  1. Dec 4, 2013 at 12:04 PM
    Boone
    Boone Vaginas are rad.
    Boone, NC
    Airbags deployed
    Not all 'Mericuh, just some.
  2. Dec 4, 2013 at 12:51 PM
    Spencer
    Spencer Future President
    TIGGLEBITTIES
    Upland, Chino... all of 909.
    2013 DCSB 4X4 6cyl Sex Machine
    Redline hood lift, Flyzeye cabin lights, tailgate lock, SPOD Power block, VIAR onboard air, Cobra CB radio, Firestick 4' Antenna, Hot Blonde CoPilot Mod, SIX 9" Hella 4000 HID conversion with external 55W ballasts, Six 6" LED bars, Napier Bed Tent, Mudflaps delete using rocks, Roof rack by Brute force, Rock sliders by Brute force, Bed LED lights, Underhood LED automatic lights, Constant 12V bed plug, Rugged race radio, ICON uniball UCA's, KING 2.5 700 rate coilovers, Deaver rear leaf springs, KING 2.5 resi rear shocks (Flat 0.15 stack on compression shims), Scangauge, Empty wallet Mod Bug disease, AllPro Apex front bumper, On board heat exchange shower & water pump (Heater Core intercept mod), On Board Air - Viair for now, ARB when it dies-, allpro Skids back to gas tank- Tepui RTT on the shittiest "Bed Rack" ever made.... AllPro U Bolt flip kit with timbren bumps NEXT UP- expo leafs & bed rack, hydraulic bumps in rear, Total Chaos stock LCA's w/ Bypass, Rear 12" shock hoop relocate
    Lol well I was trying to make a joke & see why the bus scared him and now look what I've started. MERKUH
  3. Dec 4, 2013 at 12:52 PM
    Boone
    Boone, NC
    Airbags deployed
    Still races.
  4. Dec 4, 2013 at 2:08 PM
    LUSETACO
    LUSETACO Here for the Taco Pron
    Dennis
    South Central Pee A
    2005 PIMP MOBILE
    Yes
    Lost the dip and went with paint...
    4A58D0C0-ECCB-4B5D-BEF8-657A668337F4-451_f4feeb9e87756dc30b666968b41ae4585f9eebea.jpg
  5. Dec 4, 2013 at 2:17 PM
    MtnManTaco
    MtnManTaco Active Member
    2013 DCSB 4x4
    Color matched grille, installed. :cool:
  6. Dec 4, 2013 at 2:35 PM
    Pchop
    Pchop Beavis Killer
    Rob I
    Stuart, FL
    '09 Tacoma TRD
    I'm moving to the Shaw in Jan. Been going back and forth there since I was a kid. I'm def not. Come to the Cork with me on Adams and Buckingham. Me and my cousin are the ONLY white people in there. So much fun, plus the up side is all the black chics think your a novelty:D
  7. Dec 4, 2013 at 2:36 PM
    anarion55
    anarion55 Well-Known Member
    Tony
    S. Florida
    2013 PreRunner SR5
    ImMrYo's Mirror Mod, Stereo Upgrade - Power Pro 60x4 Amp/Kicker powered 8" sub/Pioneer component speakers, PassPort 8500 Radar Detector, Locking Bed Storage Cubbies, Onboard air system - Viair 450C compressor/16 gal. PVC tank/15 & 16" horns, quick-d/c air chuck in bed cubby 24" LED light Bar (mounted to skidplate)A Headlights, foglights interior lights and backup lights all converted to LED (HUGE difference)
    A lot of racers cut their own siping with razor blades or hot knives, and are pretty particular about the pattern they each use...all different; almost like a fingerprint.
    Downside to siping is the tires tend to "chunk" more easily...
  8. Dec 4, 2013 at 2:41 PM
    yogster
    yogster merkwürdigliebe
    Tom
    Massachusetts
    13 Black DCLB SR5
    DCLB Black 4WD Illumination dial from 4runner, Flyzeyes LED. Hardwire GPS and Valentine1 with BlendMount mirror mount, TRD shift knob, tube steps, swapped out for signal lamp mirrors. Garmin Eco-Route HD for Bluetooth ODBII Diagnostics, 2014 Entune Plus w Navigation, Leer 100XL dome light wired to dome circuit, pop&lock tailgate and cap locks.
    Installed power pop & lock tailgate lock. Put loc-tite on screw, and expanding foam underneath to make it a little quieter. Ran the cables up to the b-pillar, there is a floor grommet there. Soldered, heat shrink tubing to door circuit, passenger side. While I was doing that I connected primary wire to my dome light. I attached the leads to either side of the dome light, and connected with a two-lead disconnect (not a bullet-type Autozone connector). One side of dome light will be negative switched and on factory timer. The other side is 12V constant. Ran all of this back in wire loom, wire-tied neatly to existing harness. I then ran a 4-flat wire harness through a hole in bed (with grommet and wire loom. I soldered 4-flat to dome light leads and to stop light and ground. I mounted the connector to the composite bed. It came with a weatherproof cover. I'm now ready for my cap. I'm kind of OCD about wiring! No vampire taps if at all possible! I doubt the dealer would come even close to this job, and now my cap dome light will turn on when a door is open, or switch (in cab) is turned on. And it will go off automatically if in advertently left on. I'll mate a 4-flat male to the existing cap harness myself. Of course, dealer may give me flak about not leaving without him connecting 3rd brake light or something. We'll see.
    I read of connecting it to the parking lamps or something like that. Not for me.
  9. Dec 4, 2013 at 2:58 PM
    scocar
    scocar hypotenoper
    I guess it makes it easier for you to accept that you are a racist if you assume that everyone else is, or that they would be if they lived where you are.
    This is flawed reason.
  10. Dec 4, 2013 at 3:14 PM
    Manwithoutaplan
    ID
    Throw all your logical you want, but everybody I know that has lived in this area and coming from other states slowly becomes a raciest. So when someone say there not a racist I say they are full of monkey poo.
  11. Dec 4, 2013 at 3:17 PM
    richardbui23
    richardbui23 That guy
    Richard
    Arlington Texas
    Stacy
    im races but towards everyone and equally so it all works out :D j/k im a minority :pout:
  12. Dec 4, 2013 at 3:19 PM
    Bamo
    Bamo Well-Known Member
    Barry
    North Port, FL
    09 Regular Cab 4x4
    Put on a Flowmaster Super 44 muffler today. Loud but not terrible. I will give it a few days so I can get used to it, but I think I like it.
  13. Dec 4, 2013 at 3:20 PM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    DAFUQ?! So every "minority" is bad? Also us crackers will soon be the "minority".
  14. Dec 4, 2013 at 3:25 PM
    Shauncho
    Shauncho Embrace your inner Bro-ness
    Shaun
    Parts Unknown...
    none
    I can see this topic getting out of hand so why don't we all just agree to disagree and move on...besides racism has little to do with what mods you did today...unless you just installed a dixie horn.
  15. Dec 4, 2013 at 3:31 PM
    Infra
    Infra Well-Known Member
    Az
    2010 MGM DCSB 4x4 TRD OR 6spd
    CBI Bushmaster 2.0 rear bumper with swing out tire carrier & fold down camp table, CBI Moab 2.0 front bumper, Warn M8000-S, Icon 2.5 RR CDC Extended travel CO's with 700lb springs, Icon 2.5 RR CDC rear shocks, Icon hydro bumps, Total Chaos uniball UCA's, All Pro Expo leafs, U-bolt flip kit, Softopper, diff breather mod, extended rear brake lines, Grillecraft mesh grille, Elusive Elements behind grille light bar with B.A.M.F. LED light bar brackets, okLEDlightbars.com 20" double row LED light bar, Relentless Fabrication hood cb antenna mount, Wilson Silver Load CB antenna, Uniden 520 Pro XL CB radio, Wet okole seat covers, Weather tech floor liners, Weather tech in channel window deflectors, trasharoo spare tire trash bag carrier, Box Rocket 2nd gen bed rack with (2) 2 gallon gas rotopax mounted on drivers side, (2) 2 gallon water rotopax mounted on passenger side, (1) 3 gallon gas rotopax & (1) 2 gallon gas rotopax mounted on CBI swing out, Avid weld on sliders, Mattgecko LED bed light
    All I said was the bus scared me so I decided to walk :notsure:
  16. Dec 4, 2013 at 3:31 PM
    Manwithoutaplan
    ID
    I just installed one and Stars and bars decal.
  17. Dec 4, 2013 at 3:32 PM
    Manwithoutaplan
    ID
    we already are.
  18. Dec 4, 2013 at 3:32 PM
    Shauncho
    Shaun
    Parts Unknown...
    none
    hahaha, git'er done!!!
  19. Dec 4, 2013 at 3:33 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    I am not a raceist , or a racist
    deal with it
  20. Dec 4, 2013 at 3:34 PM
    Manwithoutaplan
    ID
    :thumbsup:
    Btw when are you installing those heated mirror's
