  1. May 18, 2015 at 5:13 PM
    calico
    calico Well-Known Member
    Northeast
    13 Tacoma Limited
    Viper Alarm and Remote Start Prestigious Society mod Camera display relocated to headunit Weathertec floor mats, window deflectors, and mud flaps Toyota Bed mat Tailgate lock Undercover SE tonneau and Swing Cases (driver and passenger) Hi-lift install Fumoto Qwik Valve ImMrYo Mirror mod Salex console organizer
    Would you mind indicating the mileage? I'll be doing the same as a part of my 30k service and have been curious as to what I might be able to expect.
  2. May 18, 2015 at 5:14 PM
    Newlife
    Newlife Well-Known Member
    Adam
    Knoxville TN
    2020 t4r orp
    Bone f’n stock for now
    81,654 I do a lot of driving for work. But I also take my truck off the pavement some. And recently had a super dusty outing.
  3. May 18, 2015 at 5:18 PM
    Base Camp
    Base Camp Instagram: @willismtc
    Willis
    Roanoke, VA
    '14 Base Model 4x4
    Like a cap? ;)
  4. May 18, 2015 at 5:20 PM
    calico
    Northeast
    13 Tacoma Limited
    :cheers:
  5. May 18, 2015 at 5:28 PM
    Pigpen
    Dan
    Northwest Montana
    I just changed mine at 55K and it gets really dusty here. And I live on a dirt road. And I drive a lot of miles on other dirt roads.
    My shit looked nothing like that, just a little grey.
  6. May 18, 2015 at 5:32 PM
    Therealwinshady
    Therealwinshady Well-Known Member
    Shannon
    Portland(west linn), Or
    2011 DCLB TRD Sport
    5100's and 885's, AAL, fog light mod, map light mod, viper 5706, OR tow hook, inverter anytime mod, Firestone air bags, devil horns, hood scoop riged light bar, 32 inch bumper light bar,
    Just got my oil analysis back from Blackstone labs and am going to run it to 9K on the next oil change and see where I end up on the next oil change.
  7. May 18, 2015 at 5:33 PM
    Larry
    Larry CARL
    CARL
    Yep. I'm considering that.
  8. May 18, 2015 at 6:22 PM
    scocar
    scocar Patron of the Farts
    That's impressive.
  9. May 18, 2015 at 7:00 PM
    taczilla
    taczilla I intend to live forever; so far.... so good!
    Marc
    PEC, Ontario, Canada
    2016 RAM Rebel
    2012 TRD Sport - STOLEN! / 2016 RAM Rebel
    Me too, I'm very impressed.
    I did this instead...
    I went from this ...
    ... to this...
    I like it.
    JustinFro likes this.
  10. May 18, 2015 at 7:19 PM
    teneighty
    teneighty I'd rather be skiing...
    Right behind you. NY
    18’ F150 SCREW LB 3.5 EcoBoost
    Bilstein 5100’s (x4), 275/65/20 Cooper XLT AT3’s
    :confused:
  11. May 18, 2015 at 7:21 PM
    patbegley
    patbegley Well-Known Member
    The Kootenays
    '22 DCLB
    Took me a second to see it.... But he added eyelids
  12. May 18, 2015 at 7:23 PM
    JB
    JB ....................
    Justin
    CA
    2015 Off Road DCSB
    ICON Stage 2, SCS Wheels, Toyo R/T's, 6-Speed
    Installed Anti Dark hood light from @BeeRadd. Highly recommend it. image.jpgimage.jpg
    patbegley likes this.
  13. May 18, 2015 at 7:25 PM
    bridaw
    bridaw The light was yellow, Sir.
    Brian
    SoCal, East San Diego County
    10 DC 6-speed TRD OR 4x4 tow debadged
    tailgate hose clamp/washer mod ,disable seatbelt warning ,dealer tinted windows ,running boards ,DiamondBack SE bed cover ,OEM rubber bed mat ,TRD Japan shift knob ,bed rail corner reinforcement with angle brackets+square nuts ,Armor Tech Offroad mount for 60" highlift jack ,Scangauge II ,OEM roof rack ,BajaRack basket ,WeatherTech dark tint window deflectors ,removed mud flaps ,debadged ,stubby antenna ,D-rings - 4 in bed floor + 8 on the side rails ,cut four D-ring slots in bedmat ,secured ActionPacker 48 gal cargo box to bed ,center console lock ,relocated 7 pin harness ,Redline Tuning QuickLIFT Elite hood supports ,Pop & Lock PL5300 tailgate lock ,RAM A-pillar mounts for GPS and Drift HD170 camera ,RAM mounts on bajarack for Drift HD170 exterior shots ,relocated rear differential breather ,headrest iPad mount ,ImMrYo rear view mirror lift ,Panavise Indash mount ,265/75/16 BFG All-Terrain T/A KO on TKO black rims ,installed front and rear WeatherTechTacoma DigitalFit FloorLiners ,replaced interior/external lights with Jumpers LEDs +switchback mod +under hood light ,installed rcbs204 Illuminated 4x4 Switch ,installed left and right Relentless Off-road Fabrication hood hinge light mounts ,installed KB Voodoo's Powder Coated Tailgate Cap System ,installed front and rear Wet Okole seat covers ,made and installed mount for Trail Toys NSA Switch Panel ,did ND4's Fog Light Anytime Mod
    I did ND4's Fog Light Anytime Mod but I tapped into pin 1 of my DIM relay so it is actually Fog with low or high beam only. I can leave the Fog button pressed in and they will turn on and off with the headlights. I also rigged up a mount for my Trail Toys NSA Switch Panel with a few dollars worth of angle brackets, bolts and washers from Home Depot. I'll post a picture once the box is mounted and wired.
    Allstar780 likes this.
  14. May 18, 2015 at 7:25 PM
    wsurunner
    wsurunner Well-Known Member
    2015 Pyrite Mica DCSB
    I don't 'wheel anymore (for reasons too numerous to list) but when I used to I always wished for on-board air. I am towing the family camper with my new Tacoma, though, and between air for trailer/truck tires plus adjustment of the air helper springs I began to consider it. When I stumbled across cotrailrun's excellent writeup (here: https://www.tacomaworld.com/threads/viair-on-board-air-install.361924/) that was enough to push me over the edge, and I went for it.
    One of the issues I discovered with the air springs is that the small volume of air they contain means that even checking the pressure with a gauge can bleed off 5psi or more. With that in mind, I took advantage of the other cubby as a spot for an inline Viair air gauge and the two air spring valves, plus a Blue Sea 12v socket since I was taking the time to bring quality 12v power all the way back to the rear of the truck. I also added a Blue Sea toggle switch to allow me to turn on the light for the gauge when checking the air bags after dark, tied into the parking lights circuit.
    I also reinforced the backside of the cubby doors through a combo of epoxy and aluminum angle. I wanted to keep the stock look as much as possible but provide extra strength to reduce the likelihood that nefarious types would be able to easily pop off the covers and steal the goods. Along those same lines, I converted the twist locks to barrel locking units from www.ch751.com, matching the locks on our camper.
    [​IMG] [​IMG]
  15. May 18, 2015 at 7:28 PM
    Larry
    Larry CARL
    CARL
    Nope. Grill.
    patbegley[QUOTED] likes this.
  16. May 18, 2015 at 7:53 PM
    Allstar780
    Allstar780 Well-Known Member
    Colin
    Alberta, Canada
    15 TRD Trail Teams Sport
    3" Lift, 32" Goodyear Duratrac, XD Series Hoss Rims
    Went out in search of mud but everywhere but the river was pretty dry... Got a bit of mud on the tires and did some shooting [​IMG]
  17. May 18, 2015 at 8:23 PM
    steveo27
    steveo27 Ask me about my weiner
    Pittsburgh
    '11 TRD Off Road & 1992 VW GLI
    The same shit everyone else has.
    THIS IS AWESOME! Happen to have the parts numbers handy?
  18. May 18, 2015 at 9:52 PM
    Up2NoGood
    Up2NoGood Well-Known Member
    Jaimes
    BC, Canada
    2014 TRD Sport DCLB
    Looks like he removed eyelids and installed a PRO grill
  19. May 18, 2015 at 9:53 PM
    Up2NoGood
    Jaimes
    BC, Canada
    2014 TRD Sport DCLB
    That's a very clean looking install, nice job!
    wsurunner[QUOTED] likes this.
  20. May 18, 2015 at 9:54 PM
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    '24 X3 M40i
    Correct
