  1. Mar 18, 2015 at 5:43 PM
    scoutpilot
    scoutpilot Well-Known Member
    Dallas
    TN
    2010 4WD DCLB
    OME 886x with OME shocks, Dakar springs, LR UCAs, ARB bumper with Warn VR8000. Midland 75-822 cb with 3' firestik. Cooper AT3 265/75/16 on stock steelies, rear diff breather mod.
    Got new Cooper AT3s installed, 265/75/16. Very happy with the ride so far. Planning to plasti-dip the wheels soon.
  2. Mar 18, 2015 at 6:03 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    I don't know, those wheel studs have some rust on them. :D
  3. Mar 18, 2015 at 6:11 PM
    skygear
    skygear                    
    did a mobile 1 advanced 5w 30 change rolling 145k ish
  4. Mar 18, 2015 at 6:13 PM
    skygear
    skygear                    
  5. Mar 18, 2015 at 6:15 PM
    RearViewMirror
    RearViewMirror Saw things so much clearer once you... were in my
    Craig Christ
    State of Love and Trust
    2023 Subaru WRX GT Manual
    I haven't washed it since Nov and I'm not kidding when I say that yesterday was the first sunny day we've had in about 2 months. Rain / ice / snow here have set records.
    Anyway... pressure washer and 303 Aerospace protectant. That can you see in the background is stainless steel spray to clean the exhaust.
    Let's not grease those ;)
    I take it off road and this is completely covered in mud / snow often.
  6. Mar 18, 2015 at 6:17 PM
    Yakoma
    Yakoma Well-Known Member
    Randy
    ATL-ish
    '14 DCSB TRD Sport 4x4 - White
    Black APS Bull Bar Black Westin Step Bars Black ARE camper top with Yakima J-cradles (replaced Roll-X Tonneau) Black AMP HD Bed Extender
    Where you at? Florida? It'd probably be awright.
  7. Mar 18, 2015 at 6:30 PM
    teneighty
    teneighty I'd rather be skiing...
    Right behind you. NY
    18’ F150 SCREW LB 3.5 EcoBoost
    Bilstein 5100’s (x4), 275/65/20 Cooper XLT AT3’s
    Photoshopped
  8. Mar 18, 2015 at 6:36 PM
    josh0351
    josh0351 Californication
    Josh
    VA
    Supercharged '13 TRD OR | '96 4X4 Reg Cab (RIP)
    Some stuff...
    Yes, but the oven is only 4'X4'X4' so I had to build an extension to accommodate the AllPro bumper.
    Negative, have not seen that - thanks for sharing! After grinding on the Cab Mount for 45 minutes I decided to take the plasma cutter to it, but another day. Will look into this, thanks again!
  9. Mar 18, 2015 at 6:37 PM
    skygear
    skygear                    
    Yes. Yes it should. There is a 380mm (15") and a 355mm (14") from Rotora. Might be a 340mm (13.4") too. Stoptech has the 340 for sure.
    Our stock tacoma are a 318.7mm (12.55") - so I would just measure to be sure. Something of note though. The Aftermarket Calipers are much lower profile than the stock. That alone will help with clearance.
    Here is a great link for fitment and recommendations. Also, there is a printable template to cutout so you can measure. According to the link, 17" is the recommended minimum.
    http://www.stoptech.com/technical-support/bbk-wheel-fitment-templates
    355 fitment http://www.stoptech.com/docs/default-source/wheel-fitment-templates/98-866-2470-00
    332 fitment http://www.stoptech.com/docs/default-source/wheel-fitment-templates/98-866-2450-00
    I had hands on with the kit. Like StopTech, just thought that the 2 piece design was superior and the addition of another pair, 6 in total, of pistons would be better.
    Form what I saw, there was only the one size kit. We have a 4 piston already on the TRD OR.
    FYI to all - Here is the link to the Rotora BBK (Big Break Kit) thread. Anyone interested, or curious, thats where I'll mirror the info so it al doesn't get lost. http://www.tacomaworld.com/forum/technical-chat/367418-rotora-com-bbk-big-brake-kit-ummm-gravy.html
  10. Mar 18, 2015 at 6:39 PM
    skygear
    skygear                    
    One last link for you. Here is where lots of us cab mount cutters hang out.
    2nd Gen 4x4 35s 3" Lift w/o BODY LIFT
  11. Mar 18, 2015 at 6:44 PM
    horner21
    horner21 Well-Known Member
    Guthrie
    Got it lifted with wheels and tires!
  12. Mar 18, 2015 at 7:07 PM
    RearViewMirror
    Craig Christ
    Lol
  13. Mar 18, 2015 at 7:08 PM
    texvet61
    texvet61 Well-Known Member
    Ocala, FL
    09 Tacoma TRD Sport
    Lighting: Phillips LED headlights, BD's S2pro fog lights, LP4 pro and LP9Pro Racing LED's, Black OaK IR cubes. COMMS: Cobra WSX75 CB, Icom 7000 Ham Radio, antenna; Alpha MotoSS HF 80m-40m, CA-2x4SR tri-band 2m/70cm/ - AUDIO: ALPINE ILX-W650, KTA-450 Amp, S-A60M 300Wt mono amp, F/R door speakers, JL Audio C2-650X, JLAudio Micor 8" sub. C4 Fab Hybrid Bumper, Warn VF12000S, Locking Rear seat Gun Vault. Locking Console Gun Vault, FPV winch Camera,
    received my Hawse Fairlead and my Winch isolator today so I installed those to actually complete the Undercover HMWS winch mount... after that I sprayed the frame with rust proof so the rust that was on the frame would be killed in its track. Bad thing was while under the taco doing the frame treatment I noticed grease splattered all over the inside of the front passenger wheel and frame, I looked at the CV boot and it looked intact so Now I am worried where all that grease came from. Will try to locate tomorrow and plan on taking to shop so they can look at it. I have no idea where so much grease could come from if CV boot looks new and haven't been able to find a crack "yet".
  14. Mar 18, 2015 at 7:09 PM
    Joeyo518
    Joeyo518 Well-Known Member
    Albany NY
    14 MGM TRD DCSB OR 4x4
    Living through NY winters the underneath of my truck will never look like that
  15. Mar 18, 2015 at 7:12 PM
    RearViewMirror
    Craig Christ
    Should have seen it before I started. That was after 6hrs. I make it a point to spray off the salt and grime when I get home or at work.
  16. Mar 18, 2015 at 7:15 PM
    99TacoDriver
    99TacoDriver Well-Known Member
    South Louisiana
    OME 885x/5100s/LR UCA/3 leaf AAL/275/70/17 Terra Trac X-Venture
    i love the way your tuck sits! you not rubbing? or do you have wheel spacers too?
  17. Mar 18, 2015 at 7:17 PM
    99TacoDriver
    South Louisiana
    you used that 303 on the engine too? or did you steam it?
    also, your hands musta been cramping like a mofo after! how can your hands fit in such tight spaces?!
  18. Mar 18, 2015 at 7:17 PM
    skygear
    skygear                    
    Christ Craig!, I tried that. Had the old Gas powered Pressure washer out daily. Wife was pissed . That faded as quickly as it started.
    Now, Toyota is replacing my frame.
  19. Mar 18, 2015 at 8:17 PM
    RearViewMirror
    Craig Christ
    No... I never put water in the engine compartment. Just a lot of hands on and 303 on a wax pad. In actuality the engine compartment wasn't too bad. The undercarriage was a different story hence the 6hrs laying under the truck.
    Yeah, I try to stay on top of it as much as I can. If I get in the mud the first thing I do is spray it off when I get back.
  20. Mar 18, 2015 at 8:59 PM
    SVCTECH7
    SVCTECH7 Member
    Florida
    10 SR5 DLB CAB 4x4
    Husky Floor Liners Stubby Antenna Fog Light Mod ARE X-Series Topper w/Tool box sides Yakima Roof Rack OME 3' lift with HD spring package Bed slide Wet Okole seat covers
    New wheels and tires!
