  1. Nov 1, 2014 at 8:39 AM
    RND2
    RND2 Well-Known Member
    In my head swimming around
    12 DCSB
    RCD 4"
    I agree with having a dash cam and heading out to get one today.
    Had some asshole pull out in front of me yesterday from a side street and almost rear ended him, I slammed on the brakes and moved to the left to avoid the hit but he kept moving in the direction as if he wanted me to rear end him it was very close.
    Typically when you rear end someone its your fault and it would have been hard for me to prove it was his without a dash cam showing what actually happened so yea I'm getting one for protection against people not paying attention on the road.
  2. Nov 1, 2014 at 8:45 AM
    mikerm
    mikerm Well-Known Member
    Grand Rapids, MI
    2011 4x4 DCSB TRD
    Yup, something like that is what finally pushed me over the edge. I had been thinking about getting one, but a couple weeks ago 2 of us almost t-boned some dumb woman (Why is it always a woman?) ran a red light after it had been green for us for a while. I would have demolished her drivers door and the guy next to me would have demolished the rest. Got to test my brakes though, they still work. :mad:
  3. Nov 1, 2014 at 8:53 AM
    tacomonazul
    tacomonazul Well-Known Member
    Luis
    SOCAL
    07 DCSB LT/4LINK
    http://www.tacomaworld.com/forum/2nd-gen-builds/227832-my-never-end-build.html
    So you guys with dash cams have it on when on road and erase everything when you get home?
  4. Nov 1, 2014 at 8:56 AM
    SabMotocross
    SabMotocross Well-Known Member
    Bobby
    Santa Fe, Texas
    2014 Tacoma PreRunner SR5 DCSB V6 TRD S/C
    TRD BAJA Suspension...Rims and tires, blackout badging, TRD oil filler cap, front skid plate, N-Fab step bars, GrillCraft custom upper and lower grills. K&N air filter, TRD Supercharger.
    Stopped by my neighborhood Toyota dealership and ordered one:
  5. Nov 1, 2014 at 8:58 AM
    ThomasMore66
    Dallas/Fort Worth & Durango
    Jealous! I hope that is my near future.
  6. Nov 1, 2014 at 9:00 AM
    ERMB
    ERMB Well-Known Member
    2002 Land Cruiser
    Looks like you have stock upper and lower control arms. How did the alignment turn out afterwards? Any issues, I'm thinking of going that route.
  7. Nov 1, 2014 at 9:09 AM
    SabMotocross
    Bobby
    Santa Fe, Texas
    It should definitely stop the pestering I have recently received from a few 2015 Colorado/Canyon owners. Even though my surprisingly disadvantaged V6 is about 67 horsepower short, it still doesn't get sucked into the wake of these "supposedly superior" trucks from GM.
    It's just insurance to make sure they don't get too comfortable picking on Tacos. :D
  8. Nov 1, 2014 at 9:11 AM
    Pigpen
    Dan
    Northwest Montana
    Inquiring minds want to know...
  9. Nov 1, 2014 at 9:13 AM
    velillen
    velillen Well-Known Member
    Nick
    Wyoming
    2011 Access Cab 4x4
    Nope. Most will record in set segments (think mine is 5 minutes) then it just maes segments till SD card is full. Once SD card is full it earses the oldest segment. So it auto deletes the oldest. It really is a easy set it up and forget about it till you really need it.
  10. Nov 1, 2014 at 9:31 AM
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    '24 X3 M40i
    Very nice. Hope to get mine by Thanksgiving :thumbsup:
  11. Nov 1, 2014 at 10:03 AM
    tacomonazul
    Luis
    SOCAL
    07 DCSB LT/4LINK
    oo thats nice, so it must have a screen to see the video when needed right?
  12. Nov 1, 2014 at 10:12 AM
    Scooter WCT
    Scooter WCT Well-Known Member
    Scott
    Wesley Chapel, FL.
    2014 DCSB TRD Sport 4x4 w/ 6speed Manual
    3" Lift using Bilstein 5100 Height Adjustable front shocks and complete rear Old Man Emu Dakar springs from Toytec, 17" 4Runner TRD Pro Series w/ 32" BF ATs, Tint and much more to come
    It may have 305HP, but it only has 269TQ. Taco is 266TQ. HP means nothing, ask the Honduh boys lol.
  13. Nov 1, 2014 at 10:14 AM
    SabMotocross
    Bobby
    Santa Fe, Texas
    Good factual points, Scott!
  14. Nov 1, 2014 at 10:16 AM
    Idaholandho
    Idaholandho The other white meat
    3 Now - 2022 Trail Edition, 2015 TRD 4x4 and a 2006 SR5 4x4
    2015 Tacoma, Magnuson Supercharger, Bully Dog Flash and GT, Safari Snorkel, Toytec BOSS 2.5 Coil Over Front, Toytec BOSS Aluma 2.5 Rear, Toytec 10 Leaf Pack, Stainless Brake Lines, Icon UCA's, CBI Reverse Adj Shackle Mounts, CBI Ubolt Flip Kit, Timbren Bump Stops, CBI Bushmaster 2.0 Front Bumper w/ Warn M8000S Winch and SR2 Rigid Flood Lights, CBI Bushmaster 2.0 Rear Swingout Bumper, Rigid SR2 backup lights and Dual RotopaX / Fuel/First Aid Pack, CBI Rock Sliders, CBI Full Skids and CBI Rear Diff Armor, BAMF LCA Skids, FrontRunner Outfitters Slimline II Roof Rack w/ Rigid SR2 40" Combo Light Bar, Rock lights, Rigid pods in Bed Rack, Intelligent Battery System w/ Dual NorthStar batteries, Spod Power Distribution, illuminated switch panel in sunglasses holder, Viar Extreme Duty On-Board Air w/ 2.5 Gallon Tank under bed, Air 2 Air Sys, Magnaflow Exhaust, Fuel Off Road Trophy Wheels, 285/75/17 Toyo Open Country R/T, Diff breather mod, FX-R BHLM Demon Eye headlights, Esuse LED Fog Kit, Pelfreybilt Camera Relocation mount, Pelfreybilt ax/shovel bed mount, Debadged, tint, a 2006 Tacoma SR5 and a 2022 Trail Edition
  15. Nov 1, 2014 at 10:31 AM
    11TRDTX
    11TRDTX bruh
    Memphis, TN
    2011 TRD TX 4x4 MGM DCSB
    Lift, 285's, mud, and scratches
    Decided to get the truck dirty
  16. Nov 1, 2014 at 10:36 AM
    Overkill07
    Overkill07 Tacoitis
    Warren
    Texas
    14 TRD O/R DC MGM
    A few audio upgrades, tinted windows, remote start because it f'n hot in Texas! 6in Fabtech DB lift, 17x9 Fuel Trophy wheels, 315/70/17 Duratracs,BAMF 80in sliders w/kickout, Prinsu cab rack w/30in Heretic light bar, custom bedside decals, custom hi-lift jack brackets, US Offroad front bumper w/winch, bed rack with RTT, CB, Short wave base station, Ultra gauge, color matched grille surround, an ungodly amount of recover gear, ARB fridge, hood struts, RotoPax, traction pads.
    This is now on my short list of mods since the new lift. Interested in the possibility of the extra torque causing any drive line issue? :notsure:
  17. Nov 1, 2014 at 10:55 AM
    SabMotocross
    Bobby
    Santa Fe, Texas
    Well, it's one reason I beefed-up my stock PreRunner suspension to the stouter BAJA suspension from TRD. I knew one day my weakness for power would overcome my rational thought and I'd end up buying a blower for my truck...so here I am, LOL!
    I believe it's a mild increase in relative terms. It's not like going from a 240 horse powerplant to 400 RWHP...so our suspensions should be good. I'm just concerned about spring wrap-up under hard acceleration.....
  18. Nov 1, 2014 at 12:45 PM
    williams63
    williams63 Well-Known Member
    chili
    nh
    2011 dblcb
    boss-c/o, boss rear leafs
    I have LR uca just didn't get a pic of them. the boss c/o are very nice but really don't have anything to compare them to. thinking about the boss leaf pack next.
  19. Nov 1, 2014 at 1:22 PM
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    TRD Exhaust, URD Short Shift, TRD Supercharger, Hellwig rear sway bar, TWM shift knob, limo tint, URD Y-pipe, URD LT Headers, URD Rear O2 Sim, Custom tube front and rear bumpers, LED spot pods, K&N CAI
    Its an SD card its writing to so yeah
  20. Nov 1, 2014 at 1:29 PM
    phillstill
    phillstill Long hair don't care
    Phill
    Tulsa
    LT35TANK
    Everything
    Replaced my wheel hub assemblies.
