  1. Jul 27, 2025 at 3:35 PM
    Pixeltim
    Pixeltim Misunderstood member
    77 square miles surrounded by reality.
    '15 Black DCLB SR5
    Tires, Softopper, fully armored, winch, many pinstripes.
    What made the door locks via the fob work better?
  2. Jul 27, 2025 at 3:44 PM
    JohnDoeFasho
    JohnDoeFasho St Petersburg, FL
    St Petersburg
    2009 TRD Sport DCLB
    OTT Tune
    Actuator (locks) change
  3. Jul 27, 2025 at 3:47 PM
    ZColorado
    ZColorado Well-Known Member
    Near Boulder Colorado
    13 DCSB OR 6MT
    35's,Kings, NWF, 488, Harrop, SPC, Archive, Method, RCI, C4
    New shock bushings. Had a horrible squeaking
  4. Jul 27, 2025 at 3:56 PM
    20somethingwidataco
    20somethingwidataco Yes, my avatar is a real car.
    Will
    Washington State
    2008 AC TRD SPORT M/T
    ACLB 6 SPEED: Suspension: Bilstein 6112s (3rd perch) (F) Taco Lean Spacer Bilstein 5160s (R) TSB Leaf Pack Wheelers Offroad 3 leaf progressive AAL Wheelers Superbump Front Duro Bump U bolt flip kit Duro Bump progressive bump stop 3rd gen TRD offroad sway bar Wheels and Tires: Summit Racing Wheel Dakars (Polished Silver) 285/70r/17 Goodyear Wrangler Duratrax (Load D) "Performance": AFE CAI with custom powdercoated white filter cover MagnaFlow Performance Series Exhaust URD Cam gears XTP Intake Manifold Spacer OTT Torque Tune Brakes: Stoptech Slotted Rotors Stoptech Sport Ultra Composite Brake Pads Wheelers offroad SS brakelines (Front) Interior: Kenwood DD headunit Oem Subaru Kicker Tweeters Alpine 6x9 (Front) & 6.5 (rear) (With Taco tunes speaker mounts) Alpine 500 watt amp Sound Deadening (Doors, Rear "wall", Roof) ODI Rouge Shift Knob Weather Tech Mats Painted/wrapped trim pieces Console Safe Console Vault Gridx Organizer Ram Phone Mount Meso Customs dual color map lights Meso Customs dual color dome light Wet Okole seat covers (Black) Wet Okole center console cover (Black) 1" Seat Raisers (Driver & Passenger) AJT Designs climate control and 4x4 knobs Back Up Camera Lighting: Retrofits (Mini H1's, RGB Halos, 5500k Bulbs)(Lenses wrapped in self healing PPF) Diode Dynamics SS3 Max SAE (Yellow) Diode Dynamics SS5 Pro (Yellow) Driving lights (ditch lights) Anytime fog mod Rigid Industries E series 32" Combo bar (spot/flood) Diode Dynamics XPR Reverse Lights Diode Dynamics XP80 turn signals LED brake, parking lights and license plate lights Armor: Apex All Pro sliders BPF steel skid plate Bigass Trailer Hitch Camping/Storage: Leer canopy LED interior lighting Sleeping platform (Storage underneath) Removable snowboard Yakima mounts Extra D rings in bed (6 total) Custom Powder coated white snow shovel with custom bedrail mounts Amazon special Traction Boards Hi Lift 48" Jack with custom Rail mounts to accommodate my sleeper set up Other: All pro Bed Stiffeners Relentless Fab tailgate panel TRD sport graphics (Turd Gen spec) Anti Sun glare hood scoop wrap (Satin Black) Custom FleeBay grille 4 Hella supertones ECGS needle bearing Many Patches BPF shackle mount (With smittybuilt shackle) Tinted windows (Front/Rear + Full canopy)(18%) Meso Customs gasshole AVS inchannel window visors Diff Breather Kit 2012-2015 Oem Turn signal/folding mirrors (w/ sequential signals) 2012-2015 Oem LED taillights Full Size (285/70r17) spare DIY Larger Engine Splash Guards DIY Vipercut TRD radiator cap
    What is this line thats dripping. And why is it KILLING my frame......
    I think its an ac drain line, but i dont really use my AC and it drips like crazy
  5. Jul 27, 2025 at 5:47 PM
    JohnDoeFasho
    St Petersburg
    2009 TRD Sport DCLB
    OTT Tune
    Probably didn’t start it but definitely not helping it
  6. Jul 27, 2025 at 6:33 PM
    Trevorabc123
    Trevorabc123 Member
    Trevor
    2011, Red 4x4 Tacoma
    Lift. Suspension. Tires. Speakers.
    20250715_184155.jpg 20250726_150754.jpg 20250726_185704.jpg 20250727_122859.jpg 20250727_133923.jpg 20250705_184048.jpg
    It has been a busy month.
    I changed the differential fluid. Then hit a tree on the way back. Luckily it was very low speed.
    Then I got some used replacement parts from a scrap yard. But the replacement bunper was blue. Nothing some spray on duplicolor can't fix!
    Well...it was more complicated than I thought. I learned about a new thing for plastic called adhesion promoter.
    Then the guy who sold me the bumper helped install everything and bend everything back into place.
    I repainted my roof last month. Too.
  7. Jul 27, 2025 at 6:37 PM
    Pixeltim
    '15 Black DCLB SR5
    Does that need to be programmed?
  8. Jul 27, 2025 at 6:49 PM
    JohnDoeFasho
    St Petersburg
    2009 TRD Sport DCLB
    OTT Tune
    Nope! Pulls via the fob and otherwise works with door lock as is (mind the lock rod clips..)
    It’s just the door lock actuator assembly. Moves the components that make things work but inputs requiring programming lie outside of that.
  9. Jul 27, 2025 at 8:06 PM
    20somethingwidataco
    Will
    Washington State
    It's weird, it like cracked a layer of frame but underneath its all solid
  10. Jul 27, 2025 at 9:04 PM
    Pixeltim
    '15 Black DCLB SR5
    Cool! Mine unlocks from a distance but to lock it, I have to be right next to the door
  11. Jul 28, 2025 at 5:21 AM
    danteisme
    danteisme Well-Known Member
    South Western PA
    06 DCSB Sport, 96 Integra GSR
    Investigated a potential HG issue on the truck this weekend, found nothing out of the ordinary so I'm just going to send it until I can't.
    Also did a compression test, 198K miles on this motor.
  12. Jul 28, 2025 at 5:26 AM
    99TacoDriver
    99TacoDriver Well-Known Member
    South Louisiana
    OME 885x/5100s/LR UCA/3 leaf AAL/275/70/17 Terra Trac X-Venture
    whats the normal range of compression for these engines?
  13. Jul 28, 2025 at 5:40 AM
    danteisme
    South Western PA
    This is what i followed, I hope its right or at least close.
    lowmower likes this.
  14. Jul 28, 2025 at 6:22 AM
    JohnDoeFasho
    St Petersburg
    2009 TRD Sport DCLB
    OTT Tune
    You’ll probably need all of these if you go that route… that said dealer would charge at least $500/door
  15. Jul 28, 2025 at 6:59 AM
    Brian422
    Brian422 I fell into the pit that is TW
    Brian
    Birmingham, AL
    2012 DBCSB F/R Locked, 35's ,Long travel, 23 Tundra 4x4 limited
    Not Stock
    Love to see more on this?
  16. Jul 28, 2025 at 8:52 AM
    LarHawes
    LarHawes Member
    Saturday
    Larry
    Upgradedtailights 4.jpg tailights 3.jpg taillights 2.jpg tailights 1.jpg my tail lights - 2015 TRDOR AC
  17. Jul 28, 2025 at 8:52 AM
    LarHawes
    LarHawes Member
    Saturday
    Larry
    Upgrade my tail lights - 2015 TRDOR - AC
    hinmo24t likes this.
  18. Jul 28, 2025 at 11:53 AM
    EveryDayIsTacoTues
    EveryDayIsTacoTues Well-Known Member
    2012 Pyrite Mica DCLB TRD Sport
    On the same train, choo-choo! I went with the Morimoto XB in Red Smoke for OEM+ look.
    May LIGHT smoke them further with tint, but definitely not blacking them out. Reverse is BRIGHT. Sequential Turn is Amber despite the Red Smoke, which is chefs kiss. I did have to do some resistor calculation as I'm running aftermarket upfront too. That was fun, lol.
  19. Jul 28, 2025 at 2:36 PM
    2013TacoDCLB
    2013TacoDCLB Well-Known Member
    Mark
    2013DCLB4x4
    Military hitch, CB install, cargo rail brackets
    Hi All,
    This keeps popping out and I need a cheap fix.
    Thanks,
    Mark
  20. Jul 28, 2025 at 4:42 PM
    Richard009
    Richard009 Active Member
    09 Access Cab manual V6
    Can't wait to start!
    Installed shelving in the back seat.
    UMC, stbear and tacomakid96 like this.
