  1. Jul 9, 2025 at 8:26 AM
    Peter603Taco
    Peter603Taco Well-Known Member
    Peter
    New Hampshire
    2013 TRD Sport DCLB
    Ah that makes sense, thanks!
    IvanhoeTaco[QUOTED] likes this.
  2. Jul 9, 2025 at 10:10 AM
    anangrymarmoset
    anangrymarmoset Member
    2010 access cab 6 cyl 4x4
    Catch up post!
    Bedboxes/sleeping platform (earlier this year)
    Clazzio Seat Covers (awesome, just recently)
    Cobra CB with Firestik (Fire Stik not shown, recent)
    Finished up rear seat delete and molle panel (needs trim, just recent)
    Replaced head unit (older)
    grab-handle phone mount via Ram tutorial from Mods sticky (just finished but not pictured!)
    New front rotors and brakes (Power stop, just finished!)
    New Driveshaft (just recent, need to adjust angles)
    Small boi radio antenna (recent, of course it's right next to the Fire Stik, lol)
    Lots of other small stuff over the last couple of years to make lift and life work a little better.
    Next on agenda? Swap armrest cloth to leather, trim out molle panel, finish carpeting in cap (add light), rewire second battery for bed and add power box, need lighting (open to suggestions), finish paint on bed boxes and carve out openings for 2nd battery access, mobile water solution, dynamat doors/floor/roof, fix paint on roof, require hitch, fix cap brake light, hood struts, general maintenance overhaul (just hit 130k!) when does it end? (hopefully never)
    Cheers!
    2278B394-DB19-43A2-9886-4386C35CD171_1_105_c.jpg BB528CC4-EC39-415A-8964-17C171A18B7A_1_105_c.jpg DAC552D5-651B-4ADB-9785-E4A44672F687_1_105_c.jpg DAC552D5-651B-4ADB-9785-E4A44672F687_1_105_c.jpg CD39E7BB-95C6-4756-9107-5163331CE0DF_1_105_c.jpg F9B1F932-72F5-4D7A-AA28-A5D4B2C2461D_1_105_c.jpg AB8BFA9D-0D9F-4F5E-B36D-B5410F06DCCF_4_5005_c.jpg E3A11E9D-CA09-425F-935E-009417EE980C_4_5005_c.jpg
    Any good wheeling suggestions in Maine?
  3. Jul 9, 2025 at 12:04 PM
    Musubi3
    Musubi3 Well-Known Member
    Big Island
    2014 Tacoma DC 4x4 TRD Off Road, Supercharged
    Nice upgrades!
    What kind of driveshaft did you pick up?
  4. Jul 9, 2025 at 12:11 PM
    anangrymarmoset
    Thanks!
    I ended up with this two piece drive shaft from Extreme Terrain's site: https://www.extremeterrain.com/tacoma-rear-driveshaft-prop-shaft-assembly-apds0247.html . Super easy installation and bolted right up (took longer to unbolt the old one than to get the new one on. No complaints.
    Wanted to go with a Tom Wood's single piece but it looks like they've discontinued and the Knoxville version is roughly $1200 (yikes). That, and if I was required to pull measurements on it i'd definitely mess it up!
  5. Jul 9, 2025 at 1:44 PM
    lowmower
    lowmower Well-Known Member
    Benji
    2011 Pyrite Mica V6
    How are your pod lights mounted up front? Love the look of the new grille.
  6. Jul 9, 2025 at 6:41 PM
    jarebear74
    jarebear74 Bar down or it doesn’t count
    Colorado Springs, CO
    2010 OR DCSB
    That’s slick. Where’d you snag that from?
  7. Jul 9, 2025 at 8:09 PM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    Where'd you get that "sticker"? I have paint coming off in the same area and would like to fix it then apply some type of protection.
    Hay Lobos likes this.
  8. Jul 10, 2025 at 5:23 AM
    buck
    buck Don't sweat the petty - pet the sweaty
    Ontario, Canada
    15 DC V6 4x4 TRD Magnetic Gray
    High-flow coconut smiley-face air freshener.
    I think it had an STD... it was crusty!
  9. Jul 10, 2025 at 8:39 AM
    BigCountry762x39
    BigCountry762x39 Well-Known Member
    TL
    PNW, Oregon!
    2009 Tacoma, with the cool white paint peel
    Arb Deluxe bull bar Front Bumper Ironman4x4 12k winch synth line AFE Intake OME 2.75in Dakar Leaf springs (R) Fox 2.0 bypass shocks (R) Bilstein 6112 (F) 33's on KMC wheels off road lighting comfort mods Redrock HD roof rack Retevis rt95 Radio Slotted Rotors and HD pads
    after I mounted mine I thought about putting it in that garage door opener spot, could have done the 8 spot one even.
  10. Jul 10, 2025 at 11:58 AM
    UMC
    UMC I will not comply
    Thomas
    South Fork of the American river.
    13 TRD Sport DCLB 4x4
    37's & rear locker
    Damage while wheeling...Broke my driver parking brake and destroyed wheel cylinder leaking fluid over everything. Damaged backing plate as well. Once repair was completed brakes would not hold pressure and found that brake master cylinder damaged.
    So replaced driver wheel cylinder, backing plate, wheel bearing, and parking brake. Replaced brake shoes and hardware on both sides. Replaced brake master cylinder and reservoir.
    lowmower likes this.
  11. Jul 10, 2025 at 12:01 PM
    Pixeltim
    Pixeltim Misunderstood member
    77 square miles surrounded by reality.
    '15 Black DCLB SR5
    Tires, Softopper, fully armored, winch, many pinstripes.
    That's some serious wheeling!
    UMC[QUOTED] likes this.
  12. Jul 10, 2025 at 7:15 PM
    Charlie Bravo
    Charlie Bravo Well-Known Member
    Charlie
    Coeur d'Alene, Idaho
    2009 Red Tacoma Access Cab 4wd 2.7MT
    RedLine Tuning hood QuickLIFT, Gen3 alloy 16x7J, All Pro Off-road bed stiffeners & IFS skid plate
    Replaced the rear amber turn signal bulbs (Sylvania) with VLEDS https://www.vleds.com/3157-50-hv-amber-2.html and the VLR6 resistors, found the stock LED brake and turn signal center contains a circuit board running all those center LEDS, and I'd replaced the reverse bulbs earlier. Unpacked a Cat-branded All-in-One jack this afternoon that I'd ordered Monday from Northern. 21" maximum height with a 12" square flat steel base will handle more with a couple 6x6 blocks next to each other. This morning, I had my semiannual dental appointment and met the clinic's new hire, Dr. Jack. He looked at my latest digital X-ray photos, and remarked that my teeth are in better shape than his. Not bad for this 70-year old guy, and we share similar northern European ancestry, all mixed up. Yeah, probably nothing we'd want to learn by having that tested :rolleyes:. I think I figured out how to release the electrical connector for the front turn signals, and for the side marker lights? There's always another day... :rimshot:
  13. Jul 10, 2025 at 9:19 PM
    Justintheegreat
    Justintheegreat Well-Known Member
    Northern CA
    06 DCSB Sport
    Picked up these Yakima ski racks. Wanted to use them on my camper shell with my front runner roof rack. Since I have a baby 5' bed
    Found some extra mounting feet and drilled some holes that way they fit with my rail system.
  14. Jul 11, 2025 at 12:24 AM
    onemanstaco
    onemanstaco Member
    Alex
    05 AcessCab 2x4
    Not enough
    ARK mini mud flaps!
  15. Jul 11, 2025 at 7:10 AM
    Rodarbal
    Rodarbal Lurk lurk lurk
    RJ
    Cedar Park, TX
    2019 DCSB TRD OR Calvary Blue MT
    The tailgate of my son's '13 TRD OR came without badging (and about a 1/4" of Bondo on the left hand side LOL). So instead of OEM chrome badges my son stuck an old school Toyota decal there. He got it in gold to compliment his wheels. It looks a little small, IMO, but he's happy with it.
  16. Jul 11, 2025 at 8:17 AM
    Peter603Taco
    Peter
    New Hampshire
    2013 TRD Sport DCLB
    Joined the 200k mile club yesterday. Can't think of a more fitting way to celebrate than with a 2.5k mile road trip this weekend. Heading down to Tennessee and Alabama for a good deal on a bunch of go fast parts for the miata track build. I really need to decrease my FB marketplace range lol
  17. Jul 11, 2025 at 9:30 AM
    BigCountry762x39
    TL
    PNW, Oregon!
    i limit myself to 60 miles keeps me out of im sure way more trouble, drove 7hrs one day for a truck!
    jackn7 likes this.
  18. Jul 11, 2025 at 9:51 AM
    Pixeltim
    '15 Black DCLB SR5
    How on earth are you averaging 19.5 mpg?
    SamFransico13 likes this.
  19. Jul 11, 2025 at 10:21 AM
    Peter603Taco
    Peter
    New Hampshire
    2013 TRD Sport DCLB
    I'm not super built up and drive it pretty conservatively with most of my time being on 30-55 back roads and not much traffic. ~300lb constant in the bed between the bed cap and camping setup, light FN wheels and relatively light non E load 32" AT's with a 1" lift. That's the average over the past 10 tanks of gas with the ultraguage calibrated as such and for the slightly larger tires. I just checked last night doing road trip prep and my tires were around 40psi because one of my gauges was off 5psi so that has probably been helping me.
    reg188 and BigCountry762x39 like this.
  20. Jul 11, 2025 at 11:43 AM
    wdunnlee
    wdunnlee Well-Known Member
    Will
    Tidewater VA
    2010 Timberland Mica 4x4
    I have always liked the third gen tailgates how they say Tacoma, I have never thought of this. Cool idea, I may have to steal it :spy:
    Rodarbal[QUOTED] likes this.
