  1. Mar 9, 2015 at 4:34 PM
    Harley2
    Harley2 Well-Known Member
    Rick
    Vermont
    15 Super White Double Cab 4x4
    Repaired a passenger side dash rattle then installed a new color matched grill.
  2. Mar 9, 2015 at 4:35 PM
    bridaw
    bridaw The light was yellow, Sir.
    Brian
    SoCal, East San Diego County
    10 DC 6-speed TRD OR 4x4 tow debadged
    tailgate hose clamp/washer mod ,disable seatbelt warning ,dealer tinted windows ,running boards ,DiamondBack SE bed cover ,OEM rubber bed mat ,TRD Japan shift knob ,bed rail corner reinforcement with angle brackets+square nuts ,Armor Tech Offroad mount for 60" highlift jack ,Scangauge II ,OEM roof rack ,BajaRack basket ,WeatherTech dark tint window deflectors ,removed mud flaps ,debadged ,stubby antenna ,D-rings - 4 in bed floor + 8 on the side rails ,cut four D-ring slots in bedmat ,secured ActionPacker 48 gal cargo box to bed ,center console lock ,relocated 7 pin harness ,Redline Tuning QuickLIFT Elite hood supports ,Pop & Lock PL5300 tailgate lock ,RAM A-pillar mounts for GPS and Drift HD170 camera ,RAM mounts on bajarack for Drift HD170 exterior shots ,relocated rear differential breather ,headrest iPad mount ,ImMrYo rear view mirror lift ,Panavise Indash mount ,265/75/16 BFG All-Terrain T/A KO on TKO black rims ,installed front and rear WeatherTechTacoma DigitalFit FloorLiners ,replaced interior/external lights with Jumpers LEDs +switchback mod +under hood light ,installed rcbs204 Illuminated 4x4 Switch ,installed left and right Relentless Off-road Fabrication hood hinge light mounts ,installed KB Voodoo's Powder Coated Tailgate Cap System ,installed front and rear Wet Okole seat covers ,made and installed mount for Trail Toys NSA Switch Panel ,did ND4's Fog Light Anytime Mod
    Skip the Famous brackets. Search the forums, they vibrate. Look at the design…. of course they will.
    Relentless and CBI brackets are about the same price and you can't go wrong with either.
  3. Mar 9, 2015 at 4:37 PM
    AWF ROWD
    AWF ROWD ...eats at the " Y " often....
    Doc
    40.102° N, 82.804° W
    '13 BLOWN 4X4 Sport
    TRD Supercharger, Walbro 255 FP Upgrade, aFe Stage 2 si CAI, TRD Acrylic cover by Coupe ADD 1 OIL Catch can/SS hoses, TRD cat back exhaust, URD 2.8" Stealth pulley, 3" lift, Toytec/Bilstein C/O's, Toytec Progressive AAL's, LR UCA's, 5100 Rear Billies, Bi-Xenon HID BHLM Retro's w/ Halos RED LINE Tuning Hood Rods Swaybar Relocate, Line X'd Bull Guard/Step, Hitch, Craven Speed Dual Gauge mount, AEM Boost/AFR Gauges, Windows 20% tint, Weather Tech deflectors, GrillCraft upper and lower, Tacoma Raptor letters, LED Interior/Exterior lighting, Lund 6" Color Matched Oval Side Bars, Webasto 700 II sunroof, Heated Two toned custom leather TRD logo'd, Kenwood Multimedia 6990 HD head unit ,JL Stealthbox sub, Hertz Component speakers,, Entire cab damped with hushmat, Viper Security/Remote start, Weather Tech Liners, Blackened exterior LED Lights, Undercover Top w/LED's, Carbon fiber TRD windshield decal,, TRD stitched leather shift knob, TRD steering wheel emblem,
    Finally found someone whos worked on LR UCA's...!!!
  4. Mar 9, 2015 at 4:47 PM
    QChawks
    QChawks Well-Known Member
    Davenport, IA
    2009 TRD Sport DCLB
    Yikes. Definitely needed an alignment
  5. Mar 9, 2015 at 4:48 PM
    rcsb jon
    rcsb jon Well-Known Member
    Pittsburgh
    '17 Ridgeline RTL-T | AWD | White | Ebony
    -WeatherTech liners
    Cut the tip off last night, at the 1st exhaust flange...
    Then decided it wasn't enough, today... so cut it at the downward slope, over the axle. Can't see it all hanging down at all now
  6. Mar 9, 2015 at 4:58 PM
    AWF ROWD
    Doc
    '13 BLOWN 4X4 Sport
    Uhhh...those are my final numbers..dead on for a 3" lift IMHO....Tracks perfectly...Before alignment, I could only get 1.4* of caster..LR UCA's set at +2 "D" position..!!
  7. Mar 9, 2015 at 5:21 PM
    euroshowoff
    euroshowoff Well-Known Member
    Stafford, VA
    15 Superwhite DCSB 4x4 V6
    Toytec lift, Trailgear sliders, CBI ditch light brackets, Trailtoys LED ditch lights, Trailtoys LED reverse pods, Custom Roll-Bar, TRD skid plate, TRD sport grill, TRD custom bedsides, Custom BlueSea wiring block, OTTRAW Rockers, Pro Comp 7036, BFGoodrich KO2s, Bestop soft topper,VIAIR 88p
    Very impressed with the craftmanship of the cbi brackets, install was a breeze and I did it over the weekend.
  8. Mar 9, 2015 at 5:29 PM
    la0d0g
    running for the hills
    For crawling not hauling
    Info on rattle? Was it up towards the window area? How'd you fix it?
  9. Mar 9, 2015 at 5:32 PM
    ThomasMore66
    Dallas/Fort Worth & Durango
    When I look at the pic it seems like you're limited on the size of the lights you can use w/o hitting the hood.
  10. Mar 9, 2015 at 5:43 PM
    Base Camp
    Base Camp Instagram: @willismtc
    Willis
    Roanoke, VA
    '14 Base Model 4x4
    I was concerned about that before I put mine on. Turns out not to be a problem. I'm just running 2x2 pods though.
  11. Mar 9, 2015 at 5:46 PM
    josh0351
    josh0351 Californication
    Josh
    VA
    Supercharged '13 TRD OR | '96 4X4 Reg Cab (RIP)
    Some stuff...
    Media-blasted & acetone prep on AllPro rear bumper. Next up is to shoot it with Prismatic Powders Flatter Black powder-coat and bake it. :bananadance::woot:
    [​IMG][​IMG]
  12. Mar 9, 2015 at 5:53 PM
    CVYota
    CVYota Yarrr, me be Captn Andy
    Andy
    Crescenta Valley
    2011 DCLB V6 4WD
    Right where you want to be.
  13. Mar 9, 2015 at 6:01 PM
    BeaverYota
    BeaverYota Oregon State Edition
    Josh
    Lake St. Louis, MO
    Sold...
    Appreciate it guys. Thinking I should get me a set of these and add more lights!
  14. Mar 9, 2015 at 6:06 PM
    BeaverYota
    Josh
    Lake St. Louis, MO
    Sold...
    So you circumsized your truck! Congrats
  15. Mar 9, 2015 at 6:24 PM
    NC15TRD
    NC15TRD Well-Known Member
    Nick
    PA
    16 Sierra SLT All Terrain
    Readylift, Truxedo, Husky Liners, Carven
    :rofl:
  16. Mar 9, 2015 at 6:34 PM
    2007TacBorla4X4
    2007TacBorla4X4 Well-Known Member
    Bob
    Jax, FL
    TRD Sport 4X4 Short Bed
    Borla cat back, K&N cold air, Silver star bulbs, Nerf bars,NEW BFG, Weather teck windows, Flash light on the drivers seat, TRD off Road ft tow hook, Rear driving lights on bumper, Weather teck windows & ft bug guard, 4X4 switch glows, Windows tinted 20% sun shade
    Put a 4 pin receptacle on the for towing on the truck.
  17. Mar 9, 2015 at 6:38 PM
    hrspwr236
    hrspwr236 X-Runner Addict
    AZ
    2012 Barcelona Red X-Runner
    Python Alarm, Scangauge II, Valentine V1 w/ Blendmount, Black Front Badge, Volant CAI w/ Ram Air Scoop, TRD CBE, Doug Thorley Pipe Bomb, 19" TSW Montage, 245/45/19 Hankook V12, FLM, BHLM, 6k Heads & 3k Fogs, Undercover Tonneau Cover, Tacoma Bed Mat, Headrest Delete
    Maybe it won't get so dirty now :eek:
  18. Mar 9, 2015 at 6:48 PM
    rcsb jon
    Pittsburgh
    -WeatherTech liners
    Indeed... that's what it looked like too... a limp dick
  19. Mar 9, 2015 at 7:47 PM
    steveo27
    steveo27 Ask me about my weiner
    Pittsburgh
    '11 TRD Off Road & 1992 VW GLI
    The same shit everyone else has.
    OEM ones?
    I started on my puddle lights -
    A0F603F6-0B3E-4126-A625-5688B22CD8C6_zps_efd88f89efd5aac24693b72b30a2439a7224ac45.jpg
    Just need to figure out where to tie them in to get them to come on when you open the doors
  20. Mar 9, 2015 at 7:50 PM
    Idaholandho
    Idaholandho The other white meat
    3 Now - 2022 Trail Edition, 2015 TRD 4x4 and a 2006 SR5 4x4
    2015 Tacoma, Magnuson Supercharger, Bully Dog Flash and GT, Safari Snorkel, Toytec BOSS 2.5 Coil Over Front, Toytec BOSS Aluma 2.5 Rear, Toytec 10 Leaf Pack, Stainless Brake Lines, Icon UCA's, CBI Reverse Adj Shackle Mounts, CBI Ubolt Flip Kit, Timbren Bump Stops, CBI Bushmaster 2.0 Front Bumper w/ Warn M8000S Winch and SR2 Rigid Flood Lights, CBI Bushmaster 2.0 Rear Swingout Bumper, Rigid SR2 backup lights and Dual RotopaX / Fuel/First Aid Pack, CBI Rock Sliders, CBI Full Skids and CBI Rear Diff Armor, BAMF LCA Skids, FrontRunner Outfitters Slimline II Roof Rack w/ Rigid SR2 40" Combo Light Bar, Rock lights, Rigid pods in Bed Rack, Intelligent Battery System w/ Dual NorthStar batteries, Spod Power Distribution, illuminated switch panel in sunglasses holder, Viar Extreme Duty On-Board Air w/ 2.5 Gallon Tank under bed, Air 2 Air Sys, Magnaflow Exhaust, Fuel Off Road Trophy Wheels, 285/75/17 Toyo Open Country R/T, Diff breather mod, FX-R BHLM Demon Eye headlights, Esuse LED Fog Kit, Pelfreybilt Camera Relocation mount, Pelfreybilt ax/shovel bed mount, Debadged, tint, a 2006 Tacoma SR5 and a 2022 Trail Edition
    Where is the switch for the lights?
