  1. May 14, 2015 at 7:58 AM
    Rattletrap66
    Rattletrap66 (ノಠ益ಠ)ノ彡┻━┻
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    2014 TRD Off Road DCSB
    ╭∩╮(ಠ۝ಠ)╭∩╮
    They're gone
    Found this crap on the driver side
    MrCrobb and Allstar780 like this.
  2. May 14, 2015 at 8:00 AM
    Cmurder
    Cmurder 2011 TX TRD Offroad
    B.C.
    Kansas City
    2011 TX TRD Offroad
    nothing cool
    WD40 works also
    Edit: I'm reading the thread backwards. WD40 was already mentioned.
  3. May 14, 2015 at 8:03 AM
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    PITA more than anything. I was taking off my bumper to remount my light bar and they were only a nuisance
  4. May 14, 2015 at 8:06 AM
    Allstar780
    Allstar780 Well-Known Member
    Colin
    Alberta, Canada
    15 TRD Trail Teams Sport
    3" Lift, 32" Goodyear Duratrac, XD Series Hoss Rims
    On the other hand, you'll probably gain 1-2 mpg after shedding all that mud weight
  5. May 14, 2015 at 8:07 AM
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    Haha for real. I found this in my gas tank skid. At least 5 lbs of mud here
  6. May 14, 2015 at 11:45 AM
    plurpimpin
    plurpimpin Well-Known Member
    PDX
    2010 TRD Off Road 4x4
    This is the first I've ever heard of this as well. I spent alot of time looking at pictures of people's aux fuse panels on here before I built mine and almost everyone had them mounted the same way I do. Is vertical better because it keeps water out better? Or is it actually better for the relay itself?
    Plenty of manufacturers mount relays horizontally from the factory. Here's a pic I found from a quick googlemachine search:
    I think the pic is from a Nissan Maxima. I'm not saying you're wrong I've just never heard this before so I'm curious to learn more.
  7. May 14, 2015 at 12:09 PM
    reppinthe509
    reppinthe509 Well-Known Member
    Washington
    07 Tacoma TRD Offroad
    Added D-rings up front
    7ef5239d123d5221727aa61857e302c4_c3524fa23075954da52e7bcc286bd9b7cef81dbd.jpg502cc9bfc18f8298a7ab8f46625412d6_0ed3398e20867f5af8d504a5ae97f34d23421d01.jpg
  8. May 14, 2015 at 12:43 PM
    euroshowoff
    euroshowoff Well-Known Member
    Stafford, VA
    15 Superwhite DCSB 4x4 V6
    Toytec lift, Trailgear sliders, CBI ditch light brackets, Trailtoys LED ditch lights, Trailtoys LED reverse pods, Custom Roll-Bar, TRD skid plate, TRD sport grill, TRD custom bedsides, Custom BlueSea wiring block, OTTRAW Rockers, Pro Comp 7036, BFGoodrich KO2s, Bestop soft topper,VIAIR 88p
    Primed my aux fuse block panel.
  9. May 14, 2015 at 1:03 PM
    cuda2k
    cuda2k Well-Known Member
    Jon
    Allen, TX
    BRM 15 TRD Off Road 4wd
    LVL8 MK6 wheels,SOS Sliders,Smked 3rd Brake,Gibson Exhaust
    Finally installed my Grid-It. Probably went overboard with 4 strips of 'EXTREME VELCRO', but oh well - never know when I'll need to strap 30lbs to the underside of my center console. I think my UltraFire flashlight will fit horizontal across instead of the longer (and not as bright) as the Mini-Mag, so going to try reorganizing things later to fit better and more stuff.
  10. May 14, 2015 at 1:07 PM
    lobsterbait
    lobsterbait The Wall
    Not Paul
    Parker CO
    Goose
    Just a couple things
    image.jpg Installed my Prinsu Rack
    rileySB likes this.
  11. May 14, 2015 at 1:09 PM
    Manwithoutaplan
    ID
    this what you bought it from?
    http://www.officedepot.com/a/produc...2ijS9b2OIJLopss3EVYK5gSQ2n86g8IvaSBoC82rw_wcB
  12. May 14, 2015 at 1:11 PM
    ImplicitlyAlberta
    ImplicitlyAlberta VA6DCO
    David
    edmonton
    06 SR5 Trail Rated, 16 Tundra CM TRD
    TC Uni Uppers, TC race lowers, TC shock tower gusset/ secondary shock hoop, Modified Pelfrey rear shock relocate, ATO shackle flip,radflo hydro bumps front and rear, Radflo 2.0 CO/ 14" rear, Arb rear air locker, ARB front bump/m8000, Road armor rear bump/m8000, FJ TransCase/ Twin sticks....other shit.
  13. May 14, 2015 at 1:24 PM
    JEP
    JEP Resident Lurker
    Madison
    15 DBL V6 4WD
    N-fabs, BakFlip VP, power tailgate lock, bed lights, "raptor" grill lights. Standard mall crawler stuff.
    It's not that they don't work, it's that in the engine bay mounted vertically they are less likely to get water in them, from the bottom, which is not always sealed 100%.
  14. May 14, 2015 at 1:39 PM
    Scookum
    Scookum Professional Squeegy Boy
    Dave
    Ontario, Canada
    2015 V6 SR5 4x4 Blue Ribbon
    I put these on
  15. May 14, 2015 at 1:50 PM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    That and I read somewhere that it's better for the internal switch. Especially for offroading, and the bumps you wouldn't want the switch to bump off or on. Sometimes such a bump caused the switch to "weld" in that position. Vertical was the least likely position for something like that to happen.
  16. May 14, 2015 at 2:02 PM
    cuda2k
    Jon
    Allen, TX
  17. May 14, 2015 at 2:25 PM
    Scookum
    Dave
    Ontario, Canada
    I just installed one of these in my console top. The 5 1/2 in x 10 1/2 inch grid it fits perfect, the only thing you need to do is make a couple 1/2 inch cut outs for the console hinges. 2015 Taco.
  18. May 14, 2015 at 2:26 PM
    Manwithoutaplan
    ID
    ok thank you guys. :thumbsup:
  19. May 14, 2015 at 2:37 PM
    YanE30M3
    YanE30M3 GO PATS!
    Yan
    Woodbridge VA
    15 TRD Sport (DCLB-BRM) - 88 ///M3 (Zinnoberrot)
    OME 887/Dakars/NV305s/33" Duratracs/+
    washed and detailed, then took the wheels of the M3 to get nitor fill and working on getting the M3 down and running again.
    steveo27 likes this.
  20. May 14, 2015 at 3:15 PM
    Boilerman
    Boilerman Well-Known Member
    Brian
    Texas, northwest of the Big Pond
    2010 Prerunner SR5 Magnetic Gray 2.7L
    Installed a Pilot Motorsports stainless steel tip. Had to cut the existing tail pipe back 2-1/2" to keep the tip from sticking out so far.
