  1. May 21, 2015 at 9:07 PM
    Lars
    Lars Radio Active
    Lars
    Cedar Creek, TX
    '10 Tundra TRD RockWarrior
    Yes.
    Why would All Pro put the gussets in the center of the square tube supports?
  2. May 21, 2015 at 9:18 PM
    Lars
    Lars Radio Active
    Lars
    Cedar Creek, TX
    Yes.
    Anyone who welds a gusset into the center of a square tube is doing it wrong and should stop doing it wrong!.
    WHY this leads to cracks at the points of the gusset...
    doing it correctly looks more like this...
  3. May 21, 2015 at 9:20 PM
    Lars
    Lars Radio Active
    Lars
    Cedar Creek, TX
    Yes.
    A gusset like that, onto the center of a round tube, is a completely different thing by the way... "most" of the rock sliders I've been looking at use round tubes to connect to the frame rail mounts.
  4. May 21, 2015 at 9:23 PM
    phillstill
    phillstill Long hair don't care
    Phill
    Tulsa
    LT35TANK
    Everything
    I'm just making an assumption. I believe the gussets main purpose is to reduce the possible stresses at the location of where the square tube is welded to the frame plate. Because the square tube is acting as a cantilevered beam the maximum stresses will be at that connection point. In that case, the location of the gusset centered or not should not make a significant difference in the strength of the sliders.
  5. May 21, 2015 at 9:28 PM
    Lars
    Lars Radio Active
    Lars
    Cedar Creek, TX
    Yes.
    This just moves the stresses to the ends of the gussets because the bottom tube will flex, causing additional stress at the gusset point.
    This is entirely possible, and I know a LOT of folks run these sliders. As a result I suspect they work great. I just hadn't previously noticed what can only be described as a design flaw and couldn't shut off my "things are supposed to be right" part of my brain.
    Carry on, nothing to see here other than an eccentric radio operator.
  6. May 21, 2015 at 9:30 PM
    Lars
    Lars Radio Active
    Lars
    Cedar Creek, TX
    Yes.
    BTW, virtually all sliders are still far more protective than my "I have nothing at all at the moment" :)
  7. May 21, 2015 at 9:30 PM
    phillstill
    Phill
    Tulsa
    LT35TANK
    Everything
    I would like to see actual evidence of this gusset location causing failure on somebody's rock sliders. With the spec size of material most vendors are using I cannot image there being enough force to cause that kind of failure on rock sliders
  8. May 21, 2015 at 9:35 PM
    cuda2k
    cuda2k Well-Known Member
    Jon
    Allen, TX
    BRM 15 TRD Off Road 4wd
    LVL8 MK6 wheels,SOS Sliders,Smked 3rd Brake,Gibson Exhaust
    SOS has the same gusset location. Suspect it's a case of 'it's plenty of support for the application', but I'm just guessing here. In other news, I picked up my SOS sliders and started the painting process.
  9. May 21, 2015 at 9:55 PM
    steveo27
    steveo27 Ask me about my weiner
    Pittsburgh
    '11 TRD Off Road & 1992 VW GLI
    The same shit everyone else has.
    Nice. Where did you find this switch? Ive been looking for something similar for a while now.
  10. May 21, 2015 at 9:57 PM
    Up2NoGood
    Up2NoGood Well-Known Member
    Jaimes
    BC, Canada
    2014 TRD Sport DCLB
    Looks to be an Air On Board brand switch
  11. May 22, 2015 at 3:49 AM
    intoit247
    intoit247 Well-Known Member
    steve
    Broadview Heights
    dcsb trd off road
    Roof rack, Led headlights , Led fog lights, Led backup lamps, black tail lights, bed mat, trailer brake , turn signal mirrors, scoop hood, painted grill bezel, headlight bezel paint, 3rd brake led. Tape on vent visors, rear slider visor. Driver heated seat. Wireless video on entune. TRD shift knob, TRD plate brackets front and rear. Led front switchbacks and led rear turn bulbs. AAL. 1 inch rear block. 3 inch lift front strut spacer. FIA front seat covers. Lighted 4x4 switch from 4 runner. TRD sport 17 wheels w kumho mud terrain tires..
    EBay has them type 33mm switch in the search. They have many different ones multiple colors. Like 28 bucks though.
  12. May 22, 2015 at 4:38 AM
    Whitecloud
    Whitecloud Cloudy-fabricator of things
    Johnathan
    Albuquerque, New Mexico
    Superwhite 06 DCLB
    ICON Extended travel Coilovers, Custom leaf pack, custom sliders and F&R bumpers, 295 75 17 Toyo Open Country MT's, On-Board air with F+R connectors, On-Board water with quick disconnect shower.Trimmed fenders and body mount chop. LOTS of wiring, dual battery setup, Solar charging system, with some random lights spread around here and there.
    Lets see.......It went from this....... about 5ish months ago......
    To this today.......
    TAJJI likes this.
  13. May 22, 2015 at 5:00 AM
    BeaverYota
    BeaverYota Oregon State Edition
    Josh
    Lake St. Louis, MO
    Sold...
    It took you 5 months to walk around to the front of your truck for a picture??
  14. May 22, 2015 at 5:10 AM
    Whitecloud
    Johnathan
    Superwhite 06 DCLB
    What can I say I walk really slow......:notsure:
  15. May 22, 2015 at 6:10 AM
    BeaverYota
    Josh
    Lake St. Louis, MO
    Sold...
    Any more pictures of the back? Did you flatbed?
  16. May 22, 2015 at 6:21 AM
    Whitecloud
    Johnathan
    Superwhite 06 DCLB
    @JRGMann Nope no flatbed. Check out the build thread too but in short, boxed the frame. new rear gas tank cross member, as well as some new cross members to support the on board water and air tank set up, new rear cross member, 3/8's inch skid plate holding everything in with ggrade 10.9 hardware, new mounts on the roof /solar panel rack for L & R alley lights/bed lights/50" LED bar, Dual Battery set up w/IBS controller, a metric shit ton of wiring, tons of switches all wired for future plans, Dual flashlight chargers behind the center console, dedicated plug in the bed for the fridge with a voltage meter run directly to the Aux battery up front, new rear bumper lights, and I'm sure some other stuff that I forgot.......
    But yes pictars........I won't put in a ton. For those that want to see more please look at the build thread....
    ERMB likes this.
  17. May 22, 2015 at 6:24 AM
    BeaverYota
    Josh
    Lake St. Louis, MO
    Sold...
    Sorry if your build thread is in your signature.. I'm on Tapatalk and sigs don't show up. Thanks for a brief recap though. I'll check out the build on my computer! Looks good though man! Very nice rig
  18. May 22, 2015 at 6:31 AM
    Taco Nation
    Taco Nation Well-Known Member
    Zack
    Clinton, MS
    94.5 F350, 77 F150, 74 F100, 11 Jeep Grand Cherokee
    Lift, wheels, tires
    Finished installing the lift last night. Not quite done yet but it's sitting on it's own weight 4 inches taller. Maxtrac up front and allpro standards with 5100's in the rear. I got exactly 4 inches front and rear.
  19. May 22, 2015 at 6:35 AM
    MTopp
    MTopp Professional bear handler
    05 SR5 4x4
    trifecta tonneau, pop n' lock, Depo black bezel headlights, mb 352 wheels, 265/75r16 cooper at3s, visors, colormatched 2011 grille with raptor LEDs, much LEDs in and out Future/wanted: black valence, hood scoop, catback, CAI, 285/75r16s, OMD leaf pack mod
    Nice! trucks coming along good
  20. May 22, 2015 at 9:06 AM
    tonyt915
    tonyt915 Well-Known Member
    My Name Is Toby!!!
    Tomball, TX
    2010 TRD Off-Road
    Pelfreybilt front bumper, SOS skis plates and rear bumper, Icon extended travel coilovers, Icon 2.5 w/resi's rear shocks, Dakar lead springs, Warn 9.5ti winch, Oem roofr rack
    This is an accumulation of stuff I've been working on in the past week till last night. Bestop Supertop, BAMF a-arm skids, SOS Concepts ifs and mid skid, SOS Concepts Rear bumper, "also pulled the Pelfreybilt off to have it powdercoated to match the SOS gear",ICON extended travel co, Camburg uniball uca's, and oem roof rack. So needless to say been a busy week.
    20150522_084301_zpssnpwlglm_9943ffa1152ab2a65d88ced7c43027f16aef4083.jpg 11165174_10204433509618007_3644951742181_58e8f9ed850c8200954e4e0533f3a1b1160cb81b.jpg
    11150810_10204426370479533_8307365723199_21b6ef8cca3b2e7bd895014213bdc5862520bc2b.jpg
