Pretty slick process with the Dongar power adapter.
  16. Jun 15, 2025 at 8:57 AM
    NmapFE
    NmapFE Well-Known Member
    2014 DCLB 4x4 Limited. 6112’s/5125, KYB Top Hats, SPC UCA’s, Icon RXT leaf pack,
    Looks nice!!!
  17. Jun 15, 2025 at 10:03 AM
    20somethingwidataco
    20somethingwidataco Yes, my avatar is a real car.
    Will
    Washington State
    2008 AC TRD SPORT M/T
    ACLB 6 SPEED: Suspension: Bilstein 6112s (3rd perch) (F) Taco Lean Spacer Bilstein 5160s (R) TSB Leaf Pack Wheelers Offroad 3 leaf progressive AAL Wheelers Superbump Front Duro Bump U bolt flip kit Duro Bump progressive bump stop 3rd gen TRD offroad sway bar Wheels and Tires: Summit Racing Wheel Dakars (Polished Silver) 285/70r/17 Goodyear Wrangler Duratrax (Load D) "Performance": AFE CAI with custom powdercoated white filter cover MagnaFlow Performance Series Exhaust URD Cam gears XTP Intake Manifold Spacer OTT Torque Tune Brakes: Stoptech Slotted Rotors Stoptech Sport Ultra Composite Brake Pads Wheelers offroad SS brakelines (Front) Interior: Kenwood DD headunit Oem Subaru Kicker Tweeters Alpine 6x9 (Front) & 6.5 (rear) (With Taco tunes speaker mounts) Alpine 500 watt amp Sound Deadening (Doors, Rear "wall", Roof) ODI Rouge Shift Knob Weather Tech Mats Painted/wrapped trim pieces Console Safe Console Vault Gridx Organizer Ram Phone Mount Meso Customs dual color map lights Meso Customs dual color dome light Wet Okole seat covers (Black) Wet Okole center console cover (Black) 1" Seat Raisers (Driver & Passenger) AJT Designs climate control and 4x4 knobs Back Up Camera Lighting: Retrofits (Mini H1's, RGB Halos, 5500k Bulbs)(Lenses wrapped in self healing PPF) Diode Dynamics SS3 Max SAE (Yellow) Diode Dynamics SS5 Pro (Yellow) Driving lights (ditch lights) Anytime fog mod Rigid Industries E series 32" Combo bar (spot/flood) Diode Dynamics XPR Reverse Lights Diode Dynamics XP80 turn signals Diode Dynamics HP5 Third brake light LED brake, parking lights and license plate lights Armor: Apex All Pro sliders BPF steel skid plate Bigass Trailer Hitch Camping/Storage: Tonneau Cover (Truxedo Roll Up) KB voodoo bed bars Pelican Vault (for gear) LED interior lighting Extra D rings in bed (6 total) Custom Powder coated white snow shovel with custom bedrail mounts Amazon special Traction Boards Hi Lift 48" Jack Other: All pro Bed Stiffeners Relentless Fab tailgate panel TRD sport graphics (Turd Gen spec) Anti Sun glare hood scoop wrap (Satin Black) Custom FleeBay grille 4 Hella supertones ECGS needle bearing Many Patches BPF shackle mount (With smittybuilt shackle) Tinted windows (Front/Rear) (18%) Meso Customs gasshole AVS inchannel window visors Diff Breather Kit 2012-2015 Oem Turn signal/folding mirrors (w/ sequential signals) 2012-2015 Oem LED taillights Full Size (285/70r17) spare DIY Larger Engine Splash Guards DIY Vipercut TRD radiator cap AC drip line mod Anti Tweeker tailgate lock
    Really dig having a truck to use. It drives so much better without the canopy on it.
    My tailgate popped off and now my backup camera doesnt work, so I'll have to fix that later, oh well.
  18. Jun 15, 2025 at 12:31 PM
    Gruber1922
    Gruber1922 Well-Known Member
    Tacoma, WA
    2015 Tacoma Sport
    I haven't been for a few years but got back into it recently. I really like Steven's so I'm excited to try Snoqualmie this year
  19. Jun 15, 2025 at 1:16 PM
    herecomesace
    herecomesace Well-Known Member
    2013 Tacoma TRD Offroad Access Cab MGM Supercharged
    Installed ARK splashguards with microflares.
    jackn7, lowmower, NmapFE and 6 others like this.
  20. Jun 15, 2025 at 2:21 PM
    RockinU
    Texas
    I’ve read complaints about the holes not lining up, and the fasteners being not awesome…how was your experience with the ark guard?
