  1. Nov 23, 2014 at 7:40 PM
    Timbo's Customs
    Timbo's Customs Well-Known Member
    Timothy
    Lakeland FL
    2019 f250 6”lift 37s deleted 1997 T4r, tons and 4ds
    1997 t4r has super duty axles, 5.13s locked front and rear. 3 link front with 14" kings. Rear 63s.
    Nice bubble in the T
    Other then that it looks way better
  2. Nov 23, 2014 at 7:41 PM
    bullaculla
    bullaculla IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
    The old one had more bubbles :D I'll work more of them out after it sits in the sun a bit. It's really hard getting that giant thing down without bubbles or wrinkles.
    Thanks tho :)
  3. Nov 23, 2014 at 8:22 PM
    steveo27
    steveo27 Ask me about my weiner
    Pittsburgh
    '11 TRD Off Road & 1992 VW GLI
    The same shit everyone else has.
    Thanks :beer:
  4. Nov 23, 2014 at 8:23 PM
    ERMB
    ERMB Well-Known Member
    2002 Land Cruiser
    Did you prep anything first, or just go in spraying? Thinking about doing this soon. Want to know what I'm getting into.
  5. Nov 23, 2014 at 8:44 PM
    MikeyMcFly
    MikeyMcFly This is heavy, Doc.
    I'm a Masshole
    2016 TRD Off-Road 6MT / 2021 WRX STI
    Building a Broja
    Hit the car wash and sprayed the frame with the high pressure water but otherwise no.
    This is my third winter and third FF treatment. Year one I went crazy and applied with my hands and a brush and coated every square inch of the frame. Last year I used my hand and a brush and did the same. This year I relied on the Kellsport upgrade spray gun to do the dirty work. I like how it applied the FF and I used the extension to get the box by the cats. I will most likely touch up with the aerosol can once I have the front wheels off to swap to my winter tires.
  6. Nov 23, 2014 at 8:57 PM
    ERMB
    2002 Land Cruiser
    Ahh good, I was hoping I wouldn't have to get under there an wire wheel every rust spot. Kit is probably well worth it then, I was wondering if using a few cans would be enough but doesn't sound like it.
  7. Nov 23, 2014 at 8:59 PM
    norrinraad
    norrinraad Active Member
    gw
    Louisiana
    2014 pre runner sr5
    4 spindle lift, Rear 2" tapered block w/ex tended bilsteins, ome foldout rack, powder coated Rockstar 2 wheels, toyo open countries, misc. decals, seat covers,6 shooter shifter grip and extension, Plasticoated badges, tool box
    No point
    just personal preference. :)
  8. Nov 23, 2014 at 9:03 PM
    ThomasMore66
    Dallas/Fort Worth & Durango
    Perfect. Nobody at my office understands the point of a lifted, supercharged Tacoma either.
  9. Nov 23, 2014 at 9:42 PM
    tacomonazul
    tacomonazul Well-Known Member
    Luis
    SOCAL
    07 DCSB LT/4LINK
    http://www.tacomaworld.com/forum/2nd-gen-builds/227832-my-never-end-build.html
    It was awesome! Wether was perfect just little wind and got a little cold at night.
  10. Nov 23, 2014 at 9:50 PM
    GoldenGeek
    GoldenGeek Well-Known Member
    Brandon
    Oro Valley, AZ
    Finished with the interior pieces but also dipped the badges!
    JUST put all interior back together, but I wanted to wait until tomorrow for daylight pics!
    Tore apart my shifter knob. Gonna slap some new leather on it as well as a shift boot (maybe in a month or two).
  11. Nov 23, 2014 at 10:12 PM
    tacomonazul
    Luis
    SOCAL
    07 DCSB LT/4LINK
    Took to the truck for a walk to glamis again
  12. Nov 24, 2014 at 3:15 AM
    mgord
    mgord Well-Known Member
    Harrisburg, PA
    07 TRD
    K&N, Leaf Springs, Home Built Camper
    Homebuilt Cap. 2 weekends. Scrap roofing from the blimp hanger in the background and leftover deck material. 4 cans of black bedliner and about $30 in hardware.
  13. Nov 24, 2014 at 4:21 AM
    Hot2na
    Hot2na Well-Known Member
    U forgot to add: 1 can of Ugly.....
  14. Nov 24, 2014 at 5:47 AM
    45longcolt
    45longcolt Well-Known Member
    DFW Area
    2020 Off Road
    Looks very sturdy and the price was so right. Always good when you can re-use something and you made good use of that material.
  15. Nov 24, 2014 at 5:50 AM
    rbishopp
    rbishopp Well-Known Member
    Rich
    Webster, NY
    2009 4WD Reg cab Taco. Keepin it simple.
    So far I've added an Advance folding bed cover and since removed it. Gave it to my son in Maine, he has an 05 2wd. GT perfect fit seat covers. Weathertech floor mats and window vent visors. Waag center brush/grill guard. Hose clamp tailgate mod. Turned off the seat belt chime. Added Ultra-Gauge. Trailer hitch. Softopper. Replaced sun visors with slide out style. Toyota bed extender. Had Firestone Destinations and now Michelin LTX AT2 in stock size. More mods to come; Fog lights, locking storage in bed, intermittent wipers. Now looking for Radio/HU upgrade. and maybe a lift way down the road.
    Now that's pennsyltucky.
  16. Nov 24, 2014 at 5:53 AM
    ERMB
    2002 Land Cruiser
    What the framework on the inside look like? Is that where you used the decking?
    Damn that looks good! What's your plan for a bumper. Looks to be the only thing left.
  17. Nov 24, 2014 at 6:06 AM
    tacomonazul
    Luis
    SOCAL
    07 DCSB LT/4LINK
    Thanks! Follow my build ;)
  18. Nov 24, 2014 at 6:52 AM
    josefmd
    josefmd Well-Known Member
    Springboro OH
    2017 4R TRD Pro Cement. 2024 Ford Ranger Raptor
    Just did mine as well! Kind of nice when the truck is new! No prep or cleaning this year!! I bought 6 cans of Fluid Film from my local O Reilly's, ended up spraying 3 cans on mine... Got to get a spray gun and buy the 1 gal can for my next application...
  19. Nov 24, 2014 at 7:07 AM
    4x4Taco2012
    4x4Taco2012 Well-Known Member
    Tim
    Huntingdon Valley, PA
    2022 DCSB Limited 4x4
    TRD lift, TRD SEMA wheels, TRD skid plate, TRD Pro fog lights, TRD Heritage Grill, OEM bed cover, LT275/70/17 Falken Wildpeak AT3Ws, OEM bed lights, OEM all weather floor mats, OEM door skid plates, OEM mud guards, OEM bed mat, Black lug nuts
    This is the third year I have sprayed Fluid Film on mine and my frame and undercarriage still looks new. I used cans the first year and I believe I went through five or six of them ... can't remember. This year I bought the kit and used the spray gun and it works very well. I coated the frame/undercarriage on all three of our vehicles a few weeks ago and used almost an entire gallon jug. Most people probably don't use that much but I would rather have too much than not enough on there.
  20. Nov 24, 2014 at 8:10 AM
    Zero Cool
    Zero Cool Taco Padawan
    Southern Cali
    14 DC SB TRD Sport Prerunner
    BHLM, 285/70/17 Bridgestone AT Dueler Revos, Ultra Gauntlet wheels, Debadged, TW Sticker, Custom bedside decals.
    [​IMG][/QUOTE]
    What color did you use and how fun was it to tape off those circles?
