  1. Jul 6, 2014 at 9:27 AM
    06texasedition
    06texasedition Well-Known Member
    Picayune ms
    06 Tacoma Texas edition(RIP) 14 tundra limited 4x4
    3" rough country lift. Blue interior lights courtesy of jumper led. Led tail lights avid front and rear bumper guard with 4 Hellas on front. Borla dual exhaust blue led reverse lights color matched satoshi grille
    Yes. So if I change leaf springs it will fix it
  2. Jul 6, 2014 at 9:30 AM
    Pdugan6
    Pdugan6 Well-Known Member
    Patrick
    Sunnyvale California
    3 link solid axle 2011 Tacoma 4x4
    Great idea right there.
  3. Jul 6, 2014 at 9:33 AM
    BostonBilly
    BostonBilly Well-Known Member
    Easton
    2018 Jeep Wrangler JL Rubicon
    Yes if you get a better non OEM set. I went with the Iron Man lift and haven't looked back since. Not only did I have the axel wrap but I also had the tendency to have the rear end want to come around under heavy braking/emergency braking on the highway. Both issues were fixed with the Iron Man install
  4. Jul 6, 2014 at 12:50 PM
    MikeyMcFly
    MikeyMcFly This is heavy, Doc.
    I'm a Masshole
    2016 TRD Off-Road 6MT / 2021 WRX STI
    Building a Broja
    Got the Philips Daylight 4 LED DRL kit installed and working on the ARB.
    Pretty neat piece. I do wish it was a little brighter as it tends to wash out in the super bright sunlight, but it is a neat unit as far as the way it turns on and off based on battery voltage.
  5. Jul 6, 2014 at 12:58 PM
    wgreenlee1021
    wgreenlee1021 Off the Meds Again...
    Get us some nighttime pics when you can.:thumbsup:
  6. Jul 6, 2014 at 1:10 PM
    MikeyMcFly
    I'm a Masshole
    Building a Broja
    Will do.
    The way the unit is designed it will automatically turn off once my parking lights are on, but I can snap a picture with just the lights out. They're quite bright at night. I imagine they'd be decently bright on an overcast day as well.
    In hindsight, maybe I should have put the trigger on the headlights instead of the parking lights so that I could use them along with the parking lights, but I think I like them as-is. I also would prefer not the rip apart the wiring again.
  7. Jul 6, 2014 at 2:18 PM
    Beerrun
    Beerrun Well-Known Member
    Jon
    Spokane WA
    10 Sedan Sport LB
    Fog light rewire- debadge- front window tint- 5100's @ 1.75- Toytec 1.5 AAL- Avid sliders- 4x4 lighted switch- Sockmonkey decals- Truxedo low pro QT cover- Weather Techs- Back up light Mod. Diff. breather mod. OEM roof rack-Yakima bars. HomerTaco grill. Hella Black Magic Lts. WT vent visors.
    Why not just do the belt chime delete mod?
  8. Jul 6, 2014 at 2:24 PM
    bueller
    bueller Well-Known Member
    AZ
    Installed 5100's at 1.75 with sport coils on my off road.
  9. Jul 6, 2014 at 2:42 PM
    Zednix
    Zednix Well-Known Member
    Edmonton, Alberta, Canada
    14 TRD Sport
    I will certainly keep this in mind if my clean up doesn't turn out decent.
    I checked on my truck at 8 am and it was a little bit damp but not seeping water if you pressed on the seat. I have the damprid sitting in its little jar/bucket on the floor soaking up any moisture in the air. It has been in there for most of the day and there is no smell in the truck currently. The seat is completely dry and there is a bit of residual water on the floor mat(rubber) that I just dabbed up with napkins. So things are going well with clean up.
    In other news it seems I have picked up a rock and it is trapped somewhere that causes a pretty ugly grinding/screeching noise when I'm driving. It seems to be louder while in reverse. I went through a rather large puddle today so I think a rock might have been deposited somewhere. No idea where it could be lol.
  10. Jul 6, 2014 at 2:59 PM
    Dragons Taco
    Dragons Taco Well-Known Member
    Derek
    Cary/Raleigh NC
    06 Black TRD-S 4WD 4D 6SPD and MINE!
    Can ya spell Tonneau
    I like it. Simple and easy to deal with. Hope puppy can dodge the airbag.
  11. Jul 6, 2014 at 3:01 PM
    ClayCrusher
    ClayCrusher Texas Transplant Taco
    Corpus Christi, TX
    13 DCLB MGM
    5100, OME 886 deaver 2" AAL, 1.5" Block Peacemaker deluxe front bumper, 20" led bar, sPOD with custom switches, 285/70/17 Goodyear Wrangler Duratracks, Procomp 7033
    Washed her! 55f2458b-2659-4aae-8bbf-5c31160e1349_3759aab7b5b9e260ea63d4236ea8574f16e5d18e.jpg
  12. Jul 6, 2014 at 4:18 PM
    VaGlock
    VaGlock Well-Known Member
    Kevin
    central virginia
    14 DBLC / Sport / Blue Ribbon Metalic
    Weathertech mats and wind deflectors, Bak Flip cover, CB Radio,Clazzio seat covers,Scan gauge,Uni filter,LED interior lights, Redline hood struts
    Plasti Dip'd the front valence, turned out great. Did the hose clamp on the tailgate hinge and washers on the tailgate cables theft deter-ant mod. Installed some red led's in the third (center) brake light.
  13. Jul 6, 2014 at 4:28 PM
    Robman
    Robman Well-Known Member
    Rob
    Hawaii
    '14 Tacoma Double Cab
    Added 12v outlet to rear of center console. Used and add-a-circuit, constant 12v.
  14. Jul 6, 2014 at 4:29 PM
    Phils514
    Phils514 Well-Known Member
    Phil
    Dcsb
    Plasti derp my grille
  15. Jul 6, 2014 at 4:37 PM
    BeePee
    BeePee Well-Known Member
    Cody
    CA
    09 DCSB TRD Sport Pyrite Mica
    6" ProComp. Icon Coilovers. Alcan Leafs. Bronze BFDs. TRD Caps. BORA Spacers. Toyo. Magnaflow. Debadge. Viper. WeatherTech.
    Didnt want it turned off completely. With this I can click it in when I need it, take it out when I dont.
    He's only ~30lbs, so the airbag turns off automatically. Not sure if thats a good thing or a bad thing.
  16. Jul 6, 2014 at 4:41 PM
    CanisLupus
    CanisLupus Member since 2011
    Stokesdale | NC
    ‘19 Honda Civic Hatchback
    If it's beeping, that means the airbag is active though, correct? Or else it wouldn't beep because it thinks no one is in the passenger seat?
  17. Jul 6, 2014 at 4:43 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Yep
  18. Jul 6, 2014 at 4:51 PM
    tacodane
    tacodane The Slow But Getting Somewhere Build
    Dane
    2013 Tacoma Prerunner SR5
    Led Interior Lights AFE CAI Stage II, Aero Turbine 2525 Muffler Snugtop Cab-Hi shell TRS Retrofitted Headlights
    What fuse did you tap?
  19. Jul 6, 2014 at 4:55 PM
    06texasedition
    Picayune ms
    How much did it cost
  20. Jul 6, 2014 at 5:33 PM
    wgreenlee1021
    Both of them look really cool!!!:thumbsup:
